How to build start.o using waf?
Sebastian Huber
Mon Sep 30 13:14:43 UTC 2019
Hello,
I would like to work on a new build system prototype. The idea is to use
specification items maintained by Doorstop (YAML files), a Python
configuration script and waf to build RTEMS and the tests. This is
similar to the libbsd build. The difference is that in libbsd the build
data is maintained directly in Python code (libbsd.py).
How do you build a singe object file (start.o) from assembly files in
waf? An example would be great.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
