[PATCH 2/3] testsuite: User input define added
Wed Apr 1 05:40:49 UTC 2020
On 01/04/2020 00:06, Chris Johns wrote:
> On 2020-03-31 21:02, Sebastian Huber wrote:
>> On 31/03/2020 11:56, Chris Johns wrote:
>>> On 2020-03-31 19:57, Moyano, Gabriel wrote:
>>>> diff --git a/testsuite/arphole/test_main.c
>>>> b/testsuite/arphole/test_main.c
>>>> index 19d67b89..45a28cc0 100644
>>>> --- a/testsuite/arphole/test_main.c
>>>> +++ b/testsuite/arphole/test_main.c
>>>> @@ -54,6 +54,7 @@
>>>>   #include <rtems/bsd/util.h>
>>>>     #define TEST_NAME "LIBBSD ARP HOLE"
>>>> +#define TEST_STATE_USER_INPUT 1
>>> In rtems.git these test states are defined on the compiler command
>>> line. The user input state is OK to define in the code but it gets
>>> more difficult with the others to manage them in the code and so I
>>> am wondering how we manage the other states in libbsd? And if we
>>> manage those in the build system then why manage this one?
>> Why should this define move to the build system of libbsd. It is a
>> property of the test if it is interactive or not.
> I was only highlighting the inconsistencies and problems that result.
> Placing the define in the source of a test was consider in rtems.git
> however having all data related to controlling tests in a single place
> was considered the better path. I asset this is still valid.
Yes, you are right, however, this patch is already an improvement which
is worth to commit. Making this even better is a different topic and a
secondary step from my point of view. Before the new build system for
RTEMS is not integrated I am not in favour of adding more complexity to
the libbsd build system.
