[PATCH v2] doc: Moving BSP Content to User Manual (#3905)
Wed Apr 1 22:01:42 UTC 2020
Thanks and looking good. There is a long line with a length of 96 at the
end ...
On 2020-04-02 08:54, Mritunjay wrote:
>   user/bsps/bsps-m68k.rst | 196 +++++++++++++++++++++++++++++++++++++++-
>   1 file changed, 194 insertions(+), 2 deletions(-)
> diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> index 60882fb..84f5f9d 100644
> --- a/user/bsps/bsps-m68k.rst
> +++ b/user/bsps/bsps-m68k.rst
> @@ -1,6 +1,13 @@
>   .. SPDX-License-Identifier: CC-BY-SA-4.0
>   .. Copyright (C) 2018 embedded brains GmbH
> +.. Copyright (C) 2008 Mriek
> +.. Copyright (C) 2011 Richard Campbell
> +.. Copyright (C) 2010 Daniel Code
> +.. Copyright (C) 2010 Mattrajca
> +.. Copyright (C) 2009,2010 Joel Sherill
> +.. Copyright (C) 2020 Mritunjay Sharma
>   m68k (Motorola 68000 / ColdFire)
> @@ -53,7 +60,19 @@ TODO.
>   mcf5329
> -TODO.
> +Overview
> +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a Motorola
> +evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
> +development kit features the MCF5329 based Fire Engine, as well as a plug-in
> +system-on-module containing 32 MB of DDR-SDRAM. The board also includes 2 MB of
> +boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard 800x600
> +LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100 Ethernet.
> +You can find the link to MCF5329 Reference Manual below:
> +* `MCF5329 Reference Manual <https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
>   mrm332
> @@ -73,7 +92,180 @@ TODO.
>   mvme162
> -TODO.
> +Overview
> +The MVME162 family provides OEMs and solution developers an ideal platform for
> +embedded monitoring and control apllications it allows an OEM to minimize
> +engineering expenses while integrating value-added hardware and software
> +applications onto an off-the-shelf product. In order to provide the wide range
> +of solutions, the MVME162 allows a variety of MPU, memory, and interface
> +options such as floating-point, Ethernet, SCSI, and VME. The result is a
> +variation of the MVME162 which most closely fits the application requirement.
> +There are a large number of model variations on this board. This was the first
> +user submitted BSP and continues to be a fairly popular simply because at one
> +point it was the highest selling VMEBus board of all time.
> +Board Setup
> +We will setup the RTEMS Lab Board initally to proceed further for the setup
> +of TFTP transfer.
> +The env settings are:
> +.. code-block:: none
> +    MPU Clock Speed =25Mhz
> +    162-Bug>env
> +    Bug or System environment [B/S] = B?
> +    Field Service Menu Enable [Y/N] = N?
> +	Remote Start Method Switch [G/M/B/N] = B?
> +	Probe System for Supported I/O Controllers [Y/N] = Y?
> +	Negate VMEbus SYSFAIL* Always [Y/N] = N?
> +	Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> +	Local SCSI Bus Negotiations Type [A/S/N]       = A?
> +	Industry Pack Reset on Debugger Startup [Y/N]  = Y?
> +	Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
> +	Auto Boot Enable [Y/N]   = N?
> +	Auto Boot at power-up only [Y/N] = Y?
> +	Auto Boot Controller LUN = 00?
> +	Auto Boot Device LUN     = 00?
> +	Auto Boot Abort Delay    = 15?
> +	Auto Boot Default String [NULL for a empty string] = ?
> +	ROM Boot Enable [Y/N]            = N?
> +	ROM Boot at power-up only [Y/N]  = Y?
> +	ROM Boot Enable search of VMEbus [Y/N] = N?
> +	ROM Boot Abort Delay             = 0?
> +	ROM Boot Direct Starting Address = FF800000?
> +	ROM Boot Direct Ending Address   = FFDFFFFC?
> +	Network Auto Boot Enable [Y/N]   = N?
> +	Network Auto Boot at power-up only [Y/N] = Y?
> +	Network Auto Boot Controller LUN = 00?
> +	Network Auto Boot Device LUN     = 00?
> +	Network Auto Boot Abort Delay    = 5?
> +	Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
> +	Memory Search Starting Address   = 00000000?
> +	Memory Search Ending Address     = 01000000?
> +	Memory Search Increment Size     = 00010000?
> +	Memory Search Delay Enable [Y/N] = N?
> +	Memory Search Delay Address      = FFFFD20F?
> +	Memory Size Enable [Y/N]         = Y?
> +	Memory Size Starting Address     = 00000000?
> +	Memory Size Ending Address       = 01000000?
> +	Base Address of Dynamic Memory   = 00000000?
> +	Size of Parity Memory            = 00000000?
> +	Size of ECC Memory Board #0      = 01000000?
> +	Size of ECC Memory Board #1      = 00000000?
> +	Base Address of Static Memory    = FFE00000?
> +	Size of Static Memory            = 00020000?
> +	Slave Enable #1 [Y/N] = Y?
> +	Slave Starting Address #1 = 00000000?
> +	Slave Ending Address #1   = 00FFFFFF?
> +	Slave Address Translation Address #1 = 00000000?
> +	Slave Address Translation Select #1  = 00000000?
> +	Slave Control #1 = 03FF?
> +	Slave Enable #2 [Y/N] = N?
> +	Slave Starting Address #2 = 00000000?
> +	Slave Ending Address #2   = 00000000?
> +	Slave Address Translation Address #2 = 00000000?
> +	Slave Address Translation Select #2  = 00000000?
> +	Slave Control #2 = 0000?
> +	Master Enable #1 [Y/N] = Y?
> +	Master Starting Address #1 = 01000000?
> +	Master Ending Address #1   = EFFFFFFF?
> +	Master Control #1 = 0D?
> +	Master Enable #2 [Y/N] = N?
> +	Master Starting Address #2 = 00000000?
> +	Master Ending Address #2   = 00000000?
> +	Master Control #2 = 00?
> +	Master Enable #3 [Y/N] = N?
> +	Master Starting Address #3 = 00000000?
> +	Master Ending Address #3   = 00000000?
> +	Master Control #3 = 00?
> +	Master Enable #4 [Y/N] = N?
> +	Master Starting Address #4 = 00000000?
> +	Master Ending Address #4   = 00000000?
> +	Master Address Translation Address #4 = 00000000?
> +	Master Address Translation Select #4  = 00000000?
> +	Master Control #4 = 00?
> +	Short I/O (VMEbus A16) Enable [Y/N] = Y?
> +	Short I/O (VMEbus A16) Control      = 01?
> +	F-Page (VMEbus A24) Enable [Y/N]    = Y?
> +	F-Page (VMEbus A24) Control         = 02?
> +	ROM Access Time Code          = 03?
> +	FLASH Access Time Code        = 02?
> +	MCC Vector Base               = 05?
> +	VMEC2 Vector Base #1          = 06?
> +	VMEC2 Vector Base #2          = 07?
> +	VMEC2 GCSR Group Base Address = D2?
> +	VMEC2 GCSR Board Base Address = 00?
> +	VMEbus Global Time Out Code   = 01?
> +	Local Bus Time Out Code       = 02?
> +	VMEbus Access Time Out Code   = 02?
> +	IP A Base Address              = 00000000?
> +	IP B Base Address              = 00000000?
> +	IP C Base Address              = 00000000?
> +	IP D Base Address              = 00000000?
> +	IP D/C/B/A Memory Size         = 00000000?
> +	IP D/C/B/A General Control     = 00000000?
> +	IP D/C/B/A Interrupt 0 Control = 00000000?
> +	IP D/C/B/A Interrupt 1 Control = 00000000?
> +To setup the Server/Client IP Addresses for the TFTP Transfer, we will use the
> +NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command commonly
> +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> +The NIOT command goes something like this:
> +    162-Bug>niot
> +	Controller LUN =00?
> +	Device LUN     =00?
> +	Node Control Memory Address =FFE10000?
> +	Client IP Address      =192.168.1.245?
> +	Server IP Address      =192.168.1.92?
> +	Subnet IP Address Mask =255.255.255.0?
> +	Broadcast IP Address   =192.168.1.255?
> +	Gateway IP Address     =0.0.0.0?
> +	Boot File Name ("NULL" for None)     =/mvme162.img?
> +	Argument File Name ("NULL" for None) =?
> +	Boot File Load Address         =00020000?
> +	Boot File Execution Address    =00020000?
> +	Boot File Execution Delay      =00000000?
> +	Boot File Length               =00000000?
> +	Boot File Byte Offset          =00000000?
> +	BOOTP/RARP Request Retry       =00?
> +	TFTP/ARP Request Retry         =00?
> +	Trace Character Buffer Address =00000000?
> +	BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> +	BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
> +Downloading and Executing
> +Download from the TFTP server using the 162-Bug's "NBO" (Network Boot Operating System) command:
Please wrap this line.
> +    162-Bug>nbo
> +    Network Booting from: VME162, Controller 0, Device 0
> +	Loading: /mvme162.img
> +	Client IP Address      = 192.168.1.245
> +	Server IP Address      = 192.168.1.92
> +	Gateway IP Address     = 0.0.0.0
> +	Subnet IP Address Mask = 255.255.255.0
> +	Boot File Name         = /mvme162.img
> +	Argument File Name     =
> +	Network Boot File load in progress... To abort hit <BREAK>
> +	Bytes Received =&356528, Bytes Loaded =&356528
> +	Bytes/Second   =&89132, Elapsed Time =4 Second(s)
> +The program will automatically run when download is complete.
>   mvme167
