[PATCH v4] doc: Moving M68K BSP Content to User Manual (#3905)
Mritunjay mritunjaysharma394 at gmail.com
Wed Apr 1 23:24:27 UTC 2020
 user/bsps/bsps-m68k.rst | 190 +++++++++++++++++++++++++++++++++++++++-
 1 file changed, 188 insertions(+), 2 deletions(-)
diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
index 60882fb..1e41f72 100644
--- a/user/bsps/bsps-m68k.rst
+++ b/user/bsps/bsps-m68k.rst
@@ -53,7 +53,19 @@ TODO.
 mcf5329
-TODO.
+Overview
+This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a Motorola
+evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
+development kit features the MCF5329 based Fire Engine, as well as a plug-in
+system-on-module containing 32 MB of DDR-SDRAM. The board also includes 2 MB of
+boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard 800x600
+LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100 Ethernet.
+You can find the link to MCF5329 Reference Manual below:
+* `MCF5329 Reference Manual <https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
 mrm332
@@ -73,7 +85,181 @@ TODO.
 mvme162
-TODO.
+Overview
+The MVME162 family provides OEMs and solution developers an ideal platform for
+embedded monitoring and control apllications it allows an OEM to minimize
+engineering expenses while integrating value-added hardware and software
+applications onto an off-the-shelf product. In order to provide the wide range
+of solutions, the MVME162 allows a variety of MPU, memory, and interface
+options such as floating-point, Ethernet, SCSI, and VME. The result is a
+variation of the MVME162 which most closely fits the application requirement.
+There are a large number of model variations on this board. This was the first
+user submitted BSP and continues to be a fairly popular simply because at one
+point it was the highest selling VMEBus board of all time.
+Board Setup
+We will setup the RTEMS Lab Board initally to proceed further for the setup
+of TFTP transfer.
+The env settings are:
+.. code-block:: none
+    MPU Clock Speed =25Mhz
+    162-Bug>env
+    Bug or System environment [B/S] = B?
+    Field Service Menu Enable [Y/N] = N?
+	Remote Start Method Switch [G/M/B/N] = B?
+	Probe System for Supported I/O Controllers [Y/N] = Y?
+	Negate VMEbus SYSFAIL* Always [Y/N] = N?
+	Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
+	Local SCSI Bus Negotiations Type [A/S/N]       = A?
+	Industry Pack Reset on Debugger Startup [Y/N]  = Y?
+	Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
+	Auto Boot Enable [Y/N]   = N?
+	Auto Boot at power-up only [Y/N] = Y?
+	Auto Boot Controller LUN = 00?
+	Auto Boot Device LUN     = 00?
+	Auto Boot Abort Delay    = 15?
+	Auto Boot Default String [NULL for a empty string] = ?
+	ROM Boot Enable [Y/N]            = N?
+	ROM Boot at power-up only [Y/N]  = Y?
+	ROM Boot Enable search of VMEbus [Y/N] = N?
+	ROM Boot Abort Delay             = 0?
+	ROM Boot Direct Starting Address = FF800000?
+	ROM Boot Direct Ending Address   = FFDFFFFC?
+	Network Auto Boot Enable [Y/N]   = N?
+	Network Auto Boot at power-up only [Y/N] = Y?
+	Network Auto Boot Controller LUN = 00?
+	Network Auto Boot Device LUN     = 00?
+	Network Auto Boot Abort Delay    = 5?
+	Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
+	Memory Search Starting Address   = 00000000?
+	Memory Search Ending Address     = 01000000?
+	Memory Search Increment Size     = 00010000?
+	Memory Search Delay Enable [Y/N] = N?
+	Memory Search Delay Address      = FFFFD20F?
+	Memory Size Enable [Y/N]         = Y?
+	Memory Size Starting Address     = 00000000?
+	Memory Size Ending Address       = 01000000?
+	Base Address of Dynamic Memory   = 00000000?
+	Size of Parity Memory            = 00000000?
+	Size of ECC Memory Board #0      = 01000000?
+	Size of ECC Memory Board #1      = 00000000?
+	Base Address of Static Memory    = FFE00000?
+	Size of Static Memory            = 00020000?
+	Slave Enable #1 [Y/N] = Y?
+	Slave Starting Address #1 = 00000000?
+	Slave Ending Address #1   = 00FFFFFF?
+	Slave Address Translation Address #1 = 00000000?
+	Slave Address Translation Select #1  = 00000000?
+	Slave Control #1 = 03FF?
+	Slave Enable #2 [Y/N] = N?
+	Slave Starting Address #2 = 00000000?
+	Slave Ending Address #2   = 00000000?
+	Slave Address Translation Address #2 = 00000000?
+	Slave Address Translation Select #2  = 00000000?
+	Slave Control #2 = 0000?
+	Master Enable #1 [Y/N] = Y?
+	Master Starting Address #1 = 01000000?
+	Master Ending Address #1   = EFFFFFFF?
+	Master Control #1 = 0D?
+	Master Enable #2 [Y/N] = N?
+	Master Starting Address #2 = 00000000?
+	Master Ending Address #2   = 00000000?
+	Master Control #2 = 00?
+	Master Enable #3 [Y/N] = N?
+	Master Starting Address #3 = 00000000?
+	Master Ending Address #3   = 00000000?
+	Master Control #3 = 00?
+	Master Enable #4 [Y/N] = N?
+	Master Starting Address #4 = 00000000?
+	Master Ending Address #4   = 00000000?
+	Master Address Translation Address #4 = 00000000?
+	Master Address Translation Select #4  = 00000000?
+	Master Control #4 = 00?
+	Short I/O (VMEbus A16) Enable [Y/N] = Y?
+	Short I/O (VMEbus A16) Control      = 01?
+	F-Page (VMEbus A24) Enable [Y/N]    = Y?
+	F-Page (VMEbus A24) Control         = 02?
+	ROM Access Time Code          = 03?
+	FLASH Access Time Code        = 02?
+	MCC Vector Base               = 05?
+	VMEC2 Vector Base #1          = 06?
+	VMEC2 Vector Base #2          = 07?
+	VMEC2 GCSR Group Base Address = D2?
+	VMEC2 GCSR Board Base Address = 00?
+	VMEbus Global Time Out Code   = 01?
+	Local Bus Time Out Code       = 02?
+	VMEbus Access Time Out Code   = 02?
+	IP A Base Address              = 00000000?
+	IP B Base Address              = 00000000?
+	IP C Base Address              = 00000000?
+	IP D Base Address              = 00000000?
+	IP D/C/B/A Memory Size         = 00000000?
+	IP D/C/B/A General Control     = 00000000?
+	IP D/C/B/A Interrupt 0 Control = 00000000?
+	IP D/C/B/A Interrupt 1 Control = 00000000?
+To setup the Server/Client IP Addresses for the TFTP Transfer, we will use the
+NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command commonly
+used to setup the Server/Client IP Addresses for the TFTP Transfer.
+The NIOT command goes something like this:
+    162-Bug>niot
+	Controller LUN =00?
+	Device LUN     =00?
+	Node Control Memory Address =FFE10000?
+	Client IP Address      =192.168.1.245?
+	Server IP Address      =192.168.1.92?
+	Subnet IP Address Mask =255.255.255.0?
+	Broadcast IP Address   =192.168.1.255?
+	Gateway IP Address     =0.0.0.0?
+	Boot File Name ("NULL" for None)     =/mvme162.img?
+	Argument File Name ("NULL" for None) =?
+	Boot File Load Address         =00020000?
+	Boot File Execution Address    =00020000?
+	Boot File Execution Delay      =00000000?
+	Boot File Length               =00000000?
+	Boot File Byte Offset          =00000000?
+	BOOTP/RARP Request Retry       =00?
+	TFTP/ARP Request Retry         =00?
+	Trace Character Buffer Address =00000000?
+	BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
+	BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
+Downloading and Executing
+Download from the TFTP server using the 162-Bug's "NBO"
+(Network Boot Operating System) command:
+    162-Bug>nbo
+    Network Booting from: VME162, Controller 0, Device 0
+	Loading: /mvme162.img
+	Client IP Address      = 192.168.1.245
+	Server IP Address      = 192.168.1.92
+	Gateway IP Address     = 0.0.0.0
+	Subnet IP Address Mask = 255.255.255.0
+	Boot File Name         = /mvme162.img
+	Argument File Name     =
+	Network Boot File load in progress... To abort hit <BREAK>
+	Bytes Received =&356528, Bytes Loaded =&356528
+	Bytes/Second   =&89132, Elapsed Time =4 Second(s)
+The program will automatically run when download is complete.
 mvme167
2.17.1
