[PATCH] bsps/arm: Add support for MPU region alignment
Gedare Bloom
gedare at rtems.org
Thu Apr 2 14:44:19 UTC 2020
On Thu, Apr 2, 2020 at 12:15 AM Sebastian Huber
> bsps/arm/shared/start/linkcmds.base | 21 +++++++++++++++++++++
> 1 file changed, 21 insertions(+)
> diff --git a/bsps/arm/shared/start/linkcmds.base b/bsps/arm/shared/start/linkcmds.base
> index 1f5f1ef959..d0663cf97e 100644
> --- a/bsps/arm/shared/start/linkcmds.base
> +++ b/bsps/arm/shared/start/linkcmds.base
> @@ -81,6 +81,17 @@ SECTIONS {
> } > REGION_TEXT AT > REGION_TEXT_LOAD
> .fini : ALIGN_WITH_INPUT {
> KEEP (*(.fini))
> + * If requested, align the size of the combined start and text
> + * section to the next power of two to meet MPU region
> + * alignment requirements.
> + . = DEFINED (bsp_section_do_mpu_align) ?
> + bsp_section_start_begin
> + + ALIGN (. - bsp_section_start_begin,
> + 1 << LOG2CEIL (. - bsp_section_start_begin)) : .;
This looks alright. I don't find the symbol bsp_section_do_mpu_align
anywhere though, is it currently unused?
Do you need this in 5.1.0 for something?
> bsp_section_text_end = .;
> bsp_section_text_size = bsp_section_text_end - bsp_section_text_begin;
> @@ -248,6 +259,16 @@ SECTIONS {
> *(set_pseudo_*);
> KEEP (*(SORT(.rtemsroset.*)))
> + * If requested, align the size of the rodata section to the
> + * next power of two to meet MPU region alignment requirements.
> + bsp_section_rodata_begin
> + + ALIGN (. - bsp_section_rodata_begin,
> + 1 << LOG2CEIL (. - bsp_section_rodata_begin)) : .;
> bsp_section_rodata_end = .;
> } > REGION_RODATA AT > REGION_RODATA_LOAD
> bsp_section_rodata_size = bsp_section_rodata_end - bsp_section_rodata_begin;
> 2.16.4
> devel mailing list
> devel at rtems.org
