[PATCH rtems-docs] user/imx: Add i.MX6UL/ULL.
Thu Apr 2 14:51:33 UTC 2020
On Thu, Apr 2, 2020 at 8:43 AM Christian Mauderer
<christian.mauderer at embedded-brains.de> wrote:
> Update #3869
>  user/bsps/arm/imx.rst | 49 ++++++++++++++++++++++++++++++++++++++++++++++---
>  1 file changed, 46 insertions(+), 3 deletions(-)
> diff --git a/user/bsps/arm/imx.rst b/user/bsps/arm/imx.rst
> index bc93ae3..51c3b7e 100644
> --- a/user/bsps/arm/imx.rst
> +++ b/user/bsps/arm/imx.rst
> @@ -7,9 +7,10 @@ imx (NXP i.MX)
>  This BSP offers only one variant, the `imx7`.  This variant supports the i.MX
> -7Dual processor.  The basic hardware initialization is not performed by the
> -BSP.  A boot loader with device tree support must be used to start the BSP,
> -e.g. U-Boot.
> +7Dual processor and the i.MX 6UL/ULL processor family (with slightly different
> +clock settings).  The basic hardware initialization is not performed by the BSP.
> +A boot loader with device tree support must be used to start the BSP, e.g.
> +U-Boot or barebox.
>  Build Configuration Options
> @@ -40,9 +41,30 @@ The following options are available at the configure command line.
>  ``IMX_CCM_UART_HZ``
>     The UART clock frequency in Hz (default is 24000000).
> +``IMX_CCM_ECSPI_HZ``
> +   The ECSPI clock frequency in Hz (default is 67500000).
>  ``IMX_CCM_AHB_HZ``
>     The AHB clock frequency in Hz (default is 135000000).
> +``IMX_CCM_SDHCI_HZ``
> +   The SDHCI clock frequency in Hz (default is 196363000).
> +Clock settings for different boards
> +The default clock settings are targeted for an i.MX 7Dual evaluation board using
> +U-Boot. Some other boards with different boot loaders need different settings:
> + * Phytec phyCORE-i.MX 6ULL (system on module) with MCIMX6Y2CVM08AB and a
> +   barebox bootloader (version ``2019.01.0-bsp-yocto-i.mx6ul-pd19.1.0``):
> +   * IMX_CCM_IPG_HZ=66000000
> +   * IMX_CCM_UART_HZ=80000000
> +   * IMX_CCM_AHB_HZ=66000000
> +   * IMX_CCM_SDHCI_HZ=198000000
> +   * IMX_CCM_ECSPI_HZ=60000000
>  Boot via U-Boot
> @@ -65,6 +87,14 @@ The ``loadfdt`` command may be not defined in your U-Boot environment.  Just
>  replace it with the appropriate commands to load the device tree at
>  ``${fdt_addr}``.
> +Boot via barebox
> +The same command like for U-Boot can be used to generate an application image.
> +In a default configuration barebox expects an fdt image called `oftree` and a
> +kernel image called `zImage` in the root folder of the bootable medium (e.g. an
> +SD card).
>  Clock Driver
> @@ -133,6 +163,18 @@ system controls:
>  A value of zero for the time or count disables the interrupt coalescing in the
>  corresponding direction.
> +On the Phytec phyCORE-i.MX 6ULL modules the PHY needs an initialization for the
> +clock. A special PHY driver handles that (``ksz8091rnb``). Add it to your libbsd
> +config like that:
> +.. code-block:: c
> +    #define RTEMS_BSD_CONFIG_BSP_CONFIG
> +    #define RTEMS_BSD_CONFIG_INIT
> +    SYSINIT_DRIVER_REFERENCE(ksz8091rnb, miibus);
> +    #include <machine/rtems-bsd-config.h>
Is the extra space needed here?
>  MMC/SDCard Driver
> @@ -147,3 +189,4 @@ Caveats
>  The clock and pin configuration support is quite rudimentary and mostly relies
>  on the boot loader.  For a pin group configuration see
>  ``imx_iomux_configure_pins()``.  There is no power management support.
Many docs end without the blank line. It does cause git to complain.
I'm not sure if we have any rule about it for writing docs.
> 2.16.4
> devel mailing list
> devel at rtems.org
