[PATCH docs] start/gsoc: GSoC Getting started instructions.
Thu Apr 2 15:37:27 UTC 2020
Thanks for this, I pushed it, but changed the location in the index to
the end of the Getting Started Guide.
On Thu, Apr 2, 2020 at 8:05 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> Added instructions to setup development environment for students
> interested in GSoC.
>  user/index.rst       |   1 +
>  user/start/gsoc.rst  | 132 +++++++++++++++++++++++++++++++++++++++++++
>  user/start/index.rst |   1 +
>  3 files changed, 134 insertions(+)
>  create mode 100644 user/start/gsoc.rst
> diff --git a/user/index.rst b/user/index.rst
> index 7b584c5..4e91994 100644
> --- a/user/index.rst
> +++ b/user/index.rst
> @@ -10,6 +10,7 @@ RTEMS User Manual (|version|).
>  .. topic:: Copyrights and License
> +    | |copy| 2020 Niteesh Babu
>      | |copy| 2019 Vijay Kumar Banerjee
>      | |copy| 2018 Amaan Cheval
>      | |copy| 2018 Marçal Comajoan Cara
> diff --git a/user/start/gsoc.rst b/user/start/gsoc.rst
> new file mode 100644
> index 0000000..62154ff
> --- /dev/null
> +++ b/user/start/gsoc.rst
> @@ -0,0 +1,132 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 Niteesh Babu <niteesh.gs at gmail.com>
> +.. _QuickStartGSoC:
> +GSoC Getting Started
> +The goal of this page is to help new users, especially students get RTEMS
> +compiled and running so they can start with the real work.
> +Please join the :r:list:`users` and :r:list:`devel` and ask
> +questions. Help correct any deficiencies in the code or documentation you spot,
> +including those on the wiki. The ultimate goal of GSoC is to help you become
> +part of the open source community.
> +This section will help you to quickly setup a development environment without
> +delving into the details. For more information you can go through the other
> +subsections under :ref:`Quick Start <QuickStart>` chapter or ask on the
> +:r:list:`devel`.
> +You will be best served by using a GNU/Linux environment, which could be in a
> +virtual machine, for example that uses `Virtualbox <https://www.virtualbox.org/>`_
> +and should run on most modern desktop systems. You should also be able to work
> +with a MacOS or Windows system, but might encounter more difficulty than a *nix
> +environment.
> +Setting up a development environment consists of the following steps.
> +1) Installing dependencies for your host operating system.
> +2) Choosing an installation prefix.
> +3) Downloading the source code.
> +4) Installing the tool suite.
> +5) Building the Board Support Package (BSP).
> +6) Testing the Board Support Package (BSP).
> +Installing Dependencies
> +You need tools for your host’s operating system to build the RTEMS tool suite
> +from source. Please have a look at the :ref:`host-computer` chapter for the
> +instructions to install the tools for your OS.
> +Choosing an installation prefix
> +The term ``prefix`` refers to the path on your computer where the software is to
> +be installed.
> +You can refer to the :ref:`Prefix <QuickStartPrefixes>` section for details on
> +choosing an installation prefix.
> +Downloading the Sources
> +We will be using Git to clone the sources for RTEMS and RSB. This is the
> +preferred way if you are planning to make contributions to the RTEMS project.
> +Please refer to the :ref:`QuickStartSources_Git` section for instructions on
> +obtaining sources using Git.
> +Installing the Tool Suite
> +The Tools suite is the collection of tools required to build the BSP. This
> +includes the compiler, debugger, assembler and other tools. These tools are
> +architecture-specific. We will be installing the SPARC tool suite since we are
> +building a SPARC based BSP.
> +Please refer to the :ref:`QuickStartTools` section for instructions on
> +building and installing the tool suite.
> +Building the Board Support Package
> +There are two ways of building a BSP. We could either ask RSB to build the BSP
> +or manually build it. In this section will we be building it manually.
> +Please refer the :ref:`QuickStartBSPBuild_Manual` section for the
> +instructions.
> +Testing the Board Support Package
> +Testing is an essential part of RTEMS development process. The main reason for
> +choosing the SPARC erc32 BSP is that, it has very good simulator support. This
> +will allow you to test your changes without the need for SPARC hardware.
> +Please refer to :ref:`QuickStartBSPTest` for instructions on testing the BSP.
> +Prove You Can Work On RTEMS
> +This section is only for students interested in Google Summer of Code.
> +You have to finish the following task to prove that you can work on RTEMS.
> +Modify the hello world example to include a new different print statement.
> +Something like "Hello from The Dark Side!". Then send us enough to prove to us
> +that you did this. We want to know you can work with RTEMS.
> +Create a patch of your changes and send it to :r:list:`devel` along with the
> +screenshot of the output.
> +If you followed this guide, this hello world modification will likely need to be
> +made in ``$HOME/quick-start/src/rtems/testsuites/samples/hello/init.c``.
> +To test your changes, you have to build the BSP again. This could be done by
> +running `make` in the BSP build directory.
> +.. code-block:: none
> +  cd $HOME/quick-start/build/b-erc32
> +  make
> +If you are happy with your changes you can commit the changes and send the patch
> +to :r:list:`devel`.
> +Creating and Sending Patches
> +Before sending patches, make sure that the changes you have made conforms to
> +RTEMS coding standards.
> +You can refer to :ref:`Contributing` section for instruction on creating and
> +sending patches.
> +Here are a few pointers to keep in mind while creating the patches.
> +* Make sure not to commit changes in the master branch. This is to avoid merge
> +  conflicts when you are pulling the latest changes from the remote branch.
> +* Avoid trailing whitespace errors.
> +* The author name of the patch is your full name.
> +* The author email of the patch is your valid email address.
> +* Ensure that your patch builds before sending them for review.
> \ No newline at end of file
> diff --git a/user/start/index.rst b/user/start/index.rst
> index 3289fa2..ab1bcb7 100644
> --- a/user/start/index.rst
> +++ b/user/start/index.rst
> @@ -14,6 +14,7 @@ applications on top of RTEMS.
>  .. toctree::
> +    gsoc
>      preparation
>      prefixes
>      sources
> 2.17.1
