[rtems-docs commit] user/start/gsoc: fix unicode error and grammar typo
Thu Apr 2 18:16:54 UTC 2020
There was a problem with building latex pdf docs, it turned out to be
some invisible unicode that slipped in the GSoC Getting Started patch.
On Thu, Apr 2, 2020 at 12:15 PM Gedare Bloom <gedare at rtems.org> wrote:
> Module:    rtems-docs
> Branch:    master
> Commit:    d4d30673d094e1e7c796c5a6d3de3e12ccaa1b9e
> Changeset: http://git.rtems.org/rtems-docs/commit/?id=d4d30673d094e1e7c796c5a6d3de3e12ccaa1b9e
> Author:    Gedare Bloom <gedare at rtems.org>
> Date:      Thu Apr  2 12:14:51 2020 -0600
>  user/start/gsoc.rst | 4 ++--
>  1 file changed, 2 insertions(+), 2 deletions(-)
> diff --git a/user/start/gsoc.rst b/user/start/gsoc.rst
> index 62154ff..7f27d7b 100644
> --- a/user/start/gsoc.rst
> +++ b/user/start/gsoc.rst
> @@ -21,7 +21,7 @@ subsections under :ref:`Quick Start <QuickStart>` chapter or ask on the
>  :r:list:`devel`.
>  You will be best served by using a GNU/Linux environment, which could be in a
> -virtual machine, for example that uses `Virtualbox <https://www.virtualbox.org/>`_
> +virtual machine, for example that uses `Virtualbox <https://www.virtualbox.org/>`_
>  and should run on most modern desktop systems. You should also be able to work
>  with a MacOS or Windows system, but might encounter more difficulty than a *nix
>  environment.
> @@ -129,4 +129,4 @@ Here are a few pointers to keep in mind while creating the patches.
>  * Avoid trailing whitespace errors.
>  * The author name of the patch is your full name.
>  * The author email of the patch is your valid email address.
> -* Ensure that your patch builds before sending them for review.
> \ No newline at end of file
> +* Ensure that your patches build before sending them for review.
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
