[PATCH v5] doc: Moving M68K BSP Content to User Manual (#3905)
Thu Apr 2 22:05:42 UTC 2020
Is there now a list of wiki pages that need to be deleted?
Thank you and I'm glad to see this patch. :)
--joel
On Thu, Apr 2, 2020 at 4:54 PM Chris Johns <chrisj at rtems.org> wrote:
> Pushed and again thank you for doing this.
> Chris
> On 2020-04-02 19:49, Mritunjay wrote:
> > Fixed trailing spaces.
> >   user/bsps/bsps-m68k.rst | 190 +++++++++++++++++++++++++++++++++++++++-
> >   1 file changed, 188 insertions(+), 2 deletions(-)
> > diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> > index 60882fb..bdb516b 100644
> > --- a/user/bsps/bsps-m68k.rst
> > +++ b/user/bsps/bsps-m68k.rst
> > @@ -53,7 +53,19 @@ TODO.
> >   mcf5329
> > -TODO.
> > +Overview
> > +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a
> Motorola
> > +evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
> > +development kit features the MCF5329 based Fire Engine, as well as a
> plug-in
> > +system-on-module containing 32 MB of DDR-SDRAM. The board also includes
> 2 MB of
> > +boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard
> 800x600
> > +LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100
> Ethernet.
> > +You can find the link to MCF5329 Reference Manual below:
> > +* `MCF5329 Reference Manual <
> https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
> >   mrm332
> > @@ -73,7 +85,181 @@ TODO.
> >   mvme162
> > -TODO.
> > +Overview
> > +The MVME162 family provides OEMs and solution developers an ideal
> platform for
> > +embedded monitoring and control apllications it allows an OEM to
> minimize
> > +engineering expenses while integrating value-added hardware and software
> > +applications onto an off-the-shelf product. In order to provide the
> wide range
> > +of solutions, the MVME162 allows a variety of MPU, memory, and interface
> > +options such as floating-point, Ethernet, SCSI, and VME. The result is a
> > +variation of the MVME162 which most closely fits the application
> requirement.
> > +There are a large number of model variations on this board. This was
> the first
> > +user submitted BSP and continues to be a fairly popular simply because
> at one
> > +point it was the highest selling VMEBus board of all time.
> > +Board Setup
> > +We will setup the RTEMS Lab Board initally to proceed further for the
> setup
> > +of TFTP transfer.
> > +The env settings are:
> > +.. code-block:: none
> > +    MPU Clock Speed =25Mhz
> > +    162-Bug>env
> > +    Bug or System environment [B/S] = B?
> > +    Field Service Menu Enable [Y/N] = N?
> > +     Remote Start Method Switch [G/M/B/N] = B?
> > +     Probe System for Supported I/O Controllers [Y/N] = Y?
> > +     Negate VMEbus SYSFAIL* Always [Y/N] = N?
> > +     Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> > +     Local SCSI Bus Negotiations Type [A/S/N]       = A?
> > +     Industry Pack Reset on Debugger Startup [Y/N]  = Y?
> > +     Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
> > +     Auto Boot Enable [Y/N]   = N?
> > +     Auto Boot at power-up only [Y/N] = Y?
> > +     Auto Boot Controller LUN = 00?
> > +     Auto Boot Device LUN     = 00?
> > +     Auto Boot Abort Delay    = 15?
> > +     Auto Boot Default String [NULL for a empty string] = ?
> > +     ROM Boot Enable [Y/N]            = N?
> > +     ROM Boot at power-up only [Y/N]  = Y?
> > +     ROM Boot Enable search of VMEbus [Y/N] = N?
> > +     ROM Boot Abort Delay             = 0?
> > +     ROM Boot Direct Starting Address = FF800000?
> > +     ROM Boot Direct Ending Address   = FFDFFFFC?
> > +     Network Auto Boot Enable [Y/N]   = N?
> > +     Network Auto Boot at power-up only [Y/N] = Y?
> > +     Network Auto Boot Controller LUN = 00?
> > +     Network Auto Boot Device LUN     = 00?
> > +     Network Auto Boot Abort Delay    = 5?
> > +     Network Auto Boot Configuration Parameters Pointer (NVRAM) =
> FFE0FF00?
> > +     Memory Search Starting Address   = 00000000?
> > +     Memory Search Ending Address     = 01000000?
> > +     Memory Search Increment Size     = 00010000?
> > +     Memory Search Delay Enable [Y/N] = N?
> > +     Memory Search Delay Address      = FFFFD20F?
> > +     Memory Size Enable [Y/N]         = Y?
> > +     Memory Size Starting Address     = 00000000?
> > +     Memory Size Ending Address       = 01000000?
> > +     Base Address of Dynamic Memory   = 00000000?
> > +     Size of Parity Memory            = 00000000?
> > +     Size of ECC Memory Board #0      = 01000000?
> > +     Size of ECC Memory Board #1      = 00000000?
> > +     Base Address of Static Memory    = FFE00000?
> > +     Size of Static Memory            = 00020000?
> > +     Slave Enable #1 [Y/N] = Y?
> > +     Slave Starting Address #1 = 00000000?
> > +     Slave Ending Address #1   = 00FFFFFF?
> > +     Slave Address Translation Address #1 = 00000000?
> > +     Slave Address Translation Select #1  = 00000000?
> > +     Slave Control #1 = 03FF?
> > +     Slave Enable #2 [Y/N] = N?
> > +     Slave Starting Address #2 = 00000000?
> > +     Slave Ending Address #2   = 00000000?
> > +     Slave Address Translation Address #2 = 00000000?
> > +     Slave Address Translation Select #2  = 00000000?
> > +     Slave Control #2 = 0000?
> > +     Master Enable #1 [Y/N] = Y?
> > +     Master Starting Address #1 = 01000000?
> > +     Master Ending Address #1   = EFFFFFFF?
> > +     Master Control #1 = 0D?
> > +     Master Enable #2 [Y/N] = N?
> > +     Master Starting Address #2 = 00000000?
> > +     Master Ending Address #2   = 00000000?
> > +     Master Control #2 = 00?
> > +     Master Enable #3 [Y/N] = N?
> > +     Master Starting Address #3 = 00000000?
> > +     Master Ending Address #3   = 00000000?
> > +     Master Control #3 = 00?
> > +     Master Enable #4 [Y/N] = N?
> > +     Master Starting Address #4 = 00000000?
> > +     Master Ending Address #4   = 00000000?
> > +     Master Address Translation Address #4 = 00000000?
> > +     Master Address Translation Select #4  = 00000000?
> > +     Master Control #4 = 00?
> > +     Short I/O (VMEbus A16) Enable [Y/N] = Y?
> > +     Short I/O (VMEbus A16) Control      = 01?
> > +     F-Page (VMEbus A24) Enable [Y/N]    = Y?
> > +     F-Page (VMEbus A24) Control         = 02?
> > +     ROM Access Time Code          = 03?
> > +     FLASH Access Time Code        = 02?
> > +     MCC Vector Base               = 05?
> > +     VMEC2 Vector Base #1          = 06?
> > +     VMEC2 Vector Base #2          = 07?
> > +     VMEC2 GCSR Group Base Address = D2?
> > +     VMEC2 GCSR Board Base Address = 00?
> > +     VMEbus Global Time Out Code   = 01?
> > +     Local Bus Time Out Code       = 02?
> > +     VMEbus Access Time Out Code   = 02?
> > +     IP A Base Address              = 00000000?
> > +     IP B Base Address              = 00000000?
> > +     IP C Base Address              = 00000000?
> > +     IP D Base Address              = 00000000?
> > +     IP D/C/B/A Memory Size         = 00000000?
> > +     IP D/C/B/A General Control     = 00000000?
> > +     IP D/C/B/A Interrupt 0 Control = 00000000?
> > +     IP D/C/B/A Interrupt 1 Control = 00000000?
> > +To setup the Server/Client IP Addresses for the TFTP Transfer, we will
> use the
> > +NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command
> commonly
> > +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> > +The NIOT command goes something like this:
> > +    162-Bug>niot
> > +     Controller LUN =00?
> > +     Device LUN     =00?
> > +     Node Control Memory Address =FFE10000?
> > +     Client IP Address      =192.168.1.245?
> > +     Server IP Address      =192.168.1.92?
> > +     Subnet IP Address Mask =255.255.255.0?
> > +     Broadcast IP Address   =192.168.1.255?
> > +     Gateway IP Address     =0.0.0.0?
> > +     Boot File Name ("NULL" for None)     =/mvme162.img?
> > +     Argument File Name ("NULL" for None) =?
> > +     Boot File Load Address         =00020000?
> > +     Boot File Execution Address    =00020000?
> > +     Boot File Execution Delay      =00000000?
> > +     Boot File Length               =00000000?
> > +     Boot File Byte Offset          =00000000?
> > +     BOOTP/RARP Request Retry       =00?
> > +     TFTP/ARP Request Retry         =00?
> > +     Trace Character Buffer Address =00000000?
> > +     BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> > +     BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
> > +Downloading and Executing
> > +Download from the TFTP server using the 162-Bug's "NBO"
> > +(Network Boot Operating System) command:
> > +    162-Bug>nbo
> > +    Network Booting from: VME162, Controller 0, Device 0
> > +     Loading: /mvme162.img
> > +     Client IP Address      = 192.168.1.245
> > +     Server IP Address      = 192.168.1.92
> > +     Gateway IP Address     = 0.0.0.0
> > +     Subnet IP Address Mask = 255.255.255.0
> > +     Boot File Name         = /mvme162.img
> > +     Argument File Name     =
> > +     Network Boot File load in progress... To abort hit <BREAK>
> > +     Bytes Received =&356528, Bytes Loaded =&356528
> > +     Bytes/Second   =&89132, Elapsed Time =4 Second(s)
> > +The program will automatically run when download is complete.
> >   mvme167
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200402/7ddd84c0/attachment-0001.html>
