[PATCH v2 1/1] testsuite: A description for each test added
Moyano, Gabriel
gabriel.moyano at dlr.de
Fri Apr 3 07:35:23 UTC 2020
testsuite/arphole/test_main.c | 6 ++--
testsuite/cdev01/test_main.c | 7 +++++
testsuite/commands01/test_main.c | 7 +++++
testsuite/condvar01/test_main.c | 7 +++++
testsuite/crypto01/test_main.c | 6 ++++
testsuite/debugger01/test_main.c | 6 ++++
testsuite/dhcpcd01/test_main.c | 8 +++++
testsuite/dhcpcd02/test_main.c | 6 ++++
testsuite/epoch01/test_main.c | 8 +++++
testsuite/evdev01/init.c | 6 ++++
testsuite/foobarclient/test_main.c | 10 ++++++
testsuite/foobarserver/test_main.c | 12 ++++++++
testsuite/ftpd01/test_main.c | 6 ++++
testsuite/ftpd02/test_main.c | 6 ++++
testsuite/init01/test_main.c | 4 ++-
testsuite/ipsec01/test_main.c | 8 +++++
testsuite/lagg01/test_main.c | 8 +++++
testsuite/log01/test_main.c | 6 ++++
testsuite/loopback01/test_main.c | 9 ++++--
testsuite/media01/test_main.c | 8 +++++
testsuite/mutex01/test_main.c | 6 ++++
testsuite/netshell01/test_main.c | 11 ++++---
testsuite/nfs01/test_main.c | 6 ++++
testsuite/openssl01/test_main.c | 6 ++++
testsuite/openssl02/test_main.c | 7 +++++
testsuite/pf01/test_main.c | 6 ++++
testsuite/pf02/test_main.c | 8 +++++
testsuite/ping01/test_main.c | 6 ++++
testsuite/ppp01/test_main.c | 26 ++++++++--------
testsuite/program01/test_main.c | 6 ++++
testsuite/rcconf01/test_main.c | 8 +++++
testsuite/rcconf02/test_main.c | 52 +++++++++++++++++---------------
testsuite/rwlock01/test_main.c | 6 ++++
testsuite/selectpollkqueue01/test_main.c | 6 ++++
testsuite/sleep01/test_main.c | 10 ++++++
testsuite/smp01/test_main.c | 8 +++++
testsuite/swi01/init.c | 8 +++++
testsuite/syscalls01/test_main.c | 6 ++++
testsuite/telnetd01/test_main.c | 6 ++++
testsuite/termios/test_main.c | 6 ++++
testsuite/termios01/test_main.c | 8 +++++
testsuite/termios02/test_main.c | 9 +++++-
testsuite/termios03/test_main.c | 8 ++++-
testsuite/termios04/test_main.c | 8 ++++-
testsuite/termios05/test_main.c | 8 ++++-
testsuite/termios06/test_main.c | 7 +++++
testsuite/thread01/test_main.c | 9 ++++++
testsuite/timeout01/init.c | 6 ++++
testsuite/unix01/test_main.c | 6 ++++
testsuite/usb01/init.c | 8 +++++
testsuite/usbkbd01/init.c | 8 +++++
testsuite/usbmouse01/init.c | 13 +++++---
testsuite/usbserial01/init.c | 8 +++++
testsuite/vlan01/test_main.c | 6 ++++
testsuite/zerocopy01/test_main.c | 8 +++++
55 files changed, 413 insertions(+), 55 deletions(-)
diff --git a/testsuite/arphole/test_main.c b/testsuite/arphole/test_main.c
index 45a28cc0..a77c79ee 100644
--- a/testsuite/arphole/test_main.c
+++ b/testsuite/arphole/test_main.c
@@ -1,8 +1,10 @@
* @file
- * This test program processes all ARP requests and claims every IP address it
- * notices. Use with care in production networks.
+ * @brief This test program processes all ARP requests and claims every IP address it
+ * notices.
+ * Use with care in production networks.
diff --git a/testsuite/cdev01/test_main.c b/testsuite/cdev01/test_main.c
index cbff9133..e5963423 100644
--- a/testsuite/cdev01/test_main.c
+++ b/testsuite/cdev01/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * It creates a character device (cdev) and tests the basic i/o functions,
+ * e.g. open(), read(), write(), ioctl(), etc.
* Copyright (c) 2016 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/commands01/test_main.c b/testsuite/commands01/test_main.c
index 73168eac..3bd38a70 100644
--- a/testsuite/commands01/test_main.c
+++ b/testsuite/commands01/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * The following commands are tested: route, ifconfig, ping, ping6 (if defined),
+ * netstat and wlanstats (if defined).
* Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/condvar01/test_main.c b/testsuite/condvar01/test_main.c
index 8b2d102b..3734ae32 100644
--- a/testsuite/condvar01/test_main.c
+++ b/testsuite/condvar01/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * It tests condition variable (condvar) sending RTEMS events to two
+ * workers (RTEMS tasks).
* Copyright (c) 2014 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/crypto01/test_main.c b/testsuite/crypto01/test_main.c
index 5c6b725e..ddea9f64 100644
--- a/testsuite/crypto01/test_main.c
+++ b/testsuite/crypto01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It tests /dev/crypto device.
* Copyright (c) 2018 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/debugger01/test_main.c b/testsuite/debugger01/test_main.c
index 777e8a76..3c3040fb 100644
--- a/testsuite/debugger01/test_main.c
+++ b/testsuite/debugger01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It tests RTEMS debugger (TCP:1122).
* Copyright (c) 2016 Chris Johns <chrisj at rtems.org>
* All rights reserved.
diff --git a/testsuite/dhcpcd01/test_main.c b/testsuite/dhcpcd01/test_main.c
index 358b4ac8..c1d97a3f 100644
--- a/testsuite/dhcpcd01/test_main.c
+++ b/testsuite/dhcpcd01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief It tests to add a hook to DHCP client daemon (dhcpcd).
+ * Every time the hook is called, the environment is printed out.
* Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/dhcpcd02/test_main.c b/testsuite/dhcpcd02/test_main.c
index 611c12b1..221b096f 100644
--- a/testsuite/dhcpcd02/test_main.c
+++ b/testsuite/dhcpcd02/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It tests the DHCP client daemon (dhcpcd).
diff --git a/testsuite/epoch01/test_main.c b/testsuite/epoch01/test_main.c
index dd8aa50f..98ae006a 100644
--- a/testsuite/epoch01/test_main.c
+++ b/testsuite/epoch01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * The following epoch functions are tested with parallel tasks: epoch_enter(),
+ * epoch_exit(), epoch_call(), epoch_wait(), epoch_enter_preempt(),
+ * epoch_exit_preempt(), epoch_wait_preempt() and epoch_drain_callbacks().
diff --git a/testsuite/evdev01/init.c b/testsuite/evdev01/init.c
index af375ee4..4bdc19c5 100644
--- a/testsuite/evdev01/init.c
+++ b/testsuite/evdev01/init.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Different event devices (evdev) are tested in different RTEMS tasks.
* COPYRIGHT (c) 2017 Kevin Kirspel
diff --git a/testsuite/foobarclient/test_main.c b/testsuite/foobarclient/test_main.c
index 85007ee8..d55b55c6 100644
--- a/testsuite/foobarclient/test_main.c
+++ b/testsuite/foobarclient/test_main.c
@@ -1,3 +1,13 @@
+ * @file
+ * @brief The multicast DNS (mDNS) protocol is tested.
+ * To run this test is also required to run foobarserver.
+ * The following functions are called: mDNS_StartBrowse(),
+ * mDNS_StartResolveService() and mDNS_StopResolveService().
diff --git a/testsuite/foobarserver/test_main.c b/testsuite/foobarserver/test_main.c
index a239a561..84c40c4d 100644
--- a/testsuite/foobarserver/test_main.c
+++ b/testsuite/foobarserver/test_main.c
@@ -1,3 +1,15 @@
+ * @file
+ * To run this test is also required to run foobarclient.
+ * A TCP socket (SOCK_STREAM) is open from port FOOBAR_PORT_BEGIN to
+ * port FOOBAR_PORT_END - 1 on at a time.
+ * The following functions are called: mDNS_RegisterService(),
+ * mDNS_DeregisterService() and mDNS_RenameAndReregisterService().
diff --git a/testsuite/ftpd01/test_main.c b/testsuite/ftpd01/test_main.c
index 98eb47ef..7ec17b96 100644
--- a/testsuite/ftpd01/test_main.c
+++ b/testsuite/ftpd01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It starts an FTP daemon (ftpd).
* Copyright (c) 2013 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/ftpd02/test_main.c b/testsuite/ftpd02/test_main.c
index 3eb079d2..d62976b4 100644
--- a/testsuite/ftpd02/test_main.c
+++ b/testsuite/ftpd02/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief File handling basics are tested in an FTP file system locally.
* Copyright (c) 2011, 2016 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/init01/test_main.c b/testsuite/init01/test_main.c
index 61d7836b..ea45b511 100644
--- a/testsuite/init01/test_main.c
+++ b/testsuite/init01/test_main.c
@@ -1,4 +1,6 @@
+ * @file
* This is the body of the test. It does not do much except ensure
* that the target is alive after initializing the TCP/IP stack.
diff --git a/testsuite/ipsec01/test_main.c b/testsuite/ipsec01/test_main.c
index 651a4056..e8a8455e 100644
--- a/testsuite/ipsec01/test_main.c
+++ b/testsuite/ipsec01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief It tests Internet Protocol Security protocol (ipsec).
+ * It needs a communication partner (see testsuit/ipsec01/README).
diff --git a/testsuite/lagg01/test_main.c b/testsuite/lagg01/test_main.c
index 99544a52..96256d36 100644
--- a/testsuite/lagg01/test_main.c
+++ b/testsuite/lagg01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief A link aggregation (lagg) is tested.
+ * ifconfig command is used to do this.
* Copyright (c) 2015 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/log01/test_main.c b/testsuite/log01/test_main.c
index 45f62cdf..4eaa9017 100644
--- a/testsuite/log01/test_main.c
+++ b/testsuite/log01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Different logging levels are tested.
diff --git a/testsuite/loopback01/test_main.c b/testsuite/loopback01/test_main.c
index f0453e69..1b5c0064 100644
--- a/testsuite/loopback01/test_main.c
+++ b/testsuite/loopback01/test_main.c
@@ -1,6 +1,9 @@
- * This is the body of the test. It does not do much except ensure
- * that the target is alive after initializing the TCP/IP stack.
+ * @file
+ * @brief It tests socket connections locally.
+ * The server and clients are running in different RTEMS tasks.
diff --git a/testsuite/media01/test_main.c b/testsuite/media01/test_main.c
index 942664cd..91e0dd5a 100644
--- a/testsuite/media01/test_main.c
+++ b/testsuite/media01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Code used to test the Media Manager.
+ * Telnet daemon (telnetd) and FTP daemon (ftpd) are started. Events are recorded.
* Copyright (c) 2010-2016 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/mutex01/test_main.c b/testsuite/mutex01/test_main.c
index c3e193d9..323ca527 100644
--- a/testsuite/mutex01/test_main.c
+++ b/testsuite/mutex01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Different mutex methods are tested.
* Copyright (c) 2014, 2018 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/netshell01/test_main.c b/testsuite/netshell01/test_main.c
index 13d8a31c..81941d0b 100644
--- a/testsuite/netshell01/test_main.c
+++ b/testsuite/netshell01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief RTEMS shell is started and it is possible to run net commands.
* COPYRIGHT (c) 2012. On-Line Applications Research Corporation (OAR).
@@ -24,11 +30,6 @@
* SUCH DAMAGE.
#include <assert.h>
#include <stdarg.h>
diff --git a/testsuite/nfs01/test_main.c b/testsuite/nfs01/test_main.c
index d50edc37..2312040a 100644
--- a/testsuite/nfs01/test_main.c
+++ b/testsuite/nfs01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It mounts a network file system (nfs).
diff --git a/testsuite/openssl01/test_main.c b/testsuite/openssl01/test_main.c
index 4359b5f0..0cac4b98 100644
--- a/testsuite/openssl01/test_main.c
+++ b/testsuite/openssl01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief It tests encryption and decryption using openssl.
diff --git a/testsuite/openssl02/test_main.c b/testsuite/openssl02/test_main.c
index 94a735b0..32e9c03a 100644
--- a/testsuite/openssl02/test_main.c
+++ b/testsuite/openssl02/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * The openssl certificate generation is tested and performance of
+ * cryptographic algorithm is shown.
* Copyright (c) 2013-2019 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/pf01/test_main.c b/testsuite/pf01/test_main.c
index 9421f0e6..3c07b82e 100644
--- a/testsuite/pf01/test_main.c
+++ b/testsuite/pf01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Packet filter rules are tested (see defines below).
diff --git a/testsuite/pf02/test_main.c b/testsuite/pf02/test_main.c
index 3e71ebb4..92073165 100644
--- a/testsuite/pf02/test_main.c
+++ b/testsuite/pf02/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * RTEMS shell starts at the end of the test.
diff --git a/testsuite/ping01/test_main.c b/testsuite/ping01/test_main.c
index 659043c4..5702cee2 100644
--- a/testsuite/ping01/test_main.c
+++ b/testsuite/ping01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Ping (shell command) test.
diff --git a/testsuite/ppp01/test_main.c b/testsuite/ppp01/test_main.c
index 550039e9..078e96e2 100644
--- a/testsuite/ppp01/test_main.c
+++ b/testsuite/ppp01/test_main.c
@@ -1,3 +1,17 @@
+ * @file
+ * To test PPP connect the RTEMS target with your host. Start PPP on the host
+ * with something like this:
+ * pppd nodetach noauth 192.168.100.11:192.168.100.70 proxyarp 115200 dump \
+ * local nocrtscts debug mtu 296 mru 296 nolock ms-dns 192.168.96.1 novj \
+ * /dev/ttyS0
+ * Make sure IP forwarding is enabled and check the firewall settings if you
+ * want to access the internet.
@@ -29,18 +43,6 @@
* SUCH DAMAGE.
- * To test PPP connect the RTEMS target with your host. Start PPP on the host
- * with something like this:
- * pppd nodetach noauth 192.168.100.11:192.168.100.70 proxyarp 115200 dump \
- * local nocrtscts debug mtu 296 mru 296 nolock ms-dns 192.168.96.1 novj \
- * /dev/ttyS0
- * Make sure IP forwarding is enabled and check the firewall settings if you
- * want to access the internet.
#include <assert.h>
#include <sys/stat.h>
diff --git a/testsuite/program01/test_main.c b/testsuite/program01/test_main.c
index 7691b210..a318b7b8 100644
--- a/testsuite/program01/test_main.c
+++ b/testsuite/program01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief RTEMS function wrappers for BSD programs test.
diff --git a/testsuite/rcconf01/test_main.c b/testsuite/rcconf01/test_main.c
index 4701390c..c7f8ef5f 100644
--- a/testsuite/rcconf01/test_main.c
+++ b/testsuite/rcconf01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * The following functions are tested: rtems_bsd_rc_conf_argc_argv_create(),
+ * rtems_bsd_rc_conf_find(), rtems_bsd_rc_conf_print_cmd() and
+ * rtems_bsd_rc_conf_find_next().
* Copyright 2016 Chris Johns <chrisj at rtems.org>
diff --git a/testsuite/rcconf02/test_main.c b/testsuite/rcconf02/test_main.c
index 3a7b7026..c40392de 100644
--- a/testsuite/rcconf02/test_main.c
+++ b/testsuite/rcconf02/test_main.c
@@ -1,29 +1,8 @@
- * Copyright 2016 Chris Johns <chrisj at rtems.org>
+ * @file
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
+ * @brief A rc.conf script (rc_conf_text) is run. RTEMS shell starts at the end of the test.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
* Tests:
* 1. rc.conf processing
@@ -48,6 +27,31 @@
* 4. ftpd
+ * Copyright 2016 Chris Johns <chrisj at rtems.org>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
#include <sys/param.h>
#include <assert.h>
diff --git a/testsuite/rwlock01/test_main.c b/testsuite/rwlock01/test_main.c
index a0ae91b6..ed1dc126 100644
--- a/testsuite/rwlock01/test_main.c
+++ b/testsuite/rwlock01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Readers-writer lock is tested.
diff --git a/testsuite/selectpollkqueue01/test_main.c b/testsuite/selectpollkqueue01/test_main.c
index 244f5b50..1c481517 100755
--- a/testsuite/selectpollkqueue01/test_main.c
+++ b/testsuite/selectpollkqueue01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * The following system calls are tested: select(), pselect(), poll(), kqueue() and pipe().
* Copyright (c) 2013, 2019 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/sleep01/test_main.c b/testsuite/sleep01/test_main.c
index ffea7420..576c166f 100644
--- a/testsuite/sleep01/test_main.c
+++ b/testsuite/sleep01/test_main.c
@@ -1,3 +1,13 @@
+ * @file
+ * The following functions are tested: msleep(), msleep_spin(), tsleep(),
+ * wakeup() and wakeup_one().
+ * SLAVE_COUNT tasks are created. Each one increments its own counter and
+ * then it is sent to sleep with tsleep(). All tasks are grouped under the
+ * same channel. This means that all threads are woken up if wakeup() is called.
diff --git a/testsuite/smp01/test_main.c b/testsuite/smp01/test_main.c
index 583fe906..35c10c96 100644
--- a/testsuite/smp01/test_main.c
+++ b/testsuite/smp01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Symetric Multiprocessing (smp) is tested.
+ * Parallel jobs are run with rtems_test_parallel().
diff --git a/testsuite/swi01/init.c b/testsuite/swi01/init.c
index da5e4446..32e44c60 100644
--- a/testsuite/swi01/init.c
+++ b/testsuite/swi01/init.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Software interrupts (swi) are tested.
+ * The following functions are called: swi_add() and swi_sched().
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/syscalls01/test_main.c b/testsuite/syscalls01/test_main.c
index 58750561..1116890f 100644
--- a/testsuite/syscalls01/test_main.c
+++ b/testsuite/syscalls01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Different system calls are tested.
diff --git a/testsuite/telnetd01/test_main.c b/testsuite/telnetd01/test_main.c
index 8fca493e..00916843 100644
--- a/testsuite/telnetd01/test_main.c
+++ b/testsuite/telnetd01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief The telnet daemon is run.
diff --git a/testsuite/termios/test_main.c b/testsuite/termios/test_main.c
index 68a15c6f..ff805032 100644
--- a/testsuite/termios/test_main.c
+++ b/testsuite/termios/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief A program to test different setting of termios manually is run.
* COPYRIGHT (c) 1989-2010.
* On-Line Applications Research Corporation (OAR).
diff --git a/testsuite/termios01/test_main.c b/testsuite/termios01/test_main.c
index e00ff865..6f9041f4 100644
--- a/testsuite/termios01/test_main.c
+++ b/testsuite/termios01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Settings of termios (e.g. baudrate, parity, etc.) are tested.
+ * tcsetattr() is used to change the settings.
diff --git a/testsuite/termios02/test_main.c b/testsuite/termios02/test_main.c
index 3ec5c0b2..387a55bf 100644
--- a/testsuite/termios02/test_main.c
+++ b/testsuite/termios02/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * The following system calls are tested: tcflow(), tcflush(), tcgetpgrp(),
+ * tcsendbreak() and ctermid().
* COPYRIGHT (c) 1989-2017.
@@ -137,4 +144,4 @@ test_main(void)
exit(0);
-#include <rtems/bsd/test/default-termios-init.h>
\ No newline at end of file
+#include <rtems/bsd/test/default-termios-init.h>
diff --git a/testsuite/termios03/test_main.c b/testsuite/termios03/test_main.c
index c92c4f0d..a0e9cdf3 100644
--- a/testsuite/termios03/test_main.c
+++ b/testsuite/termios03/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief read() and write() are tested using the termios utilities.
@@ -70,4 +76,4 @@ test_main(void)
exit(0);
diff --git a/testsuite/termios04/test_main.c b/testsuite/termios04/test_main.c
index f4d94767..c4f24c28 100644
--- a/testsuite/termios04/test_main.c
+++ b/testsuite/termios04/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief IXON and IXOFF flags test.
@@ -66,4 +72,4 @@ test_main(void)
exit(0);
diff --git a/testsuite/termios05/test_main.c b/testsuite/termios05/test_main.c
index faad94fe..959c9c23 100644
--- a/testsuite/termios05/test_main.c
+++ b/testsuite/termios05/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief Noncanonical mode test.
@@ -62,4 +68,4 @@ test_main(void)
exit(0);
diff --git a/testsuite/termios06/test_main.c b/testsuite/termios06/test_main.c
index d70b7bdf..34972eae 100644
--- a/testsuite/termios06/test_main.c
+++ b/testsuite/termios06/test_main.c
@@ -1,3 +1,10 @@
+ * @file
+ * The behavior of the following flags are tested: IGNCR, ISRTIP, IUCLC, ICRNL,
+ * INLCR, OPOST, ONLRET, ONLCR, ONOCR, OCRNL, OXTABS and OLCUC.
diff --git a/testsuite/thread01/test_main.c b/testsuite/thread01/test_main.c
index fa15b9f6..9d5e5bba 100644
--- a/testsuite/thread01/test_main.c
+++ b/testsuite/thread01/test_main.c
@@ -1,3 +1,12 @@
+ * @file
+ * @brief The creation and execution of threads (RTEMS task, kproc, kthread) are tested.
+ * The main thread creates a worker and the waits until receives an event of the
+ * created worker.
diff --git a/testsuite/timeout01/init.c b/testsuite/timeout01/init.c
index e2a24a82..eab1e9f1 100644
--- a/testsuite/timeout01/init.c
+++ b/testsuite/timeout01/init.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief The timeout and callout functions are tested.
diff --git a/testsuite/unix01/test_main.c b/testsuite/unix01/test_main.c
index 61f9aa4e..32b37ba0 100644
--- a/testsuite/unix01/test_main.c
+++ b/testsuite/unix01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief PF_UNIX sockets test.
diff --git a/testsuite/usb01/init.c b/testsuite/usb01/init.c
index c719e193..f9ee1f49 100644
--- a/testsuite/usb01/init.c
+++ b/testsuite/usb01/init.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Same as media01 but without ftpd and telnetd.
* Copyright (c) 2010, 2016 embedded brains GmbH. All rights reserved.
diff --git a/testsuite/usbkbd01/init.c b/testsuite/usbkbd01/init.c
index e6fe2560..9f9fb51c 100644
--- a/testsuite/usbkbd01/init.c
+++ b/testsuite/usbkbd01/init.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief USB keyboard test.
diff --git a/testsuite/usbmouse01/init.c b/testsuite/usbmouse01/init.c
index 4d33241d..6e864b6c 100644
--- a/testsuite/usbmouse01/init.c
+++ b/testsuite/usbmouse01/init.c
@@ -1,3 +1,12 @@
+ * @file
+ * @brief USB mouse test.
+ * This test requires a USB mouse to be attached to a USB port.
@@ -24,10 +33,6 @@
* SUCH DAMAGE.
- * This test requires a USB mouse to be attached to a USB port.
#include <sys/malloc.h>
#include <assert.h>
diff --git a/testsuite/usbserial01/init.c b/testsuite/usbserial01/init.c
index ef3a45f6..a27cbe00 100644
--- a/testsuite/usbserial01/init.c
+++ b/testsuite/usbserial01/init.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief USB serial adapter test.
diff --git a/testsuite/vlan01/test_main.c b/testsuite/vlan01/test_main.c
index 5f4082ee..9450dac2 100644
--- a/testsuite/vlan01/test_main.c
+++ b/testsuite/vlan01/test_main.c
@@ -1,3 +1,9 @@
+ * @file
+ * @brief A vlan creation using ifconfig is tested.
diff --git a/testsuite/zerocopy01/test_main.c b/testsuite/zerocopy01/test_main.c
index 54051259..3e7b7b7b 100644
--- a/testsuite/zerocopy01/test_main.c
+++ b/testsuite/zerocopy01/test_main.c
@@ -1,3 +1,11 @@
+ * @file
+ * @brief Zerocopy test.
+ * Telnet daemon (telnetd) is initilized.
2.12.3
