[PATCH] score: Fix _ISR_Stack_area_end
Sebastian Huber
Fri Apr 3 07:52:55 UTC 2020
The _ISR_Stack_area_begin and _ISR_Stack_area_end symbols are in
different sections. They must have the same alignment, otherwise the
following linker directive could separate them:
*(SORT_BY_ALIGNMENT (SORT_BY_NAME (.rtemsstack*)))
Update #3799.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/confdefs/percpu.h | 5 -----
cpukit/score/src/isrstackareaend.c | 36 ++++++++++++++++++++++++++++++++++
3 files changed, 37 insertions(+), 5 deletions(-)
create mode 100644 cpukit/score/src/isrstackareaend.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 3af69bd615..1486a4156f 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1014,6 +1014,7 @@ librtemscpu_a_SOURCES += score/src/chainnodecount.c
librtemscpu_a_SOURCES += score/src/debugisthreaddispatchingallowed.c
librtemscpu_a_SOURCES += score/src/interr.c
librtemscpu_a_SOURCES += score/src/isr.c
+librtemscpu_a_SOURCES += score/src/isrstackareaend.c
librtemscpu_a_SOURCES += score/src/wkspace.c
librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
diff --git a/cpukit/include/rtems/confdefs/percpu.h b/cpukit/include/rtems/confdefs/percpu.h
index 730571b54a..a902b4735c 100644
--- a/cpukit/include/rtems/confdefs/percpu.h
+++ b/cpukit/include/rtems/confdefs/percpu.h
@@ -98,11 +98,6 @@ char _ISR_Stack_area_begin[
] RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
RTEMS_SECTION( ".rtemsstack.interrupt.begin" );
-RTEMS_DEFINE_GLOBAL_SYMBOL_IN_SECTION(
- _ISR_Stack_area_end,
- ".rtemsstack.interrupt.end"
/* Thread stack size configuration */
#ifndef CONFIGURE_MINIMUM_TASK_STACK_SIZE
diff --git a/cpukit/score/src/isrstackareaend.c b/cpukit/score/src/isrstackareaend.c
new file mode 100644
index 0000000000..9d48384b62
--- /dev/null
+++ b/cpukit/score/src/isrstackareaend.c
@@ -0,0 +1,36 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/isr.h>
+RTEMS_SECTION( ".rtemsstack.interrupt.end" )
+RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
+const char _ISR_Stack_area_end[ 0 ];
2.16.4
