[PATCH] Add a release procedure section.
Fri Apr 3 13:42:38 UTC 2020
Hi Chris,
Mostly good. I can tell you wrote it top-down and got tired by the end
:) Some errors in the last half, nothing major except the part about
tagging.
Thanks for this, see below:
On Fri, Apr 3, 2020 at 1:15 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
>  eng/release-mgmt.rst    |   4 +-
>  eng/release-process.rst | 275 ++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 276 insertions(+), 3 deletions(-)
>  create mode 100644 eng/release-process.rst
> diff --git a/eng/release-mgmt.rst b/eng/release-mgmt.rst
> index 6706d62..ff97d19 100644
> --- a/eng/release-mgmt.rst
> +++ b/eng/release-mgmt.rst
> @@ -7,11 +7,9 @@
>  Software Release Management
> -TBD write content
>  .. COMMENT: Subsections
>  .. toctree::
> +    release-process
>      change-reports
>      vdd-generation
> diff --git a/eng/release-process.rst b/eng/release-process.rst
> new file mode 100644
> index 0000000..91f3ee6
> --- /dev/null
> +++ b/eng/release-process.rst
> @@ -0,0 +1,275 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2020 Contemporary Software
> +.. Copyright (C) 2020 Chris Johns
Remove one space
Add a reference linkage?
.. _Release_Process
> +Release Process
> +The release process creates an RTEMS release. The process has a number of
> +stages that happen before a release can be made, during the creation of the
> +release procedure and after the release has been made.
> +Releases
> +RTEMS is released as a collection of ready to use source code and built
> +documentation. Releases are publicly available on the RTEMS servers under
> +https://ftp.rtems.org/pub/rtems/releases.
> +Releases are group under the major version number as a collection of
> +directories consisting of the version number. This is termed a release
> +series. A release may also contain release snapshots.
> +All releases must have a three digit version number and this can be optionally
> +followed by a dash character (``-``) and an identifier, e.g. ``5.1.0-acme-1``.
> +The RTEMS Project reserves releases with only the three digit version number,
> +e.g. ``5.1.0``. This identifies an RTEMS Project release.
> +Release Layout
> +* All released source archives are XZ compressed tar files.
> +* Top level contains:
> +:file:`README.txt`:
> +    A set of brief release instructions.
> +:file:`contrib`:
> +    Contributed sources. For example the release scripts used to create the
> +    release.
> +:file:`docs`:
> +    Compressed documentation build in HTML, Single page HTML and PDF
> +    formats. Provide compressed files for each document and a single archive
> +    of all the documentation. Provide an SHA512 check sum file.
> +:file:`rtems-<VERSION>-release-notes.pdf`:
> +    RTEMS Release notes document the changes in a release. This is a capture
> +    of the Trac report for the release's milestone in PDF format.
> +:file:`sha512sum.txt`:
> +    SHA512 checksum of all files in this directory.
> +:file:`sources`:
> +    All source code referenced by the release.
> +Release Version Numbering
> +The release numbering scheme changed with RTEMS 5.
> +The master branch has the version N.0.0 with N being the next major release
> +number. The release branch in a repository will be just the major number.
> +The first release of this series will have the version number N.1.0. The first
> +bugfix release (minor release) of this series will have the version number
> +N.2.0.
> +The release branch will have the version number N.M.1 with M being the last
> +minor release of this series. Tools will use N as the version number and must
> +be compatible with all releases and the release branch of the N series.
> +Examples:
> + - ``5.0.0`` is the version number of the development master for the 5 series
> + - ``5.1.0`` is the first release of the 5 series
> + - ``5.1.1`` is the version number of the 5 series release branch right after
> +   the 5.1.0 release until 5.2.0 is released
> + - ``5.2.0`` is the first bugfix release of the 5 series
> + - ``5.2.1`` is the version number of the 5 series release branch right after
> +   the 5.2.0 release until 5.3.0 is released
> + - ``6.0.0`` is the version number of the development master for the 6 series
> +Release Scripts
> +* The release scripts are held in the top level repository
> +  https://git.rtems.org/rtems-release.git.
> +* The scripts are written for FreeBSD and can run on FreeBSD 10 through to
delete 'to'
> +  FreeBSD 12. No other host operating system is support for the release
s/support/supported
> +  scripts. Updates are welcome if the changes do not effect the operation on
s/effect/affect
> +  FreeBSD.
> +* A Python ``virutalenv`` environment is required for a working Sphinx
> +  documentation building environment. Follow the procedure in the
> +  ``rtems-docs.git`` top level ``README`` file.
> +* Building a standard release required you provide the release major number
s/required/requires
> +  and the release's remaining version string including any addition
s/addition/additional
> +  identifiers:
> +  .. code-block:: none
> +     ./rtems-release 5 1.0
> +  To create a release snapshot:
> +    ./rtems-release 5 0.0-m2003
> +* A 3rd option of a release URL can be provided to create a test or deploy-able
no hyphen needed in deployable
> +  release. The URL is a base path the RSB uses to download the release source
> +  files from:
> +    ./rtems-release \
> +        -u https://ftp.rtems.org/pub/rtems/people/chrisj/releases \
> +        5 0.0-m2003-2
> +* Building the release notes requires the Web Toolkit HTML to PDF converter be
> +  installed. The FreeBSD package is ``wkhtmltopdf``.
> +Release Snapshots
> +* Release snapshots are only created for the current development version of
> +  RTEMS. For example RTEMS 5 snapshot path is :file:`5/5.0.0/5.0.0-m2003`.
> +* Release snapshots are based on the development sources and may be unstable or
> +  not suitable for use in production.
> +* A release snapshot is created each month and are named as
s/are/is
> +  ``<major>/<version>/<version>-<YYMM>`` where ``YY`` is the last two digits of
> +  the current year and ``MM`` is the month as a two digit number.
> +* In the lead up to a release more than one snapshot can be created by
> +  appending ``-<count>`` to the snapshot version string where ``<count>`` is
> +  incremented starting from ``1``. The first snapshot without a count is
> +  considered number ``0``.
> +* Release snapshots maybe removed from the RTEMS servers at the discretion of
s/maybe/may be
> +  the RTEMS project
> +Release Repositories
> +The following are the repositories a release effects. Any repository action is
"repositories that a release"
> +to be performed in the following repositories:
> +#. rtems.git
> +#. rtems-docs.git
> +#. rtems-examples.git
> +#. rtems-libbsd.git
> +#. rtems-source-builder.git
> +#. rtems-tools
> +#. rtems_waf
> +Pre-Release Procedure
> +* All tickets must be resolved, close or moved to a later milestone.
s/close/closed
> +* The following BSP must build using the RSB:
> +  - ``arm/beagleboneblack``
> +* Branch label are the major number as branch releases increment the minor number.
s/label/labels
> +* The commands to set a remote branch for a release in a repository are:
> +      git checkout -b <VERSION> origin/master
> +      git push origin <VERSION>
> +  Example:
> +      git clone ssh://chrisj@dispatch.rtems.org/data/git/rtems.git rtems.git
> +      cd rtems.git
> +      git checkout -b 5 origin/master
> +      git push origin 5
Creating the release branch is only needed for major releases. It
should be clarified somehow?
> +Release Procedure
> +The release procedure can be performed on any FreeBSD machine and uploaded to
> +the RTEMS FTP server. You will need ssh access to the RTEMS server
> +``dispatch.rtems.org`` and suitable permissions to write into the FTP release
> +path on the RTEMS server.
> +#. Create the RTEMS release run the release script:
"To create" or "by running"
> +       ./rtems-release <VERSION> <REVISION>
> +   Example:
> +       cd
> +       mkdir -p development/rtems/releases
> +       cd development/rtems/releases
> +       git clone git://git.rtems.org/rtems-release.git rtems-release.git
> +       cd rtems-release.git
> +#. Copy the release to the RTEMS FTP server:
> +       ssh <user>@dispatch.rtems.org mkdir -p /data/ftp/pub/rtems/releases/<VERSION>
> +       scp -r <VERSION>.<REVISION> <user>@dispatch.rtems.org:/data/ftp/pub/rtems/releases/<VERSION>/.
> +   Example:
> +       ssh chrisj at dispatch.rtems.org mkdir -p /data/ftp/pub/rtems/releases/5
> +       scp -r 5.1.0 chrisj at dispatch.rtems.org:/data/ftp/pub/rtems/releases/5/.
> +#. Verify the release has been uploaded by checking the link:
> +   https://ftp.rtems.org/pub/rtems/releases/<VERSION>/<VERSION>.<REVISION>
> +#. Tag the release repositories with the following command:
> +       git tag <TAG> <VERSION>
> +       git push origin
git push origin <TAG>
> +   Example:
> +      cd rtems.git
> +      git 5.1.0 origin/5
git tag
> +      git push origin
git push origin 5.1.0
But do you need to be on the /5 branch?
Maybe switch to it before creating the tag?
    cd rtems.git
    git checkout -b origin/5
    git tag 5.1.0
Might be a better process.
> +      cd
> +Post-Release Procedure
> +The follow procedures are performed after a release have been created.
s/follow/following
s/have/has
> +#. TDB
s/TDB/TBD
> 2.24.1
> devel mailing list
> devel at rtems.org
