[PATCH v3] Tests for inttype.h methods
Eshan dhawan
eshandhawan51 at gmail.com
Fri Apr 3 16:52:20 UTC 2020
testsuites/psxtests/psxinttypes01/init.c | 25 ++++++++++++++++---
.../psxtests/psxinttypes01/psxinttypes01.doc | 10 +++++++-
2 files changed, 31 insertions(+), 4 deletions(-)
diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
index 030aa2aa57..d86313b251 100644
--- a/testsuites/psxtests/psxinttypes01/init.c
+++ b/testsuites/psxtests/psxinttypes01/init.c
@@ -6,6 +6,7 @@
* SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020, Eshan Dhawan
* Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
@@ -64,11 +65,29 @@ rtems_task Init(rtems_task_argument ignored)
wchar_t *nptr2_n_errange = L"-9999999999999999999999";
wchar_t *endptr2 = NULL;
- intmax_t result_strtoimax;
+ intmax_t result_strtoimax, result_imaxabs, input_1, input_2 ;
+ imaxdiv_t result_exp, result_imaxdiv ;
uintmax_t result_strtoumax;
TEST_BEGIN();
+ /* Test for imaxabs */
+ input_1 = -10 ;
+ result_imaxabs = 10 ;
+ rtems_test_assert( imaxabs(input_1) == result_imaxabs );
+ input_1 = 10 ;
+ /* Test for imaxdiv */
+ input_1 = 10 ;
+ input_2 = 3 ;
+ result_exp.quot = input_1 / input_2 ;
+ result_exp.rem = input_1 % input_2 ;
+ result_imaxdiv = imaxdiv(input_1, input_2) ;
+ rtems_test_assert( result_imaxdiv.quot == result_exp.quot &&
+ result_imaxdiv.rem == result_exp.rem );
/* Test for strtoimax */
puts( "\nstrtoimax Testcases...." );
puts( "Valid Inputs - Positive Number" );
@@ -83,7 +102,7 @@ rtems_task Init(rtems_task_argument ignored)
rtems_test_assert( result_strtoimax == -123 );
puts( "Final string pointed by endptr" );
- rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
+ rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
puts( "Valid Input - Positive Number - Number out of Range" );
result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
index 19f63af34b..499ef0c72c 100644
--- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
+++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
@@ -1,4 +1,4 @@
-This File describes the concepts tested by this test suite.
+This File describes the concepts tested by this test suite.
inttypes.h - fixed size integer types
@@ -37,3 +37,11 @@ test suite name: PSXINTTYPE 01
- checks for output for string having a negative number - Number Out of Range
- checks for final string pointed by endptr
- checks for output for invalid argument - Invalid Base
+- Checks for imaxabs Testcases
+ - checks for output with an input with any negative number
+ - checks for output with an input with any positive number
+- Checks for imaxdiv Testcases
+ -checks for the output quotient and remainder with input with positive numbers
2.17.1
