[PATCH v11] tests for fenv.h functions
Vaibhav Gupta
vaibhav.varodek at gmail.com
Fri Apr 3 19:32:32 UTC 2020
On Sat, Apr 4, 2020, 1:01 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Apr 3, 2020 at 1:11 PM Vaibhav Gupta <vaibhav.varodek at gmail.com>
> wrote:
> > IMO we should have a rule for nested CPP directives.
> > And also the commenting. It makes the code more readable
> > as a part of good coding style.
> > Specially if the directives are nested, because they don't
> > use brackets, too many opening-closing pair can make
> > the code hard to read.
> We do have some precedent for aligning the #ifdef with the surrounding
> code when it is in a scoped block. I can at least get on board with
> that, and the commenting. The discussion should be had in a separate
> thread though. Would you care to present the proposal?
Sure!
--Vaibhav Gupta
> > -- Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200404/35e9ac58/attachment.html>
