[PATCH] bsp/raspberry: Add a bsp_fdt_map_intr().
Christian Mauderer
oss at c-mauderer.de
Sat Apr 4 10:56:29 UTC 2020
From: Christian Mauderer <christian.mauderer at embedded-brains.de>
Fixes #3903
bsps/arm/raspberrypi/include/bsp/irq.h | 2 ++
bsps/arm/raspberrypi/start/bspstart.c | 23 +++++++++++++++++++++++
2 files changed, 25 insertions(+)
diff --git a/bsps/arm/raspberrypi/include/bsp/irq.h b/bsps/arm/raspberrypi/include/bsp/irq.h
index 6a9d05cba6..6758094519 100644
--- a/bsps/arm/raspberrypi/include/bsp/irq.h
+++ b/bsps/arm/raspberrypi/include/bsp/irq.h
@@ -35,6 +35,8 @@
#define BCM2835_INTC_TOTAL_IRQ 64 + 8
+#define BCM2835_IRQ_SET1_MIN 0
+#define BCM2835_IRQ_SET2_MIN 32
#define BCM2835_IRQ_ID_GPU_TIMER_M0 0
#define BCM2835_IRQ_ID_GPU_TIMER_M1 1
diff --git a/bsps/arm/raspberrypi/start/bspstart.c b/bsps/arm/raspberrypi/start/bspstart.c
index 49896e4d47..89fe8707f1 100644
--- a/bsps/arm/raspberrypi/start/bspstart.c
+++ b/bsps/arm/raspberrypi/start/bspstart.c
@@ -101,6 +101,29 @@ void *raspberrypi_get_reg_of_node(const void *fdt, int node)
return (BUS_TO_PHY((void *) fdt32_to_cpu(val[0])));
+#ifdef BSP_FDT_IS_SUPPORTED
+uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells)
+ uint32_t controller = intr[0];
+ uint32_t source = intr[1];
+ switch(controller) {
+ case 0:
+ return source + BCM2835_IRQ_ID_BASIC_BASE_ID;
+ break;
+ case 1:
+ return source + BCM2835_IRQ_SET1_MIN;
+ break;
+ case 2:
+ return source + BCM2835_IRQ_SET2_MIN;
+ break;
+ default:
+ return (uint32_t)(-1);
+ break;
+#endif /* BSP_FDT_IS_SUPPORTED */
void bsp_start(void)
bcm2835_get_board_spec_entries spec = { 0 };
2.25.1
