[PATCH rtems-tools] rtemstoolkit: add override option for rtems_version
Vijay Kumar Banerjee
vijay at rtems.org
Sat Apr 4 22:26:50 UTC 2020
On Sun, Apr 5, 2020, 3:55 AM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Sun, Apr 5, 2020, 3:45 AM Gedare Bloom <gedare at rtems.org> wrote:
>> Use in tester to allow defining custom rtems_version
>> to use in tools.
>> Closes #3671.
> Looks like someone else was also chasing this bug with a similar approach
> https://lists.rtems.org/pipermail/devel/2020-April/059001.html
>> rtemstoolkit/options.py | 1 +
>> tester/rtems/version.cfg | 4 +++-
>> 2 files changed, 4 insertions(+), 1 deletion(-)
>> diff --git a/rtemstoolkit/options.py b/rtemstoolkit/options.py
>> index 32a7016..e991bc8 100644
>> --- a/rtemstoolkit/options.py
>> +++ b/rtemstoolkit/options.py
>> @@ -80,6 +80,7 @@ class command_line(object):
>> self.long_opts = {
>> # key macro handler
>> param defs init
>> '--jobs' : ('_jobs', self._lo_jobs,
>> True, 'default', True),
>> + '--rtems-version' : ('rtems_version', self._lo_string,
>> True, None, False),
>> '--log' : ('_logfile', self._lo_string,
>> True, None, False),
>> '--macros' : ('_macros', self._lo_string,
>> True, None, False),
>> '--force' : ('_force', self._lo_bool,
>> False, '0', True),
>> diff --git a/tester/rtems/version.cfg b/tester/rtems/version.cfg
>> index 2cd9073..0ca057e 100644
>> --- a/tester/rtems/version.cfg
>> +++ b/tester/rtems/version.cfg
>> @@ -32,4 +32,6 @@
>> # RTEMS Version
>> -%define rtems_version 5
>> +%if ! %{defined rtems_version}
>> + %define rtems_version 5
>> +%endif
>> 2.17.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/ed104f7b/attachment.html>
