[PATCH v5] Chapter-on-need-for-RTEMS-specific-cross-compiler
Sun Apr 5 04:24:30 UTC 2020
Pushed, thank you for your contribution!
On Fri, Apr 3, 2020 at 9:46 PM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> Removed '-' character and provided definition list format
>  user/start/tools.rst | 33 +++++++++++++++++++++++++++++++++
>  1 file changed, 33 insertions(+)
> diff --git a/user/start/tools.rst b/user/start/tools.rst
> index c3f039b..1d83062 100644
> --- a/user/start/tools.rst
> +++ b/user/start/tools.rst
> @@ -3,6 +3,7 @@
>  .. Copyright (C) 2019 embedded brains GmbH
>  .. Copyright (C) 2019 Sebastian Huber
>  .. Copyright (C) 2020 Chris Johns
> +.. Copyright (C) 2020 Utkarsh Rai
>  .. _QuickStartTools:
> @@ -76,3 +77,35 @@ source code used.
>  Add ``--verbose`` to the GCC command for the the verbose version details.
> +Need for RTEMS-Specific Cross-Compiler
> +New users are often confused as to why they cannot use their distribution's
> +cross-compiler for their target on rtems, e.g., the riscv64-linux-gnu or the
> +arm-none-eabi-gcc on RTEMS. Below mentioned are some of the reasons for using
> +the RTEMS cross-compiler.
> + Correct configuration of Newlib
> +     Newlib is a C standard library implementation intended for use on embedded
> +     systems. Most of the POSIX and libc support for RTEMS is derived from
> +     Newlib. The RTEMS cross-compiler configures Newlib correctly for RTEMS.
> + Threading in GCC support libraries
> +     Several threading packages in GCC such as Go threads (libgo), OpenMP
> +     (libgomp), and OpenACC need to be customized according to RTEMS. This is
> +     done by the RTEMS specific cross-compiler.
> + Provide preprocessor define __rtems__
> +     The  ``__rtems__``  preprocessor define is used to provide conditional code
> +     compilation in source files that are shared with other projects e.g. in
> +     Newlib or imported code from FreeBSD.
> + Multilib variants to match the BSP
> +     RTEMS configures GCC to create separate runtime libraries for each
> +     supported instruction set, floating point unit, vector unit, word size
> +     (e.g. 32-bit and 64-bit), endianness, ABI, processor errata workarounds,
> +     and so on in the architecture. These libraries are termed as :ref:`Multilib
> +     <TargetArchitectures>` variants. Multilib variants to match the BSP are set
> +     by selecting a specific set of machine options using the RTEMS
> +     cross-compiler.
> 2.17.1
> devel mailing list
> devel at rtems.org
