[PATCH] user/rsb: describe how to create configuration reports
Gedare Bloom
gedare at rtems.org
Sun Apr 5 04:43:55 UTC 2020
Closes #3629.
user/rsb/configuration.rst | 21 ++++++++++++++++++---
1 file changed, 18 insertions(+), 3 deletions(-)
diff --git a/user/rsb/configuration.rst b/user/rsb/configuration.rst
index 8c8c87f..7ad58ed 100644
--- a/user/rsb/configuration.rst
+++ b/user/rsb/configuration.rst
@@ -364,11 +364,26 @@ points to are loaded. The second is a file called ``.rsb_macros`` in your home
directory. You need to have the environment variable ``HOME`` defined for this
work.
+Configuration Reports
+A configuration report detailing a build configuration is generated by the
+``sb-set-builder`` command. The report can also be generated separately from
+the build process by invoking the ``sb-report`` command on the build set used
+for the build, for example:
+.. code-block:: shell
+ cd rtems
+ ../source-builder/sb-reports 5/rtems-sparc
+ less 5-rtems-sparc.txt
Report Mailing
-The build reports can be mailed to a specific email address to logging and
-monitoring. Mailing requires a number of parameters to function. These are:
+Configuration reports from a build can be mailed to a specific email address
+for logging and monitoring. Mailing requires a number of parameters to
+function. These are:
- To mail address
2.17.1
