[PATCH] pthreadgetcpuclockid.c: Implement pthread_getcpuclockid to return thread Id
Eshan Dhawan eshandhawan51 at gmail.com
Sun Apr 5 10:02:37 UTC 2020
Is this patch pushed?
where will its test be added?
thanks
- Eshan
On Fri, Mar 13, 2020 at 1:30 AM Joel Sherrill <joel at rtems.org> wrote:
>  cpukit/posix/src/pthreadgetcpuclockid.c | 31
>  1 file changed, 26 insertions(+), 5 deletions(-)
> diff --git a/cpukit/posix/src/pthreadgetcpuclockid.c
> b/cpukit/posix/src/pthreadgetcpuclockid.c
> index cd7814b..c15962e 100644
> --- a/cpukit/posix/src/pthreadgetcpuclockid.c
> +++ b/cpukit/posix/src/pthreadgetcpuclockid.c
> @@ -7,8 +7,10 @@
>   *  20.1.6 Accessing a Thread CPU-time Clock, P1003.4b/Draft 8, p. 58
> - *  COPYRIGHT (c) 1989-2007.
> + *  COPYRIGHT (c) 1989-2007,2020.
>   *  On-Line Applications Research Corporation (OAR).
>   *  The license and distribution terms for this file may be
> @@ -23,12 +25,31 @@
>  #include <pthread.h>
>  #include <errno.h>
> -#include <rtems/seterr.h>
> +#include <rtems/score/threadimpl.h>
>  int pthread_getcpuclockid(
> -  pthread_t    pid,
> +  pthread_t    thread,
>    clockid_t   *clock_id
> -  rtems_set_errno_and_return_minus_one( ENOSYS );
> +  Thread_Control               *the_thread;
> +  ISR_lock_Context              lock_context;
> +  if ( clock_id == NULL ) {
> +    return EINVAL;
> +  the_thread = _Thread_Get( thread, &lock_context );
> +  if ( the_thread == NULL ) {
> +    return ESRCH;
> +  _Thread_State_acquire_critical( the_thread, &lock_context );
> +  *clock_id = the_thread->Object.id;
> +  _Thread_State_release( the_thread, &lock_context );
> +  return 0;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200405/6d546113/attachment.html>
