Review on user/rsb/configuration.rst
Cláudio Maia
clrrm at isep.ipp.pt
Sun Apr 5 17:07:41 UTC 2020
Hello everyone,
I have reviewed the file user/rsb/configuration.rst and I want to send a patch with my proposed changes. However, before doing that I would like to clarify some aspects before sending the patch, namely:
- In the section 13.5.7 it is mentioned the following "The Device Tree Compiler source code can be downloaded from http://www.jdl.com/software.". However this web site is offline and I'm not sure if it is supposed to be online or it the went down between the time the documentation was produced and now. Should we correct the link (if so, which should be the new one?) or leave it as it is for example purposes and put a note on the document stating that it is offline?
- In section 13.5.1.1, the "xy" compression format is mentioned, however a search on google revealed no such format. Is this a typo or does this format really exist?
- In section 13.5.2.1, the following text appears"See <<X1,``_configdir``>> variable for details.". What is "<<X1,``_configdir``>>" supposed to mean? Should it be a cross reference to some other place?
- In section 13.5.7.4., it is mentioned a "|DESTDIR|" and a "DISTDIR". I believe there is a typo on the second one, as it is not mentioned anywhere else on the text in the page. Can someone please confirm if my judgement is correct?
- In section 13.5.8.2, a different notation is used using + signs, as for instance "+%prep+" and "+%source+" which I also believe it is a typo and these should be using this notation``%prep``. Again, can please someone confirm this?
Regards,
Cláudio
