sis broken on freebsd 12
Gedare Bloom
gedare at rtems.org
Mon Apr 6 03:37:02 UTC 2020
On Sun, Apr 5, 2020 at 8:35 PM Chris Johns <chrisj at rtems.org> wrote:
> On 2020-04-06 10:38, Joel Sherrill wrote:
> > On Sun, Apr 5, 2020 at 7:25 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> > On 2020-04-06 10:20, Joel Sherrill wrote:
> > > Hi
> > > sis fails to build on FreeBSD 12. I. The full log is at
> > https://lists.rtems.org/pipermail/build/2020-April/012855.html and it
> > > fails for sparc and riscv.
> > > checking for gcc... gcc
> > > checking whether the C compiler works... no
> > > configure: error: in
> > `/usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/sis-2.21':
> > > configure: error: C compiler cannot create executables
> > > See `config.log' for more details
> > > shell cmd failed: /bin/sh -ex
> > /usr/home/joel/rtems-cron-5/rtems-source-builder/rtems/build/sis-2.21-x86_64-freebsd12.1-1/do-build
> > > error: building sis-2.21-x86_64-freebsd12.1-1
> > > See error report: rsb-report-sis-2.21-x86_64-freebsd12.1-1.txt
> > > I will try to investigate over the next few days. But I would
> > appreciate it Jiri could take a swing at it. It is really all I can
> > do to review the build logs from 100+ hours of test time across
> > three computers.
> > I am confused, it builds for me ...
> > ruru bare $ ../source-builder/sb-set-builder --no-install --log=sis.txt
> > devel/sis
> > RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
> > Build Set: devel/sis
> > config: devel/sis-2-1.cfg
> > package: sis-2.21-x86_64-freebsd12.1-1
> > download: https://git.rtems.org/sis/snapshot/sis-2.21.tar.bz2 ->
> > sources/sis-2.21.tar.bz2
> > downloading: sources/sis-2.21.tar.bz2 - 289.3kB
> > building: sis-2.21-x86_64-freebsd12.1-1
> > sizes: sis-2.21-x86_64-freebsd12.1-1: 2.144MB (installed: 226.492KB)
> > cleaning: sis-2.21-x86_64-freebsd12.1-1
> > reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.txt
> > reporting: devel/sis-2-1.cfg -> sis-2.21-x86_64-freebsd12.1-1.xml
> > Build Set: Time 0:00:04.409849
> > ruru bare $ uname -a
> > FreeBSD ruru 12.1-RELEASE-p2 FreeBSD 12.1-RELEASE-p2 GENERIC amd64
> > From config.log:
> > configure:3033: checking whether the C compiler works
> > configure:3055: gcc -O2 -pipe -fbracket-depth=1024
> > -I/usr/home/joel/rtems-cron-5
> > /rtems-source-builder/rtems/build/tmp/sb-1002/5/rtems-sparc/home/joel/rtems-cron
> > -5/tools/5/include conftest.c >&5
> > gcc: error: unrecognized command line option '-fbracket-depth=1024'
> > configure:3059: $? = 1 >
> > $ gcc --version
> > gcc (FreeBSD Ports Collection) 9.2.0
> > Copyright (C) 2019 Free Software Foundation, Inc.
> The OS compiler is llvm so something is picking up gcc. The OS compiler
> is preferred over a port. What is your path?
Override Environment variable defined for CC?
> Chris
> devel mailing list
> devel at rtems.org
