[PATCH rtems-source-builder] dtc: Update to 1.6.0.
Mon Apr 6 17:09:21 UTC 2020
I tested it and it failed.
         CC treesource.o
gmake: *** No rule to make target 'yaml.h', needed by 'yamltree.o'.  Stop.
+ cd
/usr/home/joel/rtems-work/rtems-source-builder/bare/build/dtc-1.6.0-x86_64-freebsd12.1-1
+ echo '==> %install:'
==> %install:
+ pwd
build_top=/usr/home/joel/rtems-work/rtems-source-builder/bare/build/dtc-1.6.0-x86_64-freebsd12.1-1
I am guessing it has picked up a dependency on yaml that is not accounted
for.
This is the place where spike references dtc.
$ git diff
diff --git a/bare/config/devel/spike.bset b/bare/config/devel/spike.bset
index 76392f7..bf52b9f 100644
--- a/bare/config/devel/spike.bset
+++ b/bare/config/devel/spike.bset
@@ -4,5 +4,5 @@
 %define release 1
-devel/dtc-1.4.1-1
+devel/dtc-1.6.0-1
 devel/spike-1.1.0
On Mon, Apr 6, 2020 at 11:29 AM Joel Sherrill <joel at rtems.org> wrote:
> Before I test it, what about the spike.bset? It still references dtc 1.4?
> On Mon, Apr 6, 2020 at 10:54 AM Christian Mauderer <oss at c-mauderer.de>
> wrote:
>>  bare/config/devel/dtc-1.6.0-1.cfg | 18 ++++++++++++++++++
>>  bare/config/devel/dtc.bset        |  2 +-
>>  2 files changed, 19 insertions(+), 1 deletion(-)
>>  create mode 100644 bare/config/devel/dtc-1.6.0-1.cfg
>> diff --git a/bare/config/devel/dtc-1.6.0-1.cfg
>> b/bare/config/devel/dtc-1.6.0-1.cfg
>> new file mode 100644
>> index 0000000..f293f12
>> --- /dev/null
>> +++ b/bare/config/devel/dtc-1.6.0-1.cfg
>> @@ -0,0 +1,18 @@
>> +# DTC (Device Tree Compiler) 1.6.0
>> +%if %{release} == %{nil}
>> +%define release 1
>> +%endif
>> +%include %{_configdir}/base.cfg
>> +%define dtc_version 1.6.0
>> +%hash sha256 dtc-%{dtc_version}.tar.gz
>> 9fbe07223a98f2d7088a340b5505d4dfe682d77580e788d08cfcc1b61d8be237
>> +# The DTC build instructions. We use 1.x.x Release 1.
>> +%include %{_configdir}/dtc-1-1.cfg
>> diff --git a/bare/config/devel/dtc.bset b/bare/config/devel/dtc.bset
>> index d701f93..6700823 100644
>> --- a/bare/config/devel/dtc.bset
>> +++ b/bare/config/devel/dtc.bset
>> @@ -4,4 +4,4 @@
>>  %define release 1
>> -devel/dtc-1.2.0
>> +devel/dtc-1.6.0-1
>> 2.25.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200406/2ea6d95c/attachment.html>
