[PATCH 1/2] score: Add and use RTEMS_SYMBOL_NAME()
Mon Apr 6 17:57:46 UTC 2020
Update #3799.
 cpukit/include/rtems/score/basedefs.h | 21 +++++++++++++++++----
 1 file changed, 17 insertions(+), 4 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 4589bea4aa..a2eb14a642 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -321,6 +321,19 @@
 #define RTEMS_DECLARE_GLOBAL_SYMBOL( _name ) \
   extern char _name[]
+ * @brief Constructs a symbol name.
+ * @param _name The user defined name of the symbol.  The name must be a valid
+ *   designator.  On the name a macro expansion is performed.
+#if defined(__USER_LABEL_PREFIX__)
+  #define RTEMS_SYMBOL_NAME( _name ) RTEMS_XCONCAT( __USER_LABEL_PREFIX__, _name )
+#else
+  #define _RTEMS_SYMBOL_NAME( _name ) _name
+  #define RTEMS_SYMBOL_NAME( _name ) _RTEMS_SYMBOL_NAME( _name )
+#endif
  * @brief Defines a global symbol with the specified name and value.
@@ -335,8 +348,8 @@
 #if defined(__GNUC__)
   #define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value ) \
     __asm__( \
-      "\t.globl " RTEMS_XSTRING( __USER_LABEL_PREFIX__ ) #_name \
-      "\n\t.set " RTEMS_XSTRING( __USER_LABEL_PREFIX__ ) #_name \
+      "\t.globl " RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) \
+      "\n\t.set " RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) \
       ", " RTEMS_STRING( _value ) "\n" \
 #else
@@ -355,8 +368,8 @@
     __asm__( \
       ".pushsection \"" _section "\"\n" \
       "\t.globl " \
-      RTEMS_XSTRING( RTEMS_XCONCAT( __USER_LABEL_PREFIX__, _name ) ) "\n" \
-      RTEMS_XSTRING( RTEMS_XCONCAT( __USER_LABEL_PREFIX__, _name ) ) ":\n" \
+      RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) "\n" \
+      RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) ":\n" \
       "\t.popsection\n" \
 #else
2.16.4
