RTEMS Release Snapshot: 5.0.0-m2004 (02 Apr 2020)
Alan Cudmore alan.cudmore at gmail.com
Tue Apr 7 01:44:47 UTC 2020
Chris,
I tested this release on the Raspberry Pi (Zero), Raspberry Pi 2,
Beaglebone Black with LibBSD, xilinx_zynq_a9_qemu, and partially on
the leon3. ( samples all work on Leon3 QEMU, but I'm still configuring
my application )
To help generate tools and BSPs for releases like this, I created a
series of Dockerfiles to generate a base system, Add tools, then build
BSPs. I was learning docker, and I thought generating release
candidate images might be a good exercise :)
Here are the Dockerfiles in case anyone is interested:
https://github.com/alanc98/rtems-release-docker
To use these, create the "rtems5-m2004-base" image first, then for the
ARM tools, the "rtems5-m2004-arm-tools" image. Finally, you can create
an image like "rtems5-m2004-arm-bbb" to build the RTEMS BSP and
rtems-libbsd for the Beaglebone Black.
The resulting Docker image will allow you to build RTEMS applications
that are shared through the "/host" directory in the container.
With these, I hope to be able to crank out a series of builds for the
targets I'm interested in for future releases.
I'm also working on integration of my RTEMS Kernel Image (RKI) with
rtems-libbsd. I have it working on the Beaglebone black and the
zynq_a9_qemu target. That is a work in progress here:
https://github.com/alanc98/rki2
All of the above targets work except for the leon3 right now. (
Raspberry Pi targets are not libbsd)
Alan
On Thu, Apr 2, 2020 at 6:13 AM <chrisj at rtems.org> wrote:
> RTEMS Release Build - 5.0.0-m2004
> RTEMS 5 Release snapshot m2004 is avaliable for testing.
> It can be found at:
>  https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m2004
> Please test and report any issues to the user at rtems.org or devel at rtems.org
> mailing lists or please raise a ticket.
> If you are part of the RTEMS testing program please build on your preferred
> host posting build and BSP test results to build at rtems.org.
> This is a development release and may have errors and be unstable.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
