[PATCH] RTEMS: Improve GCC specification
Sebastian Huber
Tue Apr 7 07:29:34 UTC 2020
Add a start/end file specification if the -qrtems option is present.
Allow targets to customize it.
Support the standard -nodefaultlibs option.
gcc/
* config/rs6000/rtems.h (RTEMS_STARTFILE_SPEC): Define.
(RTEMS_ENDFILE_SPEC): Likewise.
* config/rtems.h (RTEMS_STARTFILE_SPEC): Define if undefined.
(STARTFILE_SPEC): Update comment. Add RTEMS_STARTFILE_SPEC.
(ENDFILE_SPEC): Add RTEMS_ENDFILE_SPEC.
(LIB_SPECS): Support -nodefaultlibs option.
gcc/config/rs6000/rtems.h | 4 ++++
gcc/config/rtems.h | 26 ++++++++++++++++++--------
2 files changed, 22 insertions(+), 8 deletions(-)
diff --git a/gcc/config/rs6000/rtems.h b/gcc/config/rs6000/rtems.h
index 6ce05bfc6d6..c3dffd83e6f 100644
--- a/gcc/config/rs6000/rtems.h
+++ b/gcc/config/rs6000/rtems.h
@@ -292,3 +292,7 @@
"%{mads|myellowknife|mmvme|msim:%G %L %G;" \
"!mcall-*|mcall-linux:" GNU_USER_TARGET_LINK_GCC_C_SEQUENCE_SPEC ";" \
":%G %L %G}"
+#define RTEMS_STARTFILE_SPEC "ecrti%O%s rtems_crti%O%s crtbegin%O%s"
+#define RTEMS_ENDFILE_SPEC "crtend%O%s rtems_crtn%O%s ecrtn%O%s"
diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
index 55d568f83b5..30ad6258949 100644
--- a/gcc/config/rtems.h
+++ b/gcc/config/rtems.h
@@ -22,15 +22,25 @@
see the files COPYING3 and COPYING.RUNTIME respectively. If not, see
<http://www.gnu.org/licenses/>. */
+#ifndef RTEMS_STARTFILE_SPEC
+#define RTEMS_STARTFILE_SPEC "crti%O%s crtbegin%O%s"
+#endif
+#ifndef RTEMS_ENDFILE_SPEC
+#define RTEMS_ENDFILE_SPEC "crtend%O%s crtn%O%s"
+#endif
- * Dummy start/end specification to let linker work as
- * needed by autoconf scripts using this compiler.
+ * The crt0.o is a dummy start file to let the linker work as needed by
+ * autoconf scripts using this compiler.
#undef STARTFILE_SPEC
-#define STARTFILE_SPEC "crt0.o%s"
+#define STARTFILE_SPEC "%{!qrtems:crt0%O%s} " \
+"%{qrtems:%{!nostdlib:%{!nostartfiles:" RTEMS_STARTFILE_SPEC "}}}"
#undef ENDFILE_SPEC
-#define ENDFILE_SPEC ""
+#define ENDFILE_SPEC \
+"%{qrtems:%{!nostdlib:%{!nostartfiles:" RTEMS_ENDFILE_SPEC "}}}"
* Some targets do not set up LIB_SPECS, override it, here.
@@ -38,10 +48,10 @@
#define STD_LIB_SPEC "%{!shared:%{g*:-lg} %{!p:%{!pg:-lc}}%{p:-lc_p}%{pg:-lc_p}}"
#undef LIB_SPEC
-#define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
-"%{!nostdlib: %{qrtems: --start-group \
- -lrtemsbsp -lrtemscpu \
- -latomic -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
+#define LIB_SPEC "%{!qrtems:" STD_LIB_SPEC "} " \
+"%{qrtems:%{!nostdlib:%{!nodefaultlibs:" \
+"--start-group -lrtemsbsp -lrtemscpu -latomic -lc -lgcc --end-group} " \
+"%{!qnolinkcmds:-T linkcmds%s}}}"
#define TARGET_POSIX_IO
2.16.4
