[PATCH] Tests for pthread_getcpuclockid method
Eshan dhawan eshandhawan51 at gmail.com
Tue Apr 7 11:27:58 UTC 2020
 testsuites/psxtests/Makefile.am               | 10 ++
 testsuites/psxtests/configure.ac              |  1 +
 testsuites/psxtests/psxgetcpuclockid01/init.c | 96 +++++++++++++++++++
 .../psxgetcpuclockid01/psxgetcpuclockid01.doc | 19 ++++
 .../psxgetcpuclockid01/psxgetcpuclockid01.scn |  4 +
 5 files changed, 130 insertions(+)
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
 create mode 100644 testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..ffadff16e7 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetattrnp01) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxgetcpuclockid01
+psx_tests += psxgetcpuclockid01
+psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
+psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
+psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
+psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
+	$(support_includes)
+endif
 if TEST_psxgetrusage01
 psx_tests += psxgetrusage01
 psx_screens += psxgetrusage01/psxgetrusage01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..c509086abc 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
 RTEMS_TEST_CHECK([psxfile02])
 RTEMS_TEST_CHECK([psxfilelock01])
 RTEMS_TEST_CHECK([psxgetattrnp01])
+RTEMS_TEST_CHECK([psxgetcpuclockid01])
 RTEMS_TEST_CHECK([psxgetrusage01])
 RTEMS_TEST_CHECK([psxglobalcon01])
 RTEMS_TEST_CHECK([psxglobalcon02])
diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c b/testsuites/psxtests/psxgetcpuclockid01/init.c
new file mode 100644
index 0000000000..b2b26339d2
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
@@ -0,0 +1,96 @@
+ *  @file
+ *  @brief Test suite for getcpuclockid methods
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan
+ * are met:
+#define _GNU_SOURCE
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <pthread.h>
+#include <stdint.h>
+#include <rtems/test.h>
+#include <sys/utsname.h>
+#include <unistd.h>
+#include <errno.h>
+#include <sched.h>
+#include <rtems/score/todimpl.h>
+#include <rtems/score/threadimpl.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
+/* Forward declaration to avoid warnings */
+rtems_task Init(rtems_task_argument ignored);
+void *test_task(void);
+/* test_task function begins */
+void *test_task()
+  int r;
+  clockid_t cid;
+  r = pthread_getcpuclockid(pthread_self(), &cid);
+  if(r)
+    printf("pthread_getcpuclockid : 0x%d", r );
+  rtems_test_assert( r == 0 );
+  return NULL;
+/* init test function begins */
+  TEST_BEGIN();
+  test_task();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
index 0000000000..bfe9c7b9ff
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
@@ -0,0 +1,19 @@
+#  COPYRIGHT (c) 2020
+#  On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name:  psxgetcpuclockid 1
+Directives:
+  Pthread_getcpuclockid()
+Concepts:
++ This test exercises the getcpuclockid methods.
++ For pthread_getcpuclockid it gets the clockid_t for the current thread.
diff --git a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
index 0000000000..937a908fd5
--- /dev/null
+++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXGETCLOCKID 1 ***
+*** END OF TEST PSXGETCPUCLOCKID 1 ***
2.17.1
