[PATCH v5] Tests for inttype.h methods
Gedare Bloom
gedare at rtems.org
Tue Apr 7 19:23:17 UTC 2020
Applying: Tests for inttype.h methods
.git/rebase-apply/patch:14: trailing whitespace.
* Copyright (C) 2020, Eshan Dhawan
.git/rebase-apply/patch:29: trailing whitespace.
.git/rebase-apply/patch:30: trailing whitespace.
/* Test for imaxabs */
.git/rebase-apply/patch:34: trailing whitespace.
.git/rebase-apply/patch:44: trailing whitespace.
result_imaxdiv = imaxdiv( input_1, input_2 );
warning: squelched 13 whitespace errors
warning: 18 lines add whitespace errors.
Please fix these
On Tue, Apr 7, 2020 at 1:22 PM Gedare Bloom <gedare at rtems.org> wrote:
> It looks alright, I'm testing it now.
> On Tue, Apr 7, 2020 at 1:13 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> > I sent this patch a few days ago.
> > if anyone could look at it.
> > the code was tested by dr joel.
> > But had some style issues.
> > I have covered all the suggestions.
> > Do any more changes need to be made before it is merged?
> > Thanks
> > -Eshan
> > On Sat, Apr 4, 2020 at 12:46 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
> >> testsuites/psxtests/psxinttypes01/init.c | 28 +++++++++++++++++--
> >> .../psxtests/psxinttypes01/psxinttypes01.doc | 10 ++++++-
> >> 2 files changed, 34 insertions(+), 4 deletions(-)
> >> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
> >> index 030aa2aa57..28f7336fb8 100644
> >> --- a/testsuites/psxtests/psxinttypes01/init.c
> >> +++ b/testsuites/psxtests/psxinttypes01/init.c
> >> @@ -6,6 +6,7 @@
> >> * SPDX-License-Identifier: BSD-2-Clause
> >> + * Copyright (C) 2020, Eshan Dhawan
> >> * Copyright (C) 2019, Aditya Upadhyay and Vaibhav Gupta
> >> * Redistribution and use in source and binary forms, with or without
> >> @@ -64,11 +65,32 @@ rtems_task Init(rtems_task_argument ignored)
> >> wchar_t *nptr2_n_errange = L"-9999999999999999999999";
> >> wchar_t *endptr2 = NULL;
> >> - intmax_t result_strtoimax;
> >> + intmax_t result_strtoimax, result_imaxabs, input_1, input_2;
> >> + imaxdiv_t result_exp, result_imaxdiv;
> >> uintmax_t result_strtoumax;
> >> TEST_BEGIN();
> >> + /* Test for imaxabs */
> >> + input_1 = -10;
> >> + result_imaxabs = 10;
> >> + rtems_test_assert( imaxabs(input_1) == result_imaxabs );
> >> + input_1 = 10;
> >> + /* Test for imaxdiv */
> >> + input_1 = 10;
> >> + input_2 = 3;
> >> + result_exp.quot = input_1 / input_2;
> >> + result_exp.rem = input_1 % input_2;
> >> + result_imaxdiv = imaxdiv( input_1, input_2 );
> >> + result_imaxdiv.quot == result_exp.quot &&
> >> + result_imaxdiv.rem == result_exp.rem
> >> /* Test for strtoimax */
> >> puts( "\nstrtoimax Testcases...." );
> >> puts( "Valid Inputs - Positive Number" );
> >> @@ -83,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
> >> rtems_test_assert( result_strtoimax == -123 );
> >> puts( "Final string pointed by endptr" );
> >> - rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> >> + rtems_test_assert( endptr1 == ( nptr1_n + 4 ) );
> >> puts( "Valid Input - Positive Number - Number out of Range" );
> >> result_strtoimax = strtoimax( nptr1_p_errange, &endptr1, base );
> >> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> >> index 19f63af34b..59b76796e2 100644
> >> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> >> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> >> @@ -1,4 +1,4 @@
> >> -This File describes the concepts tested by this test suite.
> >> +This File describes the concepts tested by this test suite.
> >> inttypes.h - fixed size integer types
> >> @@ -37,3 +37,11 @@ test suite name: PSXINTTYPE 01
> >> - checks for output for string having a negative number - Number Out of Range
> >> - checks for final string pointed by endptr
> >> - checks for output for invalid argument - Invalid Base
> >> +- Checks for imaxabs Testcases
> >> + - checks for output with an input with any negative number
> >> + - checks for output with an input with any positive number
> >> +- Checks for imaxdiv Testcases
> >> + - checks for the output quotient and remainder with input with positive numbers
> >> 2.17.1
