[PATCH RSB] bare/glib-2.39.3-1: Add patches to suppress string literal warning
Vijay Kumar Banerjee
vijay at rtems.org
Tue Apr 7 22:28:38 UTC 2020
On Wed, Apr 8, 2020, 2:46 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 7, 2020 at 2:06 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> > On Wed, Apr 8, 2020 at 12:49 AM Gedare Bloom <gedare at rtems.org> wrote:
> >> On Tue, Apr 7, 2020 at 12:03 PM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> > On Tue, Apr 7, 2020 at 11:12 PM Joel Sherrill <joel at rtems.org> wrote:
> >> >> On Tue, Apr 7, 2020 at 12:35 PM Gedare Bloom <gedare at rtems.org>
> wrote:
> >> >>> I'm not sure what error this is fixing, is there a ticket open for
> the warning?
> >> >> No idea on this.
> >> >>> Is there a fix for the warning besides squelching it?
> >> >> I think these are the warnings that are build failures on some
> hosts. <I think>
> >> > I get these errors on Fedora30:
> >> > ../../glib-2.39.3/gio/gdbusauth.c: In function
> '_g_dbus_auth_run_server':
> >> > ../../glib-2.39.3/gio/gdbusauth.c:1297:11: error: '%s' directive
> argument is null [-Werror=format-overflow=]
> >> > 1297 | debug_print ("SERVER: WaitingForBegin, read '%s'",
> line);
> >> > The added patches fix this.
> >> I see, this is a build error with newer gcc toolchains?
> > Yes
> >> Is this only
> >> affecting qemu-couverture?
> > yes, it's only affecting qemu-couverture
> >> What version of gcc is your host using?
> > $>gcc --version
> > gcc (GCC) 9.2.1 20190827 (Red Hat 9.2.1-1)
> >> Can
> >> you try to find if there is a ticket open in glib or if this is fixed
> >> in newer version, so we can track for the upstream fix?
> > I found these patches from the bugzilla issue:
> > https://bugzilla.gnome.org/show_bug.cgi?id=761550
> OK go ahead and push this. It would be better if qemu was updated or
> could use the new-enough version, but I understand.
I will try to update the qemu couverture then. Last time I tried I was
having some trouble with capstone but I'll try it again and post in the
list if it doesn't work.
> >> If newer versions of glib fix it, consider bumping the version?
> > I'm getting these errors from glib-2.48.2 as well.
> >> Is
> >> qemu-couverture up-to-date?
> > No, and it fails to build. There are issues in qemu-couverture as well.
> >> >>> How permanent is that gitlab? Should we just pluck these patches
> ourselves?
> >> >> That's gnome.gitlab.org and per the link at
> https://www.gnome.org/gnome-3/source/,
> >> >> it appears to be the official GNOME git repository. I think I would
> trust it.
> >> >> --joel
> >> >>> On Tue, Apr 7, 2020, 7:59 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
> >> >>>> bare/config/devel/glib-2.39.3-1.cfg | 4 ++++
> >> >>>> 1 file changed, 4 insertions(+)
> >> >>>> diff --git a/bare/config/devel/glib-2.39.3-1.cfg
> b/bare/config/devel/glib-2.39.3-1.cfg
> >> >>>> index 9ff7af5..bd5770a 100644
> >> >>>> --- a/bare/config/devel/glib-2.39.3-1.cfg
> >> >>>> +++ b/bare/config/devel/glib-2.39.3-1.cfg
> >> >>>> @@ -14,6 +14,10 @@
> >> >>>> %hash sha256 glib-%{glib_version}.tar.xz
> d9fa6c9aa645a5e688a3bb29013bb83801b19ee767d99e33ff52e004e1cc5fc8
> >> >>>> +#Patch to supress string literal warning
> >> >>>> +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/0817af40e8c74c721c30f6ef482b1f53d12044c7.patch
> >> >>>> +%patch add glib
> https://gitlab.gnome.org/GNOME/glib/commit/566e1d61a500267c7849ad0b2552feec9c9a29a6.patch
> >> >>>> # The GLib build instructions. We use 2.x.x Release 1.
> >> >>>> 2.21.1
> >> >>>> _______________________________________________
> >> >>>> devel mailing list
> >> >>>> devel at rtems.org
> >> >>>> http://lists.rtems.org/mailman/listinfo/devel
> >> >>> devel mailing list
> >> >>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200408/75719eaa/attachment.html>
