GCC 10 build status
Wed Apr 8 17:45:58 UTC 2020
Hello,
in order to test a patch for the removal of the bsp_specs I built all
BSPs (POSIX and tests enabled) with GCC 10 using the new build system.
http://devel.rtems.org/ticket/3937
The situation with epiphany turned out to be quite bad:
http://devel.rtems.org/ticket/3941
There is an issue on i386:
http://devel.rtems.org/ticket/3943
There are some problems on powerpc:
https://lists.rtems.org/pipermail/devel/2020-April/059176.html
Otherwise it looks good. I was able to build with bsp_specs removed from
the sources.
