[PATCH 1/2] score: Add RTEMS_WEAK
Thu Apr 9 04:50:22 UTC 2020
 cpukit/include/rtems/score/basedefs.h  | 12 ++++++++
 testsuites/sptests/Makefile.am         |  2 +-
 testsuites/sptests/spmisc01/init.c     |  9 ++++++
 testsuites/sptests/spmisc01/spmisc01.h | 51 ++++++++++++++++++++++++++++++++++
 testsuites/sptests/spmisc01/strong.c   | 42 ++++++++++++++++++++++++++++
 5 files changed, 115 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/sptests/spmisc01/spmisc01.h
 create mode 100644 testsuites/sptests/spmisc01/strong.c
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 4589bea4aa..87f980ccda 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -197,6 +197,18 @@
   #define RTEMS_ALIAS( _target )
 #endif
+ * @brief Instructs the compiler to define a weak function.
+ * Use this attribute for function definitions.  Do not use it for function
+ * declarations.
+#if defined(__GNUC__)
+  #define RTEMS_WEAK __attribute__((__weak__))
+#else
+#endif
  * @brief Instructs the compiler to generate a weak alias to the specified
  * target function.
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 62bb1aa685..a8b9ac482a 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1464,7 +1464,7 @@ if TEST_spmisc01
 sp_tests += spmisc01
 sp_screens += spmisc01/spmisc01.scn
 sp_docs += spmisc01/spmisc01.doc
-spmisc01_SOURCES = spmisc01/init.c
+spmisc01_SOURCES = spmisc01/init.c spmisc01/strong.c
 spmisc01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spmisc01) \
 	$(support_includes)
 endif
diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
index 8d713c4219..d18402a13c 100644
--- a/testsuites/sptests/spmisc01/init.c
+++ b/testsuites/sptests/spmisc01/init.c
@@ -21,6 +21,8 @@
 #include <tmacros.h>
+#include "spmisc01.h"
 const char rtems_test_name[] = "SPMISC 1";
 RTEMS_INLINE_ROUTINE int inline_func(void)
@@ -70,6 +72,11 @@ static int alias_func(void) RTEMS_ALIAS(noinline_func);
 int weak_alias_func(void) RTEMS_WEAK_ALIAS(noinline_func);
+RTEMS_WEAK int weak_or_strong(void)
+  return 99;
 static char aligned_variable RTEMS_ALIGNED(64);
 typedef struct {
@@ -209,6 +216,8 @@ static void Init(rtems_task_argument arg)
   rtems_test_assert(sizeof(packed_struct) == 5);
   rtems_test_assert(alias_func() == 14);
   rtems_test_assert(weak_alias_func() == 14);
+  pull_in_strong();
+  rtems_test_assert(weak_or_strong() == 77);
   rtems_test_assert(((uintptr_t) &aligned_variable) % 64 == 0);
   rtems_test_assert(offsetof(aligned_member_struct, aligned_member) % 64 == 0);
   unreachable();
diff --git a/testsuites/sptests/spmisc01/spmisc01.h b/testsuites/sptests/spmisc01/spmisc01.h
new file mode 100644
index 0000000000..0bd0fbbfca
--- /dev/null
+++ b/testsuites/sptests/spmisc01/spmisc01.h
@@ -0,0 +1,51 @@
+ * @file
+ * @ingroup %
+ * @brief %
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifndef _SPMISC01_H
+#define _SPMISC01_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+int weak_or_strong(void);
+void pull_in_strong(void);
+#ifdef __cplusplus
+#endif
+#endif /* _SPMISC01_H */
diff --git a/testsuites/sptests/spmisc01/strong.c b/testsuites/sptests/spmisc01/strong.c
index 0000000000..4a2d3b6f11
--- /dev/null
+++ b/testsuites/sptests/spmisc01/strong.c
@@ -0,0 +1,42 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+  return 77;
+  /* Do nothing */
2.16.4
