Test for clock_nanosleep with CLOCK_MONOTONIC (# 3890)
Sebastian Huber
Thu Apr 9 12:39:34 UTC 2020
Hello Utkarsh Rai,
On 09/04/2020 14:28, Utkarsh Rai wrote:
> I am willing to add tests for clock_nanosleep with CLOCK_MONOTONIC.
> What is the standard way of adding test for an already present API but
> with different configuration? For eg. should I add
> 'psxtmclocknanosleep04/ 05/ 06' in the testsuite?
the psxtm* tests are timing/performance tests. Functionality should be
tested in testsuites/psxtests. I would add new test cases to an existing
test program, e.g. in separate functions which are called by the main
thread.
An alternative would be to add the tests using the new RTEMS Test framework:
https://docs.rtems.org/branches/master/eng/test-framework.html#the-rtems-test-framework
The new test framework has also some support for performance tests which
give more useful results on modern hardware:
https://docs.rtems.org/branches/master/eng/test-framework.html#code-runtime-measurements
