Test for clock_nanosleep with CLOCK_MONOTONIC (# 3890)
Sebastian Huber
Thu Apr 9 13:13:45 UTC 2020
On 09/04/2020 15:04, Joel Sherrill wrote:
> On Thu, Apr 9, 2020, 7:43 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 09/04/2020 14:40, Joel Sherrill wrote:
>> On Thu, Apr 9, 2020, 7:28 AM Utkarsh Rai <utkarsh.rai60 at gmail.com
>> <mailto:utkarsh.rai60 at gmail.com>> wrote:
>> Hi,
>> I am willing to add tests for clock_nanosleep with
>> CLOCK_MONOTONIC. What is the standard way of adding test for
>> an already present API but with different configuration? For
>> eg. should I add 'psxtmclocknanosleep04/ 05/ 06' in the
>> testsuite?
>> Yes. That is the pattern.
> We should try to reduce the count of test programs since on boards
> with a long reboot time, more tests programs means much more test
> time (compared to the new test cases alone).
> And there is the competing factor that you end up with test
> executables that are overly complex, do not have clean environments
> for many of the test cases, and are too large to fit on many target
> boards.
The RTEMS Test framework has checks to ensure that the environment is
sane before a new test case is executed. It decouples the test cases
from the runner. This could be used to group test cases to test suites
depending on the target memory size.
> I know you have seen how long the list is of tests that you can't run
> on many boards. That's a bad quality attribute
I don't think that tests for clock_nanosleep() will result in big
executables. The executable size is mostly defined by the feature to be
tested.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200409/14bc5f6d/attachment-0001.html>
