[PATCH 0/5] Proposes fixes for RTEMS Tester documentation page
clrrm at isep.ipp.pt
Thu Apr 9 14:34:08 UTC 2020
This set of patches proposes several fixes for RTEMS Tester
documentation. Namely:
- Text was reviewed and improved for clarity;
- References to 'sparc-rtems5-run' command and 'erc32-run' were removed
from the documentation page. Now, the example uses 'erc32-sis' instead.
Further references to 'sparc-rtems5-run' are still in other parts of the
documentation (Sections 10.2 and 10.3) which also need to be updated in
the future.
Cláudio Maia (5):
user/tools/tester.rst: Cleans up text
user/tools/tester.rst: Removes wrong reference to GDB
user/tools/tester.rst: Clarifies the need of --rtems-tools in
rtems-test command line
user/tools/tester.rst: Removes example using 'sparc-rtems5-run'
user/tools/tester.rst: Removes text references to 'erc32-run' and
replaces the example with 'erc32-sis'
user/tools/tester.rst | 199 ++++++++++++++++++++----------------------
1 file changed, 97 insertions(+), 102 deletions(-)
2.17.1
