[PATCH RSB 3/4] source-builder: Add capstone
Vijay Kumar Banerjee
vijay at rtems.org
Thu Apr 9 20:21:54 UTC 2020
bare/config/devel/capstone-4.0.1-1.cfg | 27 +++++++++++
bare/config/devel/capstone.bset | 7 +++
source-builder/config/capstone-1-1.cfg | 62 ++++++++++++++++++++++++++
3 files changed, 96 insertions(+)
create mode 100644 bare/config/devel/capstone-4.0.1-1.cfg
create mode 100644 bare/config/devel/capstone.bset
create mode 100644 source-builder/config/capstone-1-1.cfg
diff --git a/bare/config/devel/capstone-4.0.1-1.cfg b/bare/config/devel/capstone-4.0.1-1.cfg
new file mode 100644
index 0000000..9f3627c
--- /dev/null
+++ b/bare/config/devel/capstone-4.0.1-1.cfg
@@ -0,0 +1,27 @@
+# Capstone from Git
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/base.cfg
+%include %{_configdir}/bare-config.cfg
+# Capstone Version.
+%define capstone_version 4.0.1
+# Set source from github.
+%source set capstone --rsb-file=capstone-%{capstone_version}.tar.gz https://github.com/aquynh/capstone/archive/%{capstone_version}.tar.gz
+%hash sha512 capstone-%{capstone_version}.tar.gz 43c52024065b41b45eff9423341db3f3d5163fa7aa01b360faa30437786740c8f2c34c36faa04dced5308e09d8bd78df3bad0ab9c06f98612169edb176f83c36
+# The build instructions.
+%include %{_configdir}/capstone-1-1.cfg
diff --git a/bare/config/devel/capstone.bset b/bare/config/devel/capstone.bset
index 0000000..d56406d
--- /dev/null
+++ b/bare/config/devel/capstone.bset
@@ -0,0 +1,7 @@
+# Build set for Capstone Disassembler
+%define release 1
+devel/capstone-4.0.1-1
diff --git a/source-builder/config/capstone-1-1.cfg b/source-builder/config/capstone-1-1.cfg
index 0000000..703fd54
--- /dev/null
+++ b/source-builder/config/capstone-1-1.cfg
@@ -0,0 +1,62 @@
+# This configuration file configure's, make's and install's CAPSTONE.
+%define release 1
+%endif
+# Select Snapshot Macro Maps
+%select capstone-snapshot
+# The description.
+Name: capstone-%{capstone_version}-%{_host}-%{release}
+Summary: Capstone is light-weight multiplatform disassembler.
+Version: %{capstone_version}
+Release: %{release}
+URL: http://www.capstone-engine.org/
+# Source
+%source set capstone https://github.com/aquynh/capstone/archive/capstone-%{capstone_version}.tar.gz
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_capstone="capstone-%{capstone_version}"
+ %source setup capstone -q -n capstone-%{capstone_version}
+ %patch setup capstone -p1
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ %{build_directory}
+ cd ${source_dir_capstone}
+ %{__make} PREFIX=%{_prefix}
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ %{__rmdir} ${SB_BUILD_ROOT}
+ %{__make} DESTDIR=$SB_BUILD_ROOT PREFIX=%{_prefix} install
+ cd ${build_top}
2.21.1
