[PATCH 3/9] [waf] Move bsp_specs flag to GCC only file
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Fri Apr 10 10:39:30 UTC 2020
spec/build/bsps/RTEMS-BUILD-BSP-OPTLDFLAGS.yml | 2 --
spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTGCC.yml | 6 ++++++
2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/spec/build/bsps/RTEMS-BUILD-BSP-OPTLDFLAGS.yml b/spec/build/bsps/RTEMS-BUILD-BSP-OPTLDFLAGS.yml
index 75d4f6637f..85b53c2eec 100644
--- a/spec/build/bsps/RTEMS-BUILD-BSP-OPTLDFLAGS.yml
+++ b/spec/build/bsps/RTEMS-BUILD-BSP-OPTLDFLAGS.yml
@@ -1,8 +1,6 @@
actions:
- set-value:
- -qrtems
- - -specs
- - bsp_specs
- -B${TOP}/bsps/${ARCH}/shared/start
- -B${TOP}/bsps/${ARCH}/${BSP_FAMILY}/start
- substitute: null
diff --git a/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTGCC.yml b/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTGCC.yml
index 246e8df180..e77cafa5e4 100644
--- a/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTGCC.yml
+++ b/spec/build/cpukit/RTEMS-BUILD-CPUKIT-OPTGCC.yml
@@ -18,6 +18,12 @@ actions:
- substitute: null
- find-program: null
- env-assign: LD
+- set-value:
+ - -specs
+ - bsp_specs
+ - -B${TOP}/bsps/${ARCH}/shared/start
+ - -B${TOP}/bsps/${ARCH}/${BSP_FAMILY}/start
+- env-append: LDFLAGS
- script: |
load = "ar g++ gas gcc"
if not is_windows_host:
2.17.1
