[PATCH v3] bsp/beagle: Update console to new Termios API.
Christian Mauderer oss at c-mauderer.de
Sat Apr 11 07:47:12 UTC 2020
On 10/04/2020 20:53, Niteesh G. S. wrote:
> On Fri, Apr 10, 2020 at 9:18 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     Hello Niteesh,
>     sorry for the late review. It somehow slipped my attention.
>     Although I'm generally OK with it, my suggestion would be to move it
>     after the release. It's a not strictly necessary change and therefore I
>     don't want to potentially break stuff with it now.
> Okay then, I will make the changes and will send the patches after the
> release.
You can send it anytime before the release too so that we can merge it
right after it.
>     I added some comments below:
>     On 23/03/2020 11:28, G S Niteesh Babu wrote:
>     > This patch updates the console driver to new Termios API.
>     > Update #3034
>     >  bsps/arm/beagle/console/console-config.c | 117
>     >  c/src/lib/libbsp/arm/beagle/Makefile.am  |   4 +-
>     >  2 files changed, 69 insertions(+), 52 deletions(-)
>     > diff --git a/bsps/arm/beagle/console/console-config.c
>     b/bsps/arm/beagle/console/console-config.c
>     > index 78af5f6a93..b2246571f8 100644
>     > --- a/bsps/arm/beagle/console/console-config.c
>     > +++ b/bsps/arm/beagle/console/console-config.c
>     > @@ -21,12 +21,15 @@
>     >   * Modified by Ben Gras <beng at shrike-systems.com
>     <mailto:beng at shrike-systems.com>> to make
>     >   * interrupt-driven uart i/o work for beagleboards; beaglebone
>     support added.
>     > + * Modified by Niteesh Babu G S <niteesh.gs at gmail.com
>     <mailto:niteesh.gs at gmail.com>>
>     > + * Update console to new termios API.
>>     > -#include <libchip/serial.h>
>     >  #include <libchip/ns16550.h>
>>     >  #include <rtems/bspIo.h>
>     > +#include <rtems/console.h>
>>     >  #include <bsp.h>
>     >  #include <bsp/irq.h>
>     > @@ -41,6 +44,8 @@
>     >  #define TX_FIFO_E (1<<5)
>     >  #define RX_FIFO_E (1<<0)
>>     > +#define BEAGLE_UART0 "/dev/ttyS0"
>     >  static uint8_t beagle_uart_get_register(uintptr_t addr, uint8_t i)
>     >    uint8_t v;
>     > @@ -65,77 +70,91 @@ static void beagle_uart_set_register(uintptr_t
>     addr, uint8_t i, uint8_t val)
>     >    reg [i] = val;
>>     > -console_tbl Console_Configuration_Ports [] = {
>     > -      .sDeviceName = "/dev/ttyS0",
>     > -      .deviceType = SERIAL_NS16550,
>     > -#if CONSOLE_POLLED   /* option to facilitate running the tests */
>     > -      .pDeviceFns = &ns16550_fns_polled,
>     > -#else
>     > -      .pDeviceFns = &ns16550_fns,
>     > -#endif
>     > -      .ulMargin = 16,
>     > -      .ulHysteresis = 8,
>     > -      .pDeviceParams = (void *) CONSOLE_BAUD,
>     > -      .ulCtrlPort1 = BSP_CONSOLE_UART_BASE,
>     > -      .ulDataPort = BSP_CONSOLE_UART_BASE,
>     > -      .ulIntVector = BSP_CONSOLE_UART_IRQ,
>     > -      .getRegister = beagle_uart_get_register,
>     > -      .setRegister = beagle_uart_set_register,
>     > -      .ulClock = UART_CLOCK,  /* 48MHz base clock */
>     > -unsigned long Console_Configuration_Count = 1;
>     > -static int init_needed = 1; // don't rely on bss being 0
>     > +static ns16550_context uart_context;
>     > +static void uart_write_polled( char c );
>>     >  static void beagle_console_init(void)
>     > -  if(init_needed) {
>     > -    const uint32_t div = UART_CLOCK / 16 / CONSOLE_BAUD;
>     > -    CONSOLE_SYSC = 2;
>     > -    while ((CONSOLE_SYSS & 1) == 0)
>     > -    if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) ==
>     CONSOLE_LSR_THRE) {
>     > -      CONSOLE_LCR = 0x83;
>     > -      CONSOLE_DLL = div;
>     > -      CONSOLE_DLM = (div >> 8) & 0xff;
>     > -      CONSOLE_LCR = 0x03;
>     > -      CONSOLE_ACR = 0x00;
>     > +  ns16550_context *ctx;
>     > +  static bool initialized = false;
>>     > -    while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
>     > +  if ( initialized ) {
>     You never set initialized to true. So this will never happen.
>     > +    return ;
>>     > -    CONSOLE_LCR = 0x80 | 0x03;
>     > -    CONSOLE_DLL = 0x00;
>     > -    CONSOLE_DLM = 0x00;
>     > -    CONSOLE_MCR = 0x03;
>     > -    CONSOLE_FCR = 0x07;
>     > +   * Don't rely on BSS being zeroed
>     > +  memset(&uart_context, 0, sizeof(uart_context));
>     > +  ctx = &uart_context;
>     > +  ctx->port = BSP_CONSOLE_UART_BASE;
>     > +  ctx->irq = BSP_CONSOLE_UART_IRQ;
>     > +  ctx->set_reg = beagle_uart_set_register;
>     > +  ctx->get_reg = beagle_uart_get_register;
>     > +  ctx->initial_baud = CONSOLE_BAUD;
>     > +  ctx->clock = UART_CLOCK;
>     > +  const uint32_t div = UART_CLOCK / 16 / CONSOLE_BAUD;
>     I would prefer declarations at the top of the function.
>     > +  CONSOLE_SYSC = 2;
>     > +  while ((CONSOLE_SYSS & 1) == 0)
>     > +  if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) ==
>     CONSOLE_LSR_THRE) {
>     >      CONSOLE_LCR = 0x83;
>     >      CONSOLE_DLL = div;
>     >      CONSOLE_LCR = 0x03;
>     >      CONSOLE_ACR = 0x00;
>     > -    init_needed = 0;
>     > +  while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
>     > +  CONSOLE_LCR = 0x80 | 0x03;
>     > +  CONSOLE_DLL = 0x00;
>     > +  CONSOLE_DLM = 0x00;
>     > +  CONSOLE_LCR = 0x03;
>     > +  CONSOLE_MCR = 0x03;
>     > +  CONSOLE_FCR = 0x07;
>     > +  CONSOLE_LCR = 0x83;
>     > +  CONSOLE_DLL = div;
>     > +  CONSOLE_DLM = (div >> 8) & 0xff;
>     > +  CONSOLE_ACR = 0x00;
>     > +  BSP_output_char = uart_write_polled;
>>     >  #define CONSOLE_THR8 (*(volatile uint8_t *)
>     (BSP_CONSOLE_UART_BASE + 0x00))
>     > -  if(init_needed) beagle_console_init();
>     >    while( ( CONSOLE_LSR & TX_FIFO_E ) == 0 )
>     >    CONSOLE_THR8 = c;
>>     > +rtems_status_code console_initialize(
>     > +  rtems_device_major_number major,
>     > +  rtems_device_minor_number minor,
>     > +  void *arg
>     > +  rtems_termios_initialize();
>     > +  beagle_console_init();
>     > +  rtems_termios_device_install(
>     > +    BEAGLE_UART0,
>     > +    &ns16550_handler_polled,
>     > +    NULL,
>     > +    &uart_context.base
>     > +  return RTEMS_SUCCESSFUL;
>     >  static void _BSP_put_char( char c ) {
>     Maybe in this case it would be more correct to call it something like
>     "early_uart_write_polled" or "init_uart_and_write_polled" or
>     "uart_write_polled_first". This makes it a bit more clear what the
>     function does and that it is only called once.
>     > -   uart_write_polled( c );
>     > +  uart_write_polled( c );
>>     >  static int _BSP_get_char(void)
>     > diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
>     b/c/src/lib/libbsp/arm/beagle/Makefile.am
>     > index e37472373c..1cd9920b2f 100644
>     > --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
>     > +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
>     > @@ -62,9 +62,7 @@ librtemsbsp_a_SOURCES +=
>     ../../../../../../bsps/shared/irq/irq-default-handler.c
>     >  librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/irq/irq.c
>>     >  # Console
>     > -librtemsbsp_a_SOURCES +=
>     ../../../../../../bsps/shared/dev/serial/legacy-console.c
>     ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>     ../../../../../../bsps/shared/dev/serial/legacy-console-select.c
>     > +librtemsbsp_a_SOURCES +=
>     ../../../../../../bsps/shared/dev/serial/console-termios.c
>     ../../../../../../bsps/arm/beagle/console/console-config.c
>>     >  # I2C
