[PATCH 9/9] [waf] Add an option to build C++ sample applications
Sebastian Huber
Sat Apr 11 13:46:04 UTC 2020
On 10/04/2020 23:18, Hesham Almatary wrote:
> Also similar to the legacy autotools (--disable-cxx), users might want
> to disable building CXX apps from config.ini or the spec.
Ok, what about an ENABLE_CXX option which is enabled by clang? I think
all GCC architectures have C++ support. If a particular C++ test runs on
a BSP should be handled by the test states.
