[PATCH] build: output COMPILER for each variant in bsp_defaults
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Sat Apr 11 15:52:46 UTC 2020
Build multiple BSPs would fail without this patch as COMPILER
is only being emitted once at the end of config.ini (last BSP).
 wscript | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/wscript b/wscript
index c763e214f..d4ca98afb 100755
--- a/wscript
+++ b/wscript
@@ -1406,11 +1406,10 @@ def bsp_defaults(ctx):
                 for group in top_level_groups:
                     group.defaults(enable, variant)
                 bsps[arch][bsp].defaults(enable, variant)
+                print("COMPILER = " + compiler)
     if first:
         no_matches_error(ctx, white_list)
-    print("COMPILER = " + compiler)
 def bsp_list(ctx):
     """lists base BSP variants"""
     check_forbidden_options(ctx, ["compiler", "config", "tools"])
2.25.0
