[PATCH v2] Tests for pthread_getcpuclockid method. Ticket:3891
Eshan Dhawan eshandhawan51 at gmail.com
Mon Apr 13 20:01:44 UTC 2020
On Mon, Apr 13, 2020 at 10:26 PM Joel Sherrill <joel at rtems.org> wrote:
> I am pretty sure I can report that it won't execute on just visually
> reviewing it.
> First, it assumes at least a semi-functional pthread_getcpuclockid() and
> there is not one in the tree.
> You should be testing things yourself. There are multiple simulators which
> have BSPs and are easy to run. We can discuss which one in another thread.
> Other comments interspersed.
> On Thu, Apr 9, 2020 at 3:30 PM Eshan dhawan <eshandhawan51 at gmail.com>
> wrote:
>>  testsuites/psxtests/Makefile.am               |  10 ++
>>  testsuites/psxtests/configure.ac              |   1 +
>>  testsuites/psxtests/psxgetcpuclockid01/init.c | 120 ++++++++++++++++++
>>  .../psxgetcpuclockid01/psxgetcpuclockid01.doc |  19 +++
>>  .../psxgetcpuclockid01/psxgetcpuclockid01.scn |   4 +
>>  5 files changed, 154 insertions(+)
>>  create mode 100644 testsuites/psxtests/psxgetcpuclockid01/init.c
>>  create mode 100644
>> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
>>  create mode 100644
>> testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
>> diff --git a/testsuites/psxtests/Makefile.am
>> b/testsuites/psxtests/Makefile.am
>> index 1f9e4233ec..ffadff16e7 100755
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -462,6 +462,16 @@ psxgetattrnp01_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_psxgetattrnp01) \
>>         $(support_includes) -I$(top_srcdir)/include
>>  endif
>> +if TEST_psxgetcpuclockid01
>> +psx_tests += psxgetcpuclockid01
>> +psx_screens += psxgetcpuclockid01/psxgetcpuclockid01.scn
>> +psx_docs += psxgetcpuclockid01/psxgetcpuclockid01.doc
>> +psxgetcpuclockid01_SOURCES = psxgetcpuclockid01/init.c
>> +psxgetcpuclockid01_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_psxgetcpuclockid01) \
>> +       $(support_includes)
>> +endif
>>  if TEST_psxgetrusage01
>>  psx_tests += psxgetrusage01
>>  psx_screens += psxgetrusage01/psxgetrusage01.scn
>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>> configure.ac
>> index 139787cccb..c509086abc 100644
>> --- a/testsuites/psxtests/configure.ac
>> +++ b/testsuites/psxtests/configure.ac
>> @@ -91,6 +91,7 @@ RTEMS_TEST_CHECK([psxfile01])
>>  RTEMS_TEST_CHECK([psxfile02])
>>  RTEMS_TEST_CHECK([psxfilelock01])
>>  RTEMS_TEST_CHECK([psxgetattrnp01])
>> +RTEMS_TEST_CHECK([psxgetcpuclockid01])
>>  RTEMS_TEST_CHECK([psxgetrusage01])
>>  RTEMS_TEST_CHECK([psxglobalcon01])
>>  RTEMS_TEST_CHECK([psxglobalcon02])
>> diff --git a/testsuites/psxtests/psxgetcpuclockid01/init.c
>> b/testsuites/psxtests/psxgetcpuclockid01/init.c
>> new file mode 100644
>> index 0000000000..8e1093e44b
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxgetcpuclockid01/init.c
>> @@ -0,0 +1,120 @@
>> + *  @file
>> + *  @brief Test suite for getcpuclockid methods
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2020 Eshan Dhawan
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
>> BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +#include <errno.h>
>> +#include <pthread.h>
>> +#include <stdint.h>
>> +#include <rtems/test.h>
>> +#include <sys/utsname.h>
>> +#include <unistd.h>
>> +#include <errno.h>
>> +#include <sched.h>
>> I am sure at least some of these are not needed. I suspect almost
> everything below rtems/test.h is not needed.
> errno.h is twice.
>> +#include <rtems/score/todimpl.h>
>> +#include <rtems/score/threadimpl.h>
> Why are these needed?
>> +#include "tmacros.h"
>> +const char rtems_test_name[] = "PSXGETCPUCLOCKID 1";
>> +/* Forward declaration to avoid warnings */
>> +rtems_task Init(rtems_task_argument ignored);
>> +void *test_pthread(void *);
>> +/* test_task function begins */
>> +void *test_pthread(void *arg)
>> +  int r;
>> +  clockid_t cid;
>> +  r = pthread_getcpuclockid( pthread_self(), &cid );
>> +  if(r)
>> +    printf( "pthread_getcpuclockid : 0x%d", r );
>> +  rtems_test_assert( r == 0 );
>> +  pthread_exit(0);
>> +  return NULL;
>> +/* init test function begins */
> For POSIX tests, use a POSIX Initialization thread unless specifically
> verifying that a Classic API task has particular behavior when using POSIX
> methods.
>> +  TEST_BEGIN();
>> +  int r;
>> +  clockid_t cid;
>> +  pthread_t thread_id;
>> +  r= pthread_create( &thread_id, NULL, test_pthread, NULL );
>> +  if( r )
>> +    printf( "pthread_create : 0x%d", r );
> First, "0x%d" will print a 0x saying it is hex and then print a decimal
> number.
> Next, I think there are macro constants if you need to print RTEMS types.
> I can't find anything except pritime.h and primode.h. Perhaps someone else
> can step in here for help.
> Some style issues:
> + if( should be "if ("
> + Braces should follow the denser K&R style:
>    if (condition) {
>    } else {
>> + r = pthread_join( thread_id, NULL );
>> +  if( r )
>> +    printf( "pthread_join : 0x%d", r );
> You did not set any pthread attributes so you can't be certain that the
> thread you created is joinable.
>> +  r = pthread_getcpuclockid( thread_id, &cid );
>> +  if( r != ESRCH )
>> +  rtems_test_assert( r == ESRCH );
> I would start with a simple functional test on a single pthread that gets
> cpu clock id (should succeed).
> Then get its cpu clock and save that time.
> Use some get time API in a loop and spin (no blocking) for say 1/2 second
> of wall time passage.
> Then see if the CPU time used went up 1/2 second as expected.
> Be aware that the increase in CPU time used will not be exactly 1/2
> second. It will be at least 1/2 second but there is a reasonable upper
> bounds above that.
Can you please elaborate this part?
also, how will I check the CPU time and wall time?
>> +  TEST_END();
>> +  rtems_test_exit(0);
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
>> +#define CONFIGURE_MAXIMUM_POSIX_THREADS     2
>> +#define CONFIGURE_MAXIMUM_TASKS 1
> I see a need for 1 pthread in the code as written. Should stay 2 pthreads
> because you need to switch to pthread initialization thread.
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> Switch here to pthread initialization threads. And change Init task to
> POSIX_Init thread.
>> +#include <rtems/confdefs.h>
>> diff --git
>> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
>> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
>> index 0000000000..145f009337
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.doc
>> @@ -0,0 +1,19 @@
>> +#  COPYRIGHT (c) 2020
>> +#  On-Line Applications Research Corporation (OAR).
>> +# SPDX-License-Identifier: BSD-2-Clause
>> +This file describes the directives and concepts tested by this test set.
>> +test set name:  psxgetcpuclockid 1
>> +Directives:
>> +  Pthread_getcpuclockid()
>> +Concepts:
>> ++ This test exercises the getcpuclockid methods.
>> ++ For pthread_getcpuclockid it created a pthread using pthread_create
>> and then finds
>> +the clockid_t of that thread and then ends the thread.
>> +After the thread is ended it again tried to find the clockid_t of the
>> thread to check
>> +for ESRCH exception.
>> diff --git
>> a/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
>> b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
>> index 0000000000..937a908fd5
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxgetcpuclockid01/psxgetcpuclockid01.scn
>> @@ -0,0 +1,4 @@
>> +*** BEGIN OF TEST PSXGETCLOCKID 1 ***
>> +*** END OF TEST PSXGETCPUCLOCKID 1 ***
>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200414/e8780bc8/attachment.html>
