[PATCH RSB 3/4] source-builder: Add capstone
Vijay Kumar Banerjee vijay at rtems.org
Tue Apr 14 06:11:33 UTC 2020
On Tue, Apr 14, 2020, 10:00 AM Chris Johns <chrisj at rtems.org> wrote:
> What is the use case for this package?
qemu-couverture uses capstone.
> Chris
> On 10/4/20 6:21 am, Vijay Kumar Banerjee wrote:
> >   bare/config/devel/capstone-4.0.1-1.cfg | 27 +++++++++++
> >   bare/config/devel/capstone.bset        |  7 +++
> >   source-builder/config/capstone-1-1.cfg | 62 ++++++++++++++++++++++++++
> >   3 files changed, 96 insertions(+)
> >   create mode 100644 bare/config/devel/capstone-4.0.1-1.cfg
> >   create mode 100644 bare/config/devel/capstone.bset
> >   create mode 100644 source-builder/config/capstone-1-1.cfg
> > diff --git a/bare/config/devel/capstone-4.0.1-1.cfg
> b/bare/config/devel/capstone-4.0.1-1.cfg
> > new file mode 100644
> > index 0000000..9f3627c
> > --- /dev/null
> > +++ b/bare/config/devel/capstone-4.0.1-1.cfg
> > @@ -0,0 +1,27 @@
> > +# Capstone from Git
> > +%if %{release} == %{nil}
> > + %define release 1
> > +%endif
> > +%include %{_configdir}/base.cfg
> > +%include %{_configdir}/bare-config.cfg
> > +# Capstone Version.
> > +%define capstone_version 4.0.1
> > +# Set source from github.
> > +%source set capstone --rsb-file=capstone-%{capstone_version}.tar.gz
> https://github.com/aquynh/capstone/archive/%{capstone_version}.tar.gz
> > +%hash sha512 capstone-%{capstone_version}.tar.gz
> 43c52024065b41b45eff9423341db3f3d5163fa7aa01b360faa30437786740c8f2c34c36faa04dced5308e09d8bd78df3bad0ab9c06f98612169edb176f83c36
> > +# The build instructions.
> > +%include %{_configdir}/capstone-1-1.cfg
> > diff --git a/bare/config/devel/capstone.bset
> b/bare/config/devel/capstone.bset
> > index 0000000..d56406d
> > --- /dev/null
> > +++ b/bare/config/devel/capstone.bset
> > @@ -0,0 +1,7 @@
> > +# Build set for Capstone Disassembler
> > +%define release 1
> > +devel/capstone-4.0.1-1
> > diff --git a/source-builder/config/capstone-1-1.cfg
> b/source-builder/config/capstone-1-1.cfg
> > index 0000000..703fd54
> > --- /dev/null
> > +++ b/source-builder/config/capstone-1-1.cfg
> > @@ -0,0 +1,62 @@
> > +# This configuration file configure's, make's and install's CAPSTONE.
> > +%define release 1
> > +%endif
> > +# Select Snapshot Macro Maps
> > +%select capstone-snapshot
> > +# The description.
> > +Name:      capstone-%{capstone_version}-%{_host}-%{release}
> > +Summary:   Capstone is light-weight multiplatform disassembler.
> > +Version:   %{capstone_version}
> > +Release:   %{release}
> > +URL:            http://www.capstone-engine.org/
> > +# Source
> https://github.com/aquynh/capstone/archive/capstone-%{capstone_version}.tar.gz
> > +# Prepare the source code.
> > +%prep
> > +  build_top=$(pwd)
> > +  source_dir_capstone="capstone-%{capstone_version}"
> > +  %source setup capstone -q -n capstone-%{capstone_version}
> > +  %patch setup capstone -p1
> > +  cd ${build_top}
> > +%build
> > +  build_top=$(pwd)
> > +  %{build_directory}
> > +  cd ${source_dir_capstone}
> > +  %{__make} PREFIX=%{_prefix}
> > +  cd ${build_top}
> > +%install
> > +  build_top=$(pwd)
> > +  %{__rmdir} ${SB_BUILD_ROOT}
> > +  %{__make} DESTDIR=$SB_BUILD_ROOT PREFIX=%{_prefix} install
> > +  cd ${build_top}
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200414/00b25fec/attachment.html>
