[PATCH] Use linker garbage collection for BSP based builds
    Chris Johns
    chrisj at rtems.org
    Tue Apr 14 08:56:01 UTC 2020
On 14/4/20 5:12 pm, Sebastian Huber wrote:
> On 14/04/2020 09:02, Chris Johns wrote:
>> On 14/4/20 4:57 pm, Sebastian Huber wrote:
>>> Close #3944.
>>>   rtems/config/rtems-bsp.cfg | 2 +-
>>>   1 file changed, 1 insertion(+), 1 deletion(-)
>>> diff --git a/rtems/config/rtems-bsp.cfg b/rtems/config/rtems-bsp.cfg
>>> index d50615e..91296b1 100644
>>> --- a/rtems/config/rtems-bsp.cfg
>>> +++ b/rtems/config/rtems-bsp.cfg
>>> @@ -231,7 +231,7 @@
>>>   # The linker flags need to include the machine options for the BSP.
>>>   %define mflags_filter  awk '{for (i=1;i<NF;++i) if ($i ~ /\-m/)
>>> printf("%s ",$i);}'
>>> -%define rtems_bsp_ldflags %{rtems_bsp_ldflags} $(echo
>>> "%{rtems_bsp_cflags}" | %{mflags_filter})
>>> +%define rtems_bsp_ldflags %{rtems_bsp_ldflags} $(echo
>>> "%{rtems_bsp_cflags}" | %{mflags_filter}) -Wl,--gc-sections
>> What about adding a define like ..
>> %define rtems_bsp_ldflags_extra -Wl,--gc-sections
>> .. or something like that and then adding it to rtems_bsp_ldflags?
>> It would make it easier to track.
> Could you please change the patch and push it.
Sure, I will do this tomorrow.
> In RTEMS 6, we should replace this flag tinkering.
We need to only expose the machine flags from RTEMS by default and an
extra flags are special pkgcfg flags.
