[PATCH] Test for clock_nanosleep with CLOCK_MONOTONIC option.
Utkarsh Rai
utkarsh.rai60 at gmail.com
Tue Apr 14 12:02:53 UTC 2020
This test checks for a simple 1 ns delay with clock_nanosleep with
CLOCK_MONOTONIC.
testsuites/psxtests/Makefile.am | 9 +++
testsuites/psxtests/configure.ac | 1 +
.../psxtests/psxclocknanosleep01/init.c | 81 +++++++++++++++++++
.../psxclocknanosleep01.doc | 10 +++
.../psxclocknanosleep01.scn | 3 +
5 files changed, 104 insertions(+)
create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 1f9e4233ec..e3918ae7a5 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -321,6 +321,15 @@ psxclockrealtime01_CPPFLAGS = $(AM_CPPFLAGS) \
$(TEST_FLAGS_psxclockrealtime01) $(support_includes)
endif
+if TEST_psxclocknanosleep01
+psx_tests += psxclocknanosleep01
+psx_screens += psxclocknanosleep01/psxclocknanosleep01.scn
+psx_docs += psxclocknanosleep01/psxclocknanosleep01.doc
+psxclocknanosleep01_SOURCES = psxclocknanosleep01/init.c
+psxclocknanosleep01_CPPFLAGS = $(AM_CPPFLAGS) \
+ $(TEST_FLAGS_psxclocknanosleep01) $(support_includes)
+endif
if TEST_psxconcurrency01
psx_tests += psxconcurrency01
psx_screens += psxconcurrency01/psxconcurrency01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 139787cccb..9bfe8e2c0b 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
RTEMS_TEST_CHECK([psxcleanup02])
RTEMS_TEST_CHECK([psxclock])
RTEMS_TEST_CHECK([psxclock01])
+RTEMS_TEST_CHECK([psxclocknanosleep01])
RTEMS_TEST_CHECK([psxclockrealtime01])
RTEMS_TEST_CHECK([psxconcurrency01])
RTEMS_TEST_CHECK([psxcond01])
diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
new file mode 100644
index 0000000000..462ee114f8
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/init.c
@@ -0,0 +1,81 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include<rtems.h>
+#include<rtems/test.h>
+#include<time.h>
+#include<tmacros.h>
+/*Forward declaration to avoid compiler warning*/
+void clock_sleep(void);
+rtems_task Init(rtems_task_argument ignored);
+const char rtems_test_name[] = "PSXCLOCKNANOSLEEP 01";
+ struct timespec delay_time;
+ int status;
+ delay_time.tv_sec=0;
+ delay_time.tv_nsec=1;
+ status=clock_nanosleep(CLOCK_MONOTONIC, 0, &delay_time, (struct timespec* )NULL);
+ rtems_test_assert(!status);
+ struct timespec init_time;
+ struct timespec end_time;
+ int status;
+ TEST_BEGIN();
+ status = clock_gettime(CLOCK_MONOTONIC, &init_time);
+ clock_sleep();
+ status = clock_gettime(CLOCK_MONOTONIC, &end_time);
+ rtems_test_assert((end_time.tv_sec-init_time.tv_sec)==0);
+ rtems_test_assert((end_time.tv_nsec-init_time.tv_nsec)>=1);
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INIT
+#include<rtems/confdefs.h>
\ No newline at end of file
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
index 0000000000..ac70182aa0
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
@@ -0,0 +1,10 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclocknanosleep01
+directives: clock_nanosleep
+concepts:
++ This test ensures that the clock_nanosleep produces a 1 ns delay while using
+CLOCK_MONOTONIC option
diff --git a/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
index 0000000000..2f1b39f4f7
--- /dev/null
+++ b/testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXCLOCKNANOSLEEP 01 ***
+*** END OF TEST PSXCLOCKNANOSLEEP 01 ***
2.17.1
