[PATCH rtems-libbsd v2 03/14] imx6_ccm: Port to RTEMS
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Apr 14 14:51:04 UTC 2020
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Update #3869.
 freebsd/sys/arm/freescale/imx/imx6_ccm.c | 7 +++++++
 1 file changed, 7 insertions(+)
diff --git a/freebsd/sys/arm/freescale/imx/imx6_ccm.c b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
index 2993f1d6..cef79933 100644
--- a/freebsd/sys/arm/freescale/imx/imx6_ccm.c
+++ b/freebsd/sys/arm/freescale/imx/imx6_ccm.c
@@ -92,6 +92,7 @@ WR4(struct ccm_softc *sc, bus_size_t off, uint32_t val)
 static void
 ccm_init_gates(struct ccm_softc *sc)
+#ifndef __rtems__
 	uint32_t reg;
  	/* ahpbdma, aipstz 1 & 2 buses */
@@ -129,6 +130,7 @@ ccm_init_gates(struct ccm_softc *sc)
 	reg = CCGR6_USBOH3 | CCGR6_USDHC1 | CCGR6_USDHC2 |
 	    CCGR6_USDHC3 | CCGR6_USDHC4;
 	WR4(sc, CCM_CCGR6, reg);
+#endif /* __rtems__ */
 static int
@@ -204,7 +206,12 @@ ccm_probe(device_t dev)
 	if (!ofw_bus_status_okay(dev))
 		return (ENXIO);
+#ifndef __rtems__
         if (ofw_bus_is_compatible(dev, "fsl,imx6q-ccm") == 0)
+#else /* __rtems__ */
+        if (ofw_bus_is_compatible(dev, "fsl,imx6q-ccm") == 0 &&
+	    ofw_bus_is_compatible(dev, "fsl,imx6ul-ccm") == 0)
 		return (ENXIO);
 	device_set_desc(dev, "Freescale i.MX6 Clock Control Module");
2.16.4
