[PATCH v2] Test for clock_nanosleep with CLOCK_MONOTONIC option.
Wed Apr 15 04:56:37 UTC 2020
Hello Utkarsh Rai,
do we really need a new test program for this test case? I would prefer
add it to an existing test program or add a generic POSIX test program
using the RTEMS Test Framework.
On 14/04/2020 19:17, Utkarsh Rai wrote:
> This test checks for a simple 1 ns delay with clock_nanosleep with
> CLOCK_MONOTONIC.
>   testsuites/psxtests/Makefile.am               |  9 +++
>   testsuites/psxtests/configure.ac              |  1 +
>   .../psxtests/psxclocknanosleep01/init.c       | 81 +++++++++++++++++++
>   .../psxclocknanosleep01.doc                   | 10 +++
>   .../psxclocknanosleep01.scn                   |  3 +
>   5 files changed, 104 insertions(+)
>   create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
>   create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
>   create mode 100644 testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 1f9e4233ec..e3918ae7a5 100755
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -321,6 +321,15 @@ psxclockrealtime01_CPPFLAGS = $(AM_CPPFLAGS) \
>   	$(TEST_FLAGS_psxclockrealtime01) $(support_includes)
>   endif
> +if TEST_psxclocknanosleep01
> +psx_tests += psxclocknanosleep01
> +psx_screens += psxclocknanosleep01/psxclocknanosleep01.scn
> +psx_docs += psxclocknanosleep01/psxclocknanosleep01.doc
> +psxclocknanosleep01_SOURCES = psxclocknanosleep01/init.c
> +psxclocknanosleep01_CPPFLAGS = $(AM_CPPFLAGS) \
> +	$(TEST_FLAGS_psxclocknanosleep01) $(support_includes)
> +endif
>   if TEST_psxconcurrency01
>   psx_tests += psxconcurrency01
>   psx_screens += psxconcurrency01/psxconcurrency01.scn
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index 139787cccb..9bfe8e2c0b 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
>   RTEMS_TEST_CHECK([psxcleanup02])
>   RTEMS_TEST_CHECK([psxclock])
>   RTEMS_TEST_CHECK([psxclock01])
> +RTEMS_TEST_CHECK([psxclocknanosleep01])
>   RTEMS_TEST_CHECK([psxclockrealtime01])
>   RTEMS_TEST_CHECK([psxconcurrency01])
>   RTEMS_TEST_CHECK([psxcond01])
> diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c b/testsuites/psxtests/psxclocknanosleep01/init.c
> new file mode 100644
> index 0000000000..21b738627d
> --- /dev/null
> +++ b/testsuites/psxtests/psxclocknanosleep01/init.c
> @@ -0,0 +1,81 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020 Utkarsh Rai
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems.h>
> +#include <rtems/test.h>
> +#include <time.h>
> +#include <tmacros.h>
> +/*Forward declaration to avoid compiler warning*/
> +void clock_sleep(void);
Please use a static function instead. Most of these forward declarations
are just lazy warning fixes and bad examples.
> +rtems_task Init(rtems_task_argument ignored);
> +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP 01";
> +  struct timespec delay_time;
> +  int    status;
> +  delay_time.tv_sec = 0;
> +  delay_time.tv_nsec = 1;
> +  status=clock_nanosleep( CLOCK_MONOTONIC, 0, &delay_time, (struct timespec* )NULL );
In C code this cast is superfluous, in C++ code using NULL is out dated.
> +  rtems_test_assert( status == 0 );
> +  struct timespec init_time;
> +  struct timespec end_time;
> +  int    status;
> +  TEST_BEGIN();
> +  status = clock_gettime( CLOCK_MONOTONIC, &init_time );
> +  clock_sleep();
> +  status = clock_gettime( CLOCK_MONOTONIC, &end_time );
> +  rtems_test_assert( (end_time.tv_sec-init_time.tv_sec) == 0 );
Is end_time.tv_sec - init_time.tv_sec == 0 under all circumstances?
The test case code should be separated from the test suite boilerplate code.
> +  rtems_test_assert( (end_time.tv_nsec-init_time.tv_nsec) >=1 );
We really should think about using a C code formatter. I think that I
waste my time telling someone to put spaces between operators.
