[PATCH] Canonicalize config.h include
Wed Apr 15 07:55:33 UTC 2020
Use the following variant which was already used by most source files:
  #ifdef HAVE_CONFIG_H
  #include "config.h"
  #endif
 cpukit/dev/i2c/eeprom.c                                     | 4 ++--
 cpukit/dev/i2c/fpga-i2c-slave.c                             | 4 ++--
 cpukit/dev/i2c/gpio-nxp-pca9535.c                           | 4 ++--
 cpukit/dev/i2c/i2c-bus.c                                    | 4 ++--
 cpukit/dev/i2c/i2c-dev.c                                    | 4 ++--
 cpukit/dev/i2c/sensor-lm75a.c                               | 2 +-
 cpukit/dev/i2c/switch-nxp-pca9548a.c                        | 4 ++--
 cpukit/dev/i2c/ti-ads-16bit-adc.c                           | 4 ++--
 cpukit/dev/i2c/ti-lm25066a.c                                | 4 ++--
 cpukit/dev/i2c/ti-tmp112.c                                  | 4 ++--
 cpukit/dev/spi/spi-bus.c                                    | 4 ++--
 cpukit/ftpd/ftpd-init.c                                     | 2 +-
 cpukit/ftpd/ftpd.c                                          | 2 +-
 cpukit/libblock/src/bdbuf.c                                 | 2 +-
 cpukit/libblock/src/bdpart-register.c                       | 2 +-
 cpukit/libblock/src/blkdev-blkstats.c                       | 4 ++--
 cpukit/libblock/src/blkdev-imfs.c                           | 4 ++--
 cpukit/libblock/src/blkdev-ioctl.c                          | 4 ++--
 cpukit/libblock/src/blkdev-print-stats.c                    | 4 ++--
 cpukit/libblock/src/blkdev.c                                | 2 +-
 cpukit/libblock/src/diskdevs-init.c                         | 4 ++--
 cpukit/libblock/src/diskdevs.c                              | 2 +-
 cpukit/libblock/src/flashdisk.c                             | 2 +-
 cpukit/libblock/src/ide_part_table.c                        | 2 +-
 cpukit/libblock/src/nvdisk-sram.c                           | 2 +-
 cpukit/libblock/src/nvdisk.c                                | 2 +-
 cpukit/libblock/src/ramdisk-init.c                          | 2 +-
 cpukit/libblock/src/ramdisk-register.c                      | 2 +-
 cpukit/libblock/src/show_bdbuf.c                            | 2 +-
 cpukit/libcsupport/src/__assert.c                           | 2 +-
 cpukit/libcsupport/src/__getpid.c                           | 2 +-
 cpukit/libcsupport/src/__gettod.c                           | 2 +-
 cpukit/libcsupport/src/__times.c                            | 2 +-
 cpukit/libcsupport/src/__usrenv.c                           | 4 ++--
 cpukit/libcsupport/src/_calloc_r.c                          | 2 +-
 cpukit/libcsupport/src/_free_r.c                            | 2 +-
 cpukit/libcsupport/src/_malloc_r.c                          | 2 +-
 cpukit/libcsupport/src/_realloc_r.c                         | 2 +-
 cpukit/libcsupport/src/_rename_r.c                          | 2 +-
 cpukit/libcsupport/src/access.c                             | 2 +-
 cpukit/libcsupport/src/alignedalloc.c                       | 2 +-
 cpukit/libcsupport/src/assoc32tostring.c                    | 2 +-
 cpukit/libcsupport/src/assoclocalbyname.c                   | 2 +-
 cpukit/libcsupport/src/assoclocalbyremote.c                 | 2 +-
 cpukit/libcsupport/src/assoclocalbyremotebitfield.c         | 2 +-
 cpukit/libcsupport/src/assocnamebad.c                       | 2 +-
 cpukit/libcsupport/src/assocnamebylocal.c                   | 2 +-
 cpukit/libcsupport/src/assocnamebylocalbitfield.c           | 2 +-
 cpukit/libcsupport/src/assocnamebyremote.c                  | 2 +-
 cpukit/libcsupport/src/assocnamebyremotebitfield.c          | 2 +-
 cpukit/libcsupport/src/assocptrbylocal.c                    | 2 +-
 cpukit/libcsupport/src/assocptrbyname.c                     | 2 +-
 cpukit/libcsupport/src/assocptrbyremote.c                   | 2 +-
 cpukit/libcsupport/src/assocremotebylocal.c                 | 2 +-
 cpukit/libcsupport/src/assocremotebylocalbitfield.c         | 2 +-
 cpukit/libcsupport/src/assocremotebyname.c                  | 2 +-
 cpukit/libcsupport/src/assocthreadstatestostring.c          | 2 +-
 cpukit/libcsupport/src/base_fs.c                            | 2 +-
 cpukit/libcsupport/src/cachecoherentalloc.c                 | 4 ++--
 cpukit/libcsupport/src/calloc.c                             | 2 +-
 cpukit/libcsupport/src/cfgetispeed.c                        | 2 +-
 cpukit/libcsupport/src/cfgetospeed.c                        | 2 +-
 cpukit/libcsupport/src/cfmakeraw.c                          | 2 +-
 cpukit/libcsupport/src/cfmakesane.c                         | 2 +-
 cpukit/libcsupport/src/cfsetispeed.c                        | 2 +-
 cpukit/libcsupport/src/cfsetospeed.c                        | 2 +-
 cpukit/libcsupport/src/cfsetspeed.c                         | 2 +-
 cpukit/libcsupport/src/chdir.c                              | 4 ++--
 cpukit/libcsupport/src/chmod.c                              | 4 ++--
 cpukit/libcsupport/src/chown.c                              | 4 ++--
 cpukit/libcsupport/src/chroot.c                             | 4 ++--
 cpukit/libcsupport/src/clock.c                              | 2 +-
 cpukit/libcsupport/src/clonenode.c                          | 4 ++--
 cpukit/libcsupport/src/close.c                              | 2 +-
 cpukit/libcsupport/src/consolesimple.c                      | 2 +-
 cpukit/libcsupport/src/consolesimpletask.c                  | 2 +-
 cpukit/libcsupport/src/ctermid.c                            | 2 +-
 cpukit/libcsupport/src/dup.c                                | 2 +-
 cpukit/libcsupport/src/dup2.c                               | 2 +-
 cpukit/libcsupport/src/error.c                              | 2 +-
 cpukit/libcsupport/src/fchdir.c                             | 4 ++--
 cpukit/libcsupport/src/fchmod.c                             | 4 ++--
 cpukit/libcsupport/src/fchown.c                             | 4 ++--
 cpukit/libcsupport/src/fcntl.c                              | 4 ++--
 cpukit/libcsupport/src/fdatasync.c                          | 2 +-
 cpukit/libcsupport/src/flockfile.c                          | 2 +-
 cpukit/libcsupport/src/fpathconf.c                          | 2 +-
 cpukit/libcsupport/src/free.c                               | 2 +-
 cpukit/libcsupport/src/freenode.c                           | 4 ++--
 cpukit/libcsupport/src/fstat.c                              | 2 +-
 cpukit/libcsupport/src/fsync.c                              | 2 +-
 cpukit/libcsupport/src/ftruncate.c                          | 4 ++--
 cpukit/libcsupport/src/ftrylockfile.c                       | 2 +-
 cpukit/libcsupport/src/funlockfile.c                        | 2 +-
 cpukit/libcsupport/src/getchark.c                           | 2 +-
 cpukit/libcsupport/src/getdents.c                           | 2 +-
 cpukit/libcsupport/src/getegid.c                            | 2 +-
 cpukit/libcsupport/src/geteuid.c                            | 2 +-
 cpukit/libcsupport/src/getgid.c                             | 2 +-
 cpukit/libcsupport/src/getgrent.c                           | 2 +-
 cpukit/libcsupport/src/getgrnam.c                           | 2 +-
 cpukit/libcsupport/src/getgroups.c                          | 2 +-
 cpukit/libcsupport/src/getlogin.c                           | 2 +-
 cpukit/libcsupport/src/getpagesize.c                        | 2 +-
 cpukit/libcsupport/src/getpgrp.c                            | 2 +-
 cpukit/libcsupport/src/getpid.c                             | 2 +-
 cpukit/libcsupport/src/getppid.c                            | 2 +-
 cpukit/libcsupport/src/getpwent.c                           | 2 +-
 cpukit/libcsupport/src/getreentglobal.c                     | 2 +-
 cpukit/libcsupport/src/getrusage.c                          | 2 +-
 cpukit/libcsupport/src/getuid.c                             | 2 +-
 cpukit/libcsupport/src/gxx_wrappers.c                       | 2 +-
 cpukit/libcsupport/src/ioctl.c                              | 2 +-
 cpukit/libcsupport/src/isatty_r.c                           | 2 +-
 cpukit/libcsupport/src/issetugid.c                          | 2 +-
 cpukit/libcsupport/src/kill_noposix.c                       | 2 +-
 cpukit/libcsupport/src/lchown.c                             | 4 ++--
 cpukit/libcsupport/src/libio.c                              | 2 +-
 cpukit/libcsupport/src/libio_exit.c                         | 4 ++--
 cpukit/libcsupport/src/libio_init.c                         | 2 +-
 cpukit/libcsupport/src/link.c                               | 4 ++--
 cpukit/libcsupport/src/lseek.c                              | 4 ++--
 cpukit/libcsupport/src/lstat.c                              | 2 +-
 cpukit/libcsupport/src/malloc.c                             | 2 +-
 cpukit/libcsupport/src/malloc_deferred.c                    | 2 +-
 cpukit/libcsupport/src/malloc_dirtier.c                     | 2 +-
 cpukit/libcsupport/src/malloc_initialize.c                  | 4 ++--
 cpukit/libcsupport/src/malloc_walk.c                        | 2 +-
 cpukit/libcsupport/src/mallocdirtydefault.c                 | 2 +-
 cpukit/libcsupport/src/mallocextenddefault.c                | 2 +-
 cpukit/libcsupport/src/mallocfreespace.c                    | 2 +-
 cpukit/libcsupport/src/mallocgetheapptr.c                   | 2 +-
 cpukit/libcsupport/src/mallocinfo.c                         | 2 +-
 cpukit/libcsupport/src/mallocsetheapptr.c                   | 2 +-
 cpukit/libcsupport/src/mkdir.c                              | 2 +-
 cpukit/libcsupport/src/mkfifo.c                             | 2 +-
 cpukit/libcsupport/src/mknod.c                              | 4 ++--
 cpukit/libcsupport/src/mount-mgr.c                          | 2 +-
 cpukit/libcsupport/src/mount-mktgt.c                        | 2 +-
 cpukit/libcsupport/src/mount.c                              | 4 ++--
 cpukit/libcsupport/src/newlibc_exit.c                       | 2 +-
 cpukit/libcsupport/src/newlibc_reent.c                      | 2 +-
 cpukit/libcsupport/src/open.c                               | 4 ++--
 cpukit/libcsupport/src/open_dev_console.c                   | 2 +-
 cpukit/libcsupport/src/pathconf.c                           | 2 +-
 cpukit/libcsupport/src/posix_devctl.c                       | 2 +-
 cpukit/libcsupport/src/posix_memalign.c                     | 2 +-
 cpukit/libcsupport/src/print_fprintf.c                      | 2 +-
 cpukit/libcsupport/src/print_printf.c                       | 2 +-
 cpukit/libcsupport/src/printf_plugin.c                      | 2 +-
 cpukit/libcsupport/src/printk.c                             | 2 +-
 cpukit/libcsupport/src/printk_plugin.c                      | 2 +-
 cpukit/libcsupport/src/privateenv.c                         | 4 ++--
 cpukit/libcsupport/src/putk.c                               | 2 +-
 cpukit/libcsupport/src/pwdgrp.c                             | 2 +-
 cpukit/libcsupport/src/read.c                               | 2 +-
 cpukit/libcsupport/src/readlink.c                           | 4 ++--
 cpukit/libcsupport/src/readv.c                              | 2 +-
 cpukit/libcsupport/src/realloc.c                            | 2 +-
 cpukit/libcsupport/src/resource_snapshot.c                  | 4 ++--
 cpukit/libcsupport/src/rmdir.c                              | 4 ++--
 cpukit/libcsupport/src/rtems_heap_extend.c                  | 4 ++--
 cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c         | 4 ++--
 cpukit/libcsupport/src/rtems_heap_greedy.c                  | 4 ++--
 cpukit/libcsupport/src/rtems_heap_null_extend.c             | 4 ++--
 cpukit/libcsupport/src/rtems_memalign.c                     | 2 +-
 cpukit/libcsupport/src/rtems_mkdir.c                        | 2 +-
 cpukit/libcsupport/src/rtems_put_char.c                     | 2 +-
 cpukit/libcsupport/src/rtems_putc.c                         | 4 ++--
 cpukit/libcsupport/src/setegid.c                            | 2 +-
 cpukit/libcsupport/src/seteuid.c                            | 2 +-
 cpukit/libcsupport/src/setgid.c                             | 2 +-
 cpukit/libcsupport/src/setpgid.c                            | 2 +-
 cpukit/libcsupport/src/setsid.c                             | 2 +-
 cpukit/libcsupport/src/setuid.c                             | 2 +-
 cpukit/libcsupport/src/stat.c                               | 4 ++--
 cpukit/libcsupport/src/statvfs.c                            | 4 ++--
 cpukit/libcsupport/src/sup_fs_check_permissions.c           | 4 ++--
 cpukit/libcsupport/src/sup_fs_deviceio.c                    | 4 ++--
 cpukit/libcsupport/src/sup_fs_eval_path.c                   | 4 ++--
 cpukit/libcsupport/src/sup_fs_eval_path_generic.c           | 4 ++--
 cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c      | 4 ++--
 cpukit/libcsupport/src/sup_fs_location.c                    | 4 ++--
 cpukit/libcsupport/src/sup_fs_mount_iterate.c               | 4 ++--
 cpukit/libcsupport/src/sup_fs_next_token.c                  | 4 ++--
 cpukit/libcsupport/src/symlink.c                            | 4 ++--
 cpukit/libcsupport/src/sync.c                               | 2 +-
 cpukit/libcsupport/src/tcdrain.c                            | 2 +-
 cpukit/libcsupport/src/tcflow.c                             | 2 +-
 cpukit/libcsupport/src/tcflush.c                            | 4 ++--
 cpukit/libcsupport/src/tcgetattr.c                          | 2 +-
 cpukit/libcsupport/src/tcgetpgrp.c                          | 2 +-
 cpukit/libcsupport/src/tcsendbreak.c                        | 2 +-
 cpukit/libcsupport/src/tcsetattr.c                          | 2 +-
 cpukit/libcsupport/src/tcsetpgrp.c                          | 2 +-
 cpukit/libcsupport/src/termios.c                            | 2 +-
 cpukit/libcsupport/src/termios_baud2num.c                   | 2 +-
 cpukit/libcsupport/src/termios_baudtable.c                  | 2 +-
 cpukit/libcsupport/src/termios_num2baud.c                   | 2 +-
 cpukit/libcsupport/src/termios_posix_isig_handler.c         | 2 +-
 cpukit/libcsupport/src/termios_setbestbaud.c                | 4 ++--
 cpukit/libcsupport/src/termios_setinitialbaud.c             | 2 +-
 cpukit/libcsupport/src/termiosinitialize.c                  | 2 +-
 cpukit/libcsupport/src/truncate.c                           | 2 +-
 cpukit/libcsupport/src/umask.c                              | 4 ++--
 cpukit/libcsupport/src/unlink.c                             | 4 ++--
 cpukit/libcsupport/src/unmount.c                            | 4 ++--
 cpukit/libcsupport/src/utime.c                              | 4 ++--
 cpukit/libcsupport/src/utimes.c                             | 2 +-
 cpukit/libcsupport/src/utsname.c                            | 2 +-
 cpukit/libcsupport/src/vprintk.c                            | 2 +-
 cpukit/libcsupport/src/write.c                              | 2 +-
 cpukit/libcsupport/src/write_r.c                            | 2 +-
 cpukit/libcsupport/src/writev.c                             | 2 +-
 cpukit/libdl/dlfcn-shell.c                                  | 2 +-
 cpukit/libdl/rap-shell.c                                    | 2 +-
 cpukit/libdl/rap.c                                          | 2 +-
 cpukit/libdl/rtl-archive.c                                  | 2 +-
 cpukit/libdl/rtl-bit-alloc.c                                | 2 +-
 cpukit/libdl/rtl-chain-iterator.c                           | 2 +-
 cpukit/libdl/rtl-debugger.c                                 | 2 +-
 cpukit/libdl/rtl-elf.c                                      | 2 +-
 cpukit/libdl/rtl-error.c                                    | 2 +-
 cpukit/libdl/rtl-find-file.c                                | 2 +-
 cpukit/libdl/rtl-obj-cache.c                                | 2 +-
 cpukit/libdl/rtl-obj-comp.c                                 | 2 +-
 cpukit/libdl/rtl-obj.c                                      | 2 +-
 cpukit/libdl/rtl-rap.c                                      | 2 +-
 cpukit/libdl/rtl-shell.c                                    | 2 +-
 cpukit/libdl/rtl-sym.c                                      | 2 +-
 cpukit/libdl/rtl-trace.c                                    | 2 +-
 cpukit/libdl/rtl-unresolved.c                               | 2 +-
 cpukit/libdl/rtl-unwind-dw2.c                               | 2 +-
 cpukit/libdl/rtl.c                                          | 2 +-
 cpukit/libfs/src/defaults/default_are_nodes_equal.c         | 4 ++--
 cpukit/libfs/src/defaults/default_chown.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_clone.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_eval_path.c               | 4 ++--
 cpukit/libfs/src/defaults/default_fchmod.c                  | 4 ++--
 cpukit/libfs/src/defaults/default_freenode.c                | 4 ++--
 cpukit/libfs/src/defaults/default_fstat.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_fsync.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_fsync_success.c           | 4 ++--
 cpukit/libfs/src/defaults/default_ftruncate.c               | 4 ++--
 cpukit/libfs/src/defaults/default_ftruncate_directory.c     | 4 ++--
 cpukit/libfs/src/defaults/default_ioctl.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_kqfilter.c                | 4 ++--
 cpukit/libfs/src/defaults/default_link.c                    | 4 ++--
 cpukit/libfs/src/defaults/default_lock_and_unlock.c         | 4 ++--
 cpukit/libfs/src/defaults/default_lseek.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_lseek_directory.c         | 4 ++--
 cpukit/libfs/src/defaults/default_lseek_file.c              | 4 ++--
 cpukit/libfs/src/defaults/default_mknod.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_mmap.c                    | 4 ++--
 cpukit/libfs/src/defaults/default_open.c                    | 4 ++--
 cpukit/libfs/src/defaults/default_poll.c                    | 4 ++--
 cpukit/libfs/src/defaults/default_readlink.c                | 4 ++--
 cpukit/libfs/src/defaults/default_readv.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_rename.c                  | 4 ++--
 cpukit/libfs/src/defaults/default_rmnod.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_statvfs.c                 | 4 ++--
 cpukit/libfs/src/defaults/default_symlink.c                 | 4 ++--
 cpukit/libfs/src/defaults/default_utime.c                   | 4 ++--
 cpukit/libfs/src/defaults/default_writev.c                  | 4 ++--
 cpukit/libfs/src/dosfs/fat.c                                | 2 +-
 cpukit/libfs/src/dosfs/fat_fat_operations.c                 | 2 +-
 cpukit/libfs/src/dosfs/fat_file.c                           | 2 +-
 cpukit/libfs/src/dosfs/msdos_conv.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_create.c                       | 2 +-
 cpukit/libfs/src/dosfs/msdos_dir.c                          | 2 +-
 cpukit/libfs/src/dosfs/msdos_eval.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_file.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_format.c                       | 2 +-
 cpukit/libfs/src/dosfs/msdos_free.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_fsunmount.c                    | 2 +-
 cpukit/libfs/src/dosfs/msdos_handlers_dir.c                 | 2 +-
 cpukit/libfs/src/dosfs/msdos_handlers_file.c                | 2 +-
 cpukit/libfs/src/dosfs/msdos_init.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_initsupp.c                     | 2 +-
 cpukit/libfs/src/dosfs/msdos_misc.c                         | 2 +-
 cpukit/libfs/src/dosfs/msdos_mknod.c                        | 2 +-
 cpukit/libfs/src/dosfs/msdos_rename.c                       | 2 +-
 cpukit/libfs/src/dosfs/msdos_rmnod.c                        | 4 ++--
 cpukit/libfs/src/imfs/deviceio.c                            | 4 ++--
 cpukit/libfs/src/imfs/imfs_add_node.c                       | 2 +-
 cpukit/libfs/src/imfs/imfs_chown.c                          | 4 ++--
 cpukit/libfs/src/imfs/imfs_config.c                         | 2 +-
 cpukit/libfs/src/imfs/imfs_creat.c                          | 4 ++--
 cpukit/libfs/src/imfs/imfs_dir.c                            | 4 ++--
 cpukit/libfs/src/imfs/imfs_dir_default.c                    | 4 ++--
 cpukit/libfs/src/imfs/imfs_dir_minimal.c                    | 4 ++--
 cpukit/libfs/src/imfs/imfs_eval.c                           | 4 ++--
 cpukit/libfs/src/imfs/imfs_eval_devfs.c                     | 2 +-
 cpukit/libfs/src/imfs/imfs_fchmod.c                         | 4 ++--
 cpukit/libfs/src/imfs/imfs_fifo.c                           | 4 ++--
 cpukit/libfs/src/imfs/imfs_fsunmount.c                      | 4 ++--
 cpukit/libfs/src/imfs/imfs_handlers_device.c                | 4 ++--
 cpukit/libfs/src/imfs/imfs_init.c                           | 4 ++--
 cpukit/libfs/src/imfs/imfs_initsupp.c                       | 4 ++--
 cpukit/libfs/src/imfs/imfs_linfile.c                        | 4 ++--
 cpukit/libfs/src/imfs/imfs_link.c                           | 4 ++--
 cpukit/libfs/src/imfs/imfs_load_tar.c                       | 2 +-
 cpukit/libfs/src/imfs/imfs_make_generic_node.c              | 4 ++--
 cpukit/libfs/src/imfs/imfs_make_linfile.c                   | 2 +-
 cpukit/libfs/src/imfs/imfs_memfile.c                        | 4 ++--
 cpukit/libfs/src/imfs/imfs_mknod.c                          | 4 ++--
 cpukit/libfs/src/imfs/imfs_mount.c                          | 4 ++--
 cpukit/libfs/src/imfs/imfs_node.c                           | 2 +-
 cpukit/libfs/src/imfs/imfs_node_destroy_default.c           | 2 +-
 cpukit/libfs/src/imfs/imfs_rename.c                         | 4 ++--
 cpukit/libfs/src/imfs/imfs_rmnod.c                          | 4 ++--
 cpukit/libfs/src/imfs/imfs_stat.c                           | 4 ++--
 cpukit/libfs/src/imfs/imfs_stat_file.c                      | 4 ++--
 cpukit/libfs/src/imfs/imfs_symlink.c                        | 4 ++--
 cpukit/libfs/src/imfs/imfs_unmount.c                        | 4 ++--
 cpukit/libfs/src/imfs/imfs_utime.c                          | 4 ++--
 cpukit/libfs/src/imfs/ioman.c                               | 4 ++--
 cpukit/libfs/src/nfsclient/src/nfs.c                        | 4 ++--
 cpukit/libfs/src/nfsclient/src/rpcio.c                      | 2 +-
 cpukit/libfs/src/nfsclient/src/sock_mbuf.c                  | 2 +-
 cpukit/libfs/src/nfsclient/src/xdr_mbuf.c                   | 2 +-
 cpukit/libfs/src/pipe/fifo.c                                | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c                    | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-block.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c               | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-buffer-devio.c               | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-buffer.c                     | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c                   | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-dir.c                        | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-file-system.c                | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-file.c                       | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-format.c                     | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-group.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-inode.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-link.c                       | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-mutex.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c                  | 4 ++--
 cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c                  | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c                 | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c                | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-rtems.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-shell.c                      | 2 +-
 cpukit/libfs/src/rfs/rtems-rfs-trace.c                      | 2 +-
 cpukit/libgnat/adasupp.c                                    | 2 +-
 cpukit/libi2c/libi2c.c                                      | 2 +-
 cpukit/libmisc/cpuuse/cpuinforeport.c                       | 4 ++--
 cpukit/libmisc/fb/mw_print.c                                | 2 +-
 cpukit/libmisc/shell/main_blkstats.c                        | 4 ++--
 cpukit/libmisc/shell/main_cmdchmod.c                        | 4 ++--
 cpukit/libmisc/shell/main_cmdchown.c                        | 4 ++--
 cpukit/libmisc/shell/main_cmdls.c                           | 4 ++--
 cpukit/libmisc/shell/main_cpuinfo.c                         | 4 ++--
 cpukit/libmisc/shell/main_hexdump.c                         | 2 +-
 cpukit/libmisc/shell/main_lsof.c                            | 4 ++--
 cpukit/libmisc/shell/main_profreport.c                      | 4 ++--
 cpukit/libmisc/shell/shell_makeargs.c                       | 2 +-
 cpukit/libmisc/uuid/gen_uuid.c                              | 2 +-
 cpukit/libnetworking/libc/base64.c                          | 2 +-
 cpukit/libnetworking/libc/gethostbydns.c                    | 2 +-
 cpukit/libnetworking/libc/gethostbyht.c                     | 2 +-
 cpukit/libnetworking/libc/gethostbynis.c                    | 2 +-
 cpukit/libnetworking/libc/gethostnamadr.c                   | 2 +-
 cpukit/libnetworking/libc/getnetbydns.c                     | 2 +-
 cpukit/libnetworking/libc/getnetbyht.c                      | 2 +-
 cpukit/libnetworking/libc/getnetbynis.c                     | 2 +-
 cpukit/libnetworking/libc/getnetnamadr.c                    | 2 +-
 cpukit/libnetworking/libc/getproto.c                        | 2 +-
 cpukit/libnetworking/libc/getprotoent.c                     | 2 +-
 cpukit/libnetworking/libc/getprotoname.c                    | 2 +-
 cpukit/libnetworking/libc/getservbyname.c                   | 2 +-
 cpukit/libnetworking/libc/getservbyport.c                   | 2 +-
 cpukit/libnetworking/libc/getservent.c                      | 2 +-
 cpukit/libnetworking/libc/herror.c                          | 2 +-
 cpukit/libnetworking/libc/inet_lnaof.c                      | 2 +-
 cpukit/libnetworking/libc/inet_makeaddr.c                   | 2 +-
 cpukit/libnetworking/libc/inet_netof.c                      | 2 +-
 cpukit/libnetworking/libc/inet_network.c                    | 2 +-
 cpukit/libnetworking/libc/inet_pton.c                       | 2 +-
 cpukit/libnetworking/libc/linkaddr.c                        | 2 +-
 cpukit/libnetworking/libc/map_v4v6.c                        | 2 +-
 cpukit/libnetworking/libc/ns_name.c                         | 2 +-
 cpukit/libnetworking/libc/ns_netint.c                       | 2 +-
 cpukit/libnetworking/libc/ns_parse.c                        | 2 +-
 cpukit/libnetworking/libc/ns_print.c                        | 2 +-
 cpukit/libnetworking/libc/ns_ttl.c                          | 2 +-
 cpukit/libnetworking/libc/nsap_addr.c                       | 2 +-
 cpukit/libnetworking/libc/rcmd.c                            | 2 +-
 cpukit/libnetworking/libc/recv.c                            | 2 +-
 cpukit/libnetworking/libc/res_comp.c                        | 2 +-
 cpukit/libnetworking/libc/res_data.c                        | 2 +-
 cpukit/libnetworking/libc/res_debug.c                       | 2 +-
 cpukit/libnetworking/libc/res_init.c                        | 2 +-
 cpukit/libnetworking/libc/res_mkquery.c                     | 2 +-
 cpukit/libnetworking/libc/res_mkupdate.c                    | 2 +-
 cpukit/libnetworking/libc/res_query.c                       | 2 +-
 cpukit/libnetworking/libc/res_send.c                        | 2 +-
 cpukit/libnetworking/libc/res_stubs.c                       | 2 +-
 cpukit/libnetworking/libc/res_update.c                      | 2 +-
 cpukit/libnetworking/libc/send.c                            | 2 +-
 cpukit/libnetworking/rtems/mkrootfs.c                       | 2 +-
 cpukit/libnetworking/rtems/rtems_bootp.c                    | 2 +-
 cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c | 2 +-
 cpukit/libnetworking/rtems/rtems_dhcp.c                     | 2 +-
 cpukit/libnetworking/rtems/rtems_glue.c                     | 2 +-
 cpukit/libnetworking/rtems/rtems_malloc_mbuf.c              | 2 +-
 cpukit/libnetworking/rtems/rtems_select.c                   | 2 +-
 cpukit/libnetworking/rtems/rtems_showicmpstat.c             | 2 +-
 cpukit/libnetworking/rtems/rtems_showifstat.c               | 2 +-
 cpukit/libnetworking/rtems/rtems_showipstat.c               | 2 +-
 cpukit/libnetworking/rtems/rtems_showmbuf.c                 | 2 +-
 cpukit/libnetworking/rtems/rtems_showroute.c                | 2 +-
 cpukit/libnetworking/rtems/rtems_showtcpstat.c              | 2 +-
 cpukit/libnetworking/rtems/rtems_showudpstat.c              | 2 +-
 cpukit/libnetworking/rtems/rtems_socketpair.c               | 2 +-
 cpukit/libnetworking/rtems/rtems_syscall.c                  | 2 +-
 cpukit/libnetworking/rtems/rtems_syscall_api.c              | 2 +-
 cpukit/libnetworking/rtems/sghostname.c                     | 2 +-
 cpukit/libtest/testbeginend.c                               | 2 +-
 cpukit/libtest/testextension.c                              | 2 +-
 cpukit/libtest/testparallel.c                               | 2 +-
 cpukit/libtest/testwrappers.c                               | 2 +-
 cpukit/libtrace/record/record-client.c                      | 2 +-
 cpukit/libtrace/record/record-dump-base64.c                 | 2 +-
 cpukit/libtrace/record/record-dump-fatal.c                  | 2 +-
 cpukit/libtrace/record/record-dump-zbase64.c                | 2 +-
 cpukit/libtrace/record/record-dump-zfatal.c                 | 2 +-
 cpukit/libtrace/record/record-dump.c                        | 2 +-
 cpukit/libtrace/record/record-server.c                      | 2 +-
 cpukit/libtrace/record/record-sysinit.c                     | 2 +-
 cpukit/libtrace/record/record-text.c                        | 2 +-
 cpukit/libtrace/record/record-userext.c                     | 2 +-
 cpukit/libtrace/record/record-util.c                        | 2 +-
 cpukit/libtrace/record/record.c                             | 2 +-
 cpukit/mghttpd/mongoose.c                                   | 2 +-
 cpukit/posix/src/_execve.c                                  | 2 +-
 cpukit/posix/src/adjtime.c                                  | 2 +-
 cpukit/posix/src/aio_cancel.c                               | 2 +-
 cpukit/posix/src/aio_error.c                                | 2 +-
 cpukit/posix/src/aio_fsync.c                                | 2 +-
 cpukit/posix/src/aio_read.c                                 | 2 +-
 cpukit/posix/src/aio_return.c                               | 2 +-
 cpukit/posix/src/aio_suspend.c                              | 2 +-
 cpukit/posix/src/aio_write.c                                | 2 +-
 cpukit/posix/src/alarm.c                                    | 2 +-
 cpukit/posix/src/barrierattrdestroy.c                       | 2 +-
 cpukit/posix/src/barrierattrgetpshared.c                    | 2 +-
 cpukit/posix/src/barrierattrinit.c                          | 2 +-
 cpukit/posix/src/barrierattrsetpshared.c                    | 2 +-
 cpukit/posix/src/cancel.c                                   | 2 +-
 cpukit/posix/src/cleanuppush.c                              | 2 +-
 cpukit/posix/src/clockgetcpuclockid.c                       | 2 +-
 cpukit/posix/src/clockgetres.c                              | 2 +-
 cpukit/posix/src/clockgettime.c                             | 2 +-
 cpukit/posix/src/clocksettime.c                             | 2 +-
 cpukit/posix/src/condattrdestroy.c                          | 2 +-
 cpukit/posix/src/condattrgetclock.c                         | 2 +-
 cpukit/posix/src/condattrgetpshared.c                       | 2 +-
 cpukit/posix/src/condattrinit.c                             | 2 +-
 cpukit/posix/src/condattrsetclock.c                         | 2 +-
 cpukit/posix/src/condattrsetpshared.c                       | 2 +-
 cpukit/posix/src/condbroadcast.c                            | 2 +-
 cpukit/posix/src/conddefaultattributes.c                    | 2 +-
 cpukit/posix/src/conddestroy.c                              | 2 +-
 cpukit/posix/src/condinit.c                                 | 2 +-
 cpukit/posix/src/condsignal.c                               | 2 +-
 cpukit/posix/src/condsignalsupp.c                           | 2 +-
 cpukit/posix/src/condtimedwait.c                            | 2 +-
 cpukit/posix/src/condwait.c                                 | 2 +-
 cpukit/posix/src/condwaitsupp.c                             | 2 +-
 cpukit/posix/src/fork.c                                     | 2 +-
 cpukit/posix/src/getitimer.c                                | 2 +-
 cpukit/posix/src/key.c                                      | 2 +-
 cpukit/posix/src/keycreate.c                                | 2 +-
 cpukit/posix/src/keydelete.c                                | 2 +-
 cpukit/posix/src/keygetspecific.c                           | 2 +-
 cpukit/posix/src/keysetspecific.c                           | 2 +-
 cpukit/posix/src/keyzerokvp.c                               | 2 +-
 cpukit/posix/src/kill.c                                     | 2 +-
 cpukit/posix/src/kill_r.c                                   | 2 +-
 cpukit/posix/src/killinfo.c                                 | 2 +-
 cpukit/posix/src/lio_listio.c                               | 2 +-
 cpukit/posix/src/mlock.c                                    | 2 +-
 cpukit/posix/src/mlockall.c                                 | 2 +-
 cpukit/posix/src/mmap.c                                     | 2 +-
 cpukit/posix/src/mprotect.c                                 | 2 +-
 cpukit/posix/src/mqueue.c                                   | 2 +-
 cpukit/posix/src/mqueueclose.c                              | 2 +-
 cpukit/posix/src/mqueueconfig.c                             | 2 +-
 cpukit/posix/src/mqueuedeletesupp.c                         | 2 +-
 cpukit/posix/src/mqueuegetattr.c                            | 2 +-
 cpukit/posix/src/mqueuenotify.c                             | 2 +-
 cpukit/posix/src/mqueueopen.c                               | 2 +-
 cpukit/posix/src/mqueuereceive.c                            | 2 +-
 cpukit/posix/src/mqueuerecvsupp.c                           | 2 +-
 cpukit/posix/src/mqueuesend.c                               | 2 +-
 cpukit/posix/src/mqueuesendsupp.c                           | 2 +-
 cpukit/posix/src/mqueuesetattr.c                            | 2 +-
 cpukit/posix/src/mqueuetimedreceive.c                       | 2 +-
 cpukit/posix/src/mqueuetimedsend.c                          | 2 +-
 cpukit/posix/src/mqueueunlink.c                             | 2 +-
 cpukit/posix/src/msync.c                                    | 2 +-
 cpukit/posix/src/munlock.c                                  | 2 +-
 cpukit/posix/src/munlockall.c                               | 2 +-
 cpukit/posix/src/munmap.c                                   | 2 +-
 cpukit/posix/src/mutexattrdestroy.c                         | 2 +-
 cpukit/posix/src/mutexattrgetprioceiling.c                  | 2 +-
 cpukit/posix/src/mutexattrgetprotocol.c                     | 2 +-
 cpukit/posix/src/mutexattrgetpshared.c                      | 2 +-
 cpukit/posix/src/mutexattrgettype.c                         | 2 +-
 cpukit/posix/src/mutexattrinit.c                            | 2 +-
 cpukit/posix/src/mutexattrsetprioceiling.c                  | 2 +-
 cpukit/posix/src/mutexattrsetprotocol.c                     | 2 +-
 cpukit/posix/src/mutexattrsetpshared.c                      | 2 +-
 cpukit/posix/src/mutexattrsettype.c                         | 2 +-
 cpukit/posix/src/mutexdestroy.c                             | 2 +-
 cpukit/posix/src/mutexgetprioceiling.c                      | 2 +-
 cpukit/posix/src/mutexinit.c                                | 2 +-
 cpukit/posix/src/mutexlock.c                                | 2 +-
 cpukit/posix/src/mutexlocksupp.c                            | 2 +-
 cpukit/posix/src/mutexsetprioceiling.c                      | 2 +-
 cpukit/posix/src/mutextimedlock.c                           | 2 +-
 cpukit/posix/src/mutextrylock.c                             | 2 +-
 cpukit/posix/src/mutexunlock.c                              | 2 +-
 cpukit/posix/src/nanosleep.c                                | 2 +-
 cpukit/posix/src/pause.c                                    | 2 +-
 cpukit/posix/src/pbarrierdestroy.c                          | 2 +-
 cpukit/posix/src/pbarrierinit.c                             | 2 +-
 cpukit/posix/src/pbarrierwait.c                             | 2 +-
 cpukit/posix/src/posix_madvise.c                            | 2 +-
 cpukit/posix/src/prwlockdestroy.c                           | 2 +-
 cpukit/posix/src/prwlockinit.c                              | 2 +-
 cpukit/posix/src/prwlockrdlock.c                            | 2 +-
 cpukit/posix/src/prwlocktimedrdlock.c                       | 2 +-
 cpukit/posix/src/prwlocktimedwrlock.c                       | 2 +-
 cpukit/posix/src/prwlocktryrdlock.c                         | 2 +-
 cpukit/posix/src/prwlocktrywrlock.c                         | 2 +-
 cpukit/posix/src/prwlockunlock.c                            | 2 +-
 cpukit/posix/src/prwlockwrlock.c                            | 2 +-
 cpukit/posix/src/psignal.c                                  | 2 +-
 cpukit/posix/src/psignalclearprocesssignals.c               | 2 +-
 cpukit/posix/src/psignalclearsignals.c                      | 2 +-
 cpukit/posix/src/psignalconfig.c                            | 2 +-
 cpukit/posix/src/psignalsetprocesssignals.c                 | 2 +-
 cpukit/posix/src/psignalunblockthread.c                     | 2 +-
 cpukit/posix/src/pspindestroy.c                             | 2 +-
 cpukit/posix/src/pspininit.c                                | 2 +-
 cpukit/posix/src/pspinlock.c                                | 2 +-
 cpukit/posix/src/pspinunlock.c                              | 2 +-
 cpukit/posix/src/psxnametoid.c                              | 4 ++--
 cpukit/posix/src/psxpriorityisvalid.c                       | 2 +-
 cpukit/posix/src/psxsemaphore.c                             | 2 +-
 cpukit/posix/src/psxsemaphoreconfig.c                       | 2 +-
 cpukit/posix/src/psxtimerconfig.c                           | 2 +-
 cpukit/posix/src/psxtimercreate.c                           | 2 +-
 cpukit/posix/src/psxtimerdelete.c                           | 2 +-
 cpukit/posix/src/psxtransschedparam.c                       | 2 +-
 cpukit/posix/src/pthread.c                                  | 2 +-
 cpukit/posix/src/pthreadatfork.c                            | 2 +-
 cpukit/posix/src/pthreadattrdefault.c                       | 2 +-
 cpukit/posix/src/pthreadattrdestroy.c                       | 2 +-
 cpukit/posix/src/pthreadattrgetaffinitynp.c                 | 2 +-
 cpukit/posix/src/pthreadattrgetdetachstate.c                | 2 +-
 cpukit/posix/src/pthreadattrgetguardsize.c                  | 2 +-
 cpukit/posix/src/pthreadattrgetinheritsched.c               | 2 +-
 cpukit/posix/src/pthreadattrgetschedparam.c                 | 2 +-
 cpukit/posix/src/pthreadattrgetschedpolicy.c                | 2 +-
 cpukit/posix/src/pthreadattrgetscope.c                      | 2 +-
 cpukit/posix/src/pthreadattrgetstack.c                      | 2 +-
 cpukit/posix/src/pthreadattrgetstackaddr.c                  | 2 +-
 cpukit/posix/src/pthreadattrgetstacksize.c                  | 2 +-
 cpukit/posix/src/pthreadattrinit.c                          | 2 +-
 cpukit/posix/src/pthreadattrsetaffinitynp.c                 | 2 +-
 cpukit/posix/src/pthreadattrsetdetachstate.c                | 2 +-
 cpukit/posix/src/pthreadattrsetguardsize.c                  | 2 +-
 cpukit/posix/src/pthreadattrsetinheritsched.c               | 2 +-
 cpukit/posix/src/pthreadattrsetschedparam.c                 | 2 +-
 cpukit/posix/src/pthreadattrsetschedpolicy.c                | 2 +-
 cpukit/posix/src/pthreadattrsetscope.c                      | 2 +-
 cpukit/posix/src/pthreadattrsetstack.c                      | 2 +-
 cpukit/posix/src/pthreadattrsetstackaddr.c                  | 2 +-
 cpukit/posix/src/pthreadattrsetstacksize.c                  | 2 +-
 cpukit/posix/src/pthreadconcurrency.c                       | 2 +-
 cpukit/posix/src/pthreadconfig.c                            | 2 +-
 cpukit/posix/src/pthreadcreate.c                            | 2 +-
 cpukit/posix/src/pthreaddetach.c                            | 2 +-
 cpukit/posix/src/pthreadequal.c                             | 2 +-
 cpukit/posix/src/pthreadexit.c                              | 2 +-
 cpukit/posix/src/pthreadgetaffinitynp.c                     | 2 +-
 cpukit/posix/src/pthreadgetattrnp.c                         | 2 +-
 cpukit/posix/src/pthreadgetcpuclockid.c                     | 2 +-
 cpukit/posix/src/pthreadgetnamenp.c                         | 2 +-
 cpukit/posix/src/pthreadgetschedparam.c                     | 2 +-
 cpukit/posix/src/pthreadinitthreads.c                       | 2 +-
 cpukit/posix/src/pthreadjoin.c                              | 2 +-
 cpukit/posix/src/pthreadkill.c                              | 2 +-
 cpukit/posix/src/pthreadonce.c                              | 2 +-
 cpukit/posix/src/pthreadself.c                              | 2 +-
 cpukit/posix/src/pthreadsetaffinitynp.c                     | 2 +-
 cpukit/posix/src/pthreadsetnamenp.c                         | 2 +-
 cpukit/posix/src/pthreadsetschedparam.c                     | 2 +-
 cpukit/posix/src/pthreadsetschedprio.c                      | 2 +-
 cpukit/posix/src/pthreadsigmask.c                           | 2 +-
 cpukit/posix/src/ptimer.c                                   | 2 +-
 cpukit/posix/src/rwlockattrdestroy.c                        | 2 +-
 cpukit/posix/src/rwlockattrgetpshared.c                     | 2 +-
 cpukit/posix/src/rwlockattrinit.c                           | 2 +-
 cpukit/posix/src/rwlockattrsetpshared.c                     | 2 +-
 cpukit/posix/src/sched_getparam.c                           | 2 +-
 cpukit/posix/src/sched_getprioritymax.c                     | 2 +-
 cpukit/posix/src/sched_getprioritymin.c                     | 2 +-
 cpukit/posix/src/sched_getscheduler.c                       | 2 +-
 cpukit/posix/src/sched_rr_get_interval.c                    | 2 +-
 cpukit/posix/src/sched_setparam.c                           | 2 +-
 cpukit/posix/src/sched_setscheduler.c                       | 2 +-
 cpukit/posix/src/sched_yield.c                              | 2 +-
 cpukit/posix/src/semaphoredeletesupp.c                      | 2 +-
 cpukit/posix/src/semclose.c                                 | 2 +-
 cpukit/posix/src/semdestroy.c                               | 2 +-
 cpukit/posix/src/semgetvalue.c                              | 2 +-
 cpukit/posix/src/seminit.c                                  | 2 +-
 cpukit/posix/src/semopen.c                                  | 2 +-
 cpukit/posix/src/sempost.c                                  | 2 +-
 cpukit/posix/src/semtimedwait.c                             | 2 +-
 cpukit/posix/src/semtrywait.c                               | 2 +-
 cpukit/posix/src/semunlink.c                                | 2 +-
 cpukit/posix/src/semwait.c                                  | 2 +-
 cpukit/posix/src/setcancelstate.c                           | 2 +-
 cpukit/posix/src/setcanceltype.c                            | 2 +-
 cpukit/posix/src/setitimer.c                                | 2 +-
 cpukit/posix/src/shm.c                                      | 2 +-
 cpukit/posix/src/shmconfig.c                                | 2 +-
 cpukit/posix/src/shmheap.c                                  | 2 +-
 cpukit/posix/src/shmopen.c                                  | 2 +-
 cpukit/posix/src/shmops.c                                   | 2 +-
 cpukit/posix/src/shmunlink.c                                | 2 +-
 cpukit/posix/src/shmwkspace.c                               | 2 +-
 cpukit/posix/src/sigaction.c                                | 2 +-
 cpukit/posix/src/sigaddset.c                                | 2 +-
 cpukit/posix/src/sigdelset.c                                | 2 +-
 cpukit/posix/src/sigemptyset.c                              | 2 +-
 cpukit/posix/src/sigfillset.c                               | 2 +-
 cpukit/posix/src/sigismember.c                              | 2 +-
 cpukit/posix/src/signal_2.c                                 | 2 +-
 cpukit/posix/src/sigpending.c                               | 2 +-
 cpukit/posix/src/sigprocmask.c                              | 2 +-
 cpukit/posix/src/sigqueue.c                                 | 2 +-
 cpukit/posix/src/sigsuspend.c                               | 2 +-
 cpukit/posix/src/sigtimedwait.c                             | 2 +-
 cpukit/posix/src/sigwait.c                                  | 2 +-
 cpukit/posix/src/sigwaitinfo.c                              | 2 +-
 cpukit/posix/src/sysconf.c                                  | 2 +-
 cpukit/posix/src/testcancel.c                               | 2 +-
 cpukit/posix/src/timergetoverrun.c                          | 2 +-
 cpukit/posix/src/timergettime.c                             | 2 +-
 cpukit/posix/src/timersettime.c                             | 2 +-
 cpukit/posix/src/ualarm.c                                   | 2 +-
 cpukit/posix/src/vfork.c                                    | 2 +-
 cpukit/posix/src/wait.c                                     | 2 +-
 cpukit/posix/src/waitpid.c                                  | 2 +-
 cpukit/rtems/src/barrier.c                                  | 2 +-
 cpukit/rtems/src/barriercreate.c                            | 2 +-
 cpukit/rtems/src/barrierdelete.c                            | 2 +-
 cpukit/rtems/src/barrierident.c                             | 2 +-
 cpukit/rtems/src/barrierrelease.c                           | 2 +-
 cpukit/rtems/src/barrierwait.c                              | 2 +-
 cpukit/rtems/src/clockgetsecondssinceepoch.c                | 2 +-
 cpukit/rtems/src/clockgettickspersecond.c                   | 2 +-
 cpukit/rtems/src/clockgettod.c                              | 2 +-
 cpukit/rtems/src/clockgettodtimeval.c                       | 2 +-
 cpukit/rtems/src/clockgetuptime.c                           | 2 +-
 cpukit/rtems/src/clockgetuptimenanoseconds.c                | 4 ++--
 cpukit/rtems/src/clockgetuptimetimeval.c                    | 4 ++--
 cpukit/rtems/src/clockset.c                                 | 2 +-
 cpukit/rtems/src/clocktick.c                                | 2 +-
 cpukit/rtems/src/clocktodtoseconds.c                        | 2 +-
 cpukit/rtems/src/clocktodvalidate.c                         | 2 +-
 cpukit/rtems/src/dpmem.c                                    | 2 +-
 cpukit/rtems/src/dpmemcreate.c                              | 2 +-
 cpukit/rtems/src/dpmemdelete.c                              | 2 +-
 cpukit/rtems/src/dpmemexternal2internal.c                   | 2 +-
 cpukit/rtems/src/dpmemident.c                               | 2 +-
 cpukit/rtems/src/dpmeminternal2external.c                   | 2 +-
 cpukit/rtems/src/eventmp.c                                  | 2 +-
 cpukit/rtems/src/eventreceive.c                             | 4 ++--
 cpukit/rtems/src/eventseize.c                               | 4 ++--
 cpukit/rtems/src/eventsend.c                                | 4 ++--
 cpukit/rtems/src/eventsurrender.c                           | 4 ++--
 cpukit/rtems/src/getapiconfig.c                             | 2 +-
 cpukit/rtems/src/intrbody.c                                 | 2 +-
 cpukit/rtems/src/intrcatch.c                                | 2 +-
 cpukit/rtems/src/modes.c                                    | 2 +-
 cpukit/rtems/src/mp.c                                       | 2 +-
 cpukit/rtems/src/msg.c                                      | 2 +-
 cpukit/rtems/src/msgmp.c                                    | 2 +-
 cpukit/rtems/src/msgqbroadcast.c                            | 2 +-
 cpukit/rtems/src/msgqcreate.c                               | 2 +-
 cpukit/rtems/src/msgqdelete.c                               | 2 +-
 cpukit/rtems/src/msgqflush.c                                | 2 +-
 cpukit/rtems/src/msgqgetnumberpending.c                     | 2 +-
 cpukit/rtems/src/msgqident.c                                | 2 +-
 cpukit/rtems/src/msgqreceive.c                              | 2 +-
 cpukit/rtems/src/msgqsend.c                                 | 2 +-
 cpukit/rtems/src/msgqurgent.c                               | 2 +-
 cpukit/rtems/src/part.c                                     | 2 +-
 cpukit/rtems/src/partcreate.c                               | 2 +-
 cpukit/rtems/src/partdelete.c                               | 2 +-
 cpukit/rtems/src/partgetbuffer.c                            | 2 +-
 cpukit/rtems/src/partident.c                                | 2 +-
 cpukit/rtems/src/partmp.c                                   | 2 +-
 cpukit/rtems/src/partreturnbuffer.c                         | 2 +-
 cpukit/rtems/src/ratemon.c                                  | 2 +-
 cpukit/rtems/src/ratemoncancel.c                            | 2 +-
 cpukit/rtems/src/ratemoncreate.c                            | 2 +-
 cpukit/rtems/src/ratemondelete.c                            | 2 +-
 cpukit/rtems/src/ratemongetstatistics.c                     | 2 +-
 cpukit/rtems/src/ratemongetstatus.c                         | 2 +-
 cpukit/rtems/src/ratemonident.c                             | 2 +-
 cpukit/rtems/src/ratemonperiod.c                            | 2 +-
 cpukit/rtems/src/ratemonresetstatistics.c                   | 2 +-
 cpukit/rtems/src/ratemontimeout.c                           | 2 +-
 cpukit/rtems/src/region.c                                   | 2 +-
 cpukit/rtems/src/regioncreate.c                             | 2 +-
 cpukit/rtems/src/regiondelete.c                             | 2 +-
 cpukit/rtems/src/regionextend.c                             | 2 +-
 cpukit/rtems/src/regiongetfreeinfo.c                        | 2 +-
 cpukit/rtems/src/regiongetinfo.c                            | 2 +-
 cpukit/rtems/src/regiongetsegment.c                         | 2 +-
 cpukit/rtems/src/regiongetsegmentsize.c                     | 2 +-
 cpukit/rtems/src/regionident.c                              | 2 +-
 cpukit/rtems/src/regionprocessqueue.c                       | 2 +-
 cpukit/rtems/src/regionresizesegment.c                      | 2 +-
 cpukit/rtems/src/regionreturnsegment.c                      | 2 +-
 cpukit/rtems/src/rtclock.c                                  | 2 +-
 cpukit/rtems/src/rtemsobjectgetclassicname.c                | 2 +-
 cpukit/rtems/src/rtemsobjectgetclassinfo.c                  | 2 +-
 cpukit/rtems/src/rtemstimer.c                               | 2 +-
 cpukit/rtems/src/scheduleraddprocessor.c                    | 2 +-
 cpukit/rtems/src/schedulergetmaxprio.c                      | 2 +-
 cpukit/rtems/src/schedulergetprocessorset.c                 | 4 ++--
 cpukit/rtems/src/schedulerident.c                           | 4 ++--
 cpukit/rtems/src/scheduleridentbyprocessor.c                | 2 +-
 cpukit/rtems/src/scheduleridentbyprocessorset.c             | 2 +-
 cpukit/rtems/src/schedulermapfromposix.c                    | 2 +-
 cpukit/rtems/src/schedulermaptoposix.c                      | 2 +-
 cpukit/rtems/src/schedulerremoveprocessor.c                 | 2 +-
 cpukit/rtems/src/sem.c                                      | 2 +-
 cpukit/rtems/src/semcreate.c                                | 2 +-
 cpukit/rtems/src/semdelete.c                                | 2 +-
 cpukit/rtems/src/semflush.c                                 | 2 +-
 cpukit/rtems/src/semident.c                                 | 2 +-
 cpukit/rtems/src/semmp.c                                    | 2 +-
 cpukit/rtems/src/semobtain.c                                | 2 +-
 cpukit/rtems/src/semrelease.c                               | 2 +-
 cpukit/rtems/src/semsetpriority.c                           | 4 ++--
 cpukit/rtems/src/signalcatch.c                              | 2 +-
 cpukit/rtems/src/signalmp.c                                 | 2 +-
 cpukit/rtems/src/signalsend.c                               | 2 +-
 cpukit/rtems/src/statustext.c                               | 4 ++--
 cpukit/rtems/src/systemeventreceive.c                       | 4 ++--
 cpukit/rtems/src/systemeventsend.c                          | 4 ++--
 cpukit/rtems/src/taskcreate.c                               | 2 +-
 cpukit/rtems/src/taskdelete.c                               | 2 +-
 cpukit/rtems/src/taskexit.c                                 | 2 +-
 cpukit/rtems/src/taskgetaffinity.c                          | 2 +-
 cpukit/rtems/src/taskgetpriority.c                          | 2 +-
 cpukit/rtems/src/taskgetscheduler.c                         | 4 ++--
 cpukit/rtems/src/taskident.c                                | 2 +-
 cpukit/rtems/src/taskinitdefault.c                          | 2 +-
 cpukit/rtems/src/taskinitusers.c                            | 2 +-
 cpukit/rtems/src/taskissuspended.c                          | 2 +-
 cpukit/rtems/src/taskiterate.c                              | 2 +-
 cpukit/rtems/src/taskmode.c                                 | 2 +-
 cpukit/rtems/src/taskmp.c                                   | 2 +-
 cpukit/rtems/src/taskrestart.c                              | 2 +-
 cpukit/rtems/src/taskresume.c                               | 2 +-
 cpukit/rtems/src/tasks.c                                    | 2 +-
 cpukit/rtems/src/taskself.c                                 | 2 +-
 cpukit/rtems/src/tasksetaffinity.c                          | 2 +-
 cpukit/rtems/src/tasksetpriority.c                          | 2 +-
 cpukit/rtems/src/tasksetscheduler.c                         | 4 ++--
 cpukit/rtems/src/taskstart.c                                | 2 +-
 cpukit/rtems/src/tasksuspend.c                              | 2 +-
 cpukit/rtems/src/taskwakeafter.c                            | 2 +-
 cpukit/rtems/src/taskwakewhen.c                             | 2 +-
 cpukit/rtems/src/timercancel.c                              | 2 +-
 cpukit/rtems/src/timercreate.c                              | 2 +-
 cpukit/rtems/src/timerdelete.c                              | 2 +-
 cpukit/rtems/src/timerfireafter.c                           | 2 +-
 cpukit/rtems/src/timerfirewhen.c                            | 2 +-
 cpukit/rtems/src/timergetinfo.c                             | 2 +-
 cpukit/rtems/src/timerident.c                               | 2 +-
 cpukit/rtems/src/timerreset.c                               | 2 +-
 cpukit/rtems/src/timerserver.c                              | 2 +-
 cpukit/rtems/src/timerserverfireafter.c                     | 2 +-
 cpukit/rtems/src/timerserverfirewhen.c                      | 2 +-
 cpukit/rtems/src/workspace.c                                | 2 +-
 cpukit/rtems/src/workspacegreedy.c                          | 4 ++--
 cpukit/sapi/src/chainappendnotify.c                         | 2 +-
 cpukit/sapi/src/chaingetnotify.c                            | 2 +-
 cpukit/sapi/src/chaingetwait.c                              | 2 +-
 cpukit/sapi/src/chainprependnotify.c                        | 2 +-
 cpukit/sapi/src/chainprotected.c                            | 4 ++--
 cpukit/sapi/src/delaynano.c                                 | 2 +-
 cpukit/sapi/src/delayticks.c                                | 2 +-
 cpukit/sapi/src/exinit.c                                    | 2 +-
 cpukit/sapi/src/exshutdown.c                                | 2 +-
 cpukit/sapi/src/extension.c                                 | 2 +-
 cpukit/sapi/src/extensioncreate.c                           | 2 +-
 cpukit/sapi/src/extensiondelete.c                           | 2 +-
 cpukit/sapi/src/extensionident.c                            | 2 +-
 cpukit/sapi/src/fatal.c                                     | 2 +-
 cpukit/sapi/src/fatalsrctext.c                              | 4 ++--
 cpukit/sapi/src/getversionstring.c                          | 2 +-
 cpukit/sapi/src/interrtext.c                                | 4 ++--
 cpukit/sapi/src/io.c                                        | 2 +-
 cpukit/sapi/src/ioclose.c                                   | 2 +-
 cpukit/sapi/src/iocontrol.c                                 | 2 +-
 cpukit/sapi/src/iodefault.c                                 | 2 +-
 cpukit/sapi/src/ioinitialize.c                              | 2 +-
 cpukit/sapi/src/ioopen.c                                    | 2 +-
 cpukit/sapi/src/ioread.c                                    | 2 +-
 cpukit/sapi/src/ioregisterdriver.c                          | 2 +-
 cpukit/sapi/src/iounregisterdriver.c                        | 2 +-
 cpukit/sapi/src/iowrite.c                                   | 2 +-
 cpukit/sapi/src/posixapi.c                                  | 2 +-
 cpukit/sapi/src/profilingiterate.c                          | 2 +-
 cpukit/sapi/src/profilingreportxml.c                        | 2 +-
 cpukit/sapi/src/rbheap.c                                    | 4 ++--
 cpukit/sapi/src/rbtree.c                                    | 2 +-
 cpukit/sapi/src/rbtreefind.c                                | 2 +-
 cpukit/sapi/src/sapirbtreeinsert.c                          | 2 +-
 cpukit/sapi/src/tcsimpleinstall.c                           | 4 ++--
 cpukit/sapi/src/version.c                                   | 2 +-
 cpukit/score/cpu/arm/__aeabi_read_tp.c                      | 2 +-
 cpukit/score/cpu/arm/__tls_get_addr.c                       | 2 +-
 cpukit/score/cpu/arm/arm-context-validate.S                 | 2 +-
 cpukit/score/cpu/arm/arm-context-volatile-clobber.S         | 2 +-
 cpukit/score/cpu/arm/arm-exception-default.c                | 2 +-
 cpukit/score/cpu/arm/arm-exception-frame-print.c            | 2 +-
 cpukit/score/cpu/arm/armv4-exception-default.S              | 2 +-
 cpukit/score/cpu/arm/armv7-thread-idle.c                    | 2 +-
 cpukit/score/cpu/arm/armv7m-context-initialize.c            | 2 +-
 cpukit/score/cpu/arm/armv7m-context-restore.c               | 2 +-
 cpukit/score/cpu/arm/armv7m-context-switch.c                | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-default.c             | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-handler-get.c         | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-handler-set.c         | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-priority-get.c        | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-priority-handler.c    | 2 +-
 cpukit/score/cpu/arm/armv7m-exception-priority-set.c        | 2 +-
 cpukit/score/cpu/arm/armv7m-isr-dispatch.c                  | 2 +-
 cpukit/score/cpu/arm/armv7m-isr-enter-leave.c               | 2 +-
 cpukit/score/cpu/arm/armv7m-isr-level-get.c                 | 2 +-
 cpukit/score/cpu/arm/armv7m-isr-level-set.c                 | 2 +-
 cpukit/score/cpu/arm/armv7m-isr-vector-install.c            | 2 +-
 cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c       | 2 +-
 cpukit/score/cpu/bfin/bfin-exception-frame-print.c          | 2 +-
 cpukit/score/cpu/epiphany/epiphany-context-initialize.c     | 2 +-
 cpukit/score/cpu/epiphany/epiphany-context-switch.S         | 2 +-
 cpukit/score/cpu/lm32/lm32-exception-frame-print.c          | 2 +-
 cpukit/score/cpu/m68k/__m68k_read_tp.c                      | 2 +-
 cpukit/score/cpu/m68k/m68k-exception-frame-print.c          | 2 +-
 cpukit/score/cpu/moxie/moxie-exception-frame-print.c        | 2 +-
 cpukit/score/cpu/nios2/nios2-context-initialize.c           | 2 +-
 cpukit/score/cpu/nios2/nios2-context-switch.S               | 2 +-
 cpukit/score/cpu/nios2/nios2-context-validate.S             | 2 +-
 cpukit/score/cpu/nios2/nios2-context-volatile-clobber.S     | 2 +-
 cpukit/score/cpu/nios2/nios2-exception-frame-print.c        | 2 +-
 cpukit/score/cpu/nios2/nios2-initialize.c                   | 2 +-
 cpukit/score/cpu/nios2/nios2-isr-get-level.c                | 2 +-
 cpukit/score/cpu/nios2/nios2-isr-install-vector.c           | 2 +-
 cpukit/score/cpu/nios2/nios2-isr-is-in-progress.c           | 2 +-
 cpukit/score/cpu/nios2/nios2-isr-set-level.c                | 2 +-
 cpukit/score/cpu/nios2/nios2-mpu-add-region.c               | 2 +-
 cpukit/score/cpu/nios2/nios2-mpu-configuration.c            | 2 +-
 cpukit/score/cpu/nios2/nios2-mpu-descriptor.c               | 2 +-
 cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c        | 2 +-
 cpukit/score/cpu/nios2/nios2-mpu-reset.c                    | 2 +-
 cpukit/score/cpu/nios2/nios2-thread-dispatch-disabled.c     | 2 +-
 cpukit/score/cpu/or1k/or1k-context-initialize.c             | 2 +-
 cpukit/score/cpu/or1k/or1k-context-switch.S                 | 2 +-
 cpukit/score/cpu/or1k/or1k-context-validate.S               | 2 +-
 cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S       | 2 +-
 cpukit/score/cpu/or1k/or1k-exception-default.c              | 2 +-
 cpukit/score/cpu/or1k/or1k-exception-frame-print.c          | 2 +-
 cpukit/score/cpu/powerpc/cpu.c                              | 2 +-
 cpukit/score/cpu/powerpc/ppc-context-validate.S             | 2 +-
 cpukit/score/cpu/powerpc/ppc-context-volatile-clobber.S     | 2 +-
 cpukit/score/cpu/powerpc/ppc-isr-disable-mask.S             | 2 +-
 cpukit/score/cpu/sh/sh-exception-frame-print.c              | 2 +-
 cpukit/score/cpu/sparc/sparc-context-validate.S             | 2 +-
 cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S     | 2 +-
 cpukit/score/cpu/sparc/sparc-counter-asm.S                  | 2 +-
 cpukit/score/cpu/sparc64/sparc64-exception-frame-print.c    | 2 +-
 cpukit/score/cpu/v850/v850-exception-frame-print.c          | 2 +-
 cpukit/score/src/allocatormutex.c                           | 2 +-
 cpukit/score/src/apimutexisowner.c                          | 2 +-
 cpukit/score/src/apimutexlock.c                             | 2 +-
 cpukit/score/src/apimutexunlock.c                           | 2 +-
 cpukit/score/src/chain.c                                    | 2 +-
 cpukit/score/src/chainnodecount.c                           | 4 ++--
 cpukit/score/src/condition.c                                | 4 ++--
 cpukit/score/src/configstackspacesize.c                     | 2 +-
 cpukit/score/src/corebarrier.c                              | 2 +-
 cpukit/score/src/corebarrierrelease.c                       | 2 +-
 cpukit/score/src/corebarrierwait.c                          | 2 +-
 cpukit/score/src/coremsg.c                                  | 2 +-
 cpukit/score/src/coremsgbroadcast.c                         | 2 +-
 cpukit/score/src/coremsgclose.c                             | 2 +-
 cpukit/score/src/coremsgflush.c                             | 2 +-
 cpukit/score/src/coremsgflushwait.c                         | 2 +-
 cpukit/score/src/coremsginsert.c                            | 2 +-
 cpukit/score/src/coremsgseize.c                             | 2 +-
 cpukit/score/src/coremsgsubmit.c                            | 2 +-
 cpukit/score/src/coremutexseize.c                           | 2 +-
 cpukit/score/src/corerwlock.c                               | 2 +-
 cpukit/score/src/corerwlockobtainread.c                     | 2 +-
 cpukit/score/src/corerwlockobtainwrite.c                    | 2 +-
 cpukit/score/src/corerwlockrelease.c                        | 2 +-
 cpukit/score/src/coresem.c                                  | 2 +-
 cpukit/score/src/coretod.c                                  | 2 +-
 cpukit/score/src/coretodadjust.c                            | 2 +-
 cpukit/score/src/coretodhookdata.c                          | 2 +-
 cpukit/score/src/coretodhookregister.c                      | 2 +-
 cpukit/score/src/coretodhookrun.c                           | 2 +-
 cpukit/score/src/coretodhookunregister.c                    | 2 +-
 cpukit/score/src/coretodset.c                               | 2 +-
 cpukit/score/src/coretodtickspersec.c                       | 2 +-
 cpukit/score/src/debugisthreaddispatchingallowed.c          | 4 ++--
 cpukit/score/src/freechain.c                                | 4 ++--
 cpukit/score/src/futex.c                                    | 4 ++--
 cpukit/score/src/heap.c                                     | 4 ++--
 cpukit/score/src/heapallocate.c                             | 2 +-
 cpukit/score/src/heapextend.c                               | 2 +-
 cpukit/score/src/heapfree.c                                 | 2 +-
 cpukit/score/src/heapgetfreeinfo.c                          | 2 +-
 cpukit/score/src/heapgetinfo.c                              | 2 +-
 cpukit/score/src/heapgreedy.c                               | 4 ++--
 cpukit/score/src/heapiterate.c                              | 4 ++--
 cpukit/score/src/heapnoextend.c                             | 4 ++--
 cpukit/score/src/heapresizeblock.c                          | 2 +-
 cpukit/score/src/heapsizeofuserarea.c                       | 2 +-
 cpukit/score/src/heapwalk.c                                 | 2 +-
 cpukit/score/src/interr.c                                   | 2 +-
 cpukit/score/src/ioprintf.c                                 | 2 +-
 cpukit/score/src/isr.c                                      | 2 +-
 cpukit/score/src/isrisinprogress.c                          | 4 ++--
 cpukit/score/src/iterateoverthreads.c                       | 2 +-
 cpukit/score/src/libatomic.c                                | 2 +-
 cpukit/score/src/log2table.c                                | 2 +-
 cpukit/score/src/memoryallocate.c                           | 2 +-
 cpukit/score/src/memorydirtyfreeareas.c                     | 2 +-
 cpukit/score/src/memoryfill.c                               | 2 +-
 cpukit/score/src/memoryzerobeforeuse.c                      | 2 +-
 cpukit/score/src/memoryzerofreeareas.c                      | 2 +-
 cpukit/score/src/mpci.c                                     | 2 +-
 cpukit/score/src/mpcidefault.c                              | 2 +-
 cpukit/score/src/mutex.c                                    | 4 ++--
 cpukit/score/src/objectactivecount.c                        | 4 ++--
 cpukit/score/src/objectallocate.c                           | 2 +-
 cpukit/score/src/objectallocatenone.c                       | 2 +-
 cpukit/score/src/objectallocatestatic.c                     | 2 +-
 cpukit/score/src/objectallocateunlimited.c                  | 2 +-
 cpukit/score/src/objectclose.c                              | 2 +-
 cpukit/score/src/objectextendinformation.c                  | 2 +-
 cpukit/score/src/objectfree.c                               | 2 +-
 cpukit/score/src/objectfreestatic.c                         | 2 +-
 cpukit/score/src/objectgetlocal.c                           | 2 +-
 cpukit/score/src/objectgetnext.c                            | 2 +-
 cpukit/score/src/objectgetnoprotection.c                    | 2 +-
 cpukit/score/src/objectidtoname.c                           | 2 +-
 cpukit/score/src/objectinitializeinformation.c              | 2 +-
 cpukit/score/src/objectmp.c                                 | 2 +-
 cpukit/score/src/objectnamespaceremove.c                    | 2 +-
 cpukit/score/src/objectnametoid.c                           | 2 +-
 cpukit/score/src/objectnametoidstring.c                     | 2 +-
 cpukit/score/src/objectshrinkinformation.c                  | 2 +-
 cpukit/score/src/percpu.c                                   | 2 +-
 cpukit/score/src/percpuasm.c                                | 4 ++--
 cpukit/score/src/percpustatewait.c                          | 4 ++--
 cpukit/score/src/pheapallocate.c                            | 2 +-
 cpukit/score/src/pheapextend.c                              | 2 +-
 cpukit/score/src/pheapfree.c                                | 2 +-
 cpukit/score/src/pheapgetblocksize.c                        | 2 +-
 cpukit/score/src/pheapgetfreeinfo.c                         | 2 +-
 cpukit/score/src/pheapgetinfo.c                             | 2 +-
 cpukit/score/src/pheapgetsize.c                             | 2 +-
 cpukit/score/src/pheapinit.c                                | 2 +-
 cpukit/score/src/pheapiterate.c                             | 4 ++--
 cpukit/score/src/pheapresizeblock.c                         | 2 +-
 cpukit/score/src/pheapwalk.c                                | 2 +-
 cpukit/score/src/processormaskcopy.c                        | 2 +-
 cpukit/score/src/profilingisrentryexit.c                    | 2 +-
 cpukit/score/src/profilingsmplock.c                         | 2 +-
 cpukit/score/src/rbtreeextract.c                            | 2 +-
 cpukit/score/src/rbtreeinsert.c                             | 2 +-
 cpukit/score/src/rbtreeiterate.c                            | 4 ++--
 cpukit/score/src/rbtreenext.c                               | 4 ++--
 cpukit/score/src/rbtreepostorder.c                          | 2 +-
 cpukit/score/src/rbtreereplace.c                            | 4 ++--
 cpukit/score/src/sched.c                                    | 4 ++--
 cpukit/score/src/scheduler.c                                | 2 +-
 cpukit/score/src/schedulercbs.c                             | 2 +-
 cpukit/score/src/schedulercbsattachthread.c                 | 2 +-
 cpukit/score/src/schedulercbscleanup.c                      | 2 +-
 cpukit/score/src/schedulercbscreateserver.c                 | 2 +-
 cpukit/score/src/schedulercbsdestroyserver.c                | 2 +-
 cpukit/score/src/schedulercbsdetachthread.c                 | 2 +-
 cpukit/score/src/schedulercbsgetapprovedbudget.c            | 2 +-
 cpukit/score/src/schedulercbsgetexecutiontime.c             | 2 +-
 cpukit/score/src/schedulercbsgetparameters.c                | 2 +-
 cpukit/score/src/schedulercbsgetremainingbudget.c           | 2 +-
 cpukit/score/src/schedulercbsgetserverid.c                  | 2 +-
 cpukit/score/src/schedulercbsnodeinit.c                     | 2 +-
 cpukit/score/src/schedulercbsreleasejob.c                   | 2 +-
 cpukit/score/src/schedulercbssetparameters.c                | 2 +-
 cpukit/score/src/schedulercbsunblock.c                      | 2 +-
 cpukit/score/src/schedulerdefaultaskforhelp.c               | 4 ++--
 cpukit/score/src/schedulerdefaultmappriority.c              | 2 +-
 cpukit/score/src/schedulerdefaultnodedestroy.c              | 2 +-
 cpukit/score/src/schedulerdefaultnodeinit.c                 | 2 +-
 cpukit/score/src/schedulerdefaultpinunpin.c                 | 2 +-
 cpukit/score/src/schedulerdefaultreleasejob.c               | 2 +-
 cpukit/score/src/schedulerdefaultschedule.c                 | 4 ++--
 cpukit/score/src/schedulerdefaultsetaffinity.c              | 4 ++--
 cpukit/score/src/schedulerdefaultstartidle.c                | 4 ++--
 cpukit/score/src/schedulerdefaulttick.c                     | 2 +-
 cpukit/score/src/scheduleredf.c                             | 2 +-
 cpukit/score/src/scheduleredfblock.c                        | 2 +-
 cpukit/score/src/scheduleredfchangepriority.c               | 2 +-
 cpukit/score/src/scheduleredfnodeinit.c                     | 2 +-
 cpukit/score/src/scheduleredfreleasejob.c                   | 2 +-
 cpukit/score/src/scheduleredfschedule.c                     | 2 +-
 cpukit/score/src/scheduleredfsmp.c                          | 4 ++--
 cpukit/score/src/scheduleredfunblock.c                      | 2 +-
 cpukit/score/src/scheduleredfyield.c                        | 2 +-
 cpukit/score/src/schedulergetaffinity.c                     | 4 ++--
 cpukit/score/src/schedulerpriority.c                        | 2 +-
 cpukit/score/src/schedulerpriorityaffinitysmp.c             | 4 ++--
 cpukit/score/src/schedulerpriorityblock.c                   | 2 +-
 cpukit/score/src/schedulerprioritychangepriority.c          | 2 +-
 cpukit/score/src/schedulerpriorityschedule.c                | 2 +-
 cpukit/score/src/schedulerprioritysmp.c                     | 4 ++--
 cpukit/score/src/schedulerpriorityunblock.c                 | 2 +-
 cpukit/score/src/schedulerpriorityyield.c                   | 2 +-
 cpukit/score/src/schedulersetaffinity.c                     | 4 ++--
 cpukit/score/src/schedulersimple.c                          | 2 +-
 cpukit/score/src/schedulersimpleblock.c                     | 2 +-
 cpukit/score/src/schedulersimplechangepriority.c            | 2 +-
 cpukit/score/src/schedulersimpleschedule.c                  | 2 +-
 cpukit/score/src/schedulersimplesmp.c                       | 4 ++--
 cpukit/score/src/schedulersimpleunblock.c                   | 2 +-
 cpukit/score/src/schedulersimpleyield.c                     | 2 +-
 cpukit/score/src/schedulersmp.c                             | 2 +-
 cpukit/score/src/schedulersmpstartidle.c                    | 4 ++--
 cpukit/score/src/schedulerstrongapa.c                       | 4 ++--
 cpukit/score/src/semaphore.c                                | 4 ++--
 cpukit/score/src/smp.c                                      | 2 +-
 cpukit/score/src/smpbarrierwait.c                           | 4 ++--
 cpukit/score/src/smplock.c                                  | 4 ++--
 cpukit/score/src/stackallocator.c                           | 2 +-
 cpukit/score/src/thread.c                                   | 2 +-
 cpukit/score/src/threadallocateunlimited.c                  | 2 +-
 cpukit/score/src/threadchangepriority.c                     | 2 +-
 cpukit/score/src/threadclearstate.c                         | 2 +-
 cpukit/score/src/threadcreateidle.c                         | 2 +-
 cpukit/score/src/threaddispatch.c                           | 2 +-
 cpukit/score/src/threadentryadaptoridle.c                   | 4 ++--
 cpukit/score/src/threadentryadaptornumeric.c                | 4 ++--
 cpukit/score/src/threadentryadaptorpointer.c                | 4 ++--
 cpukit/score/src/threadget.c                                | 2 +-
 cpukit/score/src/threadgetcputimeused.c                     | 2 +-
 cpukit/score/src/threadhandler.c                            | 2 +-
 cpukit/score/src/threadidledefault.c                        | 2 +-
 cpukit/score/src/threadinitialize.c                         | 2 +-
 cpukit/score/src/threaditerate.c                            | 2 +-
 cpukit/score/src/threadloadenv.c                            | 2 +-
 cpukit/score/src/threadmp.c                                 | 2 +-
 cpukit/score/src/threadname.c                               | 2 +-
 cpukit/score/src/threadq.c                                  | 2 +-
 cpukit/score/src/threadqenqueue.c                           | 2 +-
 cpukit/score/src/threadqextractwithproxy.c                  | 2 +-
 cpukit/score/src/threadqfirst.c                             | 2 +-
 cpukit/score/src/threadqflush.c                             | 2 +-
 cpukit/score/src/threadqops.c                               | 4 ++--
 cpukit/score/src/threadqtimeout.c                           | 2 +-
 cpukit/score/src/threadrestart.c                            | 2 +-
 cpukit/score/src/threadscheduler.c                          | 2 +-
 cpukit/score/src/threadsetstate.c                           | 2 +-
 cpukit/score/src/threadstackallocate.c                      | 2 +-
 cpukit/score/src/threadstackfree.c                          | 2 +-
 cpukit/score/src/threadstart.c                              | 2 +-
 cpukit/score/src/threadstartmultitasking.c                  | 2 +-
 cpukit/score/src/threadtimeout.c                            | 4 ++--
 cpukit/score/src/threadunpin.c                              | 2 +-
 cpukit/score/src/threadwaitgetid.c                          | 4 ++--
 cpukit/score/src/threadyield.c                              | 4 ++--
 cpukit/score/src/timespecaddto.c                            | 2 +-
 cpukit/score/src/timespecdivide.c                           | 2 +-
 cpukit/score/src/timespecdividebyinteger.c                  | 2 +-
 cpukit/score/src/timespecfromticks.c                        | 2 +-
 cpukit/score/src/timespecgetasnanoseconds.c                 | 2 +-
 cpukit/score/src/timespecisvalid.c                          | 2 +-
 cpukit/score/src/timespeclessthan.c                         | 2 +-
 cpukit/score/src/timespecsubtract.c                         | 2 +-
 cpukit/score/src/timespectoticks.c                          | 2 +-
 cpukit/score/src/tlsallocsize.c                             | 2 +-
 cpukit/score/src/userext.c                                  | 4 ++--
 cpukit/score/src/userextaddset.c                            | 2 +-
 cpukit/score/src/userextiterate.c                           | 4 ++--
 cpukit/score/src/userextremoveset.c                         | 2 +-
 cpukit/score/src/watchdoginsert.c                           | 2 +-
 cpukit/score/src/watchdogremove.c                           | 2 +-
 cpukit/score/src/watchdogtick.c                             | 2 +-
 cpukit/score/src/watchdogtickssinceboot.c                   | 2 +-
 cpukit/score/src/watchdogtimeslicedefault.c                 | 2 +-
 cpukit/score/src/wkspace.c                                  | 4 ++--
 cpukit/score/src/wkspaceisunifieddefault.c                  | 2 +-
 cpukit/score/src/wkstringduplicate.c                        | 4 ++--
 cpukit/telnetd/telnetd-init.c                               | 2 +-
 testsuites/fstests/fsbdpart01/init.c                        | 2 +-
 testsuites/fstests/fsdosfsformat01/init.c                   | 2 +-
 testsuites/fstests/fsdosfsname01/init.c                     | 2 +-
 testsuites/fstests/fsdosfssync01/init.c                     | 2 +-
 testsuites/fstests/fsdosfswrite01/init.c                    | 2 +-
 testsuites/fstests/fsfseeko01/init.c                        | 2 +-
 testsuites/fstests/fsimfsconfig01/init.c                    | 2 +-
 testsuites/fstests/fsimfsconfig02/init.c                    | 2 +-
 testsuites/fstests/fsimfsconfig03/init.c                    | 2 +-
 testsuites/fstests/fsjffs2gc01/init.c                       | 2 +-
 testsuites/fstests/fsnofs01/init.c                          | 2 +-
 testsuites/fstests/fsrename/test.c                          | 2 +-
 testsuites/fstests/fsrfsbitmap01/test.c                     | 2 +-
 testsuites/fstests/fsrofs01/init.c                          | 2 +-
 testsuites/libtests/block08/test_disk.c                     | 2 +-
 testsuites/libtests/block11/init.c                          | 2 +-
 testsuites/libtests/block12/init.c                          | 2 +-
 testsuites/libtests/block13/init.c                          | 2 +-
 testsuites/libtests/block14/init.c                          | 2 +-
 testsuites/libtests/block15/init.c                          | 2 +-
 testsuites/libtests/block16/init.c                          | 2 +-
 testsuites/libtests/block17/init.c                          | 2 +-
 testsuites/libtests/complex/docomplex.c                     | 2 +-
 testsuites/libtests/complex/docomplexf.c                    | 2 +-
 testsuites/libtests/complex/docomplexl.c                    | 2 +-
 testsuites/libtests/crypt01/init.c                          | 2 +-
 testsuites/libtests/debugger01/remote.c                     | 2 +-
 testsuites/libtests/defaultconfig01/init.c                  | 2 +-
 testsuites/libtests/dl01/init.c                             | 2 +-
 testsuites/libtests/dl02/init.c                             | 2 +-
 testsuites/libtests/dl03/dl-bit-alloc.c                     | 2 +-
 testsuites/libtests/dl03/dl-cache.c                         | 2 +-
 testsuites/libtests/dl03/init.c                             | 2 +-
 testsuites/libtests/dl04/dl-load.c                          | 2 +-
 testsuites/libtests/dl04/init.c                             | 2 +-
 testsuites/libtests/dl05/dl-load.c                          | 2 +-
 testsuites/libtests/dl05/init.c                             | 2 +-
 testsuites/libtests/dl06/initimpl.h                         | 2 +-
 testsuites/libtests/dl07/init.c                             | 2 +-
 testsuites/libtests/dl08/init.c                             | 2 +-
 testsuites/libtests/dl09/init.c                             | 2 +-
 testsuites/libtests/dl10/init.c                             | 2 +-
 testsuites/libtests/exit01/init.c                           | 2 +-
 testsuites/libtests/exit02/init.c                           | 2 +-
 testsuites/libtests/flashdisk01/init.c                      | 2 +-
 testsuites/libtests/getentropy01/init.c                     | 2 +-
 testsuites/libtests/i2c01/init.c                            | 2 +-
 testsuites/libtests/libfdt01/init.c                         | 2 +-
 testsuites/libtests/math/domath.c                           | 2 +-
 testsuites/libtests/mathf/domathf.c                         | 2 +-
 testsuites/libtests/mathl/domathl.c                         | 2 +-
 testsuites/libtests/md501/init.c                            | 2 +-
 testsuites/libtests/mghttpd01/init.c                        | 2 +-
 testsuites/libtests/newlib01/init.c                         | 2 +-
 testsuites/libtests/pwdgrp01/init.c                         | 2 +-
 testsuites/libtests/pwdgrp02/init.c                         | 2 +-
 testsuites/libtests/rbheap01/init.c                         | 2 +-
 testsuites/libtests/sha/init.c                              | 2 +-
 testsuites/libtests/shell01/init.c                          | 2 +-
 testsuites/libtests/sparsedisk01/init.c                     | 2 +-
 testsuites/libtests/spi01/init.c                            | 2 +-
 testsuites/libtests/syscall01/init.c                        | 2 +-
 testsuites/libtests/utf8proc01/init.c                       | 2 +-
 testsuites/psxtests/psxcleanup02/init.c                     | 2 +-
 testsuites/psxtests/psxcleanup02/main.c                     | 2 +-
 testsuites/psxtests/psxconfig01/init.c                      | 2 +-
 testsuites/psxtests/psxglobalcon01/init.cc                  | 2 +-
 testsuites/psxtests/psxglobalcon02/init.cc                  | 2 +-
 testsuites/psxtests/psxhdrs/netdb/endhostent.c              | 2 +-
 testsuites/psxtests/psxhdrs/netdb/endnetent.c               | 2 +-
 testsuites/psxtests/psxhdrs/netdb/endprotoent.c             | 2 +-
 testsuites/psxtests/psxhdrs/netdb/endservent.c              | 2 +-
 testsuites/psxtests/psxhdrs/netdb/freeaddrinfo.c            | 2 +-
 testsuites/psxtests/psxhdrs/netdb/gai_strerror.c            | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getaddrinfo.c             | 2 +-
 testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c           | 2 +-
 testsuites/psxtests/psxhdrs/netdb/gethostbyname.c           | 2 +-
 testsuites/psxtests/psxhdrs/netdb/gethostent.c              | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getnameinfo.c             | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getnetbyaddr.c            | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getnetbyname.c            | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getnetent.c               | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getprotobyname.c          | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getprotobynumber.c        | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getprotoent.c             | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getservbyname.c           | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getservbyport.c           | 2 +-
 testsuites/psxtests/psxhdrs/netdb/getservent.c              | 2 +-
 testsuites/psxtests/psxhdrs/netdb/h_errno.c                 | 2 +-
 testsuites/psxtests/psxhdrs/netdb/sethostent.c              | 2 +-
 testsuites/psxtests/psxhdrs/netdb/setnetent.c               | 2 +-
 testsuites/psxtests/psxhdrs/netdb/setprotoent.c             | 2 +-
 testsuites/psxtests/psxhdrs/netdb/setservent.c              | 2 +-
 testsuites/psxtests/psxhdrs/string/memccpy.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/memchr.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/memcmp.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/memcpy.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/memmove.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/memset.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/stpcpy.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/stpncpy.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strcat.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strchr.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strcmp.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strcoll.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strcoll_l.c              | 2 +-
 testsuites/psxtests/psxhdrs/string/strcpy.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strcspn.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strdup.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strerror.c               | 2 +-
 testsuites/psxtests/psxhdrs/string/strerror_l.c             | 2 +-
 testsuites/psxtests/psxhdrs/string/strerror_r.c             | 2 +-
 testsuites/psxtests/psxhdrs/string/strlen.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strncat.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strncmp.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strncpy.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strndup.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strnlen.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strpbrk.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strrchr.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strsignal.c              | 2 +-
 testsuites/psxtests/psxhdrs/string/strspn.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strstr.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strtok.c                 | 2 +-
 testsuites/psxtests/psxhdrs/string/strtok_r.c               | 2 +-
 testsuites/psxtests/psxhdrs/string/strxfrm.c                | 2 +-
 testsuites/psxtests/psxhdrs/string/strxfrm_l.c              | 2 +-
 testsuites/psxtests/psxhdrs/utime/utime.c                   | 2 +-
 testsuites/smptests/smpatomic01/init.c                      | 2 +-
 testsuites/smptests/smpcache01/init.c                       | 2 +-
 testsuites/smptests/smpcapture01/init.c                     | 2 +-
 testsuites/smptests/smpclock01/init.c                       | 2 +-
 testsuites/smptests/smpfatal01/init.c                       | 2 +-
 testsuites/smptests/smpfatal02/init.c                       | 2 +-
 testsuites/smptests/smpfatal04/init.c                       | 2 +-
 testsuites/smptests/smpfatal05/init.c                       | 2 +-
 testsuites/smptests/smpfatal06/init.c                       | 2 +-
 testsuites/smptests/smpfatal08/init.c                       | 2 +-
 testsuites/smptests/smpipi01/init.c                         | 2 +-
 testsuites/smptests/smpload01/init.c                        | 2 +-
 testsuites/smptests/smplock01/init.c                        | 2 +-
 testsuites/smptests/smpmigration01/init.c                   | 2 +-
 testsuites/smptests/smpmigration02/init.c                   | 2 +-
 testsuites/smptests/smpmrsp01/init.c                        | 2 +-
 testsuites/smptests/smpmutex01/init.c                       | 2 +-
 testsuites/smptests/smpmutex02/init.c                       | 2 +-
 testsuites/smptests/smppsxmutex01/init.c                    | 2 +-
 testsuites/smptests/smppsxsignal01/init.c                   | 2 +-
 testsuites/smptests/smpschedaffinity01/init.c               | 2 +-
 testsuites/smptests/smpschedaffinity02/init.c               | 2 +-
 testsuites/smptests/smpschedaffinity03/init.c               | 2 +-
 testsuites/smptests/smpschedaffinity04/init.c               | 2 +-
 testsuites/smptests/smpschedaffinity05/init.c               | 2 +-
 testsuites/smptests/smpschededf04/init.c                    | 2 +-
 testsuites/smptests/smpschedsem01/init.c                    | 2 +-
 testsuites/smptests/smpscheduler01/init.c                   | 2 +-
 testsuites/smptests/smpscheduler02/init.c                   | 2 +-
 testsuites/smptests/smpscheduler04/init.c                   | 2 +-
 testsuites/smptests/smpsignal01/init.c                      | 2 +-
 testsuites/smptests/smpstrongapa01/init.c                   | 2 +-
 testsuites/smptests/smpswitchextension01/init.c             | 2 +-
 testsuites/smptests/smpthreadlife01/init.c                  | 2 +-
 testsuites/smptests/smpunsupported01/init.c                 | 2 +-
 testsuites/smptests/smpwakeafter01/init.c                   | 2 +-
 testsuites/sptests/spatomic01/init.c                        | 2 +-
 testsuites/sptests/spcache01/init.c                         | 2 +-
 testsuites/sptests/spcontext01/init.c                       | 2 +-
 testsuites/sptests/spcpucounter01/init.c                    | 2 +-
 testsuites/sptests/spcpuset01/test.c                        | 2 +-
 testsuites/sptests/speventsystem01/init.c                   | 2 +-
 testsuites/sptests/speventtransient01/init.c                | 2 +-
 testsuites/sptests/spextensions01/init.c                    | 2 +-
 testsuites/sptests/spfatal26/init.c                         | 2 +-
 testsuites/sptests/spglobalcon01/init.cc                    | 2 +-
 testsuites/sptests/spinternalerror01/init.c                 | 2 +-
 testsuites/sptests/spinternalerror02/init.c                 | 2 +-
 testsuites/sptests/spintrcritical10/init.c                  | 2 +-
 testsuites/sptests/spintrcritical18/init.c                  | 2 +-
 testsuites/sptests/spintrcritical20/init.c                  | 2 +-
 testsuites/sptests/spintrcritical22/init.c                  | 2 +-
 testsuites/sptests/spintrcritical23/init.c                  | 2 +-
 testsuites/sptests/splinkersets01/init.c                    | 2 +-
 testsuites/sptests/splinkersets01/items.c                   | 2 +-
 testsuites/sptests/splinkersets01/sets.c                    | 2 +-
 testsuites/sptests/spmrsp01/init.c                          | 2 +-
 testsuites/sptests/spmutex01/init.c                         | 2 +-
 testsuites/sptests/spprofiling01/init.c                     | 2 +-
 testsuites/sptests/spsem03/init.c                           | 2 +-
 testsuites/sptests/spstdthreads01/init.c                    | 2 +-
 testsuites/sptests/spstkalloc02/init.c                      | 2 +-
 testsuites/sptests/spsysinit01/init.c                       | 2 +-
 testsuites/sptests/spsyslock01/init.c                       | 2 +-
 testsuites/sptests/sptasknopreempt01/init.c                 | 2 +-
 testsuites/sptests/spthreadlife01/init.c                    | 2 +-
 testsuites/sptests/sptimecounter01/init.c                   | 2 +-
 testsuites/sptests/sptimecounter02/init.c                   | 2 +-
 testsuites/sptests/sptimecounter03/init.c                   | 2 +-
 testsuites/sptests/sptimecounter04/init.c                   | 2 +-
 testsuites/sptests/sptimerserver01/init.c                   | 2 +-
 testsuites/sptests/sptls01/init.c                           | 2 +-
 testsuites/sptests/sptls03/init.c                           | 2 +-
 testsuites/tmtests/tmcontext01/init.c                       | 2 +-
 testsuites/tmtests/tmfine01/init.c                          | 2 +-
 testsuites/tmtests/tmtimer01/init.c                         | 2 +-
 1324 files changed, 1520 insertions(+), 1520 deletions(-)
diff --git a/cpukit/dev/i2c/eeprom.c b/cpukit/dev/i2c/eeprom.c
index 97e0f55684..4dc1a1abf9 100644
--- a/cpukit/dev/i2c/eeprom.c
+++ b/cpukit/dev/i2c/eeprom.c
@@ -20,8 +20,8 @@
  * http://www.rtems.org/license/LICENSE.
-#if HAVE_CONFIG_H
-  #include "config.h"
+#ifdef HAVE_CONFIG_H
+#include "config.h"
 #endif
 #include <dev/i2c/eeprom.h>
[ lots of other changes like this, omitted here to avoid a mailing list
file size limit ]
