[PATCH 1/3] user: Update migration guide
Wed Apr 15 13:52:14 UTC 2020
On Tue, Apr 14, 2020 at 9:13 AM Sebastian Huber
> Update #3895.
>  user/migration/v4_11-to-v5.rst | 54 ++++++++++++++++++++++++++++++++----------
>  1 file changed, 42 insertions(+), 12 deletions(-)
> diff --git a/user/migration/v4_11-to-v5.rst b/user/migration/v4_11-to-v5.rst
> index 4329771..2917951 100644
> --- a/user/migration/v4_11-to-v5.rst
> +++ b/user/migration/v4_11-to-v5.rst
> @@ -1,6 +1,7 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
>  .. Copyright (C) 2020 Chris Johns
> +.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>  .. _Migration_4_11_to_5:
> @@ -10,33 +11,62 @@ RTEMS 4.11 to RTEMS 5
>  This section provides helpful information when migrating from RTEMS 4.11 to
>  RTEMS 5.
> -Configuration
> +Application Configuration Options
> +The evaluation of application configuration options in ``<rtems/confdefs.h>``
> +was reworked during the RTEMS 5 development cycle.  All options which let the
> +user define data structures were removed, this includes
> +* ``CONFIGURE_HAS_OWN_CONFIGURATION_TABLE``,
> +* ``CONFIGURE_HAS_OWN_BDBUF_TABLE``,
> +* ``CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE``,
> +* ``CONFIGURE_HAS_OWN_FILESYSTEM_TABLE``,
> +* ``CONFIGURE_HAS_OWN_INIT_TABLE``,
> -A number of configurations macros have moved as a result of internal changes in
> -RTEMS. Some of these will produce a warning indicating the new configuration
> -setings you need to define. If you need to run an application on RTEMS 4.11 and
> -RTEMS 5 the following code exmaple shows how to conditionally define the
> -settings. The example is:
> +* ``CONFIGURE_HAS_OWN_MOUNT_TABLE``,
> +* ``CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE``, and
> +* ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE``.
> +The configuration of SMP schedulers changed.  Please read the corresponding
> +chapter in the RTEMS Classic API Guide.
I guess inter-doc refs don't work, but maybe the chapter name should
be mentioned here?
> +A number of configurations options have moved or are obsolete as a result of
> +internal changes in RTEMS.  Some of these will produce a warning indicating the
> +new configuration setings you need to define. If you need to run an application
s/setings/settings
Not introduced by your change, but still should fix.
> +on RTEMS 4.11 and RTEMS 5 the following code exmaple shows how to conditionally
s/exmaple/example
Also not your typo.
> +define the settings. The example is:
>  .. code-block:: c
>      #include <rtems.h>
>      #if __RTEMS_MAJOR__ < 5
> -     #define CONFIGURE_MAXIMUM_FIFOS 10
> -     #define CONFIGURE_MAXIMUM_PIPES 10
> +      #define CONFIGURE_MAXIMUM_FIFOS 10
> +      #define CONFIGURE_MAXIMUM_PIPES 10
>      #else
> -     #define CONFIGURE_IMFS_ENABLE_MKFIFO
> +      #define CONFIGURE_IMFS_ENABLE_MKFIFO
>      #endif
>      #define MAX_FILE_DESCRIPTORS 200
> -     #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS MAX_FILE_DESCRIPTORS
> +      #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS MAX_FILE_DESCRIPTORS
>      #else
> -     #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS       MAX_FILE_DESCRIPTORS
> +      #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS       MAX_FILE_DESCRIPTORS
>      #endif
> +Clock Manager
> +The directive :c:func:`rtems_clock_get` was removed.  See the RTEMS Classic API
> +Guide for alternatives.
Again, providing further direction would help.
>  Networking
> 2.16.4
> devel mailing list
> devel at rtems.org
