[PATCH v2] Test for clock_nanosleep with CLOCK_MONOTONIC option.
Joel Sherrill
joel at rtems.org
Wed Apr 15 14:16:09 UTC 2020
On Wed, Apr 15, 2020 at 9:11 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Apr 14, 2020 at 10:56 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello Utkarsh Rai,
> > do we really need a new test program for this test case? I would prefer
> > add it to an existing test program or add a generic POSIX test program
> > using the RTEMS Test Framework.
> I would also recommend this, or perhaps develop a test for clock
> monotonic that encompasses several features (as done with clock
> realtime).
In theory, the clock monotonic test could be the clock realtime one reused
with the clock type changed. There are a few cases of doing something
similar.
The behavior is supposed to be the same for delays.
Missing in this discussion and maybe what Gedare is hinting at is that you
any sleep/delay/etc type of operation is never specified as a precise delay,
it is a minimum delay. The minimum may be set by clock tick time quantum,
other threads, processes, etc. The POSIX standard has precise language
about this for clock_nanosleep. From
https://pubs.opengroup.org/onlinepubs/9699919799/functions/clock_nanosleep.html
"The suspension time caused by this function may be longer than requested
because the argument value is rounded up to an integer multiple of the
sleep resolution, or because of the scheduling of other activity by the
system."
--joel
> > On 14/04/2020 19:17, Utkarsh Rai wrote:
> > > This test checks for a simple 1 ns delay with clock_nanosleep with
> > > CLOCK_MONOTONIC.
> > > testsuites/psxtests/Makefile.am | 9 +++
> > > testsuites/psxtests/configure.ac | 1 +
> > > .../psxtests/psxclocknanosleep01/init.c | 81
> > > .../psxclocknanosleep01.doc | 10 +++
> > > .../psxclocknanosleep01.scn | 3 +
> > > 5 files changed, 104 insertions(+)
> > > create mode 100644 testsuites/psxtests/psxclocknanosleep01/init.c
> > > create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.doc
> > > create mode 100644
> testsuites/psxtests/psxclocknanosleep01/psxclocknanosleep01.scn
> > > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > > index 1f9e4233ec..e3918ae7a5 100755
> > > --- a/testsuites/psxtests/Makefile.am
> > > +++ b/testsuites/psxtests/Makefile.am
> > > @@ -321,6 +321,15 @@ psxclockrealtime01_CPPFLAGS = $(AM_CPPFLAGS) \
> > > $(TEST_FLAGS_psxclockrealtime01) $(support_includes)
> > > endif
> > > +if TEST_psxclocknanosleep01
> > > +psx_tests += psxclocknanosleep01
> > > +psx_screens += psxclocknanosleep01/psxclocknanosleep01.scn
> > > +psx_docs += psxclocknanosleep01/psxclocknanosleep01.doc
> > > +psxclocknanosleep01_SOURCES = psxclocknanosleep01/init.c
> > > +psxclocknanosleep01_CPPFLAGS = $(AM_CPPFLAGS) \
> > > + $(TEST_FLAGS_psxclocknanosleep01) $(support_includes)
> > > +endif
> > > if TEST_psxconcurrency01
> > > psx_tests += psxconcurrency01
> > > psx_screens += psxconcurrency01/psxconcurrency01.scn
> > > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > > index 139787cccb..9bfe8e2c0b 100644
> > > --- a/testsuites/psxtests/configure.ac
> > > +++ b/testsuites/psxtests/configure.ac
> > > @@ -75,6 +75,7 @@ RTEMS_TEST_CHECK([psxcleanup01])
> > > RTEMS_TEST_CHECK([psxcleanup02])
> > > RTEMS_TEST_CHECK([psxclock])
> > > RTEMS_TEST_CHECK([psxclock01])
> > > +RTEMS_TEST_CHECK([psxclocknanosleep01])
> > > RTEMS_TEST_CHECK([psxclockrealtime01])
> > > RTEMS_TEST_CHECK([psxconcurrency01])
> > > RTEMS_TEST_CHECK([psxcond01])
> > > diff --git a/testsuites/psxtests/psxclocknanosleep01/init.c
> b/testsuites/psxtests/psxclocknanosleep01/init.c
> > > new file mode 100644
> > > index 0000000000..21b738627d
> > > --- /dev/null
> > > +++ b/testsuites/psxtests/psxclocknanosleep01/init.c
> > > @@ -0,0 +1,81 @@
> > > + * SPDX-License-Identifier: BSD-2-Clause
> > > + * Copyright (C) 2020 Utkarsh Rai
> > > + * Redistribution and use in source and binary forms, with or without
> > > + * modification, are permitted provided that the following conditions
> > > + * are met:
> > > + * 1. Redistributions of source code must retain the above copyright
> > > + * notice, this list of conditions and the following disclaimer.
> > > + * 2. Redistributions in binary form must reproduce the above
> copyright
> > > + * notice, this list of conditions and the following disclaimer in
> the
> > > + * documentation and/or other materials provided with the
> distribution.
> > > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> > > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> OF
> > > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> > > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> > > + * POSSIBILITY OF SUCH DAMAGE.
> > > +#include <rtems.h>
> > > +#include <rtems/test.h>
> > > +#include <time.h>
> > > +#include <tmacros.h>
> > > +/*Forward declaration to avoid compiler warning*/
> > > +void clock_sleep(void);
> > Please use a static function instead. Most of these forward declarations
> > are just lazy warning fixes and bad examples.
> > > +rtems_task Init(rtems_task_argument ignored);
> > > +const char rtems_test_name[] = "PSXCLOCKNANOSLEEP 01";
> > > + struct timespec delay_time;
> > > + int status;
> > > + delay_time.tv_sec = 0;
> > > + delay_time.tv_nsec = 1;
> > > + status=clock_nanosleep( CLOCK_MONOTONIC, 0, &delay_time, (struct
> timespec* )NULL );
> > In C code this cast is superfluous, in C++ code using NULL is out dated.
> > > + rtems_test_assert( status == 0 );
> > > + struct timespec init_time;
> > > + struct timespec end_time;
> > > + int status;
> > > + TEST_BEGIN();
> > > + status = clock_gettime( CLOCK_MONOTONIC, &init_time );
> > > + clock_sleep();
> > > + status = clock_gettime( CLOCK_MONOTONIC, &end_time );
> > > + rtems_test_assert( (end_time.tv_sec-init_time.tv_sec) == 0 );
> > Is end_time.tv_sec - init_time.tv_sec == 0 under all circumstances?
> > The test case code should be separated from the test suite boilerplate
> code.
> > > + rtems_test_assert( (end_time.tv_nsec-init_time.tv_nsec) >=1 );
> > We really should think about using a C code formatter. I think that I
> > waste my time telling someone to put spaces between operators.
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200415/a9ec4737/attachment.html>
