[PATCH 1/3] user: Update migration guide
Wed Apr 15 14:29:09 UTC 2020
On Wed, Apr 15, 2020 at 7:56 AM Sebastian Huber
> On 15/04/2020 15:52, Gedare Bloom wrote:
> +The configuration of SMP schedulers changed.  Please read the corresponding
> +chapter in the RTEMS Classic API Guide.
> I guess inter-doc refs don't work, but maybe the chapter name should
> be mentioned here?
> Ok, I will fix this here.
> In the long run we need a better solution for references in our documentation set.
> We have to make it also easier for others to reference our documentation. What I have in mind this is a bibtex entry in one of the front pages which someone can simply copy and paste into its bibtex data base.
Yes, having some suggested citable sources would be helpful for many
reasons. We should consider if it is possible to "publish" our release
manuals some way that makes them more easily citable.
