[PATCH rtems-libbsd v2 06/14] regulator: Import from FreeBSD.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Apr 17 06:17:11 UTC 2020
Hello Jan,
On 16/04/2020 22:27, Jan.Sommer at dlr.de wrote:
> I have a question:
> I just rebased my working tree for the i386 target to the current 5-freebsd-12 branch.
> The compilation now fails in regulator related files.
> It seems that I am missing the FDT define and that comments out some includes.
> Could you tell me what FDT means in this context and do you know where I can activate it?
FDT is a flattened device tree. That's something that isn't used on
i386. So most likely quite some more BSPs will have that problem.
It's some code that I took over quite unchanged from FreeBSD. I would
have expected that it is used in FreeBSD for a lot of different cases
and therefore didn't expect a problem like that. I'll have a look at it.
Best regards
Christian
> Cheers,
>    Jan
>> -----Ursprüngliche Nachricht-----
>> Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von Christian
>> Mauderer
>> Gesendet: Dienstag, 14. April 2020 16:51
>> An: devel at rtems.org
>> Betreff: [PATCH rtems-libbsd v2 06/14] regulator: Import from FreeBSD.
>> Update #3869.
>>  freebsd/sys/dev/extres/regulator/regulator.c       | 1321
>>  freebsd/sys/dev/extres/regulator/regulator.h       |  156 +++
>>  freebsd/sys/dev/extres/regulator/regulator_bus.c   |   89 ++
>>  freebsd/sys/dev/extres/regulator/regulator_fixed.c |  502 ++++++++
>>  freebsd/sys/dev/extres/regulator/regulator_fixed.h |   44 +
>>  freebsd/sys/dev/gpio/gpioregulator.c               |  350 ++++++
>>  6 files changed, 2462 insertions(+)
>>  create mode 100644 freebsd/sys/dev/extres/regulator/regulator.c
>>  create mode 100644 freebsd/sys/dev/extres/regulator/regulator.h
>>  create mode 100644 freebsd/sys/dev/extres/regulator/regulator_bus.c
>>  create mode 100644 freebsd/sys/dev/extres/regulator/regulator_fixed.c
>>  create mode 100644 freebsd/sys/dev/extres/regulator/regulator_fixed.h
>>  create mode 100644 freebsd/sys/dev/gpio/gpioregulator.c
>> diff --git a/freebsd/sys/dev/extres/regulator/regulator.c
>> b/freebsd/sys/dev/extres/regulator/regulator.c
>> new file mode 100644
>> index 00000000..4ad6e94a
>> --- /dev/null
>> +++ b/freebsd/sys/dev/extres/regulator/regulator.c
>> @@ -0,0 +1,1321 @@
>> +#include <machine/rtems-bsd-kernel-space.h>
>> + * Copyright 2016 Michal Meloun <mmel at FreeBSD.org>
>> + * All rights reserved.
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS
>> IS'' AND
>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>> PARTICULAR PURPOSE
>> + * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS
>> BE LIABLE
>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> CONSEQUENTIAL
>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> SUBSTITUTE GOODS
>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> INTERRUPTION)
>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> CONTRACT, STRICT
>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
>> IN ANY WAY
>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#include <sys/cdefs.h>
>> +__FBSDID("$FreeBSD$");
>> +#include <rtems/bsd/local/opt_platform.h>
>> +#include <sys/param.h>
>> +#include <sys/conf.h>
>> +#include <sys/bus.h>
>> +#include <sys/kernel.h>
>> +#include <sys/queue.h>
>> +#include <sys/kobj.h>
>> +#include <sys/malloc.h>
>> +#include <sys/mutex.h>
>> +#include <sys/limits.h>
>> +#include <sys/lock.h>
>> +#include <sys/sysctl.h>
>> +#include <sys/systm.h>
>> +#include <sys/sx.h>
>> +#ifdef FDT
>> +#include <dev/fdt/fdt_common.h>
>> +#include <dev/ofw/ofw_bus.h>
>> +#include <dev/ofw/ofw_bus_subr.h>
>> +#endif
>> +#include <dev/extres/regulator/regulator.h>
>> +#include <rtems/bsd/local/regdev_if.h>
>> +SYSCTL_NODE(_hw, OID_AUTO, regulator, CTLFLAG_RD, NULL,
>> "Regulators");
>> +MALLOC_DEFINE(M_REGULATOR, "regulator", "Regulator framework");
>> +#define	DIV_ROUND_UP(n,d) howmany(n, d)
>> +/* Forward declarations. */
>> +struct regulator;
>> +struct regnode;
>> +typedef TAILQ_HEAD(regnode_list, regnode) regnode_list_t;
>> +typedef TAILQ_HEAD(regulator_list, regulator) regulator_list_t;
>> +/* Default regulator methods. */
>> +static int regnode_method_init(struct regnode *regnode);
>> +static int regnode_method_enable(struct regnode *regnode, bool enable,
>> +    int *udelay);
>> +static int regnode_method_status(struct regnode *regnode, int *status);
>> +static int regnode_method_set_voltage(struct regnode *regnode, int
>> min_uvolt,
>> +    int max_uvolt, int *udelay);
>> +static int regnode_method_get_voltage(struct regnode *regnode, int
>> *uvolt);
>> +static void regulator_constraint(void *dummy);
>> +static void regulator_shutdown(void *dummy);
>> + * Regulator controller methods.
>> +static regnode_method_t regnode_methods[] = {
>> +	REGNODEMETHOD(regnode_init,
>> 	regnode_method_init),
>> +	REGNODEMETHOD(regnode_enable,
>> 	regnode_method_enable),
>> +	REGNODEMETHOD(regnode_status,
>> 	regnode_method_status),
>> +	REGNODEMETHOD(regnode_set_voltage,
>> 	regnode_method_set_voltage),
>> +	REGNODEMETHOD(regnode_get_voltage,
>> 	regnode_method_get_voltage),
>> +	REGNODEMETHOD(regnode_check_voltage,
>> 	regnode_method_check_voltage),
>> +	REGNODEMETHOD_END
>> +DEFINE_CLASS_0(regnode, regnode_class, regnode_methods, 0);
>> + * Regulator node - basic element for modelling SOC and bard power supply
>> + * chains. Its contains producer data.
>> +struct regnode {
>> +	KOBJ_FIELDS;
>> +	TAILQ_ENTRY(regnode)	reglist_link;	/* Global list entry */
>> +	regulator_list_t	consumers_list;	/* Consumers list */
>> +	/* Cache for already resolved names */
>> +	struct regnode		*parent;	/* Resolved parent */
>> +	/* Details of this device. */
>> +	const char		*name;		/* Globally unique
>> name */
>> +	const char		*parent_name;	/* Parent name */
>> +	device_t		pdev;		/* Producer device_t */
>> +	void			*softc;		/* Producer softc */
>> +	intptr_t		id;		/* Per producer unique id */
>> +#ifdef FDT
>> +	 phandle_t 		ofw_node;	/* OFW node of regulator */
>> +#endif
>> +	int			flags;		/* REGULATOR_FLAGS_ */
>> +	struct sx		lock;		/* Lock for this regulator */
>> +	int			ref_cnt;	/* Reference counter */
>> +	int			enable_cnt;	/* Enabled counter */
>> +	struct regnode_std_param std_param;	/* Standard
>> parameters */
>> +	struct sysctl_ctx_list	sysctl_ctx;
>> + * Per consumer data, information about how a consumer is using a
>> regulator
>> + * node.
>> + * A pointer to this structure is used as a handle in the consumer interface.
>> +struct regulator {
>> +	device_t		cdev;		/* Consumer device */
>> +	struct regnode		*regnode;
>> +	TAILQ_ENTRY(regulator)	link;		/* Consumers list
>> entry */
>> +	int			enable_cnt;
>> +	int 			min_uvolt;	/* Requested uvolt range */
>> +	int 			max_uvolt;
>> + * Regulator names must be system wide unique.
>> +static regnode_list_t regnode_list =
>> TAILQ_HEAD_INITIALIZER(regnode_list);
>> +static struct sx		regnode_topo_lock;
>> +SX_SYSINIT(regulator_topology, &regnode_topo_lock, "Regulator topology
>> lock");
>> +#define REG_TOPO_SLOCK()	sx_slock(&regnode_topo_lock)
>> +#define REG_TOPO_XLOCK()	sx_xlock(&regnode_topo_lock)
>> +#define REG_TOPO_UNLOCK()	sx_unlock(&regnode_topo_lock)
>> +#define REG_TOPO_ASSERT()	sx_assert(&regnode_topo_lock,
>> SA_LOCKED)
>> +#define REG_TOPO_XASSERT() 	sx_assert(&regnode_topo_lock,
>> SA_XLOCKED)
>> +#define REGNODE_SLOCK(_sc)	sx_slock(&((_sc)->lock))
>> +#define REGNODE_XLOCK(_sc)	sx_xlock(&((_sc)->lock))
>> +#define REGNODE_UNLOCK(_sc)	sx_unlock(&((_sc)->lock))
>> +SYSINIT(regulator_constraint, SI_SUB_LAST, SI_ORDER_ANY,
>> +    NULL);
>> +SYSINIT(regulator_shutdown, SI_SUB_LAST, SI_ORDER_ANY,
>> regulator_shutdown,
>> +    NULL);
>> +static void
>> +regulator_constraint(void *dummy)
>> +	struct regnode *entry;
>> +	int rv;
>> +	REG_TOPO_SLOCK();
>> +	TAILQ_FOREACH(entry, &regnode_list, reglist_link) {
>> +		rv = regnode_set_constraint(entry);
>> +		if (rv != 0 && bootverbose)
>> +			printf("regulator: setting constraint on %s failed
>> (%d)\n",
>> +			    entry->name, rv);
>> +	REG_TOPO_UNLOCK();
>> + * Disable unused regulator
>> + * We run this function at SI_SUB_LAST which mean that every driver that
>> needs
>> + * regulator should have already enable them.
>> + * All the remaining regulators should be those left enabled by the
>> bootloader
>> + * or enable by default by the PMIC.
>> +static void
>> +regulator_shutdown(void *dummy)
>> +	int status, ret;
>> +	int disable = 1;
>> +	TUNABLE_INT_FETCH("hw.regulator.disable_unused", &disable);
>> +	if (!disable)
>> +		return;
>> +	REG_TOPO_SLOCK();
>> +	if (bootverbose)
>> +		printf("regulator: shutting down unused regulators\n");
>> +		if (!entry->std_param.always_on) {
>> +			ret = regnode_status(entry, &status);
>> +			if (ret == 0 && status ==
>> REGULATOR_STATUS_ENABLED) {
>> +				if (bootverbose)
>> +					printf("regulator: shutting down %s...
>> +					    entry->name);
>> +				ret = regnode_stop(entry, 0);
>> +				if (bootverbose) {
>> +					 * Call out busy in particular, here,
>> +					 * because it's not unexpected to fail
>> +					 * shutdown if the regulator is simply
>> +					 * in-use.
>> +					if (ret == EBUSY)
>> +						printf("busy\n");
>> +					else if (ret != 0)
>> +						printf("error (%d)\n", ret);
>> +					else
>> +						printf("ok\n");
>> + * sysctl handler
>> +static int
>> +regnode_uvolt_sysctl(SYSCTL_HANDLER_ARGS)
>> +	struct regnode *regnode = arg1;
>> +	int rv, uvolt;
>> +	if (regnode->std_param.min_uvolt == regnode-
>>> std_param.max_uvolt) {
>> +		uvolt = regnode->std_param.min_uvolt;
>> +	} else {
>> +		REG_TOPO_SLOCK();
>> +		if ((rv = regnode_get_voltage(regnode, &uvolt)) != 0) {
>> +			return (rv);
>> +	return sysctl_handle_int(oidp, &uvolt, sizeof(uvolt), req);
>> + * Default regulator methods for base class.
>> +static int
>> +regnode_method_init(struct regnode *regnode)
>> +	return (0);
>> +static int
>> +regnode_method_enable(struct regnode *regnode, bool enable, int
>> *udelay)
>> +	if (!enable)
>> +		return (ENXIO);
>> +	*udelay = 0;
>> +	return (0);
>> +static int
>> +regnode_method_status(struct regnode *regnode, int *status)
>> +	*status = REGULATOR_STATUS_ENABLED;
>> +	return (0);
>> +static int
>> +regnode_method_set_voltage(struct regnode *regnode, int min_uvolt, int
>> max_uvolt,
>> +    int *udelay)
>> +	if ((min_uvolt > regnode->std_param.max_uvolt) ||
>> +	    (max_uvolt < regnode->std_param.min_uvolt))
>> +		return (ERANGE);
>> +	*udelay = 0;
>> +	return (0);
>> +static int
>> +regnode_method_get_voltage(struct regnode *regnode, int *uvolt)
>> +	return (regnode->std_param.min_uvolt +
>> +	    (regnode->std_param.max_uvolt - regnode-
>>> std_param.min_uvolt) / 2);
>> +int
>> +regnode_method_check_voltage(struct regnode *regnode, int uvolt)
>> +	if ((uvolt > regnode->std_param.max_uvolt) ||
>> +	    (uvolt < regnode->std_param.min_uvolt))
>> +		return (ERANGE);
>> +	return (0);
>> + * Internal functions.
>> +static struct regnode *
>> +regnode_find_by_name(const char *name)
>> +	REG_TOPO_ASSERT();
>> +		if (strcmp(entry->name, name) == 0)
>> +			return (entry);
>> +	return (NULL);
>> +regnode_find_by_id(device_t dev, intptr_t id)
>> +		if ((entry->pdev == dev) && (entry->id ==  id))
>> +			return (entry);
>> +	return (NULL);
>> + * Create and initialize regulator object, but do not register it.
>> +struct regnode *
>> +regnode_create(device_t pdev, regnode_class_t regnode_class,
>> +    struct regnode_init_def *def)
>> +	struct sysctl_oid *regnode_oid;
>> +	KASSERT(def->name != NULL, ("regulator name is NULL"));
>> +	KASSERT(def->name[0] != '\0', ("regulator name is empty"));
>> +	REG_TOPO_SLOCK();
>> +	if (regnode_find_by_name(def->name) != NULL)
>> +		panic("Duplicated regulator registration: %s\n", def->name);
>> +	/* Create object and initialize it. */
>> +	regnode = malloc(sizeof(struct regnode), M_REGULATOR,
>> +	    M_WAITOK | M_ZERO);
>> +	kobj_init((kobj_t)regnode, (kobj_class_t)regnode_class);
>> +	sx_init(&regnode->lock, "Regulator node lock");
>> +	/* Allocate softc if required. */
>> +	if (regnode_class->size > 0) {
>> +		regnode->softc = malloc(regnode_class->size,
>> M_REGULATOR,
>> +	/* Copy all strings unless they're flagged as static. */
>> +	if (def->flags & REGULATOR_FLAGS_STATIC) {
>> +		regnode->name = def->name;
>> +		regnode->parent_name = def->parent_name;
>> +	} else {
>> +		regnode->name = strdup(def->name, M_REGULATOR);
>> +		if (def->parent_name != NULL)
>> +			regnode->parent_name = strdup(def-
>>> parent_name,
>> +			    M_REGULATOR);
>> +	/* Rest of init. */
>> +	TAILQ_INIT(&regnode->consumers_list);
>> +	regnode->id = def->id;
>> +	regnode->pdev = pdev;
>> +	regnode->flags = def->flags;
>> +	regnode->parent = NULL;
>> +	regnode->std_param = def->std_param;
>> +#ifdef FDT
>> +	regnode->ofw_node = def->ofw_node;
>> +#endif
>> +	sysctl_ctx_init(&regnode->sysctl_ctx);
>> +	regnode_oid = SYSCTL_ADD_NODE(&regnode->sysctl_ctx,
>> +	    SYSCTL_STATIC_CHILDREN(_hw_regulator),
>> +	    OID_AUTO, regnode->name,
>> +	    CTLFLAG_RD, 0, "A regulator node");
>> +	SYSCTL_ADD_INT(&regnode->sysctl_ctx,
>> +	    SYSCTL_CHILDREN(regnode_oid),
>> +	    OID_AUTO, "min_uvolt",
>> +	    CTLFLAG_RD, &regnode->std_param.min_uvolt, 0,
>> +	    "Minimal voltage (in uV)");
>> +	    OID_AUTO, "max_uvolt",
>> +	    CTLFLAG_RD, &regnode->std_param.max_uvolt, 0,
>> +	    "Maximal voltage (in uV)");
>> +	    OID_AUTO, "min_uamp",
>> +	    CTLFLAG_RD, &regnode->std_param.min_uamp, 0,
>> +	    "Minimal amperage (in uA)");
>> +	    OID_AUTO, "max_uamp",
>> +	    CTLFLAG_RD, &regnode->std_param.max_uamp, 0,
>> +	    "Maximal amperage (in uA)");
>> +	    OID_AUTO, "ramp_delay",
>> +	    CTLFLAG_RD, &regnode->std_param.ramp_delay, 0,
>> +	    "Ramp delay (in uV/us)");
>> +	    OID_AUTO, "enable_delay",
>> +	    CTLFLAG_RD, &regnode->std_param.enable_delay, 0,
>> +	    "Enable delay (in us)");
>> +	    OID_AUTO, "enable_cnt",
>> +	    CTLFLAG_RD, &regnode->enable_cnt, 0,
>> +	    "The regulator enable counter");
>> +	SYSCTL_ADD_U8(&regnode->sysctl_ctx,
>> +	    OID_AUTO, "boot_on",
>> +	    CTLFLAG_RD, (uint8_t *) &regnode->std_param.boot_on, 0,
>> +	    "Is enabled on boot");
>> +	    OID_AUTO, "always_on",
>> +	    CTLFLAG_RD, (uint8_t *)&regnode->std_param.always_on, 0,
>> +	    "Is always enabled");
>> +	SYSCTL_ADD_PROC(&regnode->sysctl_ctx,
>> +	    OID_AUTO, "uvolt",
>> +	    CTLTYPE_INT | CTLFLAG_RD,
>> +	    regnode, 0, regnode_uvolt_sysctl,
>> +	    "I",
>> +	    "Current voltage (in uV)");
>> +	return (regnode);
>> +/* Register regulator object. */
>> +struct regnode *
>> +regnode_register(struct regnode *regnode)
>> +	int rv;
>> +#ifdef FDT
>> +	if (regnode->ofw_node <= 0)
>> +		regnode->ofw_node = ofw_bus_get_node(regnode->pdev);
>> +		return (NULL);
>> +#endif
>> +	rv = REGNODE_INIT(regnode);
>> +	if (rv != 0) {
>> +		printf("REGNODE_INIT failed: %d\n", rv);
>> +		return (NULL);
>> +	REG_TOPO_XLOCK();
>> +	TAILQ_INSERT_TAIL(&regnode_list, regnode, reglist_link);
>> +#ifdef FDT
>> +	OF_device_register_xref(OF_xref_from_node(regnode-
>>> ofw_node),
>> +	    regnode->pdev);
>> +#endif
>> +	return (regnode);
>> +static int
>> +regnode_resolve_parent(struct regnode *regnode)
>> +	/* All ready resolved or no parent? */
>> +	if ((regnode->parent != NULL) ||
>> +	    (regnode->parent_name == NULL))
>> +		return (0);
>> +	regnode->parent = regnode_find_by_name(regnode-
>>> parent_name);
>> +	if (regnode->parent == NULL)
>> +		return (ENODEV);
>> +	return (0);
>> +static void
>> +regnode_delay(int usec)
>> +	int ticks;
>> +	if (usec == 0)
>> +		return;
>> +	ticks = (usec * hz + 999999) / 1000000;
>> +	if (cold || ticks < 2)
>> +		DELAY(usec);
>> +	else
>> +		pause("REGULATOR", ticks);
>> + * Regulator providers interface
>> +const char *
>> +regnode_get_name(struct regnode *regnode)
>> +	return (regnode->name);
>> +const char *
>> +regnode_get_parent_name(struct regnode *regnode)
>> +	return (regnode->parent_name);
>> +int
>> +regnode_get_flags(struct regnode *regnode)
>> +	return (regnode->flags);
>> +void *
>> +regnode_get_softc(struct regnode *regnode)
>> +	return (regnode->softc);
>> +device_t
>> +regnode_get_device(struct regnode *regnode)
>> +	return (regnode->pdev);
>> +struct regnode_std_param *regnode_get_stdparam(struct regnode
>> *regnode)
>> +	return (&regnode->std_param);
>> +void regnode_topo_unlock(void)
>> +void regnode_topo_xlock(void)
>> +	REG_TOPO_XLOCK();
>> +void regnode_topo_slock(void)
>> +	REG_TOPO_SLOCK();
>> + * Real consumers executive
>> +struct regnode *
>> +regnode_get_parent(struct regnode *regnode)
>> +	int rv;
>> +	rv = regnode_resolve_parent(regnode);
>> +	if (rv != 0)
>> +		return (NULL);
>> +	return (regnode->parent);
>> + * Enable regulator.
>> +int
>> +regnode_enable(struct regnode *regnode)
>> +	int udelay;
>> +	int rv;
>> +	/* Enable regulator for each node in chain, starting from source. */
>> +	if (rv != 0)
>> +		return (rv);
>> +	if (regnode->parent != NULL) {
>> +		rv = regnode_enable(regnode->parent);
>> +		if (rv != 0)
>> +			return (rv);
>> +	/* Handle this node. */
>> +	REGNODE_XLOCK(regnode);
>> +	if (regnode->enable_cnt == 0) {
>> +		rv = REGNODE_ENABLE(regnode, true, &udelay);
>> +		if (rv != 0) {
>> +			REGNODE_UNLOCK(regnode);
>> +			return (rv);
>> +		regnode_delay(udelay);
>> +	regnode->enable_cnt++;
>> +	return (0);
>> + * Disable regulator.
>> +int
>> +regnode_disable(struct regnode *regnode)
>> +	int udelay;
>> +	int rv;
>> +	rv = 0;
>> +	/* Disable regulator for each node in chain, starting from consumer.
>> +	if (regnode->enable_cnt == 1 &&
>> +	    (regnode->flags & REGULATOR_FLAGS_NOT_DISABLE) == 0 &&
>> +	    !regnode->std_param.always_on) {
>> +		rv = REGNODE_ENABLE(regnode, false, &udelay);
>> +		if (rv != 0) {
>> +			return (rv);
>> +	regnode->enable_cnt--;
>> +	if (rv != 0)
>> +		return (rv);
>> +		rv = regnode_disable(regnode->parent);
>> +	return (rv);
>> + * Stop regulator.
>> +int
>> +regnode_stop(struct regnode *regnode, int depth)
>> +	int udelay;
>> +	int rv;
>> +	rv = 0;
>> +	/* The first node must not be enabled. */
>> +	if ((regnode->enable_cnt != 0) && (depth == 0)) {
>> +		return (EBUSY);
>> +	if ((regnode->enable_cnt == 0) &&
>> +	    ((regnode->flags & REGULATOR_FLAGS_NOT_DISABLE) == 0)) {
>> +		rv = REGNODE_STOP(regnode, &udelay);
>> +		if (rv != 0) {
>> +			return (rv);
>> +	if (rv != 0)
>> +		return (rv);
>> +	if (regnode->parent != NULL && regnode->parent->enable_cnt == 0)
>> +		rv = regnode_stop(regnode->parent, depth + 1);
>> +	return (rv);
>> + * Get regulator status. (REGULATOR_STATUS_*)
>> +int
>> +regnode_status(struct regnode *regnode, int *status)
>> +	int rv;
>> +	rv = REGNODE_STATUS(regnode, status);
>> +	return (rv);
>> + * Get actual regulator voltage.
>> +int
>> +regnode_get_voltage(struct regnode *regnode, int *uvolt)
>> +	int rv;
>> +	rv = REGNODE_GET_VOLTAGE(regnode, uvolt);
>> +	/* Pass call into parent, if regulator is in bypass mode. */
>> +	if (rv == ENOENT) {
>> +		if (rv != 0)
>> +			return (rv);
>> +			rv = regnode_get_voltage(regnode->parent, uvolt);
>> +	return (rv);
>> + * Set regulator voltage.
>> +int
>> +regnode_set_voltage(struct regnode *regnode, int min_uvolt, int
>> max_uvolt)
>> +	int udelay;
>> +	int rv;
>> +	rv = REGNODE_SET_VOLTAGE(regnode, min_uvolt, max_uvolt,
>> &udelay);
>> +	if (rv == 0)
>> +	return (rv);
>> + * Consumer variant of regnode_set_voltage().
>> +static int
>> +regnode_set_voltage_checked(struct regnode *regnode, struct regulator
>> *reg,
>> +    int min_uvolt, int max_uvolt)
>> +	int udelay;
>> +	int all_max_uvolt;
>> +	int all_min_uvolt;
>> +	struct regulator *tmp;
>> +	int rv;
>> +	/* Return error if requested range is outside of regulator range. */
>> +	    (max_uvolt < regnode->std_param.min_uvolt)) {
>> +		return (ERANGE);
>> +	/* Get actual voltage range for all consumers. */
>> +	all_min_uvolt = regnode->std_param.min_uvolt;
>> +	all_max_uvolt = regnode->std_param.max_uvolt;
>> +	TAILQ_FOREACH(tmp, &regnode->consumers_list, link) {
>> +		/* Don't take requestor in account. */
>> +		if (tmp == reg)
>> +			continue;
>> +		if (all_min_uvolt < tmp->min_uvolt)
>> +			all_min_uvolt = tmp->min_uvolt;
>> +		if (all_max_uvolt > tmp->max_uvolt)
>> +			all_max_uvolt = tmp->max_uvolt;
>> +	/* Test if request fits to actual contract. */
>> +	if ((min_uvolt > all_max_uvolt) ||
>> +	    (max_uvolt < all_min_uvolt)) {
>> +		return (ERANGE);
>> +	/* Adjust new range.*/
>> +	if (min_uvolt < all_min_uvolt)
>> +		min_uvolt = all_min_uvolt;
>> +	if (max_uvolt > all_max_uvolt)
>> +		max_uvolt = all_max_uvolt;
>> &udelay);
>> +	return (rv);
>> +int
>> +regnode_set_constraint(struct regnode *regnode)
>> +	int status, rv, uvolt;
>> +	if (regnode->std_param.boot_on != true &&
>> +	    regnode->std_param.always_on != true)
>> +		return (0);
>> +	rv = regnode_status(regnode, &status);
>> +	if (rv != 0) {
>> +		if (bootverbose)
>> +			printf("Cannot get regulator status for %s\n",
>> +			    regnode_get_name(regnode));
>> +		return (rv);
>> +	if (status == REGULATOR_STATUS_ENABLED)
>> +		return (0);
>> +	rv = regnode_get_voltage(regnode, &uvolt);
>> +	if (rv != 0) {
>> +		if (bootverbose)
>> +			printf("Cannot get regulator voltage for %s\n",
>> +		return (rv);
>> +	if (uvolt < regnode->std_param.min_uvolt ||
>> +	  uvolt > regnode->std_param.max_uvolt) {
>> +		if (bootverbose)
>> +			printf("Regulator %s current voltage %d is not in the"
>> +			    " acceptable range : %d<->%d\n",
>> +			    regnode_get_name(regnode),
>> +			    uvolt, regnode->std_param.min_uvolt,
>> +			    regnode->std_param.max_uvolt);
>> +		return (ERANGE);
>> +	rv = regnode_enable(regnode);
>> +	if (rv != 0) {
>> +		if (bootverbose)
>> +			printf("Cannot enable regulator %s\n",
>> +		return (rv);
>> +	return (0);
>> +#ifdef FDT
>> +phandle_t
>> +regnode_get_ofw_node(struct regnode *regnode)
>> +	return (regnode->ofw_node);
>> +#endif
>> + * Regulator consumers interface.
>> +/* Helper function for regulator_get*() */
>> +static regulator_t
>> +regulator_create(struct regnode *regnode, device_t cdev)
>> +	struct regulator *reg;
>> +	reg =  malloc(sizeof(struct regulator), M_REGULATOR,
>> +	reg->cdev = cdev;
>> +	reg->regnode = regnode;
>> +	reg->enable_cnt = 0;
>> +	regnode->ref_cnt++;
>> +	TAILQ_INSERT_TAIL(&regnode->consumers_list, reg, link);
>> +	reg ->min_uvolt = regnode->std_param.min_uvolt;
>> +	reg ->max_uvolt = regnode->std_param.max_uvolt;
>> +	return (reg);
>> +int
>> +regulator_enable(regulator_t reg)
>> +	int rv;
>> +	regnode = reg->regnode;
>> +	KASSERT(regnode->ref_cnt > 0,
>> +	   ("Attempt to access unreferenced regulator: %s\n", regnode-
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	if (rv == 0)
>> +		reg->enable_cnt++;
>> +	return (rv);
>> +int
>> +regulator_disable(regulator_t reg)
>> +	int rv;
>>> name));
>> +	KASSERT(reg->enable_cnt > 0,
>> +	   ("Attempt to disable already disabled regulator: %s\n",
>> +	   regnode->name));
>> +	REG_TOPO_SLOCK();
>> +	rv = regnode_disable(regnode);
>> +	if (rv == 0)
>> +		reg->enable_cnt--;
>> +	return (rv);
>> +int
>> +regulator_stop(regulator_t reg)
>> +	int rv;
>>> name));
>> +	KASSERT(reg->enable_cnt == 0,
>> +	   ("Attempt to stop already enabled regulator: %s\n", regnode-
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	rv = regnode_stop(regnode, 0);
>> +	return (rv);
>> +int
>> +regulator_status(regulator_t reg, int *status)
>> +	int rv;
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	rv = regnode_status(regnode, status);
>> +	return (rv);
>> +int
>> +regulator_get_voltage(regulator_t reg, int *uvolt)
>> +	int rv;
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	rv = regnode_get_voltage(regnode, uvolt);
>> +	return (rv);
>> +int
>> +regulator_set_voltage(regulator_t reg, int min_uvolt, int max_uvolt)
>> +	int rv;
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	rv = regnode_set_voltage_checked(regnode, reg, min_uvolt,
>> max_uvolt);
>> +	if (rv == 0) {
>> +		reg->min_uvolt = min_uvolt;
>> +		reg->max_uvolt = max_uvolt;
>> +	return (rv);
>> +int
>> +regulator_check_voltage(regulator_t reg, int uvolt)
>> +	int rv;
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	rv = REGNODE_CHECK_VOLTAGE(regnode, uvolt);
>> +	return (rv);
>> +const char *
>> +regulator_get_name(regulator_t reg)
>>> name));
>> +int
>> +regulator_get_by_name(device_t cdev, const char *name, regulator_t
>> *reg)
>> +	REG_TOPO_SLOCK();
>> +	regnode = regnode_find_by_name(name);
>> +	if (regnode == NULL) {
>> +		return (ENODEV);
>> +	*reg = regulator_create(regnode, cdev);
>> +	return (0);
>> +int
>> +regulator_get_by_id(device_t cdev, device_t pdev, intptr_t id, regulator_t
>> *reg)
>> +	REG_TOPO_SLOCK();
>> +	regnode = regnode_find_by_id(pdev, id);
>> +		return (ENODEV);
>> +	return (0);
>> +int
>> +regulator_release(regulator_t reg)
>>> name));
>> +	REG_TOPO_SLOCK();
>> +	while (reg->enable_cnt > 0) {
>> +		regnode_disable(regnode);
>> +	TAILQ_REMOVE(&regnode->consumers_list, reg, link);
>> +	regnode->ref_cnt--;
>> +	free(reg, M_REGULATOR);
>> +	return (0);
>> +#ifdef FDT
>> +/* Default DT mapper. */
>> +int
>> +regdev_default_ofw_map(device_t dev, phandle_t 	xref, int ncells,
>> +    pcell_t *cells, intptr_t *id)
>> +	if (ncells == 0)
>> +		*id = 1;
>> +	else if (ncells == 1)
>> +		*id = cells[0];
>> +	else
>> +		return  (ERANGE);
>> +	return (0);
>> +int
>> +regulator_parse_ofw_stdparam(device_t pdev, phandle_t node,
>> +	phandle_t supply_xref;
>> +	struct regnode_std_param *par;
>> +	int rv;
>> +	par = &def->std_param;
>> +	rv = OF_getprop_alloc(node, "regulator-name",
>> +	    (void **)&def->name);
>> +	if (rv <= 0) {
>> +		device_printf(pdev, "%s: Missing regulator name\n",
>> +		 __func__);
>> +		return (ENXIO);
>> +	rv = OF_getencprop(node, "regulator-min-microvolt", &par-
>>> min_uvolt,
>> +	    sizeof(par->min_uvolt));
>> +	if (rv <= 0)
>> +		par->min_uvolt = 0;
>> +	rv = OF_getencprop(node, "regulator-max-microvolt", &par-
>>> max_uvolt,
>> +	    sizeof(par->max_uvolt));
>> +	if (rv <= 0)
>> +		par->max_uvolt = 0;
>> +	rv = OF_getencprop(node, "regulator-min-microamp", &par-
>>> min_uamp,
>> +	    sizeof(par->min_uamp));
>> +	if (rv <= 0)
>> +		par->min_uamp = 0;
>> +	rv = OF_getencprop(node, "regulator-max-microamp", &par-
>>> max_uamp,
>> +	    sizeof(par->max_uamp));
>> +	if (rv <= 0)
>> +		par->max_uamp = 0;
>> +	rv = OF_getencprop(node, "regulator-ramp-delay", &par-
>>> ramp_delay,
>> +	    sizeof(par->ramp_delay));
>> +	if (rv <= 0)
>> +		par->ramp_delay = 0;
>> +	rv = OF_getencprop(node, "regulator-enable-ramp-delay",
>> +	    &par->enable_delay, sizeof(par->enable_delay));
>> +	if (rv <= 0)
>> +		par->enable_delay = 0;
>> +	if (OF_hasprop(node, "regulator-boot-on"))
>> +		par->boot_on = true;
>> +	if (OF_hasprop(node, "regulator-always-on"))
>> +		par->always_on = true;
>> +	if (OF_hasprop(node, "enable-active-high"))
>> +		par->enable_active_high = 1;
>> +	rv = OF_getencprop(node, "vin-supply", &supply_xref,
>> +	    sizeof(supply_xref));
>> +	if (rv >=  0) {
>> +		rv = OF_getprop_alloc(supply_xref, "regulator-name",
>> +		    (void **)&def->parent_name);
>> +		if (rv <= 0)
>> +			def->parent_name = NULL;
>> +	return (0);
>> +int
>> +regulator_get_by_ofw_property(device_t cdev, phandle_t cnode, char
>> *name,
>> +    regulator_t *reg)
>> +	phandle_t *cells;
>> +	device_t regdev;
>> +	int ncells, rv;
>> +	intptr_t id;
>> +	*reg = NULL;
>> +	if (cnode <= 0)
>> +		cnode = ofw_bus_get_node(cdev);
>> +	if (cnode <= 0) {
>> +		device_printf(cdev, "%s called on not ofw based device\n",
>> +		 __func__);
>> +		return (ENXIO);
>> +	cells = NULL;
>> +	ncells = OF_getencprop_alloc_multi(cnode, name, sizeof(*cells),
>> +	    (void **)&cells);
>> +	if (ncells <= 0)
>> +		return (ENOENT);
>> +	/* Translate xref to device */
>> +	regdev = OF_device_from_xref(cells[0]);
>> +	if (regdev == NULL) {
>> +		OF_prop_free(cells);
>> +		return (ENODEV);
>> +	/* Map regulator to number */
>> +	rv = REGDEV_MAP(regdev, cells[0], ncells - 1, cells + 1, &id);
>> +	if (rv != 0)
>> +		return (rv);
>> +	return (regulator_get_by_id(cdev, regdev, id, reg));
>> +#endif
>> + * Regulator utility functions.
>> +/* Convert raw selector value to real voltage */
>> +int
>> +regulator_range_sel8_to_volt(struct regulator_range *ranges, int nranges,
>> +   uint8_t sel, int *volt)
>> +	struct regulator_range *range;
>> +	int i;
>> +	if (nranges == 0)
>> +		panic("Voltage regulator have zero ranges\n");
>> +	for (i = 0; i < nranges ; i++) {
>> +		range = ranges  + i;
>> +		if (!(sel >= range->min_sel &&
>> +		      sel <= range->max_sel))
>> +			continue;
>> +		sel -= range->min_sel;
>> +		*volt = range->min_uvolt + sel * range->step_uvolt;
>> +		return (0);
>> +	return (ERANGE);
>> +int
>> +regulator_range_volt_to_sel8(struct regulator_range *ranges, int nranges,
>> +    int min_uvolt, int max_uvolt, uint8_t *out_sel)
>> +	uint8_t sel;
>> +	int uvolt;
>> +	int rv, i;
>> +	if (nranges == 0)
>> +	for (i = 0; i < nranges; i++) {
>> +		uvolt = range->min_uvolt +
>> +		    (range->max_sel - range->min_sel) * range->step_uvolt;
>> +		if ((min_uvolt > uvolt) ||
>> +		    (max_uvolt < range->min_uvolt))
>> +			continue;
>> +		if (min_uvolt <= range->min_uvolt)
>> +			min_uvolt = range->min_uvolt;
>> +		/* if step == 0 -> fixed voltage range. */
>> +		if (range->step_uvolt == 0)
>> +			sel = 0;
>> +		else
>> +			sel = DIV_ROUND_UP(min_uvolt - range->min_uvolt,
>> +			   range->step_uvolt);
>> +		sel += range->min_sel;
>> +		break;
>> +	if (i >= nranges)
>> +		return (ERANGE);
>> +	/* Verify new settings. */
>> +	rv = regulator_range_sel8_to_volt(ranges, nranges, sel, &uvolt);
>> +	if (rv != 0)
>> +		return (rv);
>> +	if ((uvolt < min_uvolt) || (uvolt > max_uvolt))
>> +		return (ERANGE);
>> +	*out_sel = sel;
>> +	return (0);
>> diff --git a/freebsd/sys/dev/extres/regulator/regulator.h
>> b/freebsd/sys/dev/extres/regulator/regulator.h
>> index 00000000..3905aa36
>> --- /dev/null
>> +++ b/freebsd/sys/dev/extres/regulator/regulator.h
>> @@ -0,0 +1,156 @@
>> + * are met:
>> IS'' AND
>> TO, THE
>> PARTICULAR PURPOSE
>> BE LIABLE
>> CONSEQUENTIAL
>> SUBSTITUTE GOODS
>> INTERRUPTION)
>> CONTRACT, STRICT
>> IN ANY WAY
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _DEV_EXTRES_REGULATOR_H_
>> +#define _DEV_EXTRES_REGULATOR_H_
>> +#ifdef FDT
>> +#endif
>> +#include <rtems/bsd/local/regnode_if.h>
>> +SYSCTL_DECL(_hw_regulator);
>> +#define REGULATOR_FLAGS_STATIC		0x00000001  /* Static strings */
>> +#define REGULATOR_FLAGS_NOT_DISABLE	0x00000002  /* Cannot be
>> disabled */
>> +#define REGULATOR_STATUS_ENABLED	0x00000001
>> +#define REGULATOR_STATUS_OVERCURRENT	0x00000002
>> +typedef struct regulator *regulator_t;
>> +/* Standard regulator parameters. */
>> +struct regnode_std_param {
>> +	int 			min_uvolt;	/* In uV */
>> +	int 			max_uvolt;	/* In uV */
>> +	int 			min_uamp;	/* In uA */
>> +	int 			max_uamp;	/* In uA */
>> +	int 			ramp_delay;	/* In uV/usec */
>> +	int 			enable_delay;	/* In usec */
>> +	bool 			boot_on;	/* Is enabled on boot */
>> +	bool 			always_on;	/* Must be enabled */
>> +	int			enable_active_high;
>> +/* Initialization parameters. */
>> +struct regnode_init_def {
>> +	char			*name;		/* Regulator name */
>> +	char			*parent_name;	/* Name of parent
>> regulator */
>> parameters */
>> +	intptr_t		id;		/* Regulator ID */
>> +	int			flags;		/* Flags */
>> +#ifdef FDT
>> +#endif
>> +struct regulator_range {
>> +	int		min_uvolt;
>> +	int		step_uvolt;
>> +	uint8_t		min_sel;
>> +	uint8_t		max_sel;
>> +#define	REG_RANGE_INIT(_min_sel, _max_sel, _min_uvolt,
>> _step_uvolt) {	\
>> +	.min_sel	= _min_sel,					\
>> +	.max_sel	= _max_sel,					\
>> +	.min_uvolt	= _min_uvolt,					\
>> +	.step_uvolt	= _step_uvolt,					\
>> + * Shorthands for constructing method tables.
>> +#define	REGNODEMETHOD		KOBJMETHOD
>> +#define	REGNODEMETHOD_END	KOBJMETHOD_END
>> +#define regnode_method_t	kobj_method_t
>> +#define regnode_class_t		kobj_class_t
>> +DECLARE_CLASS(regnode_class);
>> +/* Providers interface. */
>> +struct regnode *regnode_create(device_t pdev, regnode_class_t
>> regnode_class,
>> +    struct regnode_init_def *def);
>> +struct regnode *regnode_register(struct regnode *regnode);
>> +const char *regnode_get_name(struct regnode *regnode);
>> +const char *regnode_get_parent_name(struct regnode *regnode);
>> +struct regnode *regnode_get_parent(struct regnode *regnode);
>> +int regnode_get_flags(struct regnode *regnode);
>> +void *regnode_get_softc(struct regnode *regnode);
>> +device_t regnode_get_device(struct regnode *regnode);
>> *regnode);
>> +void regnode_topo_unlock(void);
>> +void regnode_topo_xlock(void);
>> +void regnode_topo_slock(void);
>> +int regnode_enable(struct regnode *regnode);
>> +int regnode_disable(struct regnode *regnode);
>> +int regnode_stop(struct regnode *regnode, int depth);
>> +int regnode_status(struct regnode *regnode, int *status);
>> +int regnode_get_voltage(struct regnode *regnode, int *uvolt);
>> +int regnode_set_voltage(struct regnode *regnode, int min_uvolt, int
>> max_uvolt);
>> +int regnode_set_constraint(struct regnode *regnode);
>> +/* Standard method that aren't default */
>> +int regnode_method_check_voltage(struct regnode *regnode, int uvolt);
>> +#ifdef FDT
>> +phandle_t regnode_get_ofw_node(struct regnode *regnode);
>> +#endif
>> +/* Consumers interface. */
>> +int regulator_get_by_name(device_t cdev, const char *name,
>> +     regulator_t *regulator);
>> +int regulator_get_by_id(device_t cdev, device_t pdev, intptr_t id,
>> +int regulator_release(regulator_t regulator);
>> +const char *regulator_get_name(regulator_t regulator);
>> +int regulator_enable(regulator_t reg);
>> +int regulator_disable(regulator_t reg);
>> +int regulator_stop(regulator_t reg);
>> +int regulator_status(regulator_t reg, int *status);
>> +int regulator_get_voltage(regulator_t reg, int *uvolt);
>> +int regulator_set_voltage(regulator_t reg, int min_uvolt, int max_uvolt);
>> +int regulator_check_voltage(regulator_t reg, int uvolt);
>> +#ifdef FDT
>> +int regulator_get_by_ofw_property(device_t dev, phandle_t node, char
>> *name,
>> +    regulator_t *reg);
>> +int regulator_parse_ofw_stdparam(device_t dev, phandle_t node,
>> +#endif
>> +/* Utility functions */
>> +int regulator_range_volt_to_sel8(struct regulator_range *ranges, int
>> nranges,
>> +    int min_uvolt, int max_uvolt, uint8_t *out_sel);
>> +int regulator_range_sel8_to_volt(struct regulator_range *ranges, int
>> nranges,
>> +   uint8_t sel, int *volt);
>> +#endif /* _DEV_EXTRES_REGULATOR_H_ */
>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_bus.c
>> b/freebsd/sys/dev/extres/regulator/regulator_bus.c
>> index 00000000..b79c2633
>> --- /dev/null
>> +++ b/freebsd/sys/dev/extres/regulator/regulator_bus.c
>> @@ -0,0 +1,89 @@
>> + * are met:
>> IS'' AND
>> TO, THE
>> PARTICULAR PURPOSE
>> BE LIABLE
>> CONSEQUENTIAL
>> SUBSTITUTE GOODS
>> INTERRUPTION)
>> CONTRACT, STRICT
>> IN ANY WAY
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#include <sys/module.h>
>> +#include <dev/fdt/simplebus.h>
>> +#include <dev/ofw/openfirm.h>
>> +struct ofw_regulator_bus_softc {
>> +	struct simplebus_softc simplebus_sc;
>> +static int
>> +ofw_regulator_bus_probe(device_t dev)
>> +	const char	*name;
>> +	name = ofw_bus_get_name(dev);
>> +	if (name == NULL || strcmp(name, "regulators") != 0)
>> +		return (ENXIO);
>> +	device_set_desc(dev, "OFW regulators bus");
>> +	return (0);
>> +static int
>> +ofw_regulator_bus_attach(device_t dev)
>> +	phandle_t node, child;
>> +	node  = ofw_bus_get_node(dev);
>> +	simplebus_init(dev, node);
>> +	for (child = OF_child(node); child > 0; child = OF_peer(child)) {
>> +		simplebus_add_device(dev, child, 0, NULL, -1, NULL);
>> +	return (bus_generic_attach(dev));
>> +static device_method_t ofw_regulator_bus_methods[] = {
>> +	/* Device interface */
>> +	DEVMETHOD(device_probe,		ofw_regulator_bus_probe),
>> +	DEVMETHOD(device_attach,	ofw_regulator_bus_attach),
>> +	DEVMETHOD_END
>> +DEFINE_CLASS_1(ofw_regulator_bus, ofw_regulator_bus_driver,
>> +    ofw_regulator_bus_methods, sizeof(struct ofw_regulator_bus_softc),
>> +    simplebus_driver);
>> +static devclass_t ofw_regulator_bus_devclass;
>> +EARLY_DRIVER_MODULE(ofw_regulator_bus, simplebus,
>> +    ofw_regulator_bus_devclass, 0, 0, BUS_PASS_BUS +
>> BUS_PASS_ORDER_MIDDLE);
>> +MODULE_VERSION(ofw_regulator_bus, 1);
>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>> b/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>> index 00000000..0bc6d96e
>> --- /dev/null
>> +++ b/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>> @@ -0,0 +1,502 @@
>> + * are met:
>> IS'' AND
>> TO, THE
>> PARTICULAR PURPOSE
>> BE LIABLE
>> CONSEQUENTIAL
>> SUBSTITUTE GOODS
>> INTERRUPTION)
>> CONTRACT, STRICT
>> IN ANY WAY
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> +#include <sys/gpio.h>
>> +#ifdef FDT
>> +#endif
>> +#include <dev/gpio/gpiobusvar.h>
>> +#include <dev/extres/regulator/regulator_fixed.h>
>> +MALLOC_DEFINE(M_FIXEDREGULATOR, "fixedregulator", "Fixed
>> regulator");
>> +/* GPIO list for shared pins. */
>> +typedef TAILQ_HEAD(gpio_list, gpio_entry) gpio_list_t;
>> +struct gpio_entry {
>> +	TAILQ_ENTRY(gpio_entry)	link;
>> +	struct gpiobus_pin	gpio_pin;
>> +	int 			use_cnt;
>> +	int 			enable_cnt;
>> +	bool			always_on;
>> +static gpio_list_t gpio_list = TAILQ_HEAD_INITIALIZER(gpio_list);
>> +static struct mtx gpio_list_mtx;
>> +MTX_SYSINIT(gpio_list_lock, &gpio_list_mtx, "Regulator GPIO lock",
>> MTX_DEF);
>> +struct regnode_fixed_sc {
>> +	struct regnode_std_param *param;
>> +	bool			gpio_open_drain;
>> +	struct gpio_entry	*gpio_entry;
>> +static int regnode_fixed_init(struct regnode *regnode);
>> +static int regnode_fixed_enable(struct regnode *regnode, bool enable,
>> +    int *udelay);
>> +static int regnode_fixed_status(struct regnode *regnode, int *status);
>> +static int regnode_fixed_stop(struct regnode *regnode, int *udelay);
>> +static regnode_method_t regnode_fixed_methods[] = {
>> +	/* Regulator interface */
>> +	REGNODEMETHOD(regnode_init,		regnode_fixed_init),
>> 	regnode_fixed_enable),
>> 	regnode_fixed_status),
>> +	REGNODEMETHOD(regnode_stop,		regnode_fixed_stop),
>> +	REGNODEMETHOD_END
>> +DEFINE_CLASS_1(regnode_fixed, regnode_fixed_class,
>> regnode_fixed_methods,
>> +   sizeof(struct regnode_fixed_sc), regnode_class);
>> + * GPIO list functions.
>> + * Two or more regulators can share single GPIO pins, so we must track all
>> + * GPIOs in gpio_list.
>> + * The GPIO pin is registerd and reseved for first consumer, all others share
>> + * gpio_entry with it.
>> +static struct gpio_entry *
>> +regnode_get_gpio_entry(struct gpiobus_pin *gpio_pin)
>> +	struct gpio_entry *entry, *tmp;
>> +	device_t busdev;
>> +	int rv;
>> +	busdev = GPIO_GET_BUS(gpio_pin->dev);
>> +	if (busdev == NULL)
>> +		return (NULL);
>> +	entry = malloc(sizeof(struct gpio_entry), M_FIXEDREGULATOR,
>> +	mtx_lock(&gpio_list_mtx);
>> +	TAILQ_FOREACH(tmp, &gpio_list, link) {
>> +		if (tmp->gpio_pin.dev == gpio_pin->dev &&
>> +		    tmp->gpio_pin.pin == gpio_pin->pin) {
>> +			tmp->use_cnt++;
>> +			mtx_unlock(&gpio_list_mtx);
>> +			free(entry, M_FIXEDREGULATOR);
>> +			return (tmp);
>> +	/* Reserve pin. */
>> +	/* XXX Can we call gpiobus_acquire_pin() with gpio_list_mtx held? */
>> +	rv = gpiobus_acquire_pin(busdev, gpio_pin->pin);
>> +	if (rv != 0) {
>> +		return (NULL);
>> +	/* Everything is OK, build new entry and insert it to list. */
>> +	entry->gpio_pin = *gpio_pin;
>> +	entry->use_cnt = 1;
>> +	TAILQ_INSERT_TAIL(&gpio_list, entry, link);
>> +	return (entry);
>> + * Regulator class implementation.
>> +static int
>> +regnode_fixed_init(struct regnode *regnode)
>> +	device_t dev;
>> +	struct regnode_fixed_sc *sc;
>> +	struct gpiobus_pin *pin;
>> +	uint32_t flags;
>> +	int rv;
>> +	sc = regnode_get_softc(regnode);
>> +	dev = regnode_get_device(regnode);
>> +	sc->param = regnode_get_stdparam(regnode);
>> +	if (sc->gpio_entry == NULL)
>> +		return (0);
>> +	pin = &sc->gpio_entry->gpio_pin;
>> +	flags = GPIO_PIN_OUTPUT;
>> +	if (sc->gpio_open_drain)
>> +		flags |= GPIO_PIN_OPENDRAIN;
>> +	if (sc->param->boot_on || sc->param->always_on) {
>> +		rv = GPIO_PIN_SET(pin->dev, pin->pin, sc->param-
>>> enable_active_high);
>> +		if (rv != 0) {
>> +			device_printf(dev, "Cannot set GPIO pin: %d\n",
>> +			    pin->pin);
>> +			return (rv);
>> +	rv = GPIO_PIN_SETFLAGS(pin->dev, pin->pin, flags);
>> +	if (rv != 0) {
>> +		device_printf(dev, "Cannot configure GPIO pin: %d\n", pin-
>>> pin);
>> +		return (rv);
>> +	return (0);
>> + * Enable/disable regulator.
>> + * Take shared GPIO pins in account
>> +static int
>> +regnode_fixed_enable(struct regnode *regnode, bool enable, int *udelay)
>> +	device_t dev;
>> +	int rv;
>> +	*udelay = 0;
>> +		return (0);
>> +	if (enable) {
>> +		sc->gpio_entry->enable_cnt++;
>> +		if (sc->gpio_entry->enable_cnt > 1)
>> +			return (0);
>> +	} else {
>> +		KASSERT(sc->gpio_entry->enable_cnt > 0,
>> +		    ("Invalid enable count"));
>> +		sc->gpio_entry->enable_cnt--;
>> +		if (sc->gpio_entry->enable_cnt >= 1)
>> +			return (0);
>> +	if (sc->gpio_entry->always_on && !enable)
>> +		return (0);
>> +	if (!sc->param->enable_active_high)
>> +		enable = !enable;
>> +	rv = GPIO_PIN_SET(pin->dev, pin->pin, enable);
>> +	if (rv != 0) {
>> +		device_printf(dev, "Cannot set GPIO pin: %d\n", pin->pin);
>> +		return (rv);
>> +	*udelay = sc->param->enable_delay;
>> +	return (0);
>> + * Stop (physicaly shutdown) regulator.
>> +static int
>> +regnode_fixed_stop(struct regnode *regnode, int *udelay)
>> +	device_t dev;
>> +	int rv;
>> +	*udelay = 0;
>> +		return (0);
>> +	if (sc->gpio_entry->always_on)
>> +		return (0);
>> +	if (sc->gpio_entry->enable_cnt > 0) {
>> +		/* Other regulator(s) are enabled. */
>> +		/* XXXX Any diagnostic message? Or error? */
>> +		return (0);
>> +	    sc->param->enable_active_high ? false: true);
>> +	if (rv != 0) {
>> +		return (rv);
>> +	return (0);
>> +static int
>> +regnode_fixed_status(struct regnode *regnode, int *status)
>> +	uint32_t val;
>> +	int rv;
>> +	*status = 0;
>> +	if (sc->gpio_entry == NULL) {
>> +		return (0);
>> +	rv = GPIO_PIN_GET(pin->dev, pin->pin, &val);
>> +	if (rv == 0) {
>> +		if (!sc->param->enable_active_high ^ (val != 0))
>> +	return (rv);
>> +int
>> +regnode_fixed_register(device_t dev, struct regnode_fixed_init_def
>> *init_def)
>> +	regnode = regnode_create(dev, &regnode_fixed_class,
>> +	    &init_def->reg_init_def);
>> +		device_printf(dev, "Cannot create regulator.\n");
>> +		return(ENXIO);
>> +	sc->gpio_open_drain = init_def->gpio_open_drain;
>> +	if (init_def->gpio_pin != NULL) {
>> +		sc->gpio_entry = regnode_get_gpio_entry(init_def-
>>> gpio_pin);
>> +			return(ENXIO);
>> +	regnode = regnode_register(regnode);
>> +		device_printf(dev, "Cannot register regulator.\n");
>> +		return(ENXIO);
>> +	if (sc->gpio_entry != NULL)
>> +		sc->gpio_entry->always_on |= sc->param->always_on;
>> +	return (0);
>> + * OFW Driver implementation.
>> +#ifdef FDT
>> +struct  regfix_softc
>> +	device_t			dev;
>> +	bool				attach_done;
>> +	struct regnode_fixed_init_def	init_def;
>> +	phandle_t			gpio_prodxref;
>> +	pcell_t				*gpio_cells;
>> +	int				gpio_ncells;
>> +static struct ofw_compat_data compat_data[] = {
>> +	{"regulator-fixed",		1},
>> +	{NULL,				0},
>> +static int
>> +regfix_get_gpio(struct regfix_softc * sc)
>> +	device_t busdev;
>> +	phandle_t node;
>> +	int rv;
>> +	if (sc->gpio_prodxref == 0)
>> +		return (0);
>> +	node = ofw_bus_get_node(sc->dev);
>> +	/* Test if controller exist. */
>> +	sc->gpio_pin.dev = OF_device_from_xref(sc->gpio_prodxref);
>> +	if (sc->gpio_pin.dev == NULL)
>> +		return (ENODEV);
>> +	/* Test if GPIO bus already exist. */
>> +	busdev = GPIO_GET_BUS(sc->gpio_pin.dev);
>> +		return (ENODEV);
>> +	rv = gpio_map_gpios(sc->gpio_pin.dev, node,
>> +	    OF_node_from_xref(sc->gpio_prodxref), sc->gpio_ncells,
>> +	    sc->gpio_cells, &(sc->gpio_pin.pin), &(sc->gpio_pin.flags));
>> +	if (rv != 0) {
>> +		device_printf(sc->dev, "Cannot map the gpio property.\n");
>> +		return (ENXIO);
>> +	sc->init_def.gpio_pin = &sc->gpio_pin;
>> +	return (0);
>> +static int
>> +regfix_parse_fdt(struct regfix_softc * sc)
>> +	phandle_t node;
>> +	int rv;
>> +	struct regnode_init_def *init_def;
>> +	init_def = &sc->init_def.reg_init_def;
>> +	rv = regulator_parse_ofw_stdparam(sc->dev, node, init_def);
>> +	if (rv != 0) {
>> +		device_printf(sc->dev, "Cannot parse standard
>> parameters.\n");
>> +		return(rv);
>> +	/* Fixed regulator uses 'startup-delay-us' property for enable_delay
>> +	rv = OF_getencprop(node, "startup-delay-us",
>> +	   &init_def->std_param.enable_delay,
>> +	   sizeof(init_def->std_param.enable_delay));
>> +	if (rv <= 0)
>> +		init_def->std_param.enable_delay = 0;
>> +	/* GPIO pin */
>> +	if (OF_hasprop(node, "gpio-open-drain"))
>> +		sc->init_def.gpio_open_drain = true;
>> +	if (!OF_hasprop(node, "gpio"))
>> +		return (0);
>> +	rv = ofw_bus_parse_xref_list_alloc(node, "gpio", "#gpio-cells", 0,
>> +	    &sc->gpio_prodxref, &sc->gpio_ncells, &sc->gpio_cells);
>> +	if (rv != 0) {
>> +		sc->gpio_prodxref = 0;
>> +		device_printf(sc->dev, "Malformed gpio property\n");
>> +		return (ENXIO);
>> +	return (0);
>> +static void
>> +regfix_new_pass(device_t dev)
>> +	struct regfix_softc * sc;
>> +	int rv;
>> +	sc = device_get_softc(dev);
>> +	bus_generic_new_pass(dev);
>> +	if (sc->attach_done)
>> +		return;
>> +	/* Try to get and configure GPIO. */
>> +	rv = regfix_get_gpio(sc);
>> +	if (rv != 0)
>> +		return;
>> +	/* Register regulator. */
>> +	regnode_fixed_register(sc->dev, &sc->init_def);
>> +	sc->attach_done = true;
>> +static int
>> +regfix_probe(device_t dev)
>> +	if (!ofw_bus_status_okay(dev))
>> +		return (ENXIO);
>> +	if (!ofw_bus_search_compatible(dev, compat_data)->ocd_data)
>> +		return (ENXIO);
>> +	device_set_desc(dev, "Fixed Regulator");
>> +	return (BUS_PROBE_DEFAULT);
>> +static int
>> +regfix_detach(device_t dev)
>> +	/* This device is always present. */
>> +	return (EBUSY);
>> +static int
>> +regfix_attach(device_t dev)
>> +	int rv;
>> +	sc->dev = dev;
>> +	/* Parse FDT data. */
>> +	rv = regfix_parse_fdt(sc);
>> +	if (rv != 0)
>> +		return(ENXIO);
>> +	/* Fill reset of init. */
>> +	sc->init_def.reg_init_def.id = 1;
>> +	sc->init_def.reg_init_def.flags = REGULATOR_FLAGS_STATIC;
>> +	if (rv != 0)
>> +static device_method_t regfix_methods[] = {
>> +	DEVMETHOD(device_probe,		regfix_probe),
>> +	DEVMETHOD(device_attach,	regfix_attach),
>> +	DEVMETHOD(device_detach,	regfix_detach),
>> +	/* Bus interface */
>> +	DEVMETHOD(bus_new_pass,		regfix_new_pass),
>> +	/* Regdev interface */
>> +	DEVMETHOD(regdev_map,		regdev_default_ofw_map),
>> +	DEVMETHOD_END
>> +static devclass_t regfix_devclass;
>> +DEFINE_CLASS_0(regfix, regfix_driver, regfix_methods,
>> +    sizeof(struct regfix_softc));
>> +EARLY_DRIVER_MODULE(regfix, simplebus, regfix_driver,
>> +   regfix_devclass, 0, 0, BUS_PASS_BUS);
>> +#endif /* FDT */
>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>> b/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>> index 00000000..5cc07516
>> --- /dev/null
>> +++ b/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>> @@ -0,0 +1,44 @@
>> + * are met:
>> IS'' AND
>> TO, THE
>> PARTICULAR PURPOSE
>> BE LIABLE
>> CONSEQUENTIAL
>> SUBSTITUTE GOODS
>> INTERRUPTION)
>> CONTRACT, STRICT
>> IN ANY WAY
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> +#ifndef _DEV_EXTRES_REGULATOR_FIXED_H_
>> +#define _DEV_EXTRES_REGULATOR_FIXED_H_
>> +struct regnode_fixed_init_def {
>> +	struct regnode_init_def	reg_init_def;
>> +	struct gpiobus_pin	*gpio_pin;
>> +int regnode_fixed_register(device_t dev,
>> +    struct regnode_fixed_init_def *init_def);
>> +#endif /*_DEV_EXTRES_REGULATOR_FIXED_H_*/
>> diff --git a/freebsd/sys/dev/gpio/gpioregulator.c
>> b/freebsd/sys/dev/gpio/gpioregulator.c
>> index 00000000..6d05e52e
>> --- /dev/null
>> +++ b/freebsd/sys/dev/gpio/gpioregulator.c
>> @@ -0,0 +1,350 @@
>> + * Copyright (c) 2016 Jared McNeill <jmcneill at invisible.ca>
>> + * are met:
>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
>> OR
>> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
>> WARRANTIES
>> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
>> DISCLAIMED.
>> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
>> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
>> (INCLUDING,
>> + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
>> SERVICES;
>> + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>> HOWEVER CAUSED
>> + * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>> LIABILITY,
>> + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
>> POSSIBILITY OF
>> + * SUCH DAMAGE.
>> + * $FreeBSD$
>> + * GPIO controlled regulators
>> +#include <sys/rman.h>
>> +struct gpioregulator_state {
>> +	int			val;
>> +	uint32_t		mask;
>> +struct gpioregulator_init_def {
>> +	struct gpiobus_pin		*enable_pin;
>> +	int				enable_pin_valid;
>> +	int				startup_delay_us;
>> +	int				nstates;
>> +	struct gpioregulator_state	*states;
>> +	int				npins;
>> +	struct gpiobus_pin		**pins;
>> +struct gpioregulator_reg_sc {
>> +	device_t			base_dev;
>> +	struct gpioregulator_init_def	*def;
>> +struct gpioregulator_softc {
>> +	device_t			dev;
>> +	struct gpioregulator_reg_sc	*reg_sc;
>> +	struct gpioregulator_init_def	init_def;
>> +static int
>> +gpioregulator_regnode_init(struct regnode *regnode)
>> +	struct gpioregulator_reg_sc *sc;
>> +	int error, n;
>> +	if (sc->def->enable_pin_valid == 1) {
>> +		error = gpio_pin_setflags(sc->def->enable_pin,
>> GPIO_PIN_OUTPUT);
>> +		if (error != 0)
>> +			return (error);
>> +	for (n = 0; n < sc->def->npins; n++) {
>> +		error = gpio_pin_setflags(sc->def->pins[n],
>> GPIO_PIN_OUTPUT);
>> +		if (error != 0)
>> +			return (error);
>> +	return (0);
>> +static int
>> +gpioregulator_regnode_enable(struct regnode *regnode, bool enable, int
>> *udelay)
>> +	bool active;
>> +	int error;
>> +		active = enable;
>> +			active = !active;
>> +		error = gpio_pin_set_active(sc->def->enable_pin, active);
>> +		if (error != 0)
>> +			return (error);
>> +	*udelay = sc->def->startup_delay_us;
>> +	return (0);
>> +static int
>> +gpioregulator_regnode_set_voltage(struct regnode *regnode, int
>> min_uvolt,
>> +	const struct gpioregulator_state *state;
>> +	int error, n;
>> +	state = NULL;
>> +	for (n = 0; n < sc->def->nstates; n++) {
>> +		if (sc->def->states[n].val >= min_uvolt &&
>> +		    sc->def->states[n].val <= max_uvolt) {
>> +			state = &sc->def->states[n];
>> +			break;
>> +	if (state == NULL)
>> +		return (EINVAL);
>> +		error = gpio_pin_set_active(sc->def->pins[n],
>> +		    (state->mask >> n) & 1);
>> +		if (error != 0)
>> +			return (error);
>> +	return (0);
>> +static int
>> +gpioregulator_regnode_get_voltage(struct regnode *regnode, int *uvolt)
>> +	uint32_t mask;
>> +	int error, n;
>> +	bool active;
>> +	mask = 0;
>> +		error = gpio_pin_is_active(sc->def->pins[n], &active);
>> +		if (error != 0)
>> +			return (error);
>> +		mask |= (active << n);
>> +		if (sc->def->states[n].mask == mask) {
>> +			*uvolt = sc->def->states[n].val;
>> +			return (0);
>> +	return (EIO);
>> +static regnode_method_t gpioregulator_regnode_methods[] = {
>> +	REGNODEMETHOD(regnode_init,	gpioregulator_regnode_init),
>> 	gpioregulator_regnode_enable),
>> gpioregulator_regnode_set_voltage),
>> gpioregulator_regnode_get_voltage),
>> +	REGNODEMETHOD_END
>> +DEFINE_CLASS_1(gpioregulator_regnode, gpioregulator_regnode_class,
>> +    gpioregulator_regnode_methods, sizeof(struct gpioregulator_reg_sc),
>> +    regnode_class);
>> +static int
>> +gpioregulator_parse_fdt(struct gpioregulator_softc *sc)
>> +	uint32_t *pstates, mask;
>> +	phandle_t node;
>> +	ssize_t len;
>> +	int error, n;
>> +	pstates = NULL;
>> +	mask = 0;
>> +	error = regulator_parse_ofw_stdparam(sc->dev, node,
>> +	    &sc->init_def.reg_init_def);
>> +	if (error != 0)
>> +		return (error);
>> +	/* "states" property (required) */
>> +	len = OF_getencprop_alloc_multi(node, "states", sizeof(*pstates),
>> +	    (void **)&pstates);
>> +	if (len < 2) {
>> +		device_printf(sc->dev, "invalid 'states' property\n");
>> +		error = EINVAL;
>> +		goto done;
>> +	sc->init_def.nstates = len / 2;
>> +	sc->init_def.states = malloc(sc->init_def.nstates *
>> +	    sizeof(*sc->init_def.states), M_DEVBUF, M_WAITOK);
>> +	for (n = 0; n < sc->init_def.nstates; n++) {
>> +		sc->init_def.states[n].val = pstates[n * 2 + 0];
>> +		sc->init_def.states[n].mask = pstates[n * 2 + 1];
>> +		mask |= sc->init_def.states[n].mask;
>> +	/* "startup-delay-us" property (optional) */
>> +	len = OF_getencprop(node, "startup-delay-us",
>> +	    &sc->init_def.startup_delay_us,
>> +	    sizeof(sc->init_def.startup_delay_us));
>> +	if (len <= 0)
>> +		sc->init_def.startup_delay_us = 0;
>> +	/* "enable-gpio" property (optional) */
>> +	error = gpio_pin_get_by_ofw_property(sc->dev, node, "enable-
>> gpio",
>> +	    &sc->init_def.enable_pin);
>> +	if (error == 0)
>> +		sc->init_def.enable_pin_valid = 1;
>> +	/* "gpios" property */
>> +	sc->init_def.npins = 32 - __builtin_clz(mask);
>> +	sc->init_def.pins = malloc(sc->init_def.npins *
>> +	    sizeof(sc->init_def.pins), M_DEVBUF, M_WAITOK);
>> +	for (n = 0; n < sc->init_def.npins; n++) {
>> +		error = gpio_pin_get_by_ofw_idx(sc->dev, node, n,
>> +		    &sc->init_def.pins[n]);
>> +		if (error != 0) {
>> +			device_printf(sc->dev, "cannot get pin %d\n", n);
>> +			goto done;
>> +done:
>> +	if (error != 0) {
>> +			if (sc->init_def.pins[n] != NULL)
>> +				gpio_pin_release(sc->init_def.pins[n]);
>> +		free(sc->init_def.states, M_DEVBUF);
>> +		free(sc->init_def.pins, M_DEVBUF);
>> +	OF_prop_free(pstates);
>> +	return (error);
>> +static int
>> +gpioregulator_probe(device_t dev)
>> +	if (!ofw_bus_is_compatible(dev, "regulator-gpio"))
>> +		return (ENXIO);
>> +	device_set_desc(dev, "GPIO controlled regulator");
>> +	return (BUS_PROBE_GENERIC);
>> +static int
>> +gpioregulator_attach(device_t dev)
>> +	struct gpioregulator_softc *sc;
>> +	phandle_t node;
>> +	int error;
>> +	sc->dev = dev;
>> +	error = gpioregulator_parse_fdt(sc);
>> +	if (error != 0) {
>> +		device_printf(dev, "cannot parse parameters\n");
>> +		return (ENXIO);
>> +	sc->init_def.reg_init_def.ofw_node = node;
>> +	regnode = regnode_create(dev, &gpioregulator_regnode_class,
>> +		device_printf(dev, "cannot create regulator\n");
>> +		return (ENXIO);
>> +	sc->reg_sc = regnode_get_softc(regnode);
>> +	sc->reg_sc->regnode = regnode;
>> +	sc->reg_sc->base_dev = dev;
>> +	sc->reg_sc->param = regnode_get_stdparam(regnode);
>> +	sc->reg_sc->def = &sc->init_def;
>> +	regnode_register(regnode);
>> +	return (0);
>> +static device_method_t gpioregulator_methods[] = {
>> +	DEVMETHOD(device_probe,		gpioregulator_probe),
>> +	DEVMETHOD(device_attach,	gpioregulator_attach),
>> +	DEVMETHOD_END
>> +static driver_t gpioregulator_driver = {
>> +	"gpioregulator",
>> +	gpioregulator_methods,
>> +	sizeof(struct gpioregulator_softc),
>> +static devclass_t gpioregulator_devclass;
>> +EARLY_DRIVER_MODULE(gpioregulator, simplebus, gpioregulator_driver,
>> +    gpioregulator_devclass, 0, 0, BUS_PASS_INTERRUPT +
>> BUS_PASS_ORDER_LAST);
>> +MODULE_VERSION(gpioregulator, 1);
>> 2.16.4
>> devel mailing list
>> devel at rtems.org
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
