[PATCH rtems-libbsd v2 06/14] regulator: Import from FreeBSD.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Apr 17 08:15:38 UTC 2020
Hello Jan,
On 17/04/2020 10:11, Jan.Sommer at dlr.de wrote:
> Hi Christian,
> Yes, with this patch my build works again.
> Thank you very much.
Thanks for testing.
Best regards
Christian
> Best regards,
> Jan
>> -----Ursprüngliche Nachricht-----
>> Von: Christian Mauderer [mailto:christian.mauderer at embedded-brains.de]
>> Gesendet: Freitag, 17. April 2020 09:17
>> An: Sommer, Jan; devel at rtems.org
>> Betreff: Re: [PATCH rtems-libbsd v2 06/14] regulator: Import from FreeBSD.
>> Hello Jan,
>> can you please try this patch:
>> https://lists.rtems.org/pipermail/devel/2020-April/059419.html
>> I've still seen quite some linker errors in if_em.c. But as far as I can
>> tell they doesn't seem to be related. Are they?
>> Best regards
>> Christian
>> On 17/04/2020 08:17, Christian Mauderer wrote:
>>> Hello Jan,
>>> On 16/04/2020 22:27, Jan.Sommer at dlr.de wrote:
>>>> I have a question:
>>>> I just rebased my working tree for the i386 target to the current 5-
>> freebsd-12 branch.
>>>> The compilation now fails in regulator related files.
>>>> It seems that I am missing the FDT define and that comments out some
>> includes.
>>>> Could you tell me what FDT means in this context and do you know where
>> I can activate it?
>>> FDT is a flattened device tree. That's something that isn't used on
>>> i386. So most likely quite some more BSPs will have that problem.
>>> It's some code that I took over quite unchanged from FreeBSD. I would
>>> have expected that it is used in FreeBSD for a lot of different cases
>>> and therefore didn't expect a problem like that. I'll have a look at it.
>>> Best regards
>>> Christian
>>>> Cheers,
>>>> Jan
>>>>> Von: devel [mailto:devel-bounces at rtems.org] Im Auftrag von Christian
>>>>> Mauderer
>>>>> Gesendet: Dienstag, 14. April 2020 16:51
>>>>> An: devel at rtems.org
>>>>> Betreff: [PATCH rtems-libbsd v2 06/14] regulator: Import from FreeBSD.
>>>>> Update #3869.
>>>>> freebsd/sys/dev/extres/regulator/regulator.c | 1321
>>>>> freebsd/sys/dev/extres/regulator/regulator.h | 156 +++
>>>>> freebsd/sys/dev/extres/regulator/regulator_bus.c | 89 ++
>>>>> freebsd/sys/dev/extres/regulator/regulator_fixed.c | 502 ++++++++
>>>>> freebsd/sys/dev/extres/regulator/regulator_fixed.h | 44 +
>>>>> freebsd/sys/dev/gpio/gpioregulator.c | 350 ++++++
>>>>> 6 files changed, 2462 insertions(+)
>>>>> create mode 100644 freebsd/sys/dev/extres/regulator/regulator.c
>>>>> create mode 100644 freebsd/sys/dev/extres/regulator/regulator.h
>>>>> create mode 100644 freebsd/sys/dev/extres/regulator/regulator_bus.c
>>>>> create mode 100644
>>>>> create mode 100644
>>>>> create mode 100644 freebsd/sys/dev/gpio/gpioregulator.c
>>>>> diff --git a/freebsd/sys/dev/extres/regulator/regulator.c
>>>>> b/freebsd/sys/dev/extres/regulator/regulator.c
>>>>> new file mode 100644
>>>>> index 00000000..4ad6e94a
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/extres/regulator/regulator.c
>>>>> @@ -0,0 +1,1321 @@
>>>>> +#include <machine/rtems-bsd-kernel-space.h>
>>>>> + * Copyright 2016 Michal Meloun <mmel at FreeBSD.org>
>>>>> + * All rights reserved.
>>>>> + * Redistribution and use in source and binary forms, with or without
>>>>> + * modification, are permitted provided that the following conditions
>>>>> + * are met:
>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>> + * notice, this list of conditions and the following disclaimer.
>>>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>>>> + * notice, this list of conditions and the following disclaimer in the
>>>>> + * documentation and/or other materials provided with the
>> distribution.
>>>>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS
>> ``AS
>>>>> IS'' AND
>>>>> + * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>> LIMITED
>>>>> TO, THE
>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>> PARTICULAR PURPOSE
>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR
>> CONTRIBUTORS
>>>>> BE LIABLE
>>>>> + * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>>>> CONSEQUENTIAL
>>>>> + * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>>>> SUBSTITUTE GOODS
>>>>> + * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>>>> INTERRUPTION)
>>>>> + * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>>>>> CONTRACT, STRICT
>>>>> + * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> ARISING
>>>>> IN ANY WAY
>>>>> + * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> +#include <sys/cdefs.h>
>>>>> +__FBSDID("$FreeBSD$");
>>>>> +#include <rtems/bsd/local/opt_platform.h>
>>>>> +#include <sys/param.h>
>>>>> +#include <sys/conf.h>
>>>>> +#include <sys/bus.h>
>>>>> +#include <sys/kernel.h>
>>>>> +#include <sys/queue.h>
>>>>> +#include <sys/kobj.h>
>>>>> +#include <sys/malloc.h>
>>>>> +#include <sys/mutex.h>
>>>>> +#include <sys/limits.h>
>>>>> +#include <sys/lock.h>
>>>>> +#include <sys/sysctl.h>
>>>>> +#include <sys/systm.h>
>>>>> +#include <sys/sx.h>
>>>>> +#ifdef FDT
>>>>> +#include <dev/fdt/fdt_common.h>
>>>>> +#include <dev/ofw/ofw_bus.h>
>>>>> +#include <dev/ofw/ofw_bus_subr.h>
>>>>> +#endif
>>>>> +#include <dev/extres/regulator/regulator.h>
>>>>> +#include <rtems/bsd/local/regdev_if.h>
>>>>> +SYSCTL_NODE(_hw, OID_AUTO, regulator, CTLFLAG_RD, NULL,
>>>>> "Regulators");
>>>>> +MALLOC_DEFINE(M_REGULATOR, "regulator", "Regulator
>> framework");
>>>>> +#define DIV_ROUND_UP(n,d) howmany(n, d)
>>>>> +/* Forward declarations. */
>>>>> +struct regulator;
>>>>> +struct regnode;
>>>>> +typedef TAILQ_HEAD(regnode_list, regnode) regnode_list_t;
>>>>> +typedef TAILQ_HEAD(regulator_list, regulator) regulator_list_t;
>>>>> +/* Default regulator methods. */
>>>>> +static int regnode_method_init(struct regnode *regnode);
>>>>> +static int regnode_method_enable(struct regnode *regnode, bool
>> enable,
>>>>> + int *udelay);
>>>>> +static int regnode_method_status(struct regnode *regnode, int
>> *status);
>>>>> +static int regnode_method_set_voltage(struct regnode *regnode, int
>>>>> min_uvolt,
>>>>> + int max_uvolt, int *udelay);
>>>>> +static int regnode_method_get_voltage(struct regnode *regnode, int
>>>>> *uvolt);
>>>>> +static void regulator_constraint(void *dummy);
>>>>> +static void regulator_shutdown(void *dummy);
>>>>> + * Regulator controller methods.
>>>>> +static regnode_method_t regnode_methods[] = {
>>>>> + REGNODEMETHOD(regnode_init,
>>>>> regnode_method_init),
>>>>> + REGNODEMETHOD(regnode_enable,
>>>>> regnode_method_enable),
>>>>> + REGNODEMETHOD(regnode_status,
>>>>> regnode_method_status),
>>>>> + REGNODEMETHOD(regnode_set_voltage,
>>>>> regnode_method_set_voltage),
>>>>> + REGNODEMETHOD(regnode_get_voltage,
>>>>> regnode_method_get_voltage),
>>>>> + REGNODEMETHOD(regnode_check_voltage,
>>>>> regnode_method_check_voltage),
>>>>> + REGNODEMETHOD_END
>>>>> +DEFINE_CLASS_0(regnode, regnode_class, regnode_methods, 0);
>>>>> + * Regulator node - basic element for modelling SOC and bard power
>> supply
>>>>> + * chains. Its contains producer data.
>>>>> +struct regnode {
>>>>> + KOBJ_FIELDS;
>>>>> + TAILQ_ENTRY(regnode) reglist_link; /* Global list entry */
>>>>> + regulator_list_t consumers_list; /* Consumers list */
>>>>> + /* Cache for already resolved names */
>>>>> + struct regnode *parent; /* Resolved parent */
>>>>> + /* Details of this device. */
>>>>> + const char *name; /* Globally unique
>>>>> name */
>>>>> + const char *parent_name; /* Parent name */
>>>>> + device_t pdev; /* Producer device_t */
>>>>> + void *softc; /* Producer softc */
>>>>> + intptr_t id; /* Per producer unique id */
>>>>> +#ifdef FDT
>>>>> + phandle_t ofw_node; /* OFW node of regulator */
>>>>> +#endif
>>>>> + int flags; /* REGULATOR_FLAGS_ */
>>>>> + struct sx lock; /* Lock for this regulator */
>>>>> + int ref_cnt; /* Reference counter */
>>>>> + int enable_cnt; /* Enabled counter */
>>>>> + struct regnode_std_param std_param; /* Standard
>>>>> parameters */
>>>>> + struct sysctl_ctx_list sysctl_ctx;
>>>>> + * Per consumer data, information about how a consumer is using a
>>>>> regulator
>>>>> + * node.
>>>>> + * A pointer to this structure is used as a handle in the consumer
>> interface.
>>>>> +struct regulator {
>>>>> + device_t cdev; /* Consumer device */
>>>>> + struct regnode *regnode;
>>>>> + TAILQ_ENTRY(regulator) link; /* Consumers list
>>>>> entry */
>>>>> + int enable_cnt;
>>>>> + int min_uvolt; /* Requested uvolt range */
>>>>> + int max_uvolt;
>>>>> + * Regulator names must be system wide unique.
>>>>> +static regnode_list_t regnode_list =
>>>>> TAILQ_HEAD_INITIALIZER(regnode_list);
>>>>> +static struct sx regnode_topo_lock;
>>>>> +SX_SYSINIT(regulator_topology, ®node_topo_lock, "Regulator
>> topology
>>>>> lock");
>>>>> +#define REG_TOPO_SLOCK() sx_slock(®node_topo_lock)
>>>>> +#define REG_TOPO_XLOCK() sx_xlock(®node_topo_lock)
>>>>> +#define REG_TOPO_UNLOCK() sx_unlock(®node_topo_lock)
>>>>> +#define REG_TOPO_ASSERT() sx_assert(®node_topo_lock,
>>>>> SA_LOCKED)
>>>>> +#define REG_TOPO_XASSERT() sx_assert(®node_topo_lock,
>>>>> SA_XLOCKED)
>>>>> +#define REGNODE_SLOCK(_sc) sx_slock(&((_sc)->lock))
>>>>> +#define REGNODE_XLOCK(_sc) sx_xlock(&((_sc)->lock))
>>>>> +#define REGNODE_UNLOCK(_sc) sx_unlock(&((_sc)->lock))
>>>>> +SYSINIT(regulator_constraint, SI_SUB_LAST, SI_ORDER_ANY,
>>>>> + NULL);
>>>>> +SYSINIT(regulator_shutdown, SI_SUB_LAST, SI_ORDER_ANY,
>>>>> regulator_shutdown,
>>>>> + NULL);
>>>>> +static void
>>>>> +regulator_constraint(void *dummy)
>>>>> + struct regnode *entry;
>>>>> + int rv;
>>>>> + REG_TOPO_SLOCK();
>>>>> + TAILQ_FOREACH(entry, ®node_list, reglist_link) {
>>>>> + rv = regnode_set_constraint(entry);
>>>>> + if (rv != 0 && bootverbose)
>>>>> + printf("regulator: setting constraint on %s failed
>>>>> (%d)\n",
>>>>> + entry->name, rv);
>>>>> + REG_TOPO_UNLOCK();
>>>>> + * Disable unused regulator
>>>>> + * We run this function at SI_SUB_LAST which mean that every driver
>> that
>>>>> needs
>>>>> + * regulator should have already enable them.
>>>>> + * All the remaining regulators should be those left enabled by the
>>>>> bootloader
>>>>> + * or enable by default by the PMIC.
>>>>> +static void
>>>>> +regulator_shutdown(void *dummy)
>>>>> + int status, ret;
>>>>> + int disable = 1;
>>>>> + TUNABLE_INT_FETCH("hw.regulator.disable_unused", &disable);
>>>>> + if (!disable)
>>>>> + return;
>>>>> + REG_TOPO_SLOCK();
>>>>> + if (bootverbose)
>>>>> + printf("regulator: shutting down unused regulators\n");
>>>>> + if (!entry->std_param.always_on) {
>>>>> + ret = regnode_status(entry, &status);
>>>>> + if (ret == 0 && status ==
>>>>> REGULATOR_STATUS_ENABLED) {
>>>>> + if (bootverbose)
>>>>> + printf("regulator: shutting down %s...
>>>>> + entry->name);
>>>>> + ret = regnode_stop(entry, 0);
>>>>> + if (bootverbose) {
>>>>> + * Call out busy in particular, here,
>>>>> + * because it's not unexpected to fail
>>>>> + * shutdown if the regulator is simply
>>>>> + * in-use.
>>>>> + if (ret == EBUSY)
>>>>> + printf("busy\n");
>>>>> + else if (ret != 0)
>>>>> + printf("error (%d)\n", ret);
>>>>> + else
>>>>> + printf("ok\n");
>>>>> + * sysctl handler
>>>>> +static int
>>>>> +regnode_uvolt_sysctl(SYSCTL_HANDLER_ARGS)
>>>>> + struct regnode *regnode = arg1;
>>>>> + int rv, uvolt;
>>>>> + if (regnode->std_param.min_uvolt == regnode-
>>>>>> std_param.max_uvolt) {
>>>>> + uvolt = regnode->std_param.min_uvolt;
>>>>> + } else {
>>>>> + REG_TOPO_SLOCK();
>>>>> + if ((rv = regnode_get_voltage(regnode, &uvolt)) != 0) {
>>>>> + return (rv);
>>>>> + return sysctl_handle_int(oidp, &uvolt, sizeof(uvolt), req);
>>>>> + * Default regulator methods for base class.
>>>>> +static int
>>>>> +regnode_method_init(struct regnode *regnode)
>>>>> + return (0);
>>>>> +static int
>>>>> +regnode_method_enable(struct regnode *regnode, bool enable, int
>>>>> *udelay)
>>>>> + if (!enable)
>>>>> + return (ENXIO);
>>>>> + *udelay = 0;
>>>>> + return (0);
>>>>> +static int
>>>>> +regnode_method_status(struct regnode *regnode, int *status)
>>>>> + *status = REGULATOR_STATUS_ENABLED;
>>>>> + return (0);
>>>>> +static int
>>>>> +regnode_method_set_voltage(struct regnode *regnode, int
>> min_uvolt, int
>>>>> max_uvolt,
>>>>> + int *udelay)
>>>>> + if ((min_uvolt > regnode->std_param.max_uvolt) ||
>>>>> + (max_uvolt < regnode->std_param.min_uvolt))
>>>>> + return (ERANGE);
>>>>> + *udelay = 0;
>>>>> + return (0);
>>>>> +static int
>>>>> +regnode_method_get_voltage(struct regnode *regnode, int *uvolt)
>>>>> + return (regnode->std_param.min_uvolt +
>>>>> + (regnode->std_param.max_uvolt - regnode-
>>>>>> std_param.min_uvolt) / 2);
>>>>> +int
>>>>> +regnode_method_check_voltage(struct regnode *regnode, int uvolt)
>>>>> + if ((uvolt > regnode->std_param.max_uvolt) ||
>>>>> + (uvolt < regnode->std_param.min_uvolt))
>>>>> + return (ERANGE);
>>>>> + return (0);
>>>>> + * Internal functions.
>>>>> +static struct regnode *
>>>>> +regnode_find_by_name(const char *name)
>>>>> + REG_TOPO_ASSERT();
>>>>> + if (strcmp(entry->name, name) == 0)
>>>>> + return (entry);
>>>>> + return (NULL);
>>>>> +regnode_find_by_id(device_t dev, intptr_t id)
>>>>> + if ((entry->pdev == dev) && (entry->id == id))
>>>>> + return (entry);
>>>>> + return (NULL);
>>>>> + * Create and initialize regulator object, but do not register it.
>>>>> +struct regnode *
>>>>> +regnode_create(device_t pdev, regnode_class_t regnode_class,
>>>>> + struct regnode_init_def *def)
>>>>> + struct sysctl_oid *regnode_oid;
>>>>> + KASSERT(def->name != NULL, ("regulator name is NULL"));
>>>>> + KASSERT(def->name[0] != '\0', ("regulator name is empty"));
>>>>> + REG_TOPO_SLOCK();
>>>>> + if (regnode_find_by_name(def->name) != NULL)
>>>>> + panic("Duplicated regulator registration: %s\n", def->name);
>>>>> + /* Create object and initialize it. */
>>>>> + regnode = malloc(sizeof(struct regnode), M_REGULATOR,
>>>>> + M_WAITOK | M_ZERO);
>>>>> + kobj_init((kobj_t)regnode, (kobj_class_t)regnode_class);
>>>>> + sx_init(®node->lock, "Regulator node lock");
>>>>> + /* Allocate softc if required. */
>>>>> + if (regnode_class->size > 0) {
>>>>> + regnode->softc = malloc(regnode_class->size,
>>>>> M_REGULATOR,
>>>>> + /* Copy all strings unless they're flagged as static. */
>>>>> + if (def->flags & REGULATOR_FLAGS_STATIC) {
>>>>> + regnode->name = def->name;
>>>>> + regnode->parent_name = def->parent_name;
>>>>> + } else {
>>>>> + regnode->name = strdup(def->name, M_REGULATOR);
>>>>> + if (def->parent_name != NULL)
>>>>> + regnode->parent_name = strdup(def-
>>>>>> parent_name,
>>>>> + M_REGULATOR);
>>>>> + /* Rest of init. */
>>>>> + TAILQ_INIT(®node->consumers_list);
>>>>> + regnode->id = def->id;
>>>>> + regnode->pdev = pdev;
>>>>> + regnode->flags = def->flags;
>>>>> + regnode->parent = NULL;
>>>>> + regnode->std_param = def->std_param;
>>>>> +#ifdef FDT
>>>>> + regnode->ofw_node = def->ofw_node;
>>>>> +#endif
>>>>> + sysctl_ctx_init(®node->sysctl_ctx);
>>>>> + regnode_oid = SYSCTL_ADD_NODE(®node->sysctl_ctx,
>>>>> + SYSCTL_STATIC_CHILDREN(_hw_regulator),
>>>>> + OID_AUTO, regnode->name,
>>>>> + CTLFLAG_RD, 0, "A regulator node");
>>>>> + SYSCTL_ADD_INT(®node->sysctl_ctx,
>>>>> + SYSCTL_CHILDREN(regnode_oid),
>>>>> + OID_AUTO, "min_uvolt",
>>>>> + CTLFLAG_RD, ®node->std_param.min_uvolt, 0,
>>>>> + "Minimal voltage (in uV)");
>>>>> + OID_AUTO, "max_uvolt",
>>>>> + CTLFLAG_RD, ®node->std_param.max_uvolt, 0,
>>>>> + "Maximal voltage (in uV)");
>>>>> + OID_AUTO, "min_uamp",
>>>>> + CTLFLAG_RD, ®node->std_param.min_uamp, 0,
>>>>> + "Minimal amperage (in uA)");
>>>>> + OID_AUTO, "max_uamp",
>>>>> + CTLFLAG_RD, ®node->std_param.max_uamp, 0,
>>>>> + "Maximal amperage (in uA)");
>>>>> + OID_AUTO, "ramp_delay",
>>>>> + CTLFLAG_RD, ®node->std_param.ramp_delay, 0,
>>>>> + "Ramp delay (in uV/us)");
>>>>> + OID_AUTO, "enable_delay",
>>>>> + CTLFLAG_RD, ®node->std_param.enable_delay, 0,
>>>>> + "Enable delay (in us)");
>>>>> + OID_AUTO, "enable_cnt",
>>>>> + CTLFLAG_RD, ®node->enable_cnt, 0,
>>>>> + "The regulator enable counter");
>>>>> + SYSCTL_ADD_U8(®node->sysctl_ctx,
>>>>> + OID_AUTO, "boot_on",
>>>>> + CTLFLAG_RD, (uint8_t *) ®node->std_param.boot_on, 0,
>>>>> + "Is enabled on boot");
>>>>> + OID_AUTO, "always_on",
>>>>> + CTLFLAG_RD, (uint8_t *)®node->std_param.always_on, 0,
>>>>> + "Is always enabled");
>>>>> + SYSCTL_ADD_PROC(®node->sysctl_ctx,
>>>>> + OID_AUTO, "uvolt",
>>>>> + CTLTYPE_INT | CTLFLAG_RD,
>>>>> + regnode, 0, regnode_uvolt_sysctl,
>>>>> + "I",
>>>>> + "Current voltage (in uV)");
>>>>> + return (regnode);
>>>>> +/* Register regulator object. */
>>>>> +struct regnode *
>>>>> +regnode_register(struct regnode *regnode)
>>>>> + int rv;
>>>>> +#ifdef FDT
>>>>> + if (regnode->ofw_node <= 0)
>>>>> + regnode->ofw_node = ofw_bus_get_node(regnode->pdev);
>>>>> + return (NULL);
>>>>> +#endif
>>>>> + rv = REGNODE_INIT(regnode);
>>>>> + if (rv != 0) {
>>>>> + printf("REGNODE_INIT failed: %d\n", rv);
>>>>> + return (NULL);
>>>>> + REG_TOPO_XLOCK();
>>>>> + TAILQ_INSERT_TAIL(®node_list, regnode, reglist_link);
>>>>> +#ifdef FDT
>>>>> + OF_device_register_xref(OF_xref_from_node(regnode-
>>>>>> ofw_node),
>>>>> + regnode->pdev);
>>>>> +#endif
>>>>> + return (regnode);
>>>>> +static int
>>>>> +regnode_resolve_parent(struct regnode *regnode)
>>>>> + /* All ready resolved or no parent? */
>>>>> + if ((regnode->parent != NULL) ||
>>>>> + (regnode->parent_name == NULL))
>>>>> + return (0);
>>>>> + regnode->parent = regnode_find_by_name(regnode-
>>>>>> parent_name);
>>>>> + if (regnode->parent == NULL)
>>>>> + return (ENODEV);
>>>>> + return (0);
>>>>> +static void
>>>>> +regnode_delay(int usec)
>>>>> + int ticks;
>>>>> + if (usec == 0)
>>>>> + return;
>>>>> + ticks = (usec * hz + 999999) / 1000000;
>>>>> + if (cold || ticks < 2)
>>>>> + DELAY(usec);
>>>>> + else
>>>>> + pause("REGULATOR", ticks);
>>>>> + * Regulator providers interface
>>>>> +const char *
>>>>> +regnode_get_name(struct regnode *regnode)
>>>>> + return (regnode->name);
>>>>> +const char *
>>>>> +regnode_get_parent_name(struct regnode *regnode)
>>>>> + return (regnode->parent_name);
>>>>> +int
>>>>> +regnode_get_flags(struct regnode *regnode)
>>>>> + return (regnode->flags);
>>>>> +void *
>>>>> +regnode_get_softc(struct regnode *regnode)
>>>>> + return (regnode->softc);
>>>>> +device_t
>>>>> +regnode_get_device(struct regnode *regnode)
>>>>> + return (regnode->pdev);
>>>>> +struct regnode_std_param *regnode_get_stdparam(struct regnode
>>>>> *regnode)
>>>>> + return (®node->std_param);
>>>>> +void regnode_topo_unlock(void)
>>>>> +void regnode_topo_xlock(void)
>>>>> + REG_TOPO_XLOCK();
>>>>> +void regnode_topo_slock(void)
>>>>> + REG_TOPO_SLOCK();
>>>>> + * Real consumers executive
>>>>> +struct regnode *
>>>>> +regnode_get_parent(struct regnode *regnode)
>>>>> + int rv;
>>>>> + rv = regnode_resolve_parent(regnode);
>>>>> + if (rv != 0)
>>>>> + return (NULL);
>>>>> + return (regnode->parent);
>>>>> + * Enable regulator.
>>>>> +int
>>>>> +regnode_enable(struct regnode *regnode)
>>>>> + int udelay;
>>>>> + int rv;
>>>>> + /* Enable regulator for each node in chain, starting from source. */
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + if (regnode->parent != NULL) {
>>>>> + rv = regnode_enable(regnode->parent);
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + /* Handle this node. */
>>>>> + REGNODE_XLOCK(regnode);
>>>>> + if (regnode->enable_cnt == 0) {
>>>>> + rv = REGNODE_ENABLE(regnode, true, &udelay);
>>>>> + if (rv != 0) {
>>>>> + REGNODE_UNLOCK(regnode);
>>>>> + return (rv);
>>>>> + regnode_delay(udelay);
>>>>> + regnode->enable_cnt++;
>>>>> + return (0);
>>>>> + * Disable regulator.
>>>>> +int
>>>>> +regnode_disable(struct regnode *regnode)
>>>>> + int udelay;
>>>>> + int rv;
>>>>> + rv = 0;
>>>>> + /* Disable regulator for each node in chain, starting from consumer.
>>>>> + if (regnode->enable_cnt == 1 &&
>>>>> + (regnode->flags & REGULATOR_FLAGS_NOT_DISABLE) == 0 &&
>>>>> + !regnode->std_param.always_on) {
>>>>> + rv = REGNODE_ENABLE(regnode, false, &udelay);
>>>>> + if (rv != 0) {
>>>>> + return (rv);
>>>>> + regnode->enable_cnt--;
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + rv = regnode_disable(regnode->parent);
>>>>> + return (rv);
>>>>> + * Stop regulator.
>>>>> +int
>>>>> +regnode_stop(struct regnode *regnode, int depth)
>>>>> + int udelay;
>>>>> + int rv;
>>>>> + rv = 0;
>>>>> + /* The first node must not be enabled. */
>>>>> + if ((regnode->enable_cnt != 0) && (depth == 0)) {
>>>>> + return (EBUSY);
>>>>> + if ((regnode->enable_cnt == 0) &&
>>>>> + ((regnode->flags & REGULATOR_FLAGS_NOT_DISABLE) == 0)) {
>>>>> + rv = REGNODE_STOP(regnode, &udelay);
>>>>> + if (rv != 0) {
>>>>> + return (rv);
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + if (regnode->parent != NULL && regnode->parent->enable_cnt == 0)
>>>>> + rv = regnode_stop(regnode->parent, depth + 1);
>>>>> + return (rv);
>>>>> + * Get regulator status. (REGULATOR_STATUS_*)
>>>>> +int
>>>>> +regnode_status(struct regnode *regnode, int *status)
>>>>> + int rv;
>>>>> + rv = REGNODE_STATUS(regnode, status);
>>>>> + return (rv);
>>>>> + * Get actual regulator voltage.
>>>>> +int
>>>>> +regnode_get_voltage(struct regnode *regnode, int *uvolt)
>>>>> + int rv;
>>>>> + rv = REGNODE_GET_VOLTAGE(regnode, uvolt);
>>>>> + /* Pass call into parent, if regulator is in bypass mode. */
>>>>> + if (rv == ENOENT) {
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + rv = regnode_get_voltage(regnode->parent, uvolt);
>>>>> + return (rv);
>>>>> + * Set regulator voltage.
>>>>> +int
>>>>> +regnode_set_voltage(struct regnode *regnode, int min_uvolt, int
>>>>> max_uvolt)
>>>>> + int udelay;
>>>>> + int rv;
>>>>> + rv = REGNODE_SET_VOLTAGE(regnode, min_uvolt, max_uvolt,
>>>>> &udelay);
>>>>> + if (rv == 0)
>>>>> + return (rv);
>>>>> + * Consumer variant of regnode_set_voltage().
>>>>> +static int
>>>>> +regnode_set_voltage_checked(struct regnode *regnode, struct
>> regulator
>>>>> *reg,
>>>>> + int min_uvolt, int max_uvolt)
>>>>> + int udelay;
>>>>> + int all_max_uvolt;
>>>>> + int all_min_uvolt;
>>>>> + struct regulator *tmp;
>>>>> + int rv;
>>>>> + /* Return error if requested range is outside of regulator range. */
>>>>> + (max_uvolt < regnode->std_param.min_uvolt)) {
>>>>> + return (ERANGE);
>>>>> + /* Get actual voltage range for all consumers. */
>>>>> + all_min_uvolt = regnode->std_param.min_uvolt;
>>>>> + all_max_uvolt = regnode->std_param.max_uvolt;
>>>>> + TAILQ_FOREACH(tmp, ®node->consumers_list, link) {
>>>>> + /* Don't take requestor in account. */
>>>>> + if (tmp == reg)
>>>>> + continue;
>>>>> + if (all_min_uvolt < tmp->min_uvolt)
>>>>> + all_min_uvolt = tmp->min_uvolt;
>>>>> + if (all_max_uvolt > tmp->max_uvolt)
>>>>> + all_max_uvolt = tmp->max_uvolt;
>>>>> + /* Test if request fits to actual contract. */
>>>>> + if ((min_uvolt > all_max_uvolt) ||
>>>>> + (max_uvolt < all_min_uvolt)) {
>>>>> + return (ERANGE);
>>>>> + /* Adjust new range.*/
>>>>> + if (min_uvolt < all_min_uvolt)
>>>>> + min_uvolt = all_min_uvolt;
>>>>> + if (max_uvolt > all_max_uvolt)
>>>>> + max_uvolt = all_max_uvolt;
>>>>> &udelay);
>>>>> + return (rv);
>>>>> +int
>>>>> +regnode_set_constraint(struct regnode *regnode)
>>>>> + int status, rv, uvolt;
>>>>> + if (regnode->std_param.boot_on != true &&
>>>>> + regnode->std_param.always_on != true)
>>>>> + return (0);
>>>>> + rv = regnode_status(regnode, &status);
>>>>> + if (rv != 0) {
>>>>> + if (bootverbose)
>>>>> + printf("Cannot get regulator status for %s\n",
>>>>> + regnode_get_name(regnode));
>>>>> + return (rv);
>>>>> + if (status == REGULATOR_STATUS_ENABLED)
>>>>> + return (0);
>>>>> + rv = regnode_get_voltage(regnode, &uvolt);
>>>>> + if (rv != 0) {
>>>>> + if (bootverbose)
>>>>> + printf("Cannot get regulator voltage for %s\n",
>>>>> + return (rv);
>>>>> + if (uvolt < regnode->std_param.min_uvolt ||
>>>>> + uvolt > regnode->std_param.max_uvolt) {
>>>>> + if (bootverbose)
>>>>> + printf("Regulator %s current voltage %d is not in the"
>>>>> + " acceptable range : %d<->%d\n",
>>>>> + regnode_get_name(regnode),
>>>>> + uvolt, regnode->std_param.min_uvolt,
>>>>> + regnode->std_param.max_uvolt);
>>>>> + return (ERANGE);
>>>>> + rv = regnode_enable(regnode);
>>>>> + if (rv != 0) {
>>>>> + if (bootverbose)
>>>>> + printf("Cannot enable regulator %s\n",
>>>>> + return (rv);
>>>>> + return (0);
>>>>> +#ifdef FDT
>>>>> +phandle_t
>>>>> +regnode_get_ofw_node(struct regnode *regnode)
>>>>> + return (regnode->ofw_node);
>>>>> +#endif
>>>>> + * Regulator consumers interface.
>>>>> +/* Helper function for regulator_get*() */
>>>>> +static regulator_t
>>>>> +regulator_create(struct regnode *regnode, device_t cdev)
>>>>> + struct regulator *reg;
>>>>> + reg = malloc(sizeof(struct regulator), M_REGULATOR,
>>>>> + reg->cdev = cdev;
>>>>> + reg->regnode = regnode;
>>>>> + reg->enable_cnt = 0;
>>>>> + regnode->ref_cnt++;
>>>>> + TAILQ_INSERT_TAIL(®node->consumers_list, reg, link);
>>>>> + reg ->min_uvolt = regnode->std_param.min_uvolt;
>>>>> + reg ->max_uvolt = regnode->std_param.max_uvolt;
>>>>> + return (reg);
>>>>> +int
>>>>> +regulator_enable(regulator_t reg)
>>>>> + int rv;
>>>>> + regnode = reg->regnode;
>>>>> + KASSERT(regnode->ref_cnt > 0,
>>>>> + ("Attempt to access unreferenced regulator: %s\n", regnode-
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + if (rv == 0)
>>>>> + reg->enable_cnt++;
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_disable(regulator_t reg)
>>>>> + int rv;
>>>>>> name));
>>>>> + KASSERT(reg->enable_cnt > 0,
>>>>> + ("Attempt to disable already disabled regulator: %s\n",
>>>>> + regnode->name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = regnode_disable(regnode);
>>>>> + if (rv == 0)
>>>>> + reg->enable_cnt--;
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_stop(regulator_t reg)
>>>>> + int rv;
>>>>>> name));
>>>>> + KASSERT(reg->enable_cnt == 0,
>>>>> + ("Attempt to stop already enabled regulator: %s\n", regnode-
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = regnode_stop(regnode, 0);
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_status(regulator_t reg, int *status)
>>>>> + int rv;
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = regnode_status(regnode, status);
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_get_voltage(regulator_t reg, int *uvolt)
>>>>> + int rv;
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = regnode_get_voltage(regnode, uvolt);
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_set_voltage(regulator_t reg, int min_uvolt, int max_uvolt)
>>>>> + int rv;
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = regnode_set_voltage_checked(regnode, reg, min_uvolt,
>>>>> max_uvolt);
>>>>> + if (rv == 0) {
>>>>> + reg->min_uvolt = min_uvolt;
>>>>> + reg->max_uvolt = max_uvolt;
>>>>> + return (rv);
>>>>> +int
>>>>> +regulator_check_voltage(regulator_t reg, int uvolt)
>>>>> + int rv;
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + rv = REGNODE_CHECK_VOLTAGE(regnode, uvolt);
>>>>> + return (rv);
>>>>> +const char *
>>>>> +regulator_get_name(regulator_t reg)
>>>>>> name));
>>>>> +int
>>>>> +regulator_get_by_name(device_t cdev, const char *name, regulator_t
>>>>> *reg)
>>>>> + REG_TOPO_SLOCK();
>>>>> + regnode = regnode_find_by_name(name);
>>>>> + if (regnode == NULL) {
>>>>> + return (ENODEV);
>>>>> + *reg = regulator_create(regnode, cdev);
>>>>> + return (0);
>>>>> +int
>>>>> +regulator_get_by_id(device_t cdev, device_t pdev, intptr_t id,
>> regulator_t
>>>>> *reg)
>>>>> + REG_TOPO_SLOCK();
>>>>> + regnode = regnode_find_by_id(pdev, id);
>>>>> + return (ENODEV);
>>>>> + return (0);
>>>>> +int
>>>>> +regulator_release(regulator_t reg)
>>>>>> name));
>>>>> + REG_TOPO_SLOCK();
>>>>> + while (reg->enable_cnt > 0) {
>>>>> + regnode_disable(regnode);
>>>>> + TAILQ_REMOVE(®node->consumers_list, reg, link);
>>>>> + regnode->ref_cnt--;
>>>>> + free(reg, M_REGULATOR);
>>>>> + return (0);
>>>>> +#ifdef FDT
>>>>> +/* Default DT mapper. */
>>>>> +int
>>>>> +regdev_default_ofw_map(device_t dev, phandle_t xref, int ncells,
>>>>> + pcell_t *cells, intptr_t *id)
>>>>> + if (ncells == 0)
>>>>> + *id = 1;
>>>>> + else if (ncells == 1)
>>>>> + *id = cells[0];
>>>>> + else
>>>>> + return (ERANGE);
>>>>> + return (0);
>>>>> +int
>>>>> +regulator_parse_ofw_stdparam(device_t pdev, phandle_t node,
>>>>> + phandle_t supply_xref;
>>>>> + struct regnode_std_param *par;
>>>>> + int rv;
>>>>> + par = &def->std_param;
>>>>> + rv = OF_getprop_alloc(node, "regulator-name",
>>>>> + (void **)&def->name);
>>>>> + if (rv <= 0) {
>>>>> + device_printf(pdev, "%s: Missing regulator name\n",
>>>>> + __func__);
>>>>> + return (ENXIO);
>>>>> + rv = OF_getencprop(node, "regulator-min-microvolt", &par-
>>>>>> min_uvolt,
>>>>> + sizeof(par->min_uvolt));
>>>>> + if (rv <= 0)
>>>>> + par->min_uvolt = 0;
>>>>> + rv = OF_getencprop(node, "regulator-max-microvolt", &par-
>>>>>> max_uvolt,
>>>>> + sizeof(par->max_uvolt));
>>>>> + if (rv <= 0)
>>>>> + par->max_uvolt = 0;
>>>>> + rv = OF_getencprop(node, "regulator-min-microamp", &par-
>>>>>> min_uamp,
>>>>> + sizeof(par->min_uamp));
>>>>> + if (rv <= 0)
>>>>> + par->min_uamp = 0;
>>>>> + rv = OF_getencprop(node, "regulator-max-microamp", &par-
>>>>>> max_uamp,
>>>>> + sizeof(par->max_uamp));
>>>>> + if (rv <= 0)
>>>>> + par->max_uamp = 0;
>>>>> + rv = OF_getencprop(node, "regulator-ramp-delay", &par-
>>>>>> ramp_delay,
>>>>> + sizeof(par->ramp_delay));
>>>>> + if (rv <= 0)
>>>>> + par->ramp_delay = 0;
>>>>> + rv = OF_getencprop(node, "regulator-enable-ramp-delay",
>>>>> + &par->enable_delay, sizeof(par->enable_delay));
>>>>> + if (rv <= 0)
>>>>> + par->enable_delay = 0;
>>>>> + if (OF_hasprop(node, "regulator-boot-on"))
>>>>> + par->boot_on = true;
>>>>> + if (OF_hasprop(node, "regulator-always-on"))
>>>>> + par->always_on = true;
>>>>> + if (OF_hasprop(node, "enable-active-high"))
>>>>> + par->enable_active_high = 1;
>>>>> + rv = OF_getencprop(node, "vin-supply", &supply_xref,
>>>>> + sizeof(supply_xref));
>>>>> + if (rv >= 0) {
>>>>> + rv = OF_getprop_alloc(supply_xref, "regulator-name",
>>>>> + (void **)&def->parent_name);
>>>>> + if (rv <= 0)
>>>>> + def->parent_name = NULL;
>>>>> + return (0);
>>>>> +int
>>>>> +regulator_get_by_ofw_property(device_t cdev, phandle_t cnode, char
>>>>> *name,
>>>>> + regulator_t *reg)
>>>>> + phandle_t *cells;
>>>>> + device_t regdev;
>>>>> + int ncells, rv;
>>>>> + intptr_t id;
>>>>> + *reg = NULL;
>>>>> + if (cnode <= 0)
>>>>> + cnode = ofw_bus_get_node(cdev);
>>>>> + if (cnode <= 0) {
>>>>> + device_printf(cdev, "%s called on not ofw based device\n",
>>>>> + __func__);
>>>>> + return (ENXIO);
>>>>> + cells = NULL;
>>>>> + ncells = OF_getencprop_alloc_multi(cnode, name, sizeof(*cells),
>>>>> + (void **)&cells);
>>>>> + if (ncells <= 0)
>>>>> + return (ENOENT);
>>>>> + /* Translate xref to device */
>>>>> + regdev = OF_device_from_xref(cells[0]);
>>>>> + if (regdev == NULL) {
>>>>> + OF_prop_free(cells);
>>>>> + return (ENODEV);
>>>>> + /* Map regulator to number */
>>>>> + rv = REGDEV_MAP(regdev, cells[0], ncells - 1, cells + 1, &id);
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + return (regulator_get_by_id(cdev, regdev, id, reg));
>>>>> +#endif
>>>>> + * Regulator utility functions.
>>>>> +/* Convert raw selector value to real voltage */
>>>>> +int
>>>>> +regulator_range_sel8_to_volt(struct regulator_range *ranges, int
>> nranges,
>>>>> + uint8_t sel, int *volt)
>>>>> + struct regulator_range *range;
>>>>> + int i;
>>>>> + if (nranges == 0)
>>>>> + panic("Voltage regulator have zero ranges\n");
>>>>> + for (i = 0; i < nranges ; i++) {
>>>>> + range = ranges + i;
>>>>> + if (!(sel >= range->min_sel &&
>>>>> + sel <= range->max_sel))
>>>>> + continue;
>>>>> + sel -= range->min_sel;
>>>>> + *volt = range->min_uvolt + sel * range->step_uvolt;
>>>>> + return (0);
>>>>> + return (ERANGE);
>>>>> +int
>>>>> +regulator_range_volt_to_sel8(struct regulator_range *ranges, int
>> nranges,
>>>>> + int min_uvolt, int max_uvolt, uint8_t *out_sel)
>>>>> + uint8_t sel;
>>>>> + int uvolt;
>>>>> + int rv, i;
>>>>> + if (nranges == 0)
>>>>> + for (i = 0; i < nranges; i++) {
>>>>> + uvolt = range->min_uvolt +
>>>>> + (range->max_sel - range->min_sel) * range->step_uvolt;
>>>>> + if ((min_uvolt > uvolt) ||
>>>>> + (max_uvolt < range->min_uvolt))
>>>>> + continue;
>>>>> + if (min_uvolt <= range->min_uvolt)
>>>>> + min_uvolt = range->min_uvolt;
>>>>> + /* if step == 0 -> fixed voltage range. */
>>>>> + if (range->step_uvolt == 0)
>>>>> + sel = 0;
>>>>> + else
>>>>> + sel = DIV_ROUND_UP(min_uvolt - range->min_uvolt,
>>>>> + range->step_uvolt);
>>>>> + sel += range->min_sel;
>>>>> + break;
>>>>> + if (i >= nranges)
>>>>> + return (ERANGE);
>>>>> + /* Verify new settings. */
>>>>> + rv = regulator_range_sel8_to_volt(ranges, nranges, sel, &uvolt);
>>>>> + if (rv != 0)
>>>>> + return (rv);
>>>>> + if ((uvolt < min_uvolt) || (uvolt > max_uvolt))
>>>>> + return (ERANGE);
>>>>> + *out_sel = sel;
>>>>> + return (0);
>>>>> diff --git a/freebsd/sys/dev/extres/regulator/regulator.h
>>>>> b/freebsd/sys/dev/extres/regulator/regulator.h
>>>>> index 00000000..3905aa36
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/extres/regulator/regulator.h
>>>>> @@ -0,0 +1,156 @@
>>>>> + * are met:
>> distribution.
>> ``AS
>>>>> IS'' AND
>> LIMITED
>>>>> TO, THE
>>>>> PARTICULAR PURPOSE
>> CONTRIBUTORS
>>>>> BE LIABLE
>>>>> CONSEQUENTIAL
>>>>> SUBSTITUTE GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>> ARISING
>>>>> IN ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#ifndef _DEV_EXTRES_REGULATOR_H_
>>>>> +#define _DEV_EXTRES_REGULATOR_H_
>>>>> +#ifdef FDT
>>>>> +#endif
>>>>> +#include <rtems/bsd/local/regnode_if.h>
>>>>> +SYSCTL_DECL(_hw_regulator);
>>>>> +#define REGULATOR_FLAGS_STATIC 0x00000001 /* Static
>> strings */
>>>>> +#define REGULATOR_FLAGS_NOT_DISABLE 0x00000002 /* Cannot
>> be
>>>>> disabled */
>>>>> +#define REGULATOR_STATUS_ENABLED 0x00000001
>>>>> +#define REGULATOR_STATUS_OVERCURRENT 0x00000002
>>>>> +typedef struct regulator *regulator_t;
>>>>> +/* Standard regulator parameters. */
>>>>> +struct regnode_std_param {
>>>>> + int min_uvolt; /* In uV */
>>>>> + int max_uvolt; /* In uV */
>>>>> + int min_uamp; /* In uA */
>>>>> + int max_uamp; /* In uA */
>>>>> + int ramp_delay; /* In uV/usec */
>>>>> + int enable_delay; /* In usec */
>>>>> + bool boot_on; /* Is enabled on boot */
>>>>> + bool always_on; /* Must be enabled */
>>>>> + int enable_active_high;
>>>>> +/* Initialization parameters. */
>>>>> +struct regnode_init_def {
>>>>> + char *name; /* Regulator name */
>>>>> + char *parent_name; /* Name of parent
>>>>> regulator */
>>>>> parameters */
>>>>> + intptr_t id; /* Regulator ID */
>>>>> + int flags; /* Flags */
>>>>> +#ifdef FDT
>>>>> +#endif
>>>>> +struct regulator_range {
>>>>> + int min_uvolt;
>>>>> + int step_uvolt;
>>>>> + uint8_t min_sel;
>>>>> + uint8_t max_sel;
>>>>> +#define REG_RANGE_INIT(_min_sel, _max_sel, _min_uvolt,
>>>>> _step_uvolt) { \
>>>>> + .min_sel = _min_sel, \
>>>>> + .max_sel = _max_sel, \
>>>>> + .min_uvolt = _min_uvolt, \
>>>>> + .step_uvolt = _step_uvolt, \
>>>>> + * Shorthands for constructing method tables.
>>>>> +#define REGNODEMETHOD KOBJMETHOD
>>>>> +#define REGNODEMETHOD_END KOBJMETHOD_END
>>>>> +#define regnode_method_t kobj_method_t
>>>>> +#define regnode_class_t kobj_class_t
>>>>> +DECLARE_CLASS(regnode_class);
>>>>> +/* Providers interface. */
>>>>> +struct regnode *regnode_create(device_t pdev, regnode_class_t
>>>>> regnode_class,
>>>>> + struct regnode_init_def *def);
>>>>> +struct regnode *regnode_register(struct regnode *regnode);
>>>>> +const char *regnode_get_name(struct regnode *regnode);
>>>>> +const char *regnode_get_parent_name(struct regnode *regnode);
>>>>> +struct regnode *regnode_get_parent(struct regnode *regnode);
>>>>> +int regnode_get_flags(struct regnode *regnode);
>>>>> +void *regnode_get_softc(struct regnode *regnode);
>>>>> +device_t regnode_get_device(struct regnode *regnode);
>>>>> *regnode);
>>>>> +void regnode_topo_unlock(void);
>>>>> +void regnode_topo_xlock(void);
>>>>> +void regnode_topo_slock(void);
>>>>> +int regnode_enable(struct regnode *regnode);
>>>>> +int regnode_disable(struct regnode *regnode);
>>>>> +int regnode_stop(struct regnode *regnode, int depth);
>>>>> +int regnode_status(struct regnode *regnode, int *status);
>>>>> +int regnode_get_voltage(struct regnode *regnode, int *uvolt);
>>>>> +int regnode_set_voltage(struct regnode *regnode, int min_uvolt, int
>>>>> max_uvolt);
>>>>> +int regnode_set_constraint(struct regnode *regnode);
>>>>> +/* Standard method that aren't default */
>>>>> +int regnode_method_check_voltage(struct regnode *regnode, int
>> uvolt);
>>>>> +#ifdef FDT
>>>>> +phandle_t regnode_get_ofw_node(struct regnode *regnode);
>>>>> +#endif
>>>>> +/* Consumers interface. */
>>>>> +int regulator_get_by_name(device_t cdev, const char *name,
>>>>> + regulator_t *regulator);
>>>>> +int regulator_get_by_id(device_t cdev, device_t pdev, intptr_t id,
>>>>> +int regulator_release(regulator_t regulator);
>>>>> +const char *regulator_get_name(regulator_t regulator);
>>>>> +int regulator_enable(regulator_t reg);
>>>>> +int regulator_disable(regulator_t reg);
>>>>> +int regulator_stop(regulator_t reg);
>>>>> +int regulator_status(regulator_t reg, int *status);
>>>>> +int regulator_get_voltage(regulator_t reg, int *uvolt);
>>>>> +int regulator_set_voltage(regulator_t reg, int min_uvolt, int
>> max_uvolt);
>>>>> +int regulator_check_voltage(regulator_t reg, int uvolt);
>>>>> +#ifdef FDT
>>>>> +int regulator_get_by_ofw_property(device_t dev, phandle_t node,
>> char
>>>>> *name,
>>>>> + regulator_t *reg);
>>>>> +int regulator_parse_ofw_stdparam(device_t dev, phandle_t node,
>>>>> +#endif
>>>>> +/* Utility functions */
>>>>> +int regulator_range_volt_to_sel8(struct regulator_range *ranges, int
>>>>> nranges,
>>>>> + int min_uvolt, int max_uvolt, uint8_t *out_sel);
>>>>> +int regulator_range_sel8_to_volt(struct regulator_range *ranges, int
>>>>> nranges,
>>>>> + uint8_t sel, int *volt);
>>>>> +#endif /* _DEV_EXTRES_REGULATOR_H_ */
>>>>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_bus.c
>>>>> b/freebsd/sys/dev/extres/regulator/regulator_bus.c
>>>>> index 00000000..b79c2633
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/extres/regulator/regulator_bus.c
>>>>> @@ -0,0 +1,89 @@
>>>>> + * are met:
>> distribution.
>> ``AS
>>>>> IS'' AND
>> LIMITED
>>>>> TO, THE
>>>>> PARTICULAR PURPOSE
>> CONTRIBUTORS
>>>>> BE LIABLE
>>>>> CONSEQUENTIAL
>>>>> SUBSTITUTE GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>> ARISING
>>>>> IN ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> +#include <sys/module.h>
>>>>> +#include <dev/fdt/simplebus.h>
>>>>> +#include <dev/ofw/openfirm.h>
>>>>> +struct ofw_regulator_bus_softc {
>>>>> + struct simplebus_softc simplebus_sc;
>>>>> +static int
>>>>> +ofw_regulator_bus_probe(device_t dev)
>>>>> + const char *name;
>>>>> + name = ofw_bus_get_name(dev);
>>>>> + if (name == NULL || strcmp(name, "regulators") != 0)
>>>>> + return (ENXIO);
>>>>> + device_set_desc(dev, "OFW regulators bus");
>>>>> + return (0);
>>>>> +static int
>>>>> +ofw_regulator_bus_attach(device_t dev)
>>>>> + phandle_t node, child;
>>>>> + node = ofw_bus_get_node(dev);
>>>>> + simplebus_init(dev, node);
>>>>> + for (child = OF_child(node); child > 0; child = OF_peer(child)) {
>>>>> + simplebus_add_device(dev, child, 0, NULL, -1, NULL);
>>>>> + return (bus_generic_attach(dev));
>>>>> +static device_method_t ofw_regulator_bus_methods[] = {
>>>>> + /* Device interface */
>>>>> + DEVMETHOD(device_probe, ofw_regulator_bus_probe),
>>>>> + DEVMETHOD(device_attach, ofw_regulator_bus_attach),
>>>>> + DEVMETHOD_END
>>>>> +DEFINE_CLASS_1(ofw_regulator_bus, ofw_regulator_bus_driver,
>>>>> + ofw_regulator_bus_methods, sizeof(struct
>> ofw_regulator_bus_softc),
>>>>> + simplebus_driver);
>>>>> +static devclass_t ofw_regulator_bus_devclass;
>>>>> +EARLY_DRIVER_MODULE(ofw_regulator_bus, simplebus,
>>>>> + ofw_regulator_bus_devclass, 0, 0, BUS_PASS_BUS +
>>>>> BUS_PASS_ORDER_MIDDLE);
>>>>> +MODULE_VERSION(ofw_regulator_bus, 1);
>>>>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>>>>> b/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>>>>> index 00000000..0bc6d96e
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/extres/regulator/regulator_fixed.c
>>>>> @@ -0,0 +1,502 @@
>>>>> + * are met:
>> distribution.
>> ``AS
>>>>> IS'' AND
>> LIMITED
>>>>> TO, THE
>>>>> PARTICULAR PURPOSE
>> CONTRIBUTORS
>>>>> BE LIABLE
>>>>> CONSEQUENTIAL
>>>>> SUBSTITUTE GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>> ARISING
>>>>> IN ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> +#include <sys/gpio.h>
>>>>> +#ifdef FDT
>>>>> +#endif
>>>>> +#include <dev/gpio/gpiobusvar.h>
>>>>> +#include <dev/extres/regulator/regulator_fixed.h>
>>>>> +MALLOC_DEFINE(M_FIXEDREGULATOR, "fixedregulator", "Fixed
>>>>> regulator");
>>>>> +/* GPIO list for shared pins. */
>>>>> +typedef TAILQ_HEAD(gpio_list, gpio_entry) gpio_list_t;
>>>>> +struct gpio_entry {
>>>>> + TAILQ_ENTRY(gpio_entry) link;
>>>>> + struct gpiobus_pin gpio_pin;
>>>>> + int use_cnt;
>>>>> + int enable_cnt;
>>>>> + bool always_on;
>>>>> +static gpio_list_t gpio_list = TAILQ_HEAD_INITIALIZER(gpio_list);
>>>>> +static struct mtx gpio_list_mtx;
>>>>> +MTX_SYSINIT(gpio_list_lock, &gpio_list_mtx, "Regulator GPIO lock",
>>>>> MTX_DEF);
>>>>> +struct regnode_fixed_sc {
>>>>> + struct regnode_std_param *param;
>>>>> + bool gpio_open_drain;
>>>>> + struct gpio_entry *gpio_entry;
>>>>> +static int regnode_fixed_init(struct regnode *regnode);
>>>>> +static int regnode_fixed_enable(struct regnode *regnode, bool
>> enable,
>>>>> + int *udelay);
>>>>> +static int regnode_fixed_status(struct regnode *regnode, int *status);
>>>>> +static int regnode_fixed_stop(struct regnode *regnode, int *udelay);
>>>>> +static regnode_method_t regnode_fixed_methods[] = {
>>>>> + /* Regulator interface */
>>>>> + REGNODEMETHOD(regnode_init, regnode_fixed_init),
>>>>> regnode_fixed_enable),
>>>>> regnode_fixed_status),
>>>>> + REGNODEMETHOD(regnode_stop, regnode_fixed_stop),
>>>>> + REGNODEMETHOD_END
>>>>> +DEFINE_CLASS_1(regnode_fixed, regnode_fixed_class,
>>>>> regnode_fixed_methods,
>>>>> + sizeof(struct regnode_fixed_sc), regnode_class);
>>>>> + * GPIO list functions.
>>>>> + * Two or more regulators can share single GPIO pins, so we must track
>> all
>>>>> + * GPIOs in gpio_list.
>>>>> + * The GPIO pin is registerd and reseved for first consumer, all others
>> share
>>>>> + * gpio_entry with it.
>>>>> +static struct gpio_entry *
>>>>> +regnode_get_gpio_entry(struct gpiobus_pin *gpio_pin)
>>>>> + struct gpio_entry *entry, *tmp;
>>>>> + device_t busdev;
>>>>> + int rv;
>>>>> + busdev = GPIO_GET_BUS(gpio_pin->dev);
>>>>> + if (busdev == NULL)
>>>>> + return (NULL);
>>>>> + entry = malloc(sizeof(struct gpio_entry), M_FIXEDREGULATOR,
>>>>> + mtx_lock(&gpio_list_mtx);
>>>>> + TAILQ_FOREACH(tmp, &gpio_list, link) {
>>>>> + if (tmp->gpio_pin.dev == gpio_pin->dev &&
>>>>> + tmp->gpio_pin.pin == gpio_pin->pin) {
>>>>> + tmp->use_cnt++;
>>>>> + mtx_unlock(&gpio_list_mtx);
>>>>> + free(entry, M_FIXEDREGULATOR);
>>>>> + return (tmp);
>>>>> + /* Reserve pin. */
>>>>> + /* XXX Can we call gpiobus_acquire_pin() with gpio_list_mtx held? */
>>>>> + rv = gpiobus_acquire_pin(busdev, gpio_pin->pin);
>>>>> + if (rv != 0) {
>>>>> + return (NULL);
>>>>> + /* Everything is OK, build new entry and insert it to list. */
>>>>> + entry->gpio_pin = *gpio_pin;
>>>>> + entry->use_cnt = 1;
>>>>> + TAILQ_INSERT_TAIL(&gpio_list, entry, link);
>>>>> + return (entry);
>>>>> + * Regulator class implementation.
>>>>> +static int
>>>>> +regnode_fixed_init(struct regnode *regnode)
>>>>> + device_t dev;
>>>>> + struct regnode_fixed_sc *sc;
>>>>> + struct gpiobus_pin *pin;
>>>>> + uint32_t flags;
>>>>> + int rv;
>>>>> + sc = regnode_get_softc(regnode);
>>>>> + dev = regnode_get_device(regnode);
>>>>> + sc->param = regnode_get_stdparam(regnode);
>>>>> + if (sc->gpio_entry == NULL)
>>>>> + return (0);
>>>>> + pin = &sc->gpio_entry->gpio_pin;
>>>>> + flags = GPIO_PIN_OUTPUT;
>>>>> + if (sc->gpio_open_drain)
>>>>> + flags |= GPIO_PIN_OPENDRAIN;
>>>>> + if (sc->param->boot_on || sc->param->always_on) {
>>>>> + rv = GPIO_PIN_SET(pin->dev, pin->pin, sc->param-
>>>>>> enable_active_high);
>>>>> + if (rv != 0) {
>>>>> + device_printf(dev, "Cannot set GPIO pin: %d\n",
>>>>> + pin->pin);
>>>>> + return (rv);
>>>>> + rv = GPIO_PIN_SETFLAGS(pin->dev, pin->pin, flags);
>>>>> + if (rv != 0) {
>>>>> + device_printf(dev, "Cannot configure GPIO pin: %d\n", pin-
>>>>>> pin);
>>>>> + return (rv);
>>>>> + return (0);
>>>>> + * Enable/disable regulator.
>>>>> + * Take shared GPIO pins in account
>>>>> +static int
>>>>> +regnode_fixed_enable(struct regnode *regnode, bool enable, int
>> *udelay)
>>>>> + device_t dev;
>>>>> + int rv;
>>>>> + *udelay = 0;
>>>>> + return (0);
>>>>> + if (enable) {
>>>>> + sc->gpio_entry->enable_cnt++;
>>>>> + if (sc->gpio_entry->enable_cnt > 1)
>>>>> + return (0);
>>>>> + } else {
>>>>> + KASSERT(sc->gpio_entry->enable_cnt > 0,
>>>>> + ("Invalid enable count"));
>>>>> + sc->gpio_entry->enable_cnt--;
>>>>> + if (sc->gpio_entry->enable_cnt >= 1)
>>>>> + return (0);
>>>>> + if (sc->gpio_entry->always_on && !enable)
>>>>> + return (0);
>>>>> + if (!sc->param->enable_active_high)
>>>>> + enable = !enable;
>>>>> + rv = GPIO_PIN_SET(pin->dev, pin->pin, enable);
>>>>> + if (rv != 0) {
>>>>> + device_printf(dev, "Cannot set GPIO pin: %d\n", pin->pin);
>>>>> + return (rv);
>>>>> + *udelay = sc->param->enable_delay;
>>>>> + return (0);
>>>>> + * Stop (physicaly shutdown) regulator.
>>>>> +static int
>>>>> +regnode_fixed_stop(struct regnode *regnode, int *udelay)
>>>>> + device_t dev;
>>>>> + int rv;
>>>>> + *udelay = 0;
>>>>> + return (0);
>>>>> + if (sc->gpio_entry->always_on)
>>>>> + return (0);
>>>>> + if (sc->gpio_entry->enable_cnt > 0) {
>>>>> + /* Other regulator(s) are enabled. */
>>>>> + /* XXXX Any diagnostic message? Or error? */
>>>>> + return (0);
>>>>> + sc->param->enable_active_high ? false: true);
>>>>> + if (rv != 0) {
>>>>> + return (rv);
>>>>> + return (0);
>>>>> +static int
>>>>> +regnode_fixed_status(struct regnode *regnode, int *status)
>>>>> + uint32_t val;
>>>>> + int rv;
>>>>> + *status = 0;
>>>>> + if (sc->gpio_entry == NULL) {
>>>>> + return (0);
>>>>> + rv = GPIO_PIN_GET(pin->dev, pin->pin, &val);
>>>>> + if (rv == 0) {
>>>>> + if (!sc->param->enable_active_high ^ (val != 0))
>>>>> + return (rv);
>>>>> +int
>>>>> +regnode_fixed_register(device_t dev, struct regnode_fixed_init_def
>>>>> *init_def)
>>>>> + regnode = regnode_create(dev, ®node_fixed_class,
>>>>> + &init_def->reg_init_def);
>>>>> + device_printf(dev, "Cannot create regulator.\n");
>>>>> + return(ENXIO);
>>>>> + sc->gpio_open_drain = init_def->gpio_open_drain;
>>>>> + if (init_def->gpio_pin != NULL) {
>>>>> + sc->gpio_entry = regnode_get_gpio_entry(init_def-
>>>>>> gpio_pin);
>>>>> + return(ENXIO);
>>>>> + regnode = regnode_register(regnode);
>>>>> + device_printf(dev, "Cannot register regulator.\n");
>>>>> + return(ENXIO);
>>>>> + if (sc->gpio_entry != NULL)
>>>>> + sc->gpio_entry->always_on |= sc->param->always_on;
>>>>> + return (0);
>>>>> + * OFW Driver implementation.
>>>>> +#ifdef FDT
>>>>> +struct regfix_softc
>>>>> + device_t dev;
>>>>> + bool attach_done;
>>>>> + struct regnode_fixed_init_def init_def;
>>>>> + phandle_t gpio_prodxref;
>>>>> + pcell_t *gpio_cells;
>>>>> + int gpio_ncells;
>>>>> +static struct ofw_compat_data compat_data[] = {
>>>>> + {"regulator-fixed", 1},
>>>>> + {NULL, 0},
>>>>> +static int
>>>>> +regfix_get_gpio(struct regfix_softc * sc)
>>>>> + device_t busdev;
>>>>> + phandle_t node;
>>>>> + int rv;
>>>>> + if (sc->gpio_prodxref == 0)
>>>>> + return (0);
>>>>> + node = ofw_bus_get_node(sc->dev);
>>>>> + /* Test if controller exist. */
>>>>> + sc->gpio_pin.dev = OF_device_from_xref(sc->gpio_prodxref);
>>>>> + if (sc->gpio_pin.dev == NULL)
>>>>> + return (ENODEV);
>>>>> + /* Test if GPIO bus already exist. */
>>>>> + busdev = GPIO_GET_BUS(sc->gpio_pin.dev);
>>>>> + return (ENODEV);
>>>>> + rv = gpio_map_gpios(sc->gpio_pin.dev, node,
>>>>> + OF_node_from_xref(sc->gpio_prodxref), sc->gpio_ncells,
>>>>> + sc->gpio_cells, &(sc->gpio_pin.pin), &(sc->gpio_pin.flags));
>>>>> + if (rv != 0) {
>>>>> + device_printf(sc->dev, "Cannot map the gpio property.\n");
>>>>> + return (ENXIO);
>>>>> + sc->init_def.gpio_pin = &sc->gpio_pin;
>>>>> + return (0);
>>>>> +static int
>>>>> +regfix_parse_fdt(struct regfix_softc * sc)
>>>>> + phandle_t node;
>>>>> + int rv;
>>>>> + struct regnode_init_def *init_def;
>>>>> + init_def = &sc->init_def.reg_init_def;
>>>>> + rv = regulator_parse_ofw_stdparam(sc->dev, node, init_def);
>>>>> + if (rv != 0) {
>>>>> + device_printf(sc->dev, "Cannot parse standard
>>>>> parameters.\n");
>>>>> + return(rv);
>>>>> + /* Fixed regulator uses 'startup-delay-us' property for enable_delay
>>>>> + rv = OF_getencprop(node, "startup-delay-us",
>>>>> + &init_def->std_param.enable_delay,
>>>>> + sizeof(init_def->std_param.enable_delay));
>>>>> + if (rv <= 0)
>>>>> + init_def->std_param.enable_delay = 0;
>>>>> + /* GPIO pin */
>>>>> + if (OF_hasprop(node, "gpio-open-drain"))
>>>>> + sc->init_def.gpio_open_drain = true;
>>>>> + if (!OF_hasprop(node, "gpio"))
>>>>> + return (0);
>>>>> + rv = ofw_bus_parse_xref_list_alloc(node, "gpio", "#gpio-cells", 0,
>>>>> + &sc->gpio_prodxref, &sc->gpio_ncells, &sc->gpio_cells);
>>>>> + if (rv != 0) {
>>>>> + sc->gpio_prodxref = 0;
>>>>> + device_printf(sc->dev, "Malformed gpio property\n");
>>>>> + return (ENXIO);
>>>>> + return (0);
>>>>> +static void
>>>>> +regfix_new_pass(device_t dev)
>>>>> + struct regfix_softc * sc;
>>>>> + int rv;
>>>>> + sc = device_get_softc(dev);
>>>>> + bus_generic_new_pass(dev);
>>>>> + if (sc->attach_done)
>>>>> + return;
>>>>> + /* Try to get and configure GPIO. */
>>>>> + rv = regfix_get_gpio(sc);
>>>>> + if (rv != 0)
>>>>> + return;
>>>>> + /* Register regulator. */
>>>>> + regnode_fixed_register(sc->dev, &sc->init_def);
>>>>> + sc->attach_done = true;
>>>>> +static int
>>>>> +regfix_probe(device_t dev)
>>>>> + if (!ofw_bus_status_okay(dev))
>>>>> + return (ENXIO);
>>>>> + if (!ofw_bus_search_compatible(dev, compat_data)->ocd_data)
>>>>> + return (ENXIO);
>>>>> + device_set_desc(dev, "Fixed Regulator");
>>>>> + return (BUS_PROBE_DEFAULT);
>>>>> +static int
>>>>> +regfix_detach(device_t dev)
>>>>> + /* This device is always present. */
>>>>> + return (EBUSY);
>>>>> +static int
>>>>> +regfix_attach(device_t dev)
>>>>> + int rv;
>>>>> + sc->dev = dev;
>>>>> + /* Parse FDT data. */
>>>>> + rv = regfix_parse_fdt(sc);
>>>>> + if (rv != 0)
>>>>> + return(ENXIO);
>>>>> + /* Fill reset of init. */
>>>>> + sc->init_def.reg_init_def.id = 1;
>>>>> + sc->init_def.reg_init_def.flags = REGULATOR_FLAGS_STATIC;
>>>>> + if (rv != 0)
>>>>> +static device_method_t regfix_methods[] = {
>>>>> + DEVMETHOD(device_probe, regfix_probe),
>>>>> + DEVMETHOD(device_attach, regfix_attach),
>>>>> + DEVMETHOD(device_detach, regfix_detach),
>>>>> + /* Bus interface */
>>>>> + DEVMETHOD(bus_new_pass, regfix_new_pass),
>>>>> + /* Regdev interface */
>>>>> + DEVMETHOD(regdev_map, regdev_default_ofw_map),
>>>>> + DEVMETHOD_END
>>>>> +static devclass_t regfix_devclass;
>>>>> +DEFINE_CLASS_0(regfix, regfix_driver, regfix_methods,
>>>>> + sizeof(struct regfix_softc));
>>>>> +EARLY_DRIVER_MODULE(regfix, simplebus, regfix_driver,
>>>>> + regfix_devclass, 0, 0, BUS_PASS_BUS);
>>>>> +#endif /* FDT */
>>>>> diff --git a/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>>>>> b/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>>>>> index 00000000..5cc07516
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/extres/regulator/regulator_fixed.h
>>>>> @@ -0,0 +1,44 @@
>>>>> + * are met:
>> distribution.
>> ``AS
>>>>> IS'' AND
>> LIMITED
>>>>> TO, THE
>>>>> PARTICULAR PURPOSE
>> CONTRIBUTORS
>>>>> BE LIABLE
>>>>> CONSEQUENTIAL
>>>>> SUBSTITUTE GOODS
>>>>> INTERRUPTION)
>>>>> CONTRACT, STRICT
>> ARISING
>>>>> IN ANY WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> +#ifndef _DEV_EXTRES_REGULATOR_FIXED_H_
>>>>> +#define _DEV_EXTRES_REGULATOR_FIXED_H_
>>>>> +struct regnode_fixed_init_def {
>>>>> + struct regnode_init_def reg_init_def;
>>>>> + struct gpiobus_pin *gpio_pin;
>>>>> +int regnode_fixed_register(device_t dev,
>>>>> + struct regnode_fixed_init_def *init_def);
>>>>> +#endif /*_DEV_EXTRES_REGULATOR_FIXED_H_*/
>>>>> diff --git a/freebsd/sys/dev/gpio/gpioregulator.c
>>>>> b/freebsd/sys/dev/gpio/gpioregulator.c
>>>>> index 00000000..6d05e52e
>>>>> --- /dev/null
>>>>> +++ b/freebsd/sys/dev/gpio/gpioregulator.c
>>>>> @@ -0,0 +1,350 @@
>>>>> + * Copyright (c) 2016 Jared McNeill <jmcneill at invisible.ca>
>>>>> + * are met:
>> distribution.
>>>>> + * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY
>> EXPRESS
>>>>> OR
>>>>> + * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> IMPLIED
>>>>> WARRANTIES
>>>>> + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> ARE
>>>>> DISCLAIMED.
>>>>> + * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT,
>> INDIRECT,
>>>>> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
>>>>> (INCLUDING,
>>>>> + * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
>>>>> SERVICES;
>>>>> + * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
>>>>> HOWEVER CAUSED
>>>>> + * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
>>>>> LIABILITY,
>>>>> + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
>> WAY
>>>>> POSSIBILITY OF
>>>>> + * SUCH DAMAGE.
>>>>> + * $FreeBSD$
>>>>> + * GPIO controlled regulators
>>>>> +#include <sys/rman.h>
>>>>> +struct gpioregulator_state {
>>>>> + int val;
>>>>> + uint32_t mask;
>>>>> +struct gpioregulator_init_def {
>>>>> + struct gpiobus_pin *enable_pin;
>>>>> + int enable_pin_valid;
>>>>> + int startup_delay_us;
>>>>> + int nstates;
>>>>> + struct gpioregulator_state *states;
>>>>> + int npins;
>>>>> + struct gpiobus_pin **pins;
>>>>> +struct gpioregulator_reg_sc {
>>>>> + device_t base_dev;
>>>>> + struct gpioregulator_init_def *def;
>>>>> +struct gpioregulator_softc {
>>>>> + device_t dev;
>>>>> + struct gpioregulator_reg_sc *reg_sc;
>>>>> + struct gpioregulator_init_def init_def;
>>>>> +static int
>>>>> +gpioregulator_regnode_init(struct regnode *regnode)
>>>>> + struct gpioregulator_reg_sc *sc;
>>>>> + int error, n;
>>>>> + if (sc->def->enable_pin_valid == 1) {
>>>>> + error = gpio_pin_setflags(sc->def->enable_pin,
>>>>> GPIO_PIN_OUTPUT);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + for (n = 0; n < sc->def->npins; n++) {
>>>>> + error = gpio_pin_setflags(sc->def->pins[n],
>>>>> GPIO_PIN_OUTPUT);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + return (0);
>>>>> +static int
>>>>> +gpioregulator_regnode_enable(struct regnode *regnode, bool enable,
>> int
>>>>> *udelay)
>>>>> + bool active;
>>>>> + int error;
>>>>> + active = enable;
>>>>> + active = !active;
>>>>> + error = gpio_pin_set_active(sc->def->enable_pin, active);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + *udelay = sc->def->startup_delay_us;
>>>>> + return (0);
>>>>> +static int
>>>>> +gpioregulator_regnode_set_voltage(struct regnode *regnode, int
>>>>> min_uvolt,
>>>>> + const struct gpioregulator_state *state;
>>>>> + int error, n;
>>>>> + state = NULL;
>>>>> + for (n = 0; n < sc->def->nstates; n++) {
>>>>> + if (sc->def->states[n].val >= min_uvolt &&
>>>>> + sc->def->states[n].val <= max_uvolt) {
>>>>> + state = &sc->def->states[n];
>>>>> + break;
>>>>> + if (state == NULL)
>>>>> + return (EINVAL);
>>>>> + error = gpio_pin_set_active(sc->def->pins[n],
>>>>> + (state->mask >> n) & 1);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + return (0);
>>>>> +static int
>>>>> +gpioregulator_regnode_get_voltage(struct regnode *regnode, int
>> *uvolt)
>>>>> + uint32_t mask;
>>>>> + int error, n;
>>>>> + bool active;
>>>>> + mask = 0;
>>>>> + error = gpio_pin_is_active(sc->def->pins[n], &active);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + mask |= (active << n);
>>>>> + if (sc->def->states[n].mask == mask) {
>>>>> + *uvolt = sc->def->states[n].val;
>>>>> + return (0);
>>>>> + return (EIO);
>>>>> +static regnode_method_t gpioregulator_regnode_methods[] = {
>>>>> + REGNODEMETHOD(regnode_init, gpioregulator_regnode_init),
>>>>> gpioregulator_regnode_enable),
>>>>> gpioregulator_regnode_set_voltage),
>>>>> gpioregulator_regnode_get_voltage),
>>>>> + REGNODEMETHOD_END
>>>>> +DEFINE_CLASS_1(gpioregulator_regnode,
>> gpioregulator_regnode_class,
>>>>> + gpioregulator_regnode_methods, sizeof(struct
>> gpioregulator_reg_sc),
>>>>> + regnode_class);
>>>>> +static int
>>>>> +gpioregulator_parse_fdt(struct gpioregulator_softc *sc)
>>>>> + uint32_t *pstates, mask;
>>>>> + phandle_t node;
>>>>> + ssize_t len;
>>>>> + int error, n;
>>>>> + pstates = NULL;
>>>>> + mask = 0;
>>>>> + error = regulator_parse_ofw_stdparam(sc->dev, node,
>>>>> + &sc->init_def.reg_init_def);
>>>>> + if (error != 0)
>>>>> + return (error);
>>>>> + /* "states" property (required) */
>>>>> + len = OF_getencprop_alloc_multi(node, "states", sizeof(*pstates),
>>>>> + (void **)&pstates);
>>>>> + if (len < 2) {
>>>>> + device_printf(sc->dev, "invalid 'states' property\n");
>>>>> + error = EINVAL;
>>>>> + goto done;
>>>>> + sc->init_def.nstates = len / 2;
>>>>> + sc->init_def.states = malloc(sc->init_def.nstates *
>>>>> + sizeof(*sc->init_def.states), M_DEVBUF, M_WAITOK);
>>>>> + for (n = 0; n < sc->init_def.nstates; n++) {
>>>>> + sc->init_def.states[n].val = pstates[n * 2 + 0];
>>>>> + sc->init_def.states[n].mask = pstates[n * 2 + 1];
>>>>> + mask |= sc->init_def.states[n].mask;
>>>>> + /* "startup-delay-us" property (optional) */
>>>>> + len = OF_getencprop(node, "startup-delay-us",
>>>>> + &sc->init_def.startup_delay_us,
>>>>> + sizeof(sc->init_def.startup_delay_us));
>>>>> + if (len <= 0)
>>>>> + sc->init_def.startup_delay_us = 0;
>>>>> + /* "enable-gpio" property (optional) */
>>>>> + error = gpio_pin_get_by_ofw_property(sc->dev, node, "enable-
>>>>> gpio",
>>>>> + &sc->init_def.enable_pin);
>>>>> + if (error == 0)
>>>>> + sc->init_def.enable_pin_valid = 1;
>>>>> + /* "gpios" property */
>>>>> + sc->init_def.npins = 32 - __builtin_clz(mask);
>>>>> + sc->init_def.pins = malloc(sc->init_def.npins *
>>>>> + sizeof(sc->init_def.pins), M_DEVBUF, M_WAITOK);
>>>>> + for (n = 0; n < sc->init_def.npins; n++) {
>>>>> + error = gpio_pin_get_by_ofw_idx(sc->dev, node, n,
>>>>> + &sc->init_def.pins[n]);
>>>>> + if (error != 0) {
>>>>> + device_printf(sc->dev, "cannot get pin %d\n", n);
>>>>> + goto done;
>>>>> +done:
>>>>> + if (error != 0) {
>>>>> + if (sc->init_def.pins[n] != NULL)
>>>>> + gpio_pin_release(sc->init_def.pins[n]);
>>>>> + free(sc->init_def.states, M_DEVBUF);
>>>>> + free(sc->init_def.pins, M_DEVBUF);
>>>>> + OF_prop_free(pstates);
>>>>> + return (error);
>>>>> +static int
>>>>> +gpioregulator_probe(device_t dev)
>>>>> + if (!ofw_bus_is_compatible(dev, "regulator-gpio"))
>>>>> + return (ENXIO);
>>>>> + device_set_desc(dev, "GPIO controlled regulator");
>>>>> + return (BUS_PROBE_GENERIC);
>>>>> +static int
>>>>> +gpioregulator_attach(device_t dev)
>>>>> + struct gpioregulator_softc *sc;
>>>>> + phandle_t node;
>>>>> + int error;
>>>>> + sc->dev = dev;
>>>>> + error = gpioregulator_parse_fdt(sc);
>>>>> + if (error != 0) {
>>>>> + device_printf(dev, "cannot parse parameters\n");
>>>>> + return (ENXIO);
>>>>> + sc->init_def.reg_init_def.ofw_node = node;
>>>>> + regnode = regnode_create(dev, &gpioregulator_regnode_class,
>>>>> + device_printf(dev, "cannot create regulator\n");
>>>>> + return (ENXIO);
>>>>> + sc->reg_sc = regnode_get_softc(regnode);
>>>>> + sc->reg_sc->regnode = regnode;
>>>>> + sc->reg_sc->base_dev = dev;
>>>>> + sc->reg_sc->param = regnode_get_stdparam(regnode);
>>>>> + sc->reg_sc->def = &sc->init_def;
>>>>> + regnode_register(regnode);
>>>>> + return (0);
>>>>> +static device_method_t gpioregulator_methods[] = {
>>>>> + DEVMETHOD(device_probe, gpioregulator_probe),
>>>>> + DEVMETHOD(device_attach, gpioregulator_attach),
>>>>> + DEVMETHOD_END
>>>>> +static driver_t gpioregulator_driver = {
>>>>> + "gpioregulator",
>>>>> + gpioregulator_methods,
>>>>> + sizeof(struct gpioregulator_softc),
>>>>> +static devclass_t gpioregulator_devclass;
>>>>> +EARLY_DRIVER_MODULE(gpioregulator, simplebus,
>> gpioregulator_driver,
>>>>> + gpioregulator_devclass, 0, 0, BUS_PASS_INTERRUPT +
>>>>> BUS_PASS_ORDER_LAST);
>>>>> +MODULE_VERSION(gpioregulator, 1);
>>>>> 2.16.4
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> embedded brains GmbH
>> Herr Christian Mauderer
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax: +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
